path: root/net/l2tp/l2tp_debugfs.c
2010-04-03l2tp: Add debugfs files for dumping l2tp debug infoJames Chapman
The existing pppol2tp driver exports debug info to /proc/net/pppol2tp. Rather than adding info to that file for the new functionality added in this patch series, we add new files in debugfs, leaving the old /proc file for backwards compatibility (L2TPv2 only). Currently only one file is provided: l2tp/tunnels, which lists internal debug info for all l2tp tunnels and sessions. More files may be added later. The info is for debug and problem analysis only - userspace apps should use netlink to obtain status about l2tp tunnels and sessions. Although debugfs does not support net namespaces, the tunnels and sessions dumped in l2tp/tunnels are only those in the net namespace of the process reading the file. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
