path: root/net/irda/irlap_frame.c
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
