path: root/net/ipv6
2012-09-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/team/team.c drivers/net/usb/qmi_wwan.c net/batman-adv/bat_iv_ogm.c net/ipv4/fib_frontend.c net/ipv4/route.c net/l2tp/l2tp_netlink.c The team, fib_frontend, route, and l2tp_netlink conflicts were simply overlapping changes. qmi_wwan and bat_iv_ogm were of the "use HEAD" variety. With help from Antonio Quartulli. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-27ipv6: gre: remove ip6gre_header_parse()Eric Dumazet
dev_parse_header() callers provide 8 bytes of storage, so it's not possible to store an IPv6 address. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-27nf_defrag_ipv6: fix oops on module unloadingKonstantin Khlebnikov
fix copy-paste error introduced in linux-next commit "ipv6: add a new namespace for nf_conntrack_reasm" Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Amerigo Wang <amwang@redhat.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-27tunnel: drop packet if ECN present with not-ECTstephen hemminger
Linux tunnels were written before RFC6040 and therefore never implemented the corner case of ECN getting set in the outer header and the inner header not being ready for it. Section 4.2. Default Tunnel Egress Behaviour. o If the inner ECN field is Not-ECT, the decapsulator MUST NOT propagate any other ECN codepoint onwards. This is because the inner Not-ECT marking is set by transports that rely on dropped packets as an indication of congestion and would not understand or respond to any other ECN codepoint [RFC4774]. Specifically: * If the inner ECN field is Not-ECT and the outer ECN field is CE, the decapsulator MUST drop the packet. * If the inner ECN field is Not-ECT and the outer ECN field is Not-ECT, ECT(0), or ECT(1), the decapsulator MUST forward the outgoing packet with the ECN field cleared to Not-ECT. This patch moves the ECN decap logic out of the individual tunnels into a common place. It also adds logging to allow detecting broken systems that set ECN bits incorrectly when tunneling (or an intermediate router might be changing the header). Overloads rx_frame_error to keep track of ECN related error. Thanks to Chris Wright who caught this while reviewing the new VXLAN tunnel. This code was tested by injecting faulty logic in other end GRE to send incorrectly encapsulated packets. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-27xfrm: remove extranous rcu_read_lockstephen hemminger
The handlers for xfrm_tunnel are always invoked with rcu read lock already. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-27gre: remove unnecessary rcu_read_lock/unlockstephen hemminger
The gre function pointers for receive and error handling are always called (from gre.c) with rcu_read_lock already held. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-25ipv6: mip6: fix mip6_mh_filter()Eric Dumazet
mip6_mh_filter() should not modify its input, or else its caller would need to recompute ipv6_hdr() if skb->head is reallocated. Use skb_header_pointer() instead of pskb_may_pull() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-25ipv6: raw: fix icmpv6_filter()Eric Dumazet
icmpv6_filter() should not modify its input, or else its caller would need to recompute ipv6_hdr() if skb->head is reallocated. Use skb_header_pointer() instead of pskb_may_pull() and change the prototype to make clear both sk and skb are const. Also, if icmpv6 header cannot be found, do not deliver the packet, as we do in IPv4. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-24net: use a per task frag allocatorEric Dumazet
We currently use a per socket order-0 page cache for tcp_sendmsg() operations. This page is used to build fragments for skbs. Its done to increase probability of coalescing small write() into single segments in skbs still in write queue (not yet sent) But it wastes a lot of memory for applications handling many mostly idle sockets, since each socket holds one page in sk->sk_sndmsg_page Its also quite inefficient to build TSO 64KB packets, because we need about 16 pages per skb on arches where PAGE_SIZE = 4096, so we hit page allocator more than wanted. This patch adds a per task frag allocator and uses bigger pages, if available. An automatic fallback is done in case of memory pressure. (up to 32768 bytes per frag, thats order-3 pages on x86) This increases TCP stream performance by 20% on loopback device, but also benefits on other network devices, since 8x less frags are mapped on transmit and unmapped on tx completion. Alexander Duyck mentioned a probable performance win on systems with IOMMU enabled. Its possible some SG enabled hardware cant cope with bigger fragments, but their ndo_start_xmit() should already handle this, splitting a fragment in sub fragments, since some arches have PAGE_SIZE=65536 Successfully tested on various ethernet devices. (ixgbe, igb, bnx2x, tg3, mellanox mlx4) Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Vijay Subramanian <subramanian.vijay@gmail.com> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Vijay Subramanian <subramanian.vijay@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-24Merge branch 'master' of git://1984.lsi.us.es/nf-nextDavid S. Miller
Pablo Neira Ayuso says: ==================== This patchset contains updates for your net-next tree, they are: * Mostly fixes for the recently pushed IPv6 NAT support: - Fix crash while removing nf_nat modules from Patrick McHardy. - Fix unbalanced rcu_read_unlock from Ulrich Weber. - Merge NETMAP and REDIRECT into one single xt_target module, from Jan Engelhardt. - Fix Kconfig for IPv6 NAT, which allows inconsistent configurations, from myself. * Updates for ipset, all of the from Jozsef Kadlecsik: - Add the new "nomatch" option to obtain reverse set matching. - Support for /0 CIDR in hash:net,iface set type. - One non-critical fix for a rare crash due to pass really wrong configuration parameters. - Coding style cleanups. - Sparse fixes. - Add set revision supported via modinfo.i * One extension for the xt_time match, to support matching during the transition between two days with one single rule, from Florian Westphal. * Fix maximum packet length supported by nfnetlink_queue and add NFQA_CAP_LEN attribute, from myself. You can notice that this batch contains a couple of fixes that may go to 3.6-rc but I don't consider them critical to push them: * The ipset fix for the /0 cidr case, which is triggered with one inconsistent command line invocation of ipset. * The nfnetlink_queue maximum packet length supported since it requires the new NFQA_CAP_LEN attribute to provide a full workaround for the described problem. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-22tcp: TCP Fast Open Server - take SYNACK RTT after completing 3WHSNeal Cardwell
When taking SYNACK RTT samples for servers using TCP Fast Open, fix the code to ensure that we only call tcp_valid_rtt_meas() after we receive the ACK that completes the 3-way handshake. Previously we were always taking an RTT sample in tcp_v4_syn_recv_sock(). However, for TCP Fast Open connections tcp_v4_conn_req_fastopen() calls tcp_v4_syn_recv_sock() at the time we receive the SYN. So for TFO we must wait until tcp_rcv_state_process() to take the RTT sample. To fix this, we wait until after TFO calls tcp_v4_syn_recv_sock() before we set the snt_synack timestamp, since tcp_synack_rtt_meas() already ensures that we only take a SYNACK RTT sample if snt_synack is non-zero. To be careful, we only take a snt_synack timestamp when a SYNACK transmit or retransmit succeeds. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-22tcp: extract code to compute SYNACK RTTNeal Cardwell
In preparation for adding another spot where we compute the SYNACK RTT, extract this code so that it can be shared. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-21ipv6: fix return value check in fib6_add()Wei Yongjun
In case of error, the function fib6_add_1() returns ERR_PTR() or NULL pointer. The ERR_PTR() case check is missing in fib6_add(). dpatch engine is used to generated this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-21netfilter: combine ipt_REDIRECT and ip6t_REDIRECTJan Engelhardt
Combine more modules since the actual code is so small anyway that the kmod metadata and the module in its loaded state totally outweighs the combined actual code size. IP_NF_TARGET_REDIRECT becomes a compat option; IP6_NF_TARGET_REDIRECT is completely eliminated since it has not see a release yet. Signed-off-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-21netfilter: combine ipt_NETMAP and ip6t_NETMAPJan Engelhardt
Combine more modules since the actual code is so small anyway that the kmod metadata and the module in its loaded state totally outweighs the combined actual code size. IP_NF_TARGET_NETMAP becomes a compat option; IP6_NF_TARGET_NETMAP is completely eliminated since it has not see a release yet. Signed-off-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-21netfilter: fix IPv6 NAT dependencies in KconfigPablo Neira Ayuso
* NF_NAT_IPV6 requires IP6_NF_IPTABLES * IP6_NF_TARGET_MASQUERADE, IP6_NF_TARGET_NETMAP, IP6_NF_TARGET_REDIRECT and IP6_NF_TARGET_NPT require NF_NAT_IPV6. This change just mirrors what IPv4 does in Kconfig, for consistency. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-19ipv6: unify fragment thresh handling codeAmerigo Wang
Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Kubeček <mkubecek@suse.cz> Cc: David Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19ipv6: make ip6_frag_nqueues() and ip6_frag_mem() static inlineAmerigo Wang
2012-09-19ipv6: unify conntrack reassembly expire code with standard oneAmerigo Wang
Two years ago, Shan Wei tried to fix this: http://patchwork.ozlabs.org/patch/43905/ The problem is that RFC2460 requires an ICMP Time Exceeded -- Fragment Reassembly Time Exceeded message should be sent to the source of that fragment, if the defragmentation times out. " If insufficient fragments are received to complete reassembly of a packet within 60 seconds of the reception of the first-arriving fragment of that packet, reassembly of that packet must be abandoned and all the fragments that have been received for that packet must be discarded. If the first fragment (i.e., the one with a Fragment Offset of zero) has been received, an ICMP Time Exceeded -- Fragment Reassembly Time Exceeded message should be sent to the source of that fragment. " As Herbert suggested, we could actually use the standard IPv6 reassembly code which follows RFC2460. With this patch applied, I can see ICMP Time Exceeded sent from the receiver when the sender sent out 3/4 fragmented IPv6 UDP packet. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Kubeček <mkubecek@suse.cz> Cc: David Miller <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: netfilter-devel@vger.kernel.org Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19ipv6: add a new namespace for nf_conntrack_reasmAmerigo Wang
As pointed by Michal, it is necessary to add a new namespace for nf_conntrack_reasm code, this prepares for the second patch. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Kubeček <mkubecek@suse.cz> Cc: David Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: netfilter-devel@vger.kernel.org Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19ipv6: recursive check rt->dst.from when call rt6_check_expiredLi RongQing
If dst cache dst_a copies from dst_b, and dst_b copies from dst_c, check if dst_a is expired or not, we should not end with dst_a->dst.from, dst_b, we should check dst_c. CC: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18ipv6: use DST_* macro to set obselete fieldNicolas Dichtel
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18ipv6: use net->rt_genid to check dst validityNicolas Dichtel
IPv6 dst should take care of rt_genid too. When a xfrm policy is inserted or deleted, all dst should be invalidated. To force the validation, dst entries should be created with ->obsolete set to DST_OBSOLETE_FORCE_CHK. This was already the case for all functions calling ip6_dst_alloc(), except for ip6_rt_copy(). As a consequence, we can remove the specific code in inet6_connection_sock. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/netfilter/nfnetlink_log.c net/netfilter/xt_LOG.c Rather easy conflict resolution, the 'net' tree had bug fixes to make sure we checked if a socket is a time-wait one or not and elide the logging code if so. Whereas on the 'net-next' side we are calculating the UID and GID from the creds using different interfaces due to the user namespace changes from Eric Biederman. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13ipv6: replace write lock with read lock when get route infoLi RongQing
geting route info does not write rt->rt6i_table, so replace write lock with read lock Suggested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13ipv6: route templates can be constEric Dumazet
We kmemdup() templates, so they can be const. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13ipv6: Compare addresses only bits up to the prefix length (RFC6724).YOSHIFUJI Hideaki / 吉藤英明
Compare bits up to the source address's prefix length only to allows DNS load balancing to continue to be used as a tie breaker. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-13ipv6: Add labels for site-local and 6bone testing addresses (RFC6724)YOSHIFUJI Hideaki / 吉藤英明
Added labels for site-local addresses (fec0::/10) and 6bone testing addresses (3ffe::/16) in order to depreference them. Note that the RFC introduced new rows for Teredo, ULA and 6to4 addresses in the default policy table. Some of them have different labels from ours. For backward compatibility, we do not change the "default" labels. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10ipv6: remove some useless RCU read lockAmerigo Wang
After this commit: commit 97cac0821af4474ec4ba3a9e7a36b98ed9b6db88 Author: David S. Miller <davem@davemloft.net> Date: Mon Jul 2 22:43:47 2012 -0700 ipv6: Store route neighbour in rt6_info struct. we no longer use RCU to protect route neighbour. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07ipv6: fix handling of throw routesNicolas Dichtel
It's the same problem that previous fix about blackhole and prohibit routes. When adding a throw route, it was handled like a classic route. Moreover, it was only possible to add this kind of routes by specifying an interface. Before the patch: $ ip route add throw 2001::2/128 RTNETLINK answers: No such device $ ip route add throw 2001::2/128 dev eth0 $ ip -6 route | grep 2001::2 2001::2 dev eth0 metric 1024 After: $ ip route add throw 2001::2/128 $ ip -6 route | grep 2001::2 throw 2001::2 dev lo metric 1024 error -11 Reported-by: Markus Stenberg <markus.stenberg@iki.fi> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07udp: increment UDP_MIB_INERRORS if copy failedEric Dumazet
In UDP recvmsg(), we miss an increase of UDP_MIB_INERRORS if the copy of skb to userspace failed for whatever reason. Reported-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-05ipv6: fix handling of blackhole and prohibit routesNicolas Dichtel
When adding a blackhole or a prohibit route, they were handling like classic routes. Moreover, it was only possible to add this kind of routes by specifying an interface. Bug already reported here: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=498498 Before the patch: $ ip route add blackhole 2001::1/128 RTNETLINK answers: No such device $ ip route add blackhole 2001::1/128 dev eth0 $ ip -6 route | grep 2001 2001::1 dev eth0 metric 1024 After: $ ip route add blackhole 2001::1/128 $ ip -6 route | grep 2001 blackhole 2001::1 dev lo metric 1024 error -22 v2: wrong patch v3: add a field fc_type in struct fib6_config to store RTN_* type Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-05netfilter: ipv6: using csum_ipv6_magic requires net/ip6_checksum.hStephen Rothwell
Fixes this build error: net/ipv6/netfilter/nf_nat_l3proto_ipv6.c: In function 'nf_nat_ipv6_csum_recalc': net/ipv6/netfilter/nf_nat_l3proto_ipv6.c:144:4: error: implicit declaration of function 'csum_ipv6_magic' [-Werror=implicit-function-declaration] Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-05tcp: fix possible socket refcount problem for ipv6Julian Anastasov
commit 144d56e91044181ec0ef67aeca91e9a8b5718348 ("tcp: fix possible socket refcount problem") is missing the IPv6 part. As tcp_release_cb is shared by both protocols we should hold sock reference for the TCP_MTU_REDUCED_DEFERRED bit. Signed-off-by: Julian Anastasov <ja@ssi.bg> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextPablo Neira Ayuso
This merges (3f509c6 netfilter: nf_nat_sip: fix incorrect handling of EBUSY for RTCP expectation) to Patrick McHardy's IPv6 NAT changes.
2012-08-31tcp: TCP Fast Open Server - support TFO listenersJerry Chu
This patch builds on top of the previous patch to add the support for TFO listeners. This includes - 1. allocating, properly initializing, and managing the per listener fastopen_queue structure when TFO is enabled 2. changes to the inet_csk_accept code to support TFO. E.g., the request_sock can no longer be freed upon accept(), not until 3WHS finishes 3. allowing a TCP_SYN_RECV socket to properly poll() and sendmsg() if it's a TFO socket 4. properly closing a TFO listener, and a TFO socket before 3WHS finishes 5. supporting TCP_FASTOPEN socket option 6. modifying tcp_check_req() to use to check a TFO socket as well as request_sock 7. supporting TCP's TFO cookie option 8. adding a new SYN-ACK retransmit handler to use the timer directly off the TFO socket rather than the listener socket. Note that TFO server side will not retransmit anything other than SYN-ACK until the 3WHS is completed. The patch also contains an important function "reqsk_fastopen_remove()" to manage the somewhat complex relation between a listener, its request_sock, and the corresponding child socket. See the comment above the function for the detail. Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31ipv6: remove some deadcodeSorin Dumitru
__ipv6_regen_rndid no longer returns anything other than 0 so there's no point in verifying what it returns Signed-off-by: Sorin Dumitru <sdumitru@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31net: ipv6: fix error return codeJulia Lawall
Initialize return variable before exiting on an error path. The initial initialization of the return variable is also dropped, because that value is never used. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30netfilter: ip6tables: add stateless IPv6-to-IPv6 Network Prefix Translation ↵Patrick McHardy
target Signed-off-by: Patrick McHardy <kaber@trash.net>
2012-08-30netfilter: ip6tables: add NETMAP targetPatrick McHardy
2012-08-30netfilter: ip6tables: add REDIRECT targetPatrick McHardy
2012-08-30netfilter: ip6tables: add MASQUERADE targetPatrick McHardy
2012-08-30netfilter: ipv6: add IPv6 NAT supportPatrick McHardy
2012-08-30netfilter: ipv6: expand skb head in ip6_route_me_harder after oif changePatrick McHardy
Expand the skb headroom if the oif changed due to rerouting similar to how IPv4 packets are handled. Signed-off-by: Patrick McHardy <kaber@trash.net>
2012-08-30netfilter: nf_conntrack_ipv6: fix tracking of ICMPv6 error messages ↵Patrick McHardy
containing fragments ICMPv6 error messages are tracked by extracting the conntrack tuple of the inner packet and looking up the corresponding conntrack entry. Tuple extraction uses the ->get_l4proto() callback, which in case of fragments returns NEXTHDR_FRAGMENT instead of the upper protocol, even for the first fragment when the entire next header is present, resulting in a failure to find the correct connection tracking entry. This patch changes ipv6_get_l4proto() to use ipv6_skip_exthdr() instead of nf_ct_ipv6_skip_exthdr() in order to skip fragment headers when the fragment offset is zero. Signed-off-by: Patrick McHardy <kaber@trash.net>
2012-08-30netfilter: nf_conntrack_ipv6: improve fragmentation handlingPatrick McHardy
The IPv6 conntrack fragmentation currently has a couple of shortcomings. Fragmentes are collected in PREROUTING/OUTPUT, are defragmented, the defragmented packet is then passed to conntrack, the resulting conntrack information is attached to each original fragment and the fragments then continue their way through the stack. Helper invocation occurs in the POSTROUTING hook, at which point only the original fragments are available. The result of this is that fragmented packets are never passed to helpers. This patch improves the situation in the following way: - If a reassembled packet belongs to a connection that has a helper assigned, the reassembled packet is passed through the stack instead of the original fragments. - During defragmentation, the largest received fragment size is stored. On output, the packet is refragmented if required. If the largest received fragment size exceeds the outgoing MTU, a "packet too big" message is generated, thus behaving as if the original fragments were passed through the stack from an outside point of view. - The ipv6_helper() hook function can't receive fragments anymore for connections using a helper, so it is switched to use ipv6_skip_exthdr() instead of the netfilter specific nf_ct_ipv6_skip_exthdr() and the reassembled packets are passed to connection tracking helpers. The result of this is that we can properly track fragmented packets, but still generate ICMPv6 Packet too big messages if we would have before. This patch is also required as a precondition for IPv6 NAT, where NAT helpers might enlarge packets up to a point that they require fragmentation. In that case we can't generate Packet too big messages since the proper MTU can't be calculated in all cases (f.i. when changing textual representation of a variable amount of addresses), so the packet is transparently fragmented iff the original packet or fragments would have fit the outgoing MTU. IPVS parts by Jesper Dangaard Brouer <brouer@redhat.com>. Signed-off-by: Patrick McHardy <kaber@trash.net>
2012-08-24Merge branch 'for-next' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace This is an initial merge in of Eric Biederman's work to start adding user namespace support to the networking. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-23net: reinstate rtnl in call_netdevice_notifiers()Eric Dumazet
Eric Biederman pointed out that not holding RTNL while calling call_netdevice_notifiers() was racy. This patch is a direct transcription his feedback against commit 0115e8e30d6fc (net: remove delay at device dismantle) Thanks Eric ! Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Mahesh Bandewar <maheshb@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Gao feng <gaofeng@cn.fujitsu.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-22ipv6: gre: fix ip6gre_err()Eric Dumazet
ip6gre_err() miscomputes grehlen (sizeof(ipv6h) is 4 or 8, not 40 as expected), and should take into account 'offset' parameter. Also uses pskb_may_pull() to cope with some fragged skbs Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
