path: root/net/ipv6
2012-01-12net: reintroduce missing rcu_assign_pointer() callsEric Dumazet
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTER) did a lot of incorrect changes, since it did a complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x, y). We miss needed barriers, even on x86, when y is not NULL. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04ipv6/addrconf: speedup /proc/net/if_inet6 fillingMihai Maruseac
This ensures a linear behaviour when filling /proc/net/if_inet6 thus making ifconfig run really fast on IPv6 only addresses. In fact, with this patch and the IPv4 one sent a while ago, ifconfig will run in linear time regardless of address type. IPv4 related patch: f04565ddf52e401880f8ba51de0dff8ba51c99fd dev: use name hash for dev_seq_ops ... Some statistics (running ifconfig > /dev/null on a different setup): iface count / IPv6 no-patch time / IPv6 patched time / IPv4 time ---------------------------------------------------------------- 6250 | 0.23 s | 0.13 s | 0.11 s 12500 | 0.62 s | 0.28 s | 0.22 s 25000 | 2.91 s | 0.57 s | 0.46 s 50000 | 11.37 s | 1.21 s | 0.94 s 128000 | 86.78 s | 3.05 s | 2.54 s Signed-off-by: Mihai Maruseac <mmaruseac@ixiacom.com> Cc: Daniel Baluta <dbaluta@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04ipv6: Check RA for sllao when configuring optimistic ipv6 address (v2)Neil Horman
Recently Dave noticed that a test we did in ipv6_add_addr to see if we next hop route for the interface we're adding an addres to was wrong (see commit 7ffbcecbeed91e5874e9a1cfc4c0cbb07dac3069). for one, it never triggers, and two, it was completely wrong to begin with. This test was meant to cover this section of RFC 4429: 3.3 Modifications to RFC 2462 Stateless Address Autoconfiguration * (modifies section 5.5) A host MAY choose to configure a new address as an Optimistic Address. A host that does not know the SLLAO of its router SHOULD NOT configure a new address as Optimistic. A router SHOULD NOT configure an Optimistic Address. This patch should bring us into proper compliance with the above clause. Since we only add a SLAAC address after we've received a RA which may or may not contain a source link layer address option, we can pass a pointer to that option to addrconf_prefix_rcv (which may be null if the option is not present), and only set the optimistic flag if the option was found in the RA. Change notes: (v2) modified the new parameter to addrconf_prefix_rcv to be a bool rather than a pointer to make its use more clear as per request from davem. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: "David S. Miller" <davem@davemloft.net> CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-30IPv6: Avoid taking write lock for /proc/net/ipv6_routeJosh Hunt
During some debugging I needed to look into how /proc/net/ipv6_route operated and in my digging I found its calling fib6_clean_all() which uses "write_lock_bh(&table->tb6_lock)" before doing the walk of the table. I found this on 2.6.32, but reading the code I believe the same basic idea exists currently. Looking at the rtnetlink code they are only calling "read_lock_bh(&table->tb6_lock);" via fib6_dump_table(). While I realize reading from proc isn't the recommended way of fetching the ipv6 route table; taking a write lock seems unnecessary and would probably cause network performance issues. To verify this I loaded up the ipv6 route table and then ran iperf in 3 cases: * doing nothing * reading ipv6 route table via proc (while :; do cat /proc/net/ipv6_route > /dev/null; done) * reading ipv6 route table via rtnetlink (while :; do ip -6 route show table all > /dev/null; done) * Load the ipv6 route table up with: * for ((i = 0;i < 4000;i++)); do ip route add unreachable 2000::$i; done * iperf commands: * client: iperf -i 1 -V -c <ipv6 addr> * server: iperf -V -s * iperf results - 3 runs each (in Mbits/sec) * nothing: client: 927,927,927 server: 927,927,927 * proc: client: 179,97,96,113 server: 142,112,133 * iproute: client: 928,927,928 server: 927,927,927 lock_stat shows taking the write lock is causing the slowdown. Using this info I decided to write a version of fib6_clean_all() which replaces write_lock_bh(&table->tb6_lock) with read_lock_bh(&table->tb6_lock). With this new function I see the same results as with my rtnetlink iperf test. Signed-off-by: Josh Hunt <joshhunt00@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-29ipv6: Fix neigh lookup using NULL device.David S. Miller
In some of the rt6_bind_neighbour() call sites, it hasn't hooked up the rt->dst.dev pointer yet, so we'd deref a NULL pointer when obtaining dev->ifindex for the neighbour hash function computation. Just pass the netdevice explicitly in to fix this problem. Reported-by: Bjarke Istrup Pedersen <gurligebis@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-29ipv6: Report TCP timetstamp info in cacheinfo just like ipv4 does.David S. Miller
I missed this while adding ipv6 support to inet_peer. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-28ipv6: Kill rt6i_dev and rt6i_expires defines.David S. Miller
It just obscures that the netdevice pointer and the expires value are implemented in the dst_entry sub-object of the ipv6 route. And it makes grepping for dst_entry member uses much harder too. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-28ipv6: Create fast inline ipv6 neigh lookup just like ipv4.David S. Miller
Also, create and use an rt6_bind_neighbour() in net/ipv6/route.c to consolidate some common logic. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-28ipv6: Use universal hash for NDISC.David S. Miller
In order to perform a proper universal hash on a vector of integers, we have to use different universal hashes on each vector element. Which means we need 4 different hash randoms for ipv6. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-28ipv6: Remove optimistic DAD flag test in ipv6_add_addr()David Miller
The route we have here is for the address being added to the interface, ie. for input packet processing. Therefore using that route to determine whether an output nexthop gateway is known and resolved doesn't make any sense. So, simply remove this test, it never triggered anyways. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-By: Neil Horman <nhorman@tuxdriver.com>
2011-12-26ipv6: Kill useless route tracing bits in net/ipv6/route.cDavid S. Miller
RDBG() wasn't even used, and the messages printed by RT6_DEBUG() were far from useful. Just get rid of all this stuff, we can replace it with something more suitable if we want. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-25Merge branch 'nf-next' of git://1984.lsi.us.es/net-nextDavid S. Miller
2011-12-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/bluetooth/l2cap_core.c Just two overlapping changes, one added an initialization of a local variable, and another change added a new local variable. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22net: introduce DST_NOPEER dst flagEric Dumazet
Chris Boot reported crashes occurring in ipv6_select_ident(). [ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>] ipv6_select_ident+0x31/0xa7 [ 461.578229] Call Trace: [ 461.580742] <IRQ> [ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2 [ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155 [ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b [ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e [nf_conntrack_ipv6] [ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543 [ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a [bridge] [ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459 [ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76 [bridge] [ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f [bridge] [ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.677299] [<ffffffffa0379215>] ? nf_bridge_update_protocol+0x20/0x20 [bridge] [ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack] [ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56 [bridge] [ 461.704616] [<ffffffffa0379031>] ? nf_bridge_push_encap_header+0x1c/0x26 [bridge] [ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95 [bridge] [ 461.719490] [<ffffffffa037900a>] ? nf_bridge_pull_encap_header+0x1c/0x27 [bridge] [ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge] [ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56 [bridge] This is caused by bridge netfilter special dst_entry (fake_rtable), a special shared entry, where attaching an inetpeer makes no sense. Problem is present since commit 87c48fa3b46 (ipv6: make fragment identifications less predictable) Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and __ip_select_ident() fallback to the 'no peer attached' handling. Reported-by: Chris Boot <bootc@bootc.net> Tested-by: Chris Boot <bootc@bootc.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19module_param: make bool parameters really bool (net & drivers/net)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. (Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false). Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/freescale/fsl_pq_mdio.c net/batman-adv/translation-table.c net/ipv6/route.c
2011-12-13ipv6: Check dest prefix length on original route not copied one in ↵David S. Miller
rt6_alloc_cow(). After commit 8e2ec639173f325977818c45011ee176ef2b11f6 ("ipv6: don't use inetpeer to store metrics for routes.") the test in rt6_alloc_cow() for setting the ANYCAST flag is now wrong. 'rt' will always now have a plen of 128, because it is set explicitly to 128 by ip6_rt_copy. So to restore the semantics of the test, check the destination prefix length of 'ort'. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-13ipv6: If neigh lookup fails during icmp6 dst allocation, propagate error.David S. Miller
Don't just succeed with a route that has a NULL neighbour attached. This follows the behavior of addrconf_dst_alloc(). Allowing this kind of route to end up with a NULL neigh attached will result in packet drops on output until the route is somehow invalidated, since nothing will meanwhile try to lookup the neigh again. A statistic is bumped for the case where we see a neigh-less route on output, but the resulting packet drop is otherwise silent in nature, and frankly it's a hard error for this to happen and ipv6 should do what ipv4 does which is say something in the kernel logs. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-13netfilter: add ipv6 reverse path filter matchFlorian Westphal
This is not merged with the ipv4 match into xt_rpfilter.c to avoid ipv6 module dependency issues. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-12-12per-netns ipv4 sysctl_tcp_memGlauber Costa
This patch allows each namespace to independently set up its levels for tcp memory pressure thresholds. This patch alone does not buy much: we need to make this values per group of process somehow. This is achieved in the patches that follows in this patchset. Signed-off-by: Glauber Costa <glommer@parallels.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> CC: David S. Miller <davem@davemloft.net> CC: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-12tcp memory pressure controlsGlauber Costa
This patch introduces memory pressure controls for the tcp protocol. It uses the generic socket memory pressure code introduced in earlier patches, and fills in the necessary data in cg_proto struct. Signed-off-by: Glauber Costa <glommer@parallels.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com> CC: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-12foundations of per-cgroup memory pressure controlling.Glauber Costa
This patch replaces all uses of struct sock fields' memory_pressure, memory_allocated, sockets_allocated, and sysctl_mem to acessor macros. Those macros can either receive a socket argument, or a mem_cgroup argument, depending on the context they live in. Since we're only doing a macro wrapping here, no performance impact at all is expected in the case where we don't have cgroups disabled. Signed-off-by: Glauber Costa <glommer@parallels.com> Reviewed-by: Hiroyouki Kamezawa <kamezawa.hiroyu@jp.fujitsu.com> CC: David S. Miller <davem@davemloft.net> CC: Eric W. Biederman <ebiederm@xmission.com> CC: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-12ipip, sit: copy parms.name after register_netdeviceTed Feng
Same fix as 731abb9cb2 for ipip and sit tunnel. Commit 1c5cae815d removed an explicit call to dev_alloc_name in ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice will now create a valid name, however the tunnel keeps a copy of the name in the private parms structure. Fix this by copying the name back after register_netdevice has successfully returned. This shows up if you do a simple tunnel add, followed by a tunnel show: $ sudo ip tunnel add mode ipip remote 10.2.20.211 $ ip tunnel tunl0: ip/ip remote any local any ttl inherit nopmtudisc tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit $ sudo ip tunnel add mode sit remote 10.2.20.212 $ ip tunnel sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16 sit%d: ioctl 89f8 failed: No such device sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit Cc: stable@vger.kernel.org Signed-off-by: Ted Feng <artisdom@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-12ipv6: Fix for adding multicast route for loopback device automatically.Li Wei
There is no obvious reason to add a default multicast route for loopback devices, otherwise there would be a route entry whose dst.error set to -ENETUNREACH that would blocking all multicast packets. ==================== [ more detailed explanation ] The problem is that the resulting routing table depends on the sequence of interface's initialization and in some situation, that would block all muticast packets. Suppose there are two interfaces on my computer (lo and eth0), if we initailize 'lo' before 'eth0', the resuting routing table(for multicast) would be # ip -6 route show | grep ff00:: unreachable ff00::/8 dev lo metric 256 error -101 ff00::/8 dev eth0 metric 256 When sending multicasting packets, routing subsystem will return the first route entry which with a error set to -101(ENETUNREACH). I know the kernel will set the default ipv6 address for 'lo' when it is up and won't set the default multicast route for it, but there is no reason to stop 'init' program from setting address for 'lo', and that is exactly what systemd did. I am sure there is something wrong with kernel or systemd, currently I preferred kernel caused this problem. ==================== Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-09udp: Export code sk lookup routinesPavel Emelyanov
The UDP diag get_exact handler will require them to find a socket by provided net, [sd]addr-s, [sd]ports and device. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-06ipv6: Move xfrm_lookup() call down into icmp6_dst_alloc().David S. Miller
And return error pointers. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-06ipv6: Make third arg to anycast_dst_alloc() bool.David S. Miller
2011-12-05net: Rename dst_get_neighbour{, _raw} to dst_get_neighbour_noref{, _raw}.David Miller
To reflect the fact that a refrence is not obtained to the resulting neighbour entry. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Roland Dreier <roland@purestorage.com>
2011-12-04ipv6: add ip6_route_lookupFlorian Westphal
like rt6_lookup, but allows caller to pass in flowi6 structure. Will be used by the upcoming ipv6 netfilter reverse path filter match. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-12-03Merge branch 'for-upstream' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch
2011-12-03ipv6: Kill ndisc_get_neigh() inline helper.David S. Miller
It's only used in net/ipv6/route.c and the NULL device check is superfluous for all of the existing call sites. Just expand the __ndisc_lookup_errno() call at each location. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03ipv6: Various cleanups in route.cDavid S. Miller
1) x == NULL --> !x 2) x != NULL --> x 3) (x&BIT) --> (x & BIT) 4) (BIT1|BIT2) --> (BIT1 | BIT2) 5) proper argument and struct member alignment Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03ipv6: Various cleanups in ip6_route.cDavid S. Miller
1) x == NULL --> !x 2) x != NULL --> x 3) if() --> if () 4) while() --> while () 5) (x & BIT) == 0 --> !(x & BIT) 6) (x&BIT) --> (x & BIT) 7) x=y --> x = y 8) (BIT1|BIT2) --> (BIT1 | BIT2) 9) if ((x & BIT)) --> if (x & BIT) 10) proper argument and struct member alignment Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03ipv6: Add fragment reporting to ipv6_skip_exthdr().Jesse Gross
While parsing through IPv6 extension headers, fragment headers are skipped making them invisible to the caller. This reports the fragment offset of the last header in order to make it possible to determine whether the packet is fragmented and, if so whether it is a first or last fragment. Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-12-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-12-01Revert "udp: remove redundant variable"David S. Miller
This reverts commit 81d54ec8479a2c695760da81f05b5a9fb2dbe40a. If we take the "try_again" goto, due to a checksum error, the 'len' has already been truncated. So we won't compute the same values as the original code did. Reported-by: paul bilke <fsmail@conspiracy.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-30ipv6 : mcast : Delete useless parameter in ip6_mc_add1_src()Jun Zhao
Need not to used 'delta' flag when add single-source to interface filter source list. Signed-off-by: Jun Zhao <mypopydev@gmail.com> Signed-off-by: David S. Miller <davem@drr.davemloft.net>
2011-11-30neigh: Do not set tbl->entry_size in ipv4/ipv6 neigh tables.David Miller
Let the core self-size the neigh entry based upon the key length. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-29net: dont call jump_label_dec from irq contextEric Dumazet
Igor Maravic reported an error caused by jump_label_dec() being called from IRQ context : BUG: sleeping function called from invalid context at kernel/mutex.c:271 in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper 1 lock held by swapper/0: #0: (&n->timer){+.-...}, at: [<ffffffff8107ce90>] call_timer_fn+0x0/0x340 Pid: 0, comm: swapper Not tainted 3.2.0-rc2-net-next-mpls+ #1 Call Trace: <IRQ> [<ffffffff8104f417>] __might_sleep+0x137/0x1f0 [<ffffffff816b9a2f>] mutex_lock_nested+0x2f/0x370 [<ffffffff810a89fd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff8109a37f>] ? local_clock+0x6f/0x80 [<ffffffff810a90a5>] ? lock_release_holdtime.part.22+0x15/0x1a0 [<ffffffff81557929>] ? sock_def_write_space+0x59/0x160 [<ffffffff815e936e>] ? arp_error_report+0x3e/0x90 [<ffffffff810969cd>] atomic_dec_and_mutex_lock+0x5d/0x80 [<ffffffff8112fc1d>] jump_label_dec+0x1d/0x50 [<ffffffff81566525>] net_disable_timestamp+0x15/0x20 [<ffffffff81557a75>] sock_disable_timestamp+0x45/0x50 [<ffffffff81557b00>] __sk_free+0x80/0x200 [<ffffffff815578d0>] ? sk_send_sigurg+0x70/0x70 [<ffffffff815e936e>] ? arp_error_report+0x3e/0x90 [<ffffffff81557cba>] sock_wfree+0x3a/0x70 [<ffffffff8155c2b0>] skb_release_head_state+0x70/0x120 [<ffffffff8155c0b6>] __kfree_skb+0x16/0x30 [<ffffffff8155c119>] kfree_skb+0x49/0x170 [<ffffffff815e936e>] arp_error_report+0x3e/0x90 [<ffffffff81575bd9>] neigh_invalidate+0x89/0xc0 [<ffffffff81578dbe>] neigh_timer_handler+0x9e/0x2a0 [<ffffffff81578d20>] ? neigh_update+0x640/0x640 [<ffffffff81073558>] __do_softirq+0xc8/0x3a0 Since jump_label_{inc|dec} must be called from process context only, we must defer jump_label_dec() if net_disable_timestamp() is called from interrupt context. Reported-by: Igor Maravic <igorm@etf.rs> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-28ipv6: Set mcast_hops to IPV6_DEFAULT_MCASTHOPS when -1 was given.Li Wei
We need to set np->mcast_hops to it's default value at this moment otherwise when we use it and found it's value is -1, the logic to get default hop limit doesn't take multicast into account and will return wrong hop limit(IPV6_DEFAULT_HOPLIMIT) which is for unicast. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/ipv4/inet_diag.c
2011-11-26net: Move mtu handling down to the protocol depended handlersSteffen Klassert
We move all mtu handling from dst_mtu() down to the protocol layer. So each protocol can implement the mtu handling in a different manner. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-26net: Rename the dst_opt default_mtu method to mtuSteffen Klassert
We plan to invoke the dst_opt->default_mtu() method unconditioally from dst_mtu(). So rename the method to dst_opt->mtu() to match the name with the new meaning. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-26route: Use the device mtu as the default for blackhole routesSteffen Klassert
As it is, we return null as the default mtu of blackhole routes. This may lead to a propagation of a bogus pmtu if the default_mtu method of a blackhole route is invoked. So return dst->dev->mtu as the default mtu instead. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-23ipv6: tcp: fix tcp_v6_conn_request()Eric Dumazet
Since linux 2.6.26 (commit c6aefafb7ec6 : Add IPv6 support to TCP SYN cookies), we can drop a SYN packet reusing a TIME_WAIT socket. (As a matter of fact we fail to send the SYNACK answer) As the client resends its SYN packet after a one second timeout, we accept it, because first packet removed the TIME_WAIT socket before being dropped. This probably explains why nobody ever noticed or complained. Reported-by: Jesse Young <jlyo@jlyo.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-23netfilter: Remove NOTRACK/RAW dependency on NETFILTER_ADVANCED.David S. Miller
Distributions are using this in their default scripts, so don't hide them behind the advanced setting. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-23ipv6: tcp: fix panic in SYN processingEric Dumazet
commit 72a3effaf633bc ([NET]: Size listen hash tables using backlog hint) added a bug allowing inet6_synq_hash() to return an out of bound array index, because of u16 overflow. Bug can happen if system admins set net.core.somaxconn & net.ipv4.tcp_max_syn_backlog sysctls to values greater than 65536 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-23ipv6: fix a bug in ndisc_send_redirectLi Wei
Release skb when transmit rate limit _not_ allow Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
The forcedeth changes had a conflict with the conversion over to atomic u64 statistics in net-next. The libertas cfg.c code had a conflict with the bss reference counting fix by John Linville in net-next. Conflicts: drivers/net/ethernet/nvidia/forcedeth.c drivers/net/wireless/libertas/cfg.c
