path: root/net/ipv6/xfrm6_output.c
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18xfrm6: Don't call icmpv6_send on local errorSteffen Klassert
Calling icmpv6_send() on a local message size error leads to an incorrect update of the path mtu. So use xfrm6_local_rxpmtu() to notify about the pmtu if the IPV6_DONTFRAG socket option is set on an udp or raw socket, according RFC 3542 and use ipv6_local_error() otherwise. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-10xfrm: Assign the inner mode output function to the dst entrySteffen Klassert
As it is, we assign the outer modes output function to the dst entry when we create the xfrm bundle. This leads to two problems on interfamily scenarios. We might insert ipv4 packets into ip6_fragment when called from xfrm6_output. The system crashes if we try to fragment an ipv4 packet with ip6_fragment. This issue was introduced with git commit ad0081e4 (ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed). The second issue is, that we might insert ipv4 packets in netfilter6 and vice versa on interfamily scenarios. With this patch we assign the inner mode output function to the dst entry when we create the xfrm bundle. So xfrm4_output/xfrm6_output from the inner mode is used and the right fragmentation and netfilter functions are called. We switch then to outer mode with the output_finish functions. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-19ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed.David Stevens
This patch modifies IPsec6 to fragment IPv6 packets that are locally generated as needed. This version of the patch only fragments in tunnel mode, so that fragment headers will not be obscured by ESP in transport mode. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-25netfilter: ipv6: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The semantic patch that was used: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_THRESH |nf_hook )( -PF_INET6, +NFPROTO_IPV6, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-02-18ipv6: drop unused "dev" arg of icmpv6_send()Alexey Dobriyan
Dunno, what was the idea, it wasn't used for a long time. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-06xfrm: fix fragmentation on inter family tunnelsSteffen Klassert
If an ipv4 packet (not locally generated with IP_DF flag not set) bigger than mtu size is supposed to go via a xfrm ipv6 tunnel, the packetsize check in xfrm4_tunnel_check_size() is omited and ipv6 drops the packet without sending a notice to the original sender of the ipv4 packet. Another issue is that ipv4 connection tracking does reassembling of incomming fragmented packets. If such a reassembled packet is supposed to go via a xfrm ipv6 tunnel it will be droped, even if the original sender did proper fragmentation. According to RFC 2473 (section 7) tunnel ipv6 packets resulting from the encapsulation of an original packet are considered as locally generated packets. If such a packet passed the checks in xfrm{4,6}_tunnel_check_size() fragmentation is allowed according to RFC 2473 (section 7.1/7.2). This patch sets skb->local_df in xfrm6_prepare_output() to achieve fragmentation in this case. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[IPSEC]: Fix inter address family IPsec tunnel handling.Kazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-12[IPV6]: Fix IPsec datagram fragmentationHerbert Xu
This is a long-standing bug in the IPsec IPv6 code that breaks when we emit a IPsec tunnel-mode datagram packet. The problem is that the code the emits the packet assumes the IPv6 stack will fragment it later, but the IPv6 stack assumes that whoever is emitting the packet is going to pre-fragment the packet. In the long term we need to fix both sides, e.g., to get the datagram code to pre-fragment as well as to get the IPv6 stack to fragment locally generated tunnel-mode packet. For now this patch does the second part which should make it work for the IPsec host case. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Remove nhoff from xfrm_inputHerbert Xu
The nhoff field isn't actually necessary in xfrm_input. For tunnel mode transforms we now throw away the output IP header so it makes no sense to fill in the nexthdr field. For transport mode we can now let the function transport_finish do the setting and it knows where the nexthdr field is. The only other thing that needs the nexthdr field to be set is the header extraction code. However, we can simply move the protocol extraction out of the generic header extraction. We want to minimise the amount of info we have to carry around between transforms as this simplifies the resumption process for async crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Merge most of the output pathHerbert Xu
As part of the work on asynchrnous cryptographic operations, we need to be able to resume from the spot where they occur. As such, it helps if we isolate them to one spot. This patch moves most of the remaining family-specific processing into the common output code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Add ip6_local_outHerbert Xu
Most callers of the LOCAL_OUT chain will set the IP packet length before doing so. They also share the same output function dst_output. This patch creates a new function called ip6_local_out which does all of that and converts the appropriate users over to it. Apart from removing duplicate code, it will also help in merging the IPsec output path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Separate inner/outer mode processing on inputHerbert Xu
With inter-family transforms the inner mode differs from the outer mode. Attempting to handle both sides from the same function means that it needs to handle both IPv4 and IPv6 which creates duplication and confusion. This patch separates the two parts on the input path so that each function deals with one family only. In particular, the functions xfrm4_extract_inut/xfrm6_extract_inut moves the pertinent fields from the IPv4/IPv6 IP headers into a neutral format stored in skb->cb. This is then used by the inner mode input functions to modify the inner IP header. In this way the input function no longer has to know about the outer address family. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Separate inner/outer mode processing on outputHerbert Xu
With inter-family transforms the inner mode differs from the outer mode. Attempting to handle both sides from the same function means that it needs to handle both IPv4 and IPv6 which creates duplication and confusion. This patch separates the two parts on the output path so that each function deals with one family only. In particular, the functions xfrm4_extract_output/xfrm6_extract_output moves the pertinent fields from the IPv4/IPv6 IP headers into a neutral format stored in skb->cb. This is then used by the outer mode output functions to write the outer IP header. In this way the output function no longer has to know about the inner address family. Since the extract functions are only called by tunnel modes (the only modes that can support inter-family transforms), I've also moved the xfrm*_tunnel_check_size calls into them. This allows the correct ICMP message to be sent as opposed to now where you might call icmp_send with an IPv6 packet and vice versa. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Rename mode to outer_mode and add inner_modeHerbert Xu
This patch adds a new field to xfrm states called inner_mode. The existing mode object is renamed to outer_mode. This is the first part of an attempt to fix inter-family transforms. As it is we always use the outer family when determining which mode to use. As a result we may end up shoving IPv4 packets into netfilter6 and vice versa. What we really want is to use the inner family for the first part of outbound processing and the outer family for the second part. For inbound processing we'd use the opposite pairing. I've also added a check to prevent silly combinations such as transport mode with inter-family transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Add missing BEET checksHerbert Xu
Currently BEET mode does not reinject the packet back into the stack like tunnel mode does. Since BEET should behave just like tunnel mode this is incorrect. This patch fixes this by introducing a flags field to xfrm_mode that tells the IPsec code whether it should terminate and reinject the packet back into the stack. It then sets the flag for BEET and tunnel mode. I've also added a number of missing BEET checks elsewhere where we check whether a given mode is a tunnel or not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move IP length/checksum setting out of transformsHerbert Xu
This patch moves the setting of the IP length and checksum fields out of the transforms and into the xfrmX_output functions. This would help future efforts in merging the transforms themselves. It also adds an optimisation to ipcomp due to the fact that the transport offset is guaranteed to be zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move common output code to xfrm_outputHerbert Xu
Most of the code in xfrm4_output_one and xfrm6_output_one are identical so this patch moves them into a common xfrm_output function which will live in net/xfrm. In fact this would seem to fix a bug as on IPv4 we never reset the network header after a transform which may upset netfilter later on. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6]: Decentralize EXPORT_SYMBOLs.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-04-25[NET]: Convert xtime.tv_sec to get_seconds()James Morris
Where appropriate, convert references to xtime.tv_sec to the get_seconds() helper function. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPSEC]: output mode to take an xfrm state as input paramJamal Hadi Salim
Expose IPSEC modes output path to take an xfrm state as input param. This makes it consistent with the input mode processing (which already takes the xfrm state as a param). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] IPV6: Update outbound state timestamp for each sending.Masahide NAKAMURA
With this patch transformation state is updated last used time for each sending. Xtime is used for it like other state lifetime expiration. Mobile IPv6 enabled nodes will want to know traffic status of each binding (e.g. judgement to request binding refresh by correspondent node, or to keep home/care-of nonce alive by mobile node). The last used timestamp is an important hint about it. Based on MIPL2 kernel patch. This patch was also written by: Henrik Petander <petander@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Add a hook to find offset to be inserted header in outbound.Masahide NAKAMURA
On current kernel, ip6_find_1stfragopt() is used by IPv6 IPsec to find offset to be inserted header in outbound for transport mode. (BTW, no usage may be needed for IPv4 case.) Mobile IPv6 requires another logic for routing header and destination options header respectively. This patch is common platform for the offset and adopts it to IPsec. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[XFRM]: Fix protocol field value for outgoing IPv6 GSO packetsPatrick McHardy
2006-07-08[NET] gso: Add skb_is_gsoHerbert Xu
This patch adds the wrapper function skb_is_gso which can be used instead of directly testing skb_shinfo(skb)->gso_size. This makes things a little nicer and allows us to change the primary key for indicating whether an skb is GSO (if we ever want to do that). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[IPSEC]: Handle GSO packetsHerbert Xu
This patch segments GSO packets received by the IPsec stack. This can happen when a NIC driver injects GSO packets into the stack which are then forwarded to another host. The primary application of this is going to be Xen where its backend driver may inject GSO packets into dom0. Of course this also can be used by other virtualisation schemes such as VMWare or UML since the tap device could be modified to inject GSO packets received through splice. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Fix xfrm lookup in ip_route_me_harder/ip6_route_me_harderPatrick McHardy
ip_route_me_harder doesn't use the port numbers of the xfrm lookup and uses ip_route_input for non-local addresses which doesn't do a xfrm lookup, ip6_route_me_harder doesn't do a xfrm lookup at all. Use xfrm_decode_session and do the lookup manually, make sure both only do the lookup if the packet hasn't been transformed already. Makeing sure the lookup only happens once needs a new field in the IP6CB, which exceeds the size of skb->cb. The size of skb->cb is increased to 48b. Apparently the IPv6 mobile extensions need some more room anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[XFRM]: Netfilter IPsec output hooksPatrick McHardy
Call netfilter hooks before IPsec transforms. Packets visit the FORWARD/LOCAL_OUT and POST_ROUTING hook before the first encapsulation and the LOCAL_OUT and POST_ROUTING hook before each following tunnel mode transform. Patch from Herbert Xu <herbert@gondor.apana.org.au>: Move the loop from dst_output into xfrm4_output/xfrm6_output since they're the only ones who need to it. xfrm{4,6}_output_one() processes the first SA all subsequent transport mode SAs and is called in a loop that calls the netfilter hooks between each two calls. In order to avoid the tail call issue, I've added the inline function nf_hook which is nf_hook_slow plus the empty list check. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-23[IPV6]: Fix xfrm tunnel oops with large packetsHerbert Xu
Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
