path: root/net/ipv6/reassembly.c
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: convert network timestamps to ktime_tEric Dumazet
We currently use a special structure (struct skb_timeval) and plain 'struct timeval' to store packet timestamps in sk_buffs and struct sock. This has some drawbacks : - Fixed resolution of micro second. - Waste of space on 64bit platforms where sizeof(struct timeval)=16 I suggest using ktime_t that is a nice abstraction of high resolution time services, currently capable of nanosecond resolution. As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits a 8 byte shrink of this structure on 64bit architectures. Some other structures also benefit from this size reduction (struct ipq in ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...) Once this ktime infrastructure adopted, we can more easily provide nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or SO_TIMESTAMPNS/SCM_TIMESTAMPNS) Note : this patch includes a bug correction in compat_sock_get_timestamp() where a "err = 0;" was missing (so this syscall returned -ENOENT instead of 0) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> CC: John find <linux.kernel@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Per-interface statistics support.YOSHIFUJI Hideaki
For IP MIB (RFC4293). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[NET/IPV4/IPV6]: Change some sysctl variables to __read_mostlyBrian Haley
Change net/core, ipv4 and ipv6 sysctl variables to __read_mostly. Couldn't actually measure any performance increase while testing (.3% I consider noise), but seems like the right thing to do. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[IPv6] reassembly: Always compute hash under the fragment lock.Zach Brown
This closes a race where an ipq6hashfn() caller could get a hash value and race with the cycling of the random seed. By the time they got to the read_lock they'd have a stale hash value and might not find previous fragments of their datagram. This matches the previous patch to IPv4. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: Cleanup of net/ipv6/reassambly.cIngo Oeser
Two minor cleanups: 1. Using kzalloc() in fraq_alloc_queue() saves the memset() in ipv6_frag_create(). 2. Invert sense of if-statements to streamline code. Inverts the comment, too. Signed-off-by: Ingo Oeser <ioe-lkml@rameria.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV6]: Move nextheader offset to the IP6CBPatrick McHardy
Move nextheader offset to the IP6CB to make it possible to pass a packet to ip6_input_finish multiple times and have it skip already parsed headers. As a nice side effect this gets rid of the manual hopopts skipping in ip6_input_finish. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-16[IPV4,IPV6]: replace handmade list with hlist in IPv{4,6} reassemblyYasuyuki Kozakai
Both of ipq and frag_queue have *next and **prev, and they can be replaced with hlist. Thanks Arnaldo Carvalho de Melo for the suggestion. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-08[IPV6]: Need to use pskb_trim_rcsum().Stephen Hemminger
Fix pskb_trim usage in ipv6. Only the udp one is really a bug, other places are just doing equivalent code. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Store skb->timestamp as offset to a base timestampPatrick McHardy
Reduces skb size by 8 bytes on 64-bit. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
