path: root/net/ipv6/raw.c
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4/6]: Check if packet was actually delivered to a raw socket to decide ↵Patrick McHardy
whether to send an ICMP unreachable Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV6]: Check interface bindings on IPv6 raw socket receptionAndrew McDonald
Take account of whether a socket is bound to a particular device when selecting an IPv6 raw socket to receive a packet. Also perform this check when receiving IPv6 packets with router alert options. Signed-off-by: Andrew McDonald <andrew@mcdonald.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-16[IPV6]: Fix raw socket hardware checksum failuresPatrick McHardy
When packets hit raw sockets the csum update isn't done yet, do it manually. Packets can also reach rawv6_rcv on the output path through ip6_call_ra_chain, in this case skb->ip_summed is CHECKSUM_NONE and this codepath isn't executed. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPV4/IPV6]: Replace spin_lock_irq with spin_lock_bhHerbert Xu
In light of my recent patch to net/ipv4/udp.c that replaced the spin_lock_irq calls on the receive queue lock with spin_lock_bh, here is a similar patch for all other occurences of spin_lock_irq on receive/error queue locks in IPv4 and IPv6. In these stacks, we know that they can only be entered from user or softirq context. Therefore it's safe to disable BH only. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[IPV6]: Fix raw socket checksums with IPsecHerbert Xu
I made a mistake in my last patch to the raw socket checksum code. I used the value of inet->cork.length as the length of the payload. While this works with normal packets, it breaks down when IPsec is present since the cork length includes the extension header length. So here is a patch to fix the length calculations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[IPV6]: Replace bogus instances of inet->recverrHerbert Xu
While looking at this problem I noticed that IPv6 was sometimes looking at inet->recverr which is bogus. Here is a patch to correct that and use np->recverr. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[IPV6]: IPV6_CHECKSUM socket option can corrupt kernel memoryHerbert Xu
So here is a patch that introduces skb_store_bits -- the opposite of skb_copy_bits, and uses them to read/write the csum field in rawv6. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
