path: root/net/ipv6/proc.c
2017-07-05proc: snmp6: Use correct type in memsetChristian Perle
[ Upstream commit 3500cd73dff48f28f4ba80c171c4c80034d40f76 ] Reading /proc/net/snmp6 yields bogus values on 32 bit kernels. Use "u64" instead of "unsigned long" in sizeof(). Fixes: 4a4857b1c81e ("proc: Reduce cache miss in snmp6_seq_show") Signed-off-by: Christian Perle <christian.perle@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30proc: Reduce cache miss in snmp6_seq_showJia He
This is to use the generic interfaces snmp_get_cpu_field{,64}_batch to aggregate the data by going through all the items of each cpu sequentially. Signed-off-by: Jia He <hejianet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-07udp: Increment UDP_MIB_IGNOREDMULTI for arriving unmatched multicastsRick Jones
As NIC multicast filtering isn't perfect, and some platforms are quite content to spew broadcasts, we should not trigger an event for skb:kfree_skb when we do not have a match for such an incoming datagram. We do though want to avoid sweeping the matter under the rug entirely, so increment a suitable statistic. This incorporates feedback from David L. Stevens, Karl Neiss and Eric Dumazet. V3 - use bool per David Miller Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-24ipv6: White-space cleansing : Line LayoutsIan Morris
This patch makes no changes to the logic of the code but simply addresses coding style issues as detected by checkpatch. Both objdump and diff -w show no differences. A number of items are addressed in this patch: * Multiple spaces converted to tabs * Spaces before tabs removed. * Spaces in pointer typing cleansed (char *)foo etc. * Remove space after sizeof * Ensure spacing around comparators such as if statements. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: don't account number of fragment queuesFlorian Westphal
The 'nqueues' counter is protected by the lru list lock, once thats removed this needs to be converted to atomic counter. Given this isn't used for anything except for reporting it to userspace via /proc, just remove it. We still report the memory currently used by fragment reassembly queues. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-14snmp: fix some left over of snmp statsWANG Cong
Fengguang reported the following sparse warning: >> net/ipv6/proc.c:198:41: sparse: incorrect type in argument 1 (different address spaces) net/ipv6/proc.c:198:41: expected void [noderef] <asn:3>*mib net/ipv6/proc.c:198:41: got void [noderef] <asn:3>**pcpumib Fixes: commit 698365fa1874aa7635d51667a3 (net: clean up snmp stats code) Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-07net: clean up snmp stats codeWANG Cong
commit 8f0ea0fe3a036a47767f9c80e (snmp: reduce percpu needs by 50%) reduced snmp array size to 1, so technically it doesn't have to be an array any more. What's more, after the following commit: commit 933393f58fef9963eac61db8093689544e29a600 Date: Thu Dec 22 11:58:51 2011 -0600 percpu: Remove irqsafe_cpu_xxx variants We simply say that regular this_cpu use must be safe regardless of preemption and interrupt state. That has no material change for x86 and s390 implementations of this_cpu operations. However, arches that do not provide their own implementation for this_cpu operations will now get code generated that disables interrupts instead of preemption. probably no arch wants to have SNMP_ARRAY_SZ == 2. At least after almost 3 years, no one complains. So, just convert the array to a single pointer and remove snmp_mib_init() and snmp_mib_free() as well. Cc: Christoph Lameter <cl@linux.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-08net: add SNMP counters tracking incoming ECN bitsEric Dumazet
With GRO/LRO processing, there is a problem because Ip[6]InReceives SNMP counters do not count the number of frames, but number of aggregated segments. Its probably too late to change this now. This patch adds four new counters, tracking number of frames, regardless of LRO/GRO, and on a per ECN status basis, for IPv4 and IPv6. Ip[6]NoECTPkts : Number of packets received with NOECT Ip[6]ECT1Pkts : Number of packets received with ECT(1) Ip[6]ECT0Pkts : Number of packets received with ECT(0) Ip[6]CEPkts : Number of packets received with Congestion Experienced lph37:~# nstat | egrep "Pkts|InReceive" IpInReceives 1634137 0.0 Ip6InReceives 3714107 0.0 Ip6InNoECTPkts 19205 0.0 Ip6InECT0Pkts 52651828 0.0 IpExtInNoECTPkts 33630 0.0 IpExtInECT0Pkts 15581379 0.0 IpExtInCEPkts 6 0.0 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31snmp6: remove IPSTATS_MIB_CSUMERRORSNicolas Dichtel
This stat is not relevant in IPv6, there is no checksum in IPv6 header. Just leave a comment to explain the hole. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01proc: Supply a function to remove a proc entry by PDEDavid Howells
Supply a function (proc_remove()) to remove a proc entry (and any subtree rooted there) by proc_dir_entry pointer rather than by name and (optionally) root dir entry pointer. This allows us to eliminate all remaining pde->name accesses outside of procfs. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Grant Likely <grant.likely@linaro.or> cc: linux-acpi@vger.kernel.org cc: openipmi-developer@lists.sourceforge.net cc: devicetree-discuss@lists.ozlabs.org cc: linux-pci@vger.kernel.org cc: netdev@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29net: Add MIB counters for checksum errorsEric Dumazet
Add MIB counters for checksum errors in IP layer, and TCP/UDP/ICMP layers, to help diagnose problems. $ nstat -a | grep Csum IcmpInCsumErrors 72 0.0 TcpInCsumErrors 382 0.0 UdpInCsumErrors 463221 0.0 Icmp6InCsumErrors 75 0.0 Udp6InCsumErrors 173442 0.0 IpExtInCsumErrors 10884 0.0 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14net: ipv6: proc: Fix error handlingIgor Maravic
Fix error handling in case making of dir dev_snmp6 failes Signed-off-by: Igor Maravic <igorm@etf.rs> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17ipv6: fix per device IP snmp countersEric Dumazet
In commit 4ce3c183fca (snmp: 64bit ipstats_mib for all arches), I forgot to change the /proc/net/dev_snmp6/xxx output for IP counters. percpu array is 64bit per counter but the folding still used the 'long' variant, and output garbage on 32bit arches. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-14ipv6: reduce percpu needs for icmpv6msg mibsEric Dumazet
Reading /proc/net/snmp6 on a machine with a lot of cpus is very expensive (can be ~88000 us). This is because ICMPV6MSG MIB uses 4096 bytes per cpu, and folding values for all possible cpus can read 16 Mbytes of memory (32MBytes on non x86 arches) ICMP messages are not considered as fast path on a typical server, and eventually few cpus handle them anyway. We can afford an atomic operation instead of using percpu data. This saves 4096 bytes per cpu and per network namespace. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-19ipv6: reduce per device ICMP mib sizesEric Dumazet
ipv6 has per device ICMP SNMP counters, taking too much space because they use percpu storage. needed size per device is : (512+4)*sizeof(long)*number_of_possible_cpus*2 On a 32bit kernel, 16 possible cpus, this wastes more than 64kbytes of memory per ipv6 enabled network device, taken in vmalloc pool. Since ICMP messages are rare, just use shared counters (atomic_long_t) Per network space ICMP counters are still using percpu memory, we might also convert them to shared counters in a future patch. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-30ipv6/udp: report SndbufErrors and RcvbufErrorsEric Dumazet
commit a18135eb9389 (Add UDP_MIB_{SND,RCV}BUFERRORS handling.) forgot to make the necessary changes in net/ipv6/proc.c to report additional counters in /proc/net/snmp6 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30snmp: 64bit ipstats_mib for all archesEric Dumazet
/proc/net/snmp and /proc/net/netstat expose SNMP counters. Width of these counters is either 32 or 64 bits, depending on the size of "unsigned long" in kernel. This means user program parsing these files must already be prepared to deal with 64bit values, regardless of user program being 32 or 64 bit. This patch introduces 64bit snmp values for IPSTAT mib, where some counters can wrap pretty fast if they are 32bit wide. # netstat -s|egrep "InOctets|OutOctets" InOctets: 244068329096 OutOctets: 244069348848 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03icmp: Account for ICMP out errorsEric Dumazet
When ip_append() fails because of socket limit or memory shortage, increment ICMP_MIB_OUTERRORS counter, so that "netstat -s" can report these errors. LANG=C netstat -s | grep "ICMP messages failed" 0 ICMP messages failed For IPV6, implement ICMP6_MIB_OUTERRORS counter as well. # grep Icmp6OutErrors /proc/net/dev_snmp6/* /proc/net/dev_snmp6/eth0:Icmp6OutErrors 0 /proc/net/dev_snmp6/lo:Icmp6OutErrors 0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23net: constify MIB name tablesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-10NET: ipv6, remove unnecessary checkJiri Slaby
Stanse found a potential null dereference in snmp6_unregister_dev. There is a check for idev being NULL, but it is dereferenced earlier. But idev cannot be NULL when passed to snmp6_unregister_dev, so remove the test. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "Pekka Savola (ipv6)" <pekkas@netcore.fi> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: mark read-only arrays as constJan Engelhardt
String literals are constant, and usually, we can also tag the array of pointers const too, moving it to the .rodata section. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20net: fix tiny output corruption of /proc/net/snmp6Alexey Dobriyan
Because "name" is static, it can be occasionally be filled with somewhat garbage if two processes read /proc/net/snmp6. Also, remove useless casts and "-1" -- snprintf() correctly terminates it's output. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: making ip and icmp statistics per/namespaceDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07netns: make uplitev6 mib per/namespaceDenis V. Lunev
2008-10-07netns: make udpv6 mib per/namespaceDenis V. Lunev
2008-10-07netns: allow per device ipv6 snmp statistics in non-initial namespaceDenis V. Lunev
2008-10-07netns: register global ipv6 mibs statistics in each namespaceDenis V. Lunev
Unused net variable will become used very soon. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07ipv6: separate seq_ops for global & per/device ipv6 statisticsDenis V. Lunev
idev has been stored on seq->private. NULL has been stored for global statistics. The situation is changed with net namespace. We need to store pointer to struct net and the only place is seq->private. So, we'll have for /proc/net/dev_snmp6/* and for /proc/net/snmp6 pointers of two different types stored in the same field. This effectively requires to separate seq_ops of these files. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07ipv6: consolidate ipv6 sock_stat code at the beginning of net/ipv6/proc.cDenis V. Lunev
Simple, comsolidate sockstat6 staff in one place, at the beginning of the file. Right now sockstat6_seq_open/sockstat6_seq_fops looks like an intrusion in the middle of snmp6 code. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07netns: register /proc/net/dev_snmp6/* in each nsDenis V. Lunev
Do the same for /proc/net/snmp6. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07netns: move /proc/net/dev_snmp6 to struct netDenis V. Lunev
2008-07-30ipv6: Fix useless proc net sockstat6 removalDaniel Lezcano
This call is no longer needed, sockstat6 is per namespace so it is removed at the namespace subsystem destruction. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: consolidate per-net single-release callersPavel Emelyanov
They are symmetrical to single_open ones :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: consolidate per-net single_open callersPavel Emelyanov
There are already 7 of them - time to kill some duplicate code. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02ipv6: assign PDE->data before gluing PDE into /proc treeDenis V. Lunev
Simply replace proc_create and further data assigned with proc_create_data. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[IPV6][NETNS]: Display per-net info in sockstat6 file.Pavel Emelyanov
Do with the sockstat6 file what we've already done for the sockstat. Same good side effect - ipv6 reassembling stats are now shown per-net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[SOCK][NETNS]: Register sockstat(6) files in each net.Pavel Emelyanov
Currently they live in init_net only, but now almost all the info they can provide is available per-net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[SOCK][NETNS]: Add a struct net argument to sock_prot_inuse_add and _get.Pavel Emelyanov
This counter is about to become per-proto-and-per-net, so we'll need two arguments to determine which cell in this "table" to work with. All the places, but proc already pass proper net to it - proc will be tuned a bit later. Some indentation with spaces in proc files is done to keep the file coding style consistent. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
