[ Upstream commit 9f2895461439fda2801a7906fb4c5fb3dbb37a0a ]
Before the commit d6990976af7c ("vti6: fix PMTU caching and reporting
on xmit") '!skb->ignore_df' check was always true because the function
skb_scrub_packet() was called before it, resetting ignore_df to zero.
In the commit, skb_scrub_packet() was moved below, and now this check
can be false for the packet, e.g. when sending it in the two fragments,
this prevents successful PMTU updates in such case. The next attempts
to send the packet lead to the same tx error. Moreover, vti6 initial
MTU value relies on PMTU adjustments.
This issue can be reproduced with the following LTP test script:
udp_ipsec_vti.sh -6 -p ah -m tunnel -s 2000
Fixes: ccd740cbc6e0 ("vti6: Add pmtu handling to vti6_xmit.")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit d6990976af7c5d8f55903bfb4289b6fb030bf754 ]
When setting the skb->dst before doing the MTU check, the route PMTU
caching and reporting is done on the new dst which is about to be
released.
Instead, PMTU handling should be done using the original dst.
This is aligned with IPv4 VTI.
Fixes: ccd740cbc6 ("vti6: Add pmtu handling to vti6_xmit.")
Signed-off-by: Eyal Birger <eyal.birger@gmail.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 537b361fbcbcc3cd6fe2bb47069fd292b9256d16 ]
Use valid_name() to make sure user does not provide illegal
device name.
Fixes: ed1efb2aefbb ("ipv6: Add support for IPsec virtual tunnel interfaces")
Cc: Steffen Klassert <steffen.klassert@secunet.com>
This reverts commit 1139d77d8a7f9aa6b6ae0a1c902f94775dad2f52 which is
commit 53c81e95df1793933f87748d36070a721f6cb287 upstream.
Ben writes that there are a number of follow-on patches needed to fix
this up, but they get complex to backport, and some custom fixes are
needed, so let's just revert this and wait for a "real" set of patches
to resolve this to be submitted if it is really needed.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Petr Vorel <pvorel@suse.cz>
Cc: Alexey Kodanev <alexey.kodanev@oracle.com>
Cc: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit 53c81e95df1793933f87748d36070a721f6cb287 ]
LTP/udp6_ipsec_vti tests fail when sending large UDP datagrams over
ip6_vti that require fragmentation and the underlying device has an
MTU smaller than 1500 plus some extra space for headers. This happens
because ip6_vti, by default, sets MTU to ETH_DATA_LEN and not updating
it depending on a destination address or link parameter. Further
attempts to send UDP packets may succeed because pmtu gets updated on
ICMPV6_PKT_TOOBIG in vti6_err().
In case the lower device has larger MTU size, e.g. 9000, ip6_vti works
but not using the possible maximum size, output packets have 1500 limit.
The above cases require manual MTU setup after ip6_vti creation. However
ip_vti already updates MTU based on lower device with ip_tunnel_bind_dev().
Here is the example when the lower device MTU is set to 9000:
# ip a sh ltp_ns_veth2
ltp_ns_veth2@if7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 ...
inet 10.0.0.2/24 scope global ltp_ns_veth2
inet6 fd00::2/64 scope global
# ip li add vti6 type vti6 local fd00::2 remote fd00::1
# ip li show vti6
vti6@NONE: <POINTOPOINT,NOARP> mtu 1500 ...
link/tunnel6 fd00::2 peer fd00::1
After the patch:
# ip li show vti6
vti6@NONE: <POINTOPOINT,NOARP> mtu 8832 ...
Reported-by: Petr Vorel <pvorel@suse.cz>
[ Upstream commit e3dc847a5f85b43ee2bfc8eae407a7e383483228 ]
In vti6_xmit(), the check for IPV6_MIN_MTU before we
send a ICMPV6_PKT_TOOBIG message is missing. So we might
report a PMTU below 1280. Fix this by adding the required
check.
Fixes: ccd740cbc6e ("vti6: Add pmtu handling to vti6_xmit.")
[ Upstream commit 93e246f783e6bd1bc64fdfbfe68b18161f69b28e ]
vti6 interface is registered before the rtnl_link_ops block
is attached. As a result the resulting RTM_NEWLINK is missing
IFLA_INFO_KIND. Re-order attachment of rtnl_link_ops block to fix.
Signed-off-by: Dave Forster <dforster@brocade.com>
[ Upstream commit 36f6ee22d2d66046e369757ec6bbe1c482957ba6 ]
When running LTP IPsec tests, KASan might report:
BUG: KASAN: use-after-free in vti_tunnel_xmit+0xeee/0xff0 [ip_vti]
Read of size 4 at addr ffff880dc6ad1980 by task swapper/0/0
Call Trace:
<IRQ>
dump_stack+0x63/0x89
print_address_description+0x7c/0x290
kasan_report+0x28d/0x370
? vti_tunnel_xmit+0xeee/0xff0 [ip_vti]
__asan_report_load4_noabort+0x19/0x20
? vti_init_net+0x190/0x190 [ip_vti]
? save_stack_trace+0x1b/0x20
? save_stack+0x46/0xd0
dev_hard_start_xmit+0x147/0x510
? icmp_echo.part.24+0x1f0/0x210
__dev_queue_xmit+0x1394/0x1c60
Freed by task 0:
kasan_slab_free+0x70/0xc0
kmem_cache_free+0x81/0x1e0
kfree_skbmem+0xb1/0xe0
kfree_skb+0x75/0x170
kfree_skb_list+0x3e/0x60
__dev_queue_xmit+0x1298/0x1c60
dev_queue_xmit+0x10/0x20
neigh_resolve_output+0x3a8/0x740
ip_finish_output2+0x5c0/0xe70
ip_finish_output+0x4ba/0x680
ip_output+0x1c1/0x3a0
xfrm_output_resume+0xc65/0x13d0
xfrm_output+0x1e4/0x380
xfrm4_output_finish+0x5c/0x70
Can be fixed if we get skb->len before dst_output().
Fixes: b9959fd3b0fa ("vti: switch to new ip tunnel code")
Fixes: 22e1b23dafa8 ("vti6: Support inter address family tunneling.")
[ Upstream commit 7dcdf941cdc96692ab99fd790c8cc68945514851 ]
Align vti6 with vti by returning GRE_KEY flag. This enables iproute2
to display tunnel keys on "ip -6 tunnel show"
Signed-off-by: David Forster <dforster@brocade.com>
This is the same fix than commit a5d0dc810abf ("vti: flush x-netns xfrm
cache when vti interface is removed")
This patch fixes a refcnt problem when a x-netns vti6 interface is removed:
unregister_netdevice: waiting for vti6_test to become free. Usage count = 1
Here is a script to reproduce the problem:
ip link set dev ntfp2 up
ip addr add dev ntfp2 2001::1/64
ip link add vti6_test type vti6 local 2001::1 remote 2001::2 key 1
ip netns add secure
ip link set vti6_test netns secure
ip netns exec secure ip link set vti6_test up
ip netns exec secure ip link s lo up
ip netns exec secure ip addr add dev vti6_test 2003::1/64
ip -6 xfrm policy add dir out tmpl src 2001::1 dst 2001::2 proto esp \
mode tunnel mark 1
ip -6 xfrm policy add dir in tmpl src 2001::2 dst 2001::1 proto esp \
mode tunnel mark 1
ip xfrm state add src 2001::1 dst 2001::2 proto esp spi 1 mode tunnel \
enc des3_ede 0x112233445566778811223344556677881122334455667788 mark 1
ip xfrm state add src 2001::2 dst 2001::1 proto esp spi 1 mode tunnel \
ip netns exec secure ping6 -c 4 2003::2
ip netns del secure
CC: Lance Richardson <lrichard@redhat.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Lance Richardson <lrichard@redhat.com>
Since commit 1625f4529957, vti6 is broken, all input packets are dropped
(LINUX_MIB_XFRMINNOSTATES is incremented).
XFRM_TUNNEL_SKB_CB(skb)->tunnel.ip6 is set by vti6_rcv() before calling
xfrm6_rcv()/xfrm6_rcv_spi(), thus we cannot set to NULL that value in
xfrm6_rcv_spi().
A new function xfrm6_rcv_tnl() that enables to pass a value to
xfrm6_rcv_spi() is added, so that xfrm6_rcv() is not touched (this function
is used in several handlers).
CC: Alexey Kodanev <alexey.kodanev@oracle.com>
Fixes: 1625f4529957 ("net/xfrm_input: fix possible NULL deref of tunnel.ip6->parms.i_key")
In case of inter address family tunneling (IPv6 over vti4 or IPv4 over
vti6), the inbound policy checks in vti_rcv_cb() and vti6_rcv_cb() are
using the wrong address family. As a result, all inbound inter address
family traffic is dropped.
Use the xfrm_ip2inner_mode() helper, as done in xfrm_input() (i.e., also
increment LINUX_MIB_XFRMINSTATEMODEERROR in case of error), to select the
inner_mode that contains the right address family for the inbound policy
checks.
Signed-off-by: Thomas Zeitlhofer <thomas.zeitlhofer+lkml@ze-it.at>
This is a preparatory patch for converting qdisc linked list into a
hashtable. As we'll need to include hashtable.h in netdevice.h, we first
have to make sure that this will not introduce symbol conflicts for any of
the netdevice.h users.
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
This also fix a potential race into the existing tunnel code, which
could lead to the wrong dst to be permanenty cached:
CPU1: CPU2:
<xmit on ip6_tunnel>
<cache lookup fails>
dst = ip6_route_output(...)
<tunnel params are changed via nl>
dst_cache_reset() // no effect,
// the cache is empty
dst_cache_set() // the wrong dst
// is permanenty stored
// into the cache
With the new dst implementation the above race is not possible
since the first cache lookup after dst_cache_reset will fail due
to the timestamp check
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Replace dst_output_okfn with dst_output
Add a sock paramter to dst_output making dst_output_sk superfluous.
Add a skb->sk parameter to all of the callers of dst_output
Have the callers of dst_output_sk call dst_output.
We currently rely on the PMTU discovery of xfrm.
However if a packet is localy sent, the PMTU mechanism
of xfrm tries to to local socket notification what
might not work for applications like ping that don't
check for this. So add pmtu handling to vti6_xmit to
report MTU changes immediately.
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
The vti6_rcv_cb and vti_rcv_cb calls were leaving the skb->mark modified
after completing the function. This resulted in the original skb->mark
value being lost. Since we only need skb->mark to be set for
xfrm_policy_check we can pull the assignment into the rcv_cb calls and then
just restore the original mark after xfrm_policy_check has been completed.
Instead of modifying skb->mark we can simply modify the flowi_mark that is
generated as a result of the xfrm_decode_session. By doing this we don't
need to actually touch the skb->mark and it can be preserved as it passes
out through the tunnel.
The dwmac-socfpga.c conflict was a case of a bug fix overlapping
changes in net-next to handle an error pointer differently.
When the kernel deleted a vti6 interface, this interface was not removed from
the tunnels list. Thus, when the ip6_vti module was removed, this old interface
was found and the kernel tried to delete it again. This was leading to a kernel
panic.
Fixes: 61220ab34948 ("vti6: Enable namespace changing")
Signed-off-by: Yao Xiwei <xiwei.yao@6wind.com>
Don't use dev->iflink anymore.
CC: Steffen Klassert <steffen.klassert@secunet.com>
Those are counterparts to nla_put_in_addr and nla_put_in6_addr.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
IP addresses are often stored in netlink attributes. Add generic functions
to do that.
For nla_put_in_addr, it would be nicer to pass struct in_addr but this is
not used universally throughout the kernel, in way too many places __be32 is
used to store IPv4 address.
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
Implement rtnl_link_ops->get_link_net() callback so that IFLA_LINK_NETNSID is
added to rtnetlink messages.
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2014-12-03
1) Fix a set but not used warning. From Fabian Frederick.
2) Currently we make sequence number values available to userspace
only if we use ESN. Make the sequence number values also available
for non ESN states. From Zhi Ding.
3) Remove socket policy hashing. We don't need it because socket
policies are always looked up via a linked list. From Herbert Xu.
4) After removing socket policy hashing, we can use __xfrm_policy_link
in xfrm_policy_insert. From Herbert Xu.
5) Add a lookup method for vti6 tunnels with wildcard endpoints.
I forgot this when I initially implemented vti6.
Please pull or let me know if there are problems.
Now the vti_link_ops do not point the .dellink, for fb tunnel device
(ip_vti0), the net_device will be removed as the default .dellink is
unregister_netdevice_queue,but the tunnel still in the tunnel list,
then if we add a new vti tunnel, in ip_tunnel_find():
hlist_for_each_entry_rcu(t, head, hash_node) {
if (local == t->parms.iph.saddr &&
remote == t->parms.iph.daddr &&
link == t->parms.link &&
==> type == t->dev->type &&
ip_tunnel_key_match(&t->parms, flags, key))
break;
the panic will happen, cause dev of ip_tunnel *t is null:
[ 3835.072977] IP: [<ffffffffa04103fd>] ip_tunnel_find+0x9d/0xc0 [ip_tunnel]
[ 3835.073008] PGD b2c21067 PUD b7277067 PMD 0
[ 3835.073008] Oops: 0000 [#1] SMP
[ 3835.073008] Stack:
[ 3835.073008] ffff8800b72d77f0 ffffffffa0411924 ffff8800bb956000 ffff8800b72d78e0
[ 3835.073008] ffff8800b72d78a0 0000000000000000 ffffffffa040d100 ffff8800b72d7858
[ 3835.073008] ffffffffa040b2e3 0000000000000000 0000000000000000 0000000000000000
[ 3835.073008] Call Trace:
[ 3835.073008] [<ffffffffa0411924>] ip_tunnel_newlink+0x64/0x160 [ip_tunnel]
[ 3835.073008] [<ffffffffa040b2e3>] vti_newlink+0x43/0x70 [ip_vti]
[ 3835.073008] [<ffffffff8150d4da>] rtnl_newlink+0x4fa/0x5f0
[ 3835.073008] [<ffffffff812f68bb>] ? nla_strlcpy+0x5b/0x70
[ 3835.073008] [<ffffffff81508fb0>] ? rtnl_link_ops_get+0x40/0x60
[ 3835.073008] [<ffffffff8150d11f>] ? rtnl_newlink+0x13f/0x5f0
[ 3835.073008] [<ffffffff81509cf4>] rtnetlink_rcv_msg+0xa4/0x270
[ 3835.073008] [<ffffffff8126adf5>] ? sock_has_perm+0x75/0x90
[ 3835.073008] [<ffffffff81509c50>] ? rtnetlink_rcv+0x30/0x30
[ 3835.073008] [<ffffffff81529e39>] netlink_rcv_skb+0xa9/0xc0
[ 3835.073008] [<ffffffff81509c48>] rtnetlink_rcv+0x28/0x30
modprobe ip_vti
ip link del ip_vti0 type vti
ip link add ip_vti0 type vti
rmmod ip_vti
do that one or more times, kernel will panic.
fix it by assigning ip_tunnel_dellink to vti_link_ops' dellink, in
which we skip the unregister of fb tunnel device. do the same on ip6_vti.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Signed-off-by: Cong Wang <cwang@twopensource.com>
This change has no functional impact and simply addresses some coding
style issues detected by checkpatch. Specifically this change
adjusts "if" statements which also include the assignment of a
variable.
No changes to the resultant object files result as determined by objdiff.
Currently we can't lookup tunnels with wildcard endpoints.
This patch adds a method to lookup these tunnels in the
receive path.
Currently we need the IP6_TNL_F_CAP_XMIT capabiltiy to transmit
packets through an ipv6 tunnel. This capability is set when the
tunnel gets configured, based on the tunnel endpoint addresses.
On tunnels with wildcard tunnel endpoints, we need to do the
capabiltiy checking on a per packet basis like it is done in
the receive path.
This patch extends ip6_tnl_xmit_ctl() to take local and remote
addresses as parameters to allow for per packet capabiltiy
checking.
vti6_dev_init() sets the dev->iflink via a call to
vti6_link_config(). After that, register_netdevice()
sets dev->iflink = -1. So we loose the iflink configuration
for vti6 tunnels. Fix this by using vti6_dev_init() as the
ndo_init function. Then vti6_dev_init() is called after
dev->iflink is set to -1 from register_netdevice().
Testing xmit_more support with netperf and connected UDP sockets,
I found strange dst refcount false sharing.
Current handling of IFF_XMIT_DST_RELEASE is not optimal.
Dropping dst in validate_xmit_skb() is certainly too late in case
packet was queued by cpu X but dequeued by cpu Y
The logical point to take care of drop/force is in __dev_queue_xmit()
before even taking qdisc lock.
As Julian Anastasov pointed out, need for skb_dst() might come from some
packet schedulers or classifiers.
This patch adds new helper to cleanly express needs of various drivers
or qdiscs/classifiers.
Drivers that need skb_dst() in their ndo_start_xmit() should call
following helper in their setup instead of the prior :
dev->priv_flags &= ~IFF_XMIT_DST_RELEASE;
netif_keep_dst(dev);
Instead of using a single bit, we use two bits, one being
eventually rebuilt in bonding/team drivers.
The other one, is permanent and blocks IFF_XMIT_DST_RELEASE being
rebuilt in bonding/team. Eventually, we could add something
smarter later.
Cc: Julian Anastasov <ja@ssi.bg>
vti6_locate() should not return an existing tunnel if
create is true. Otherwise it is possible to add the same
tunnel multiple times without getting an error.
So return NULL if the tunnel that should be created already
exists.
pull request (net-next): ipsec-next 2014-07-30
This is the last pull request for ipsec-next before I'll be
off for two weeks starting on friday. David, can you please
take urgent ipsec patches directly into net/net-next during
this time?
1) Error handling simplifications for vti and vti6.
From Mathias Krause.
2) Remove a duplicate semicolon after a return statement.
From Christoph Paasch.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
The error handling in the module init and exit functions can be
shortened to safe us some code.
1/ Remove the code duplications in the init function, jump straight to
the existing cleanup code by adding some labels. Also give the error
message some more value by telling the reason why loading the module has
failed.
2/ Remove the error handling in the exit function as the only legitimate
reason xfrm6_protocol_deregister() might fail is inet6_del_protocol()
returning -1. That, in turn, means some other protocol handler had been
registered for this very protocol in the meantime. But that essentially
means we haven't been handling that protocol any more, anyway. What it
definitely means not is that we "can't deregister protocol". Therefore
just get rid of that bogus warning. It's plain wrong.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
drivers/net/bonding/bond_alb.c
drivers/net/ethernet/altera/altera_msgdma.c
drivers/net/ethernet/altera/altera_sgdma.c
net/ipv6/xfrm6_output.c
Several cases of overlapping changes.
The xfrm6_output.c has a bug fix which overlaps the renaming
of skb->local_df to skb->ignore_df.
In the Altera TSE driver cases, the register access cleanups
in net-next overlapped with bug fixes done in net.
Similarly a bug fix to send ALB packets in the bonding driver using
the right source address overlaps with cleanups in net-next.
Netdev_priv is an accessor function, and has no purpose if its result is
not used.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@@ local idexpression x; @@
-x = netdev_priv(...);
... when != x
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
We need to use the mark we get from the tunnels o_key to
lookup the right vti state in the error handlers. This patch
ensures that.
Fixes: df3893c1 ("vti: Update the ipv4 side to use it's own receive hook.")
Fixes: fa9ad96d ("vti6: Update the ipv6 side to use its own receive hook.")
If we fail to register one of the xfrm protocol handlers we will
unregister the pernet ops twice on the error exit path. This will
probably lead to a kernel panic as the double deregistration
leads to a double kfree().
Fix this by removing one of the calls to do it only once.
Fixes: fa9ad96d49 ("vti6: Update the ipv6 side to use its own...")
vti6 is now fully namespace aware, so allow namespace changing
for vti devices.
The tunnel endpoints of the xfrm_state we got from the xfrm_lookup
must match the tunnel endpoints of the vti interface. This patch
ensures this matching.
With this patch we can tunnel ipv4 traffic via a vti6
interface. A vti6 interface can now have an ipv4 address
and ipv4 traffic can be routed via a vti6 interface.
The resulting traffic is xfrm transformed and tunneled
through ipv6 if matching IPsec policies and states are
present.
With this patch, vti6 uses the IPsec protocol multiplexer to
register its own receive side hooks for ESP, AH and IPCOMP.
Vti6 now does the following on receive side:
1. Do an input policy check for the IPsec packet we received.
This is required because this packet could be already
prosecces by IPsec, so an inbuond policy check is needed.
2. Mark the packet with the i_key. The policy and the state
must match this key now. Policy and state belong to the vti
namespace and policy enforcement is done at the further layers.
3. Call the generic xfrm layer to do decryption and decapsulation.
4. Wait for a callback from the xfrm layer to properly clean the
skb to not leak informations on namespace transitions and
update the device statistics.
On transmit side:
1. Mark the packet with the o_key. The policy and the state
2. Do a xfrm_lookup on the original packet with the mark applied.
3. Check if we got an IPsec route.
4. Clean the skb to not leak informations on namespace
transitions.
5. Attach the dst_enty we got from the xfrm_lookup to the skb.
6. Call dst_output to do the IPsec processing.
7. Do the device statistics.
Unlike ip6_tunnel, vti6 does not use the the tunnel
endpoint addresses to do route and xfrm lookups.
So no need to cache the flow informations. It also
does not make sense to calculate the mtu based on
such flow informations, so remove this too.
