path: root/net/ipv6/icmp.c
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate callers of the reset of checksum.h stuff.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: annotate csum_ipv6_magic() callers in net/*Al Viro
2006-12-02[IPv6]: Only modify checksum for UDPBrian Haley
Only change upper-layer checksum from 0 to 0xFFFF for UDP (as RFC 768 states), not for others as RFC 4443 doesn't require it. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Per-interface statistics support.YOSHIFUJI Hideaki
For IP MIB (RFC4293). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-12-02[IPV6]: 'info' argument of ipv6 ->err_handler() is net-endianAl Viro
2006-09-22[IPV6] MIP6: Revert address to send ICMPv6 error.Masahide NAKAMURA
IPv6 source address is replaced in receiving packet with home address option carried by destination options header. To send ICMPv6 error back, original address which is received one on wire should be used. This function checks such header is included and reverts them. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET/IPV4/IPV6]: Change some sysctl variables to __read_mostlyBrian Haley
Change net/core, ipv4 and ipv6 sysctl variables to __read_mostly. Couldn't actually measure any performance increase while testing (.3% I consider noise), but seems like the right thing to do. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Add flow labelingVenkat Yekkirala
This labels the flows that could utilize IPSec xfrms at the points the flows are defined so that IPSec policy and SAs at the right label can be used. The following protos are currently not handled, but they should continue to be able to use single-labeled IPSec like they currently do. ipmr ip_gre ipip igmp sit sctp ip6_tunnel (IPv6 over IPv6 tunnel device) decnet Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-17[IPV6]: Fix tclass setting for raw sockets.YOSHIFUJI Hideaki
np->cork.tclass is used only in cork'ed context. Otherwise, np->tclass should be used. Bug#7096 reported by Remi Denis-Courmont <rdenis@simphalempin.com>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-17[IPV6] lockdep: annotate __icmpv6_socketIngo Molnar
Split off __icmpv6_socket's sk->sk_dst_lock class, because it gets used from softirqs, which is safe for __icmpv6_sockets (because they never get directly used via userspace syscalls), but unsafe for normal sockets. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[PATCH] for_each_possible_cpu: network codesKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu under /net Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[NETFILTER]: nf_conntrack: attach conntrack to locally generated ICMPv6 errorYasuyuki Kozakai
Locally generated ICMPv6 errors should be associated with the conntrack of the original packet. Since the conntrack entry may not be in the hash tables (for the first packet), it must be manually attached. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-13[NET]: Use NIP6_FMT in kernel.hJoe Perches
There are errors and inconsistency in the display of NIP6 strings. ie: net/ipv6/ip6_flowlabel.c There are errors and inconsistency in the display of NIPQUAD strings too. ie: net/netfilter/nf_conntrack_ftp.c This patch: adds NIP6_FMT to kernel.h changes all code to use NIP6_FMT fixes net/ipv6/ip6_flowlabel.c adds NIPQUAD_FMT to kernel.h fixes net/netfilter/nf_conntrack_ftp.c changes a few uses of "%u.%u.%u.%u" to NIPQUAD_FMT for symmetry to NIP6_FMT Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV6]: Move nextheader offset to the IP6CBPatrick McHardy
Move nextheader offset to the IP6CB to make it possible to pass a packet to ip6_input_finish multiple times and have it skip already parsed headers. As a nice side effect this gets rid of the manual hopopts skipping in ip6_input_finish. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-21[IPV6]: Try not to send icmp to anycast address.YOSHIFUJI Hideaki
2005-11-29[NET]: Add const markers to various variables.Arjan van de Ven
the patch below marks various variables const in net/; the goal is to move them to the .rodata section so that they can't false-share cachelines with things that get written to, as well as potentially helping gcc a bit with optimisations. (these were found using a gcc patch to warn about such variables) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NET]: Detect hardware rx checksum faults correctlyHerbert Xu
Here is the patch that introduces the generic skb_checksum_complete which also checks for hardware RX checksum faults. If that happens, it'll call netdev_rx_csum_fault which currently prints out a stack trace with the device name. In future it can turn off RX checksum. I've converted every spot under net/ that does RX checksum checks to use skb_checksum_complete or __skb_checksum_complete with the exceptions of: * Those places where checksums are done bit by bit. These will call netdev_rx_csum_fault directly. * The following have not been completely checked/converted: ipmr ip_vs netfilter dccp This patch is based on patches and suggestions from Stephen Hemminger and David S. Miller. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-25[NET]: Wider use of for_each_*cpu()John Hawkes
In 'net' change the explicit use of for-loops and NR_CPUS into the general for_each_cpu() or for_each_online_cpu() constructs, as appropriate. This widens the scope of potential future optimizations of the general constructs, as well as takes advantage of the existing optimizations of first_cpu() and next_cpu(), which is advantageous when the true CPU count is much smaller than NR_CPUS. Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-08[XFRM]: Always release dst_entry on error in xfrm_lookupPatrick McHardy
2005-09-08[IPV6]: Support IPV6_{RECV,}TCLASS socket options / ancillary data.YOSHIFUJI Hideaki
Based on patch from David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-09-01[IPV6]: Repair Incoming Interface Handling for Raw Socket.YOSHIFUJI Hideaki
Due to changes to enforce checking interface bindings, sockets did not see loopback packets bound for our local address on our interface. e.g.) When we ping6 fe80::1%eth0, skb->dev points loopback_dev while IP6CB(skb)->iif indicates eth0. This patch fixes the issue by using appropriate incoming interface, in the sense of scoping architecture. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: use __read_mostly on kmem_cache_t , DEFINE_SNMP_STAT pointersEric Dumazet
This patch puts mostly read only data in the right section (read_mostly), to help sharing of these data between CPUS without memory ping pongs. On one of my production machine, tcp_statistics was sitting in a heavily modified cache line, so *every* SNMP update had to force a reload. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Make NETDEBUG pure printk wrappersPatrick McHardy
2005-08-29[IPV6]: Check interface bindings on IPv6 raw socket receptionAndrew McDonald
Take account of whether a socket is bound to a particular device when selecting an IPv6 raw socket to receive a packet. Also perform this check when receiving IPv6 packets with router alert options. Signed-off-by: Andrew McDonald <andrew@mcdonald.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-13[IPV6]: Ensure to use icmpv6_socket in non-preemptive context.YOSHIFUJI Hideaki
We saw following trace several times: |BUG: using smp_processor_id() in preemptible [00000001] code: httpd/30137 |caller is icmpv6_send+0x23/0x540 | [<c01ad63b>] smp_processor_id+0x9b/0xb8 | [<c02993e7>] icmpv6_send+0x23/0x540 This is because of icmpv6_socket, which is the only one user of smp_processor_id() in icmpv6_send(), AFAIK. Since it should be used in non-preemptive context, let's defer the dereference after disabling preemption (by icmpv6_xmit_lock()). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[SELINUX]: Fix ipv6_skip_exthdr() invocation causing OOPS.Herbert Xu
The SELinux hooks invoke ipv6_skip_exthdr() with an incorrect length final argument. However, the length argument turns out to be superfluous. I was just reading ipv6_skip_exthdr and it occured to me that we can get rid of len altogether. The only place where len is used is to check whether the skb has two bytes for ipv6_opt_hdr. This check is done by skb_header_pointer/skb_copy_bits anyway. Now it might appear that we've made the code slower by deferring the check to skb_copy_bits. However, this check should not trigger in the common case so this is OK. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
