We have to hold rtnl lock for fib_rules_unregister()
otherwise the following race could happen:
fib_rules_unregister(): fib_nl_delrule():
... ops = lookup_rules_ops();
list_del_rcu(&ops->list);
list_for_each_entry(ops->rules) {
fib_rules_cleanup_ops(ops); ...
list_del_rcu(); list_del_rcu();
Note, net->rules_mod_lock is actually not needed at all,
either upper layer netns code or rtnl lock guarantees
we are safe.
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
Cc: Thomas Graf <tgraf@suug.ch>
This is the IPv4 part for commit 905a6f96a1b1
(ipv6: take rtnl_lock and mark mrt6 table as freed on namespace cleanup).
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
On processing cumulative ACKs, the FRTO code was not checking the
SACKed bit, meaning that there could be a spurious FRTO undo on a
cumulative ACK of a previously SACKed skb.
The FRTO code should only consider a cumulative ACK to indicate that
an original/unretransmitted skb is newly ACKed if the skb was not yet
SACKed.
The effect of the spurious FRTO undo would typically be to make the
connection think that all previously-sent packets were in flight when
they really weren't, leading to a stall and an RTO.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO")
On s390x, gcc 4.8 compiles this part of tcp_v6_early_demux()
struct dst_entry *dst = sk->sk_rx_dst;
if (dst)
dst = dst_check(dst, inet6_sk(sk)->rx_dst_cookie);
to code reading sk->sk_rx_dst twice, once for the test and once for
the argument of ip6_dst_check() (dst_check() is inline). This allows
ip6_dst_check() to be called with null first argument, causing a crash.
Protect sk->sk_rx_dst access by READ_ONCE() both in IPv4 and IPv6
TCP early demux code.
Fixes: 41063e9dd119 ("ipv4: Early TCP socket demux.")
Fixes: c7109986db3c ("ipv6: Early TCP socket demux")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree,
they are:
1) Fix missing initialization of tuple structure in nfnetlink_cthelper
to avoid mismatches when looking up to attach userspace helpers to
flows, from Ian Wilson.
2) Fix potential crash in nft_hash when we hit -EAGAIN in
nft_hash_walk(), from Herbert Xu.
3) We don't need to indicate the hook information to update the
basechain default policy in nf_tables.
4) Restore tracing over nfnetlink_log due to recent rework to
accomodate logging infrastructure into nf_tables.
5) Fix wrong IP6T_INV_PROTO check in xt_TPROXY.
6) Set IP6T_F_PROTO flag in nft_compat so we can use SYNPROXY6 and
REJECT6 from xt over nftables.
tcp_send_fin() does not account for the memory it allocates properly, so
sk_forward_alloc can be negative in cases where we've sent a FIN:
ss example output (ss -amn | grep -B1 f4294):
tcp FIN-WAIT-1 0 1 192.168.0.1:45520 192.0.2.1:8080
skmem:(r0,rb87380,t0,tb87380,f4294966016,w1280,o0,bl0)
Since fab4085 ("netfilter: log: nf_log_packet() as real unified
interface"), the loginfo structure that is passed to nf_log_packet() is
used to explicitly indicate the logger type you want to use.
This is a problem for people tracing rules through nfnetlink_log since
packets are always routed to the NF_LOG_TYPE logger after the
aforementioned patch.
We can fix this by removing the trace loginfo structures, but that still
changes the log level from 4 to 5 for tracing messages and there may be
someone relying on this outthere. So let's just introduce a new
nf_log_trace() function that restores the former behaviour.
Reported-by: Markus Kötter <koetter@rrzn.uni-hannover.de>
I got the following trace with current net-next kernel :
[14723.885290] WARNING: CPU: 26 PID: 22658 at kernel/sched/core.c:7285 __might_sleep+0x89/0xa0()
[14723.885325] do not call blocking ops when !TASK_RUNNING; state=1 set at [<ffffffff810e8734>] prepare_to_wait_exclusive+0x34/0xa0
[14723.885355] CPU: 26 PID: 22658 Comm: netserver Not tainted 4.0.0-dbg-DEV #1379
[14723.885359] ffffffff81a223a8 ffff881fae9e7ca8 ffffffff81650b5d 0000000000000001
[14723.885364] ffff881fae9e7cf8 ffff881fae9e7ce8 ffffffff810a72e7 0000000000000000
[14723.885367] ffffffff81a57620 000000000000093a 0000000000000000 ffff881fae9e7e64
[14723.885371] Call Trace:
[14723.885377] [<ffffffff81650b5d>] dump_stack+0x4c/0x65
[14723.885382] [<ffffffff810a72e7>] warn_slowpath_common+0x97/0xe0
[14723.885386] [<ffffffff810a73e6>] warn_slowpath_fmt+0x46/0x50
[14723.885390] [<ffffffff810f4c5d>] ? trace_hardirqs_on_caller+0x10d/0x1d0
[14723.885393] [<ffffffff810e8734>] ? prepare_to_wait_exclusive+0x34/0xa0
[14723.885396] [<ffffffff810e8734>] ? prepare_to_wait_exclusive+0x34/0xa0
[14723.885399] [<ffffffff810ccdc9>] __might_sleep+0x89/0xa0
[14723.885403] [<ffffffff81581846>] lock_sock_nested+0x36/0xb0
[14723.885406] [<ffffffff815829a3>] ? release_sock+0x173/0x1c0
[14723.885411] [<ffffffff815ea1f7>] inet_csk_accept+0x157/0x2a0
[14723.885415] [<ffffffff810e8900>] ? abort_exclusive_wait+0xc0/0xc0
[14723.885419] [<ffffffff8161b96d>] inet_accept+0x2d/0x150
[14723.885424] [<ffffffff8157db6f>] SYSC_accept4+0xff/0x210
[14723.885428] [<ffffffff8165a451>] ? retint_swapgs+0xe/0x44
[14723.885431] [<ffffffff810f4c5d>] ? trace_hardirqs_on_caller+0x10d/0x1d0
[14723.885437] [<ffffffff81369c0e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[14723.885441] [<ffffffff8157ef40>] SyS_accept+0x10/0x20
[14723.885444] [<ffffffff81659872>] system_call_fastpath+0x12/0x17
[14723.885447] ---[ end trace ff74cd83355b1873 ]---
In commit 26cabd31259ba43f68026ce3f62b78094124333f
Peter added a sched_annotate_sleep() in sk_wait_event()
Is the following patch needed as well ?
Alternative would be to use sk_wait_event() from inet_csk_wait_for_connect()
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec
Steffen Klassert says:
pull request (net): ipsec 2015-03-16
1) Fix the network header offset in _decode_session6
when multiple IPv6 extension headers are present.
From Hajime Tazaki.
2) Fix an interfamily tunnel crash. We set outer mode
protocol too early and may dispatch to the wrong
address family. Move the setting of the outer mode
protocol behind the last accessing of the inner mode
to fix the crash.
3) Most callers of xfrm_lookup() expect that dst_orig
is released on error. But xfrm_lookup_route() may
need dst_orig to handle certain error cases. So
introduce a flag that tells what should be done in
case of error. From Huaibin Wang.
Please pull or let me know if there are problems.
inet_diag_dump_one_icsk() allocates too small skb.
Add inet_sk_attr_size() helper right before inet_sk_diag_fill()
so that it can be updated if/when new attributes are added.
iproute2/ss currently does not use this dump_one() interface,
this might explain nobody noticed this problem yet.
John reported that my previous commit added a regression
on his router.
This is because sender_cpu & napi_id share a common location,
so get_xps_queue() can see garbage and perform an out of bound access.
We need to make sure sender_cpu is cleared before doing the transmit,
otherwise any NIC busy poll enabled (skb_mark_napi_id()) can trigger
this bug.
Reported-by: John <jw@nuclearfallout.net>
Bisected-by: John <jw@nuclearfallout.net>
Fixes: 2bd82484bb4c ("xps: fix xps for stacked devices")
Commit 814d488c6126 ("tcp: fix the timid additive increase on stretch
ACKs") fixed a bug where tcp_cong_avoid_ai() would either credit a
connection with an increase of snd_cwnd_cnt, or increase snd_cwnd, but
not both, resulting in cwnd increasing by 1 packet on at most every
alternate invocation of tcp_cong_avoid_ai().
Although the commit correctly implemented the CUBIC algorithm, which
can increase cwnd by as much as 1 packet per 1 packet ACKed (2x per
RTT), in practice that could be too aggressive: in tests on network
paths with small buffers, YouTube server retransmission rates nearly
doubled.
This commit restores CUBIC to a maximum cwnd growth rate of 1 packet
per 2 packets ACKed (1.5x per RTT). In YouTube tests this restored
retransmit rates to low levels.
Testing: This patch has been tested in datacenter netperf transfers
and live youtube.com and google.com servers.
Fixes: 9cd981dcf174 ("tcp: fix stretch ACK bugs in CUBIC")
The recent change to tcp_cong_avoid_ai() to handle stretch ACKs
introduced a bug where snd_cwnd_cnt could accumulate a very large
value while w was large, and then if w was reduced snd_cwnd could be
incremented by a large delta, leading to a large burst and high packet
loss. This was tickled when CUBIC's bictcp_update() sets "ca->cnt =
100 * cwnd".
This bug crept in while preparing the upstream version of
814d488c6126.
Fixes: 814d488c6126 ("tcp: fix the timid additive increase on stretch ACKs")
When reading from the error queue, msg_name and msg_control are only
populated for some errors. A new exception for empty timestamp skbs
added a false positive on icmp errors without payload.
`traceroute -M udpconn` only displayed gateways that return payload
with the icmp error: the embedded network headers are pulled before
sock_queue_err_skb, leaving an skb with skb->len == 0 otherwise.
Fix this regression by refining when msg_name and msg_control
branches are taken. The solutions for the two fields are independent.
msg_name only makes sense for errors that configure serr->port and
serr->addr_offset. Test the first instead of skb->len. This also fixes
another issue. saddr could hold the wrong data, as serr->addr_offset
is not initialized in some code paths, pointing to the start of the
network header. It is only valid when serr->port is set (non-zero).
msg_control support differs between IPv4 and IPv6. IPv4 only honors
requests for ICMP and timestamps with SOF_TIMESTAMPING_OPT_CMSG. The
skb->len test can simply be removed, because skb->dev is also tested
and never true for empty skbs. IPv6 honors requests for all errors
aside from local errors and timestamps on empty skbs.
In both cases, make the policy more explicit by moving this logic to
a new function that decides whether to process msg_control and that
optionally prepares the necessary fields in skb->cb[]. After this
change, the IPv4 and IPv6 paths are more similar.
The last case is rxrpc. Here, simply refine to only match timestamps.
Fixes: 49ca0d8bfaf3 ("net-timestamp: no-payload option")
Reported-by: Jan Niehusmann <jan@gondor.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Changes
v1->v2
- fix local origin test inversion in ip6_datagram_support_cmsg
- make v4 and v6 code paths more similar by introducing analogous
ipv4_datagram_support_cmsg
- fix compile bug in rxrpc
With some mss values, it is possible tcp_xmit_size_goal() puts
one segment more in TSO packet than tcp_tso_autosize().
We send then one TSO packet followed by one single MSS.
It is not a serious bug, but we can do slightly better, especially
for drivers using netif_set_gso_max_size() to lower gso_max_size.
Using same formula avoids these corner cases and makes
tcp_xmit_size_goal() a bit faster.
Fixes: 605ad7f184b6 ("tcp: refine TSO autosizing")
Acked-by: Neal Cardwell <ncardwell@google.com>
ip_check_defrag() may be used by af_packet to defragment outgoing packets.
skb_network_offset() of af_packet's outgoing packets is not zero.
Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com>
1. For an IPv4 ping socket, ping_check_bind_addr does not check
the family of the socket address that's passed in. Instead,
make it behave like inet_bind, which enforces either that the
address family is AF_INET, or that the family is AF_UNSPEC and
the address is 0.0.0.0.
2. For an IPv6 ping socket, ping_check_bind_addr returns EINVAL
if the socket family is not AF_INET6. Return EAFNOSUPPORT
instead, for consistency with inet6_bind.
3. Make ping_v4_sendmsg and ping_v6_sendmsg return EAFNOSUPPORT
instead of EINVAL if an incorrect socket address structure is
passed in.
4. Make IPv6 ping sockets be IPv6-only. The code does not support
IPv4, and it cannot easily be made to support IPv4 because
the protocol numbers for ICMP and ICMPv6 are different. This
makes connect(::ffff:192.0.2.1) fail with EAFNOSUPPORT instead
of making the socket unusable.
Among other things, this fixes an oops that can be triggered by:
int s = socket(AF_INET, SOCK_DGRAM, IPPROTO_ICMP);
struct sockaddr_in6 sin6 = {
.sin6_family = AF_INET6,
.sin6_addr = in6addr_any,
bind(s, (struct sockaddr *) &sin6, sizeof(sin6));
Change-Id: If06ca86d9f1e4593c0d6df174caca3487c57a241
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
If an over-MTU UDP datagram is sent through a SOCK_RAW socket to a
UFO-capable device, ip_ufo_append_data() sets skb->ip_summed to
CHECKSUM_PARTIAL unconditionally as all GSO code assumes transport layer
checksum is to be computed on segmentation. However, in this case,
skb->csum_start and skb->csum_offset are never set as raw socket
transmit path bypasses udp_send_skb() where they are usually set. As a
result, driver may access invalid memory when trying to calculate the
checksum and store the result (as observed in virtio_net driver).
Moreover, the very idea of modifying the userspace provided UDP header
is IMHO against raw socket semantics (I wasn't able to find a document
clearly stating this or the opposite, though). And while allowing
CHECKSUM_NONE in the UFO case would be more efficient, it would be a bit
too intrusive change just to handle a corner case like this. Therefore
disallowing UFO for packets from SOCK_DGRAM seems to be the best option.
tcp_should_expand_sndbuf() does not expand the send buffer if we have
filled the congestion window.
However, it should use tcp_packets_in_flight() instead of
tp->packets_out to make this check.
Testing has established that the difference matters a lot if there are
many SACKed packets, causing a needless performance shortfall.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
skb_copy_bits() returns zero on success and negative value on error,
so it is needed to invert the condition in ip_check_defrag().
Fixes: 1bf3751ec90c ("ipv4: ip_check_defrag must not modify skb before unsharing")
Pull networking updates from David Miller:
1) Missing netlink attribute validation in nft_lookup, from Patrick
McHardy.
2) Restrict ipv6 partial checksum handling to UDP, since that's the
only case it works for. From Vlad Yasevich.
3) Clear out silly device table sentinal macros used by SSB and BCMA
drivers. From Joe Perches.
4) Make sure the remote checksum code never creates a situation where
the remote checksum is applied yet the tunneling metadata describing
the remote checksum transformation is still present. Otherwise an
external entity might see this and apply the checksum again. From
Tom Herbert.
5) Use msecs_to_jiffies() where applicable, from Nicholas Mc Guire.
6) Don't explicitly initialize timer struct fields, use setup_timer()
and mod_timer() instead. From Vaishali Thakkar.
7) Don't invoke tg3_halt() without the tp->lock held, from Jun'ichi
Nomura.
8) Missing __percpu annotation in ipvlan driver, from Eric Dumazet.
9) Don't potentially perform skb_get() on shared skbs, also from Eric
Dumazet.
10) Fix COW'ing of metrics for non-DST_HOST routes in ipv6, from Martin
KaFai Lau.
11) Fix merge resolution error between the iov_iter changes in vhost and
some bug fixes that occurred at the same time. From Jason Wang.
12) If rtnl_configure_link() fails we have to perform a call to
->dellink() before unregistering the device. From WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (39 commits)
net: dsa: Set valid phy interface type
rtnetlink: call ->dellink on failure when ->newlink exists
com20020-pci: add support for eae single card
vhost_net: fix wrong iter offset when setting number of buffers
net: spelling fixes
net/core: Fix warning while make xmldocs caused by dev.c
net: phy: micrel: disable NAND-tree for KSZ8021, KSZ8031, KSZ8051, KSZ8081
ipv6: fix ipv6_cow_metrics for non DST_HOST case
openvswitch: Fix key serialization.
r8152: restore hw settings
hso: fix rx parsing logic when skb allocation fails
tcp: make sure skb is not shared before using skb_get()
bridge: netfilter: Move sysctl-specific error code inside #ifdef
ipv6: fix possible deadlock in ip6_fl_purge / ip6_fl_gc
ipvlan: add a missing __percpu pcpu_stats
tg3: Hold tp->lock before calling tg3_halt() from tg3_init_one()
bgmac: fix device initialization on Northstar SoCs (condition typo)
qlcnic: Delete existing multicast MAC list before adding new
net/mlx5_core: Fix configuration of log_uar_page_sz
sunvnet: don't change gso data on clones
Spelling errors caught by codespell.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
IPv6 can keep a copy of SYN message using skb_get() in
tcp_v6_conn_request() so that caller wont free the skb when calling
kfree_skb() later.
Therefore TCP fast open has to clone the skb it is queuing in
child->sk_receive_queue, as all skbs consumed from receive_queue are
freed using __kfree_skb() (ie assuming skb->users == 1)
Fixes: 5b7ed0892f2af ("tcp: move fastopen functions to tcp_fastopen.c")
Move memcg_socket_limit_enabled decrement to tcp_destroy_cgroup (called
from memcg_destroy_kmem -> mem_cgroup_sockets_destroy) and zap a bunch of
wrapper functions.
Although this patch moves static keys decrement from __mem_cgroup_free to
mem_cgroup_css_free, it does not introduce any functional changes, because
the keys are incremented on setting the limit (tcp or kmem), which can
only happen after successful mem_cgroup_css_online.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"Highlights:
- Smack adds secmark support for Netfilter
- /proc/keys is now mandatory if CONFIG_KEYS=y
- TPM gets its own device class
- Added TPM 2.0 support
- Smack file hook rework (all Smack users should review this!)"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (64 commits)
cipso: don't use IPCB() to locate the CIPSO IP option
SELinux: fix error code in policydb_init()
selinux: add security in-core xattr support for pstore and debugfs
selinux: quiet the filesystem labeling behavior message
selinux: Remove unused function avc_sidcmp()
ima: /proc/keys is now mandatory
Smack: Repair netfilter dependency
X.509: silence asn1 compiler debug output
X.509: shut up about included cert for silent build
KEYS: Make /proc/keys unconditional if CONFIG_KEYS=y
MAINTAINERS: email update
tpm/tpm_tis: Add missing ifdef CONFIG_ACPI for pnp_acpi_device
smack: fix possible use after frees in task_security() callers
smack: Add missing logging in bidirectional UDS connect check
Smack: secmark support for netfilter
Smack: Rework file hooks
tpm: fix format string error in tpm-chip.c
char/tpm/tpm_crb: fix build error
smack: Fix a bidirectional UDS connect check typo
smack: introduce a special case for tmpfs in smack_d_instantiate()
The unified hierarchy interface for memory cgroups will no longer use "-1"
to mean maximum possible resource value. In preparation for this, make
the string an argument and let the caller supply it.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Change remote checksum handling to set checksum partial as default
behavior. Added an iflink parameter to configure not using
checksum partial (calling csum_partial to update checksum).
Signed-off-by: Tom Herbert <therbert@google.com>
This patch adds infrastructure so that remote checksum offload can
set CHECKSUM_PARTIAL instead of calling csum_partial and writing
the modfied checksum field.
Add skb_remcsum_adjust_partial function to set an skb for using
CHECKSUM_PARTIAL with remote checksum offload. Changed
skb_remcsum_process and skb_gro_remcsum_process to take a boolean
argument to indicate if checksum partial can be set or the
checksum needs to be modified using the normal algorithm.
Properly set GSO types and skb->encapsulation in the UDP tunnel GRO
complete so that packets are properly represented for GSO. This sets
SKB_GSO_UDP_TUNNEL or SKB_GSO_UDP_TUNNEL_CSUM depending on whether
non-zero checksums were received, and sets SKB_GSO_TUNNEL_REMCSUM if
the remote checksum option was processed.
Remote checksum offload processing is currently the same for both
the GRO and non-GRO path. When the remote checksum offload option
is encountered, the checksum field referred to is modified in
the packet. So in the GRO case, the packet is modified in the
GRO path and then the operation is skipped when the packet goes
through the normal path based on skb->remcsum_offload. There is
a problem in that the packet may be modified in the GRO path, but
then forwarded off host still containing the remote checksum option.
A remote host will again perform RCO but now the checksum verification
will fail since GRO RCO already modified the checksum.
To fix this, we ensure that GRO restores a packet to it's original
state before returning. In this model, when GRO processes a remote
checksum option it still changes the checksum per the algorithm
but on return from lower layer processing the checksum is restored
to its original value.
In this patch we add define gro_remcsum structure which is passed
to skb_gro_remcsum_process to save offset and delta for the checksum
being changed. After lower layer processing, skb_gro_remcsum_cleanup
is called to restore the checksum before returning from GRO.
Using the IPCB() macro to get the IPv4 options is convenient, but
unfortunately NetLabel often needs to examine the CIPSO option outside
of the scope of the IP layer in the stack. While historically IPCB()
worked above the IP layer, due to the inclusion of the inet_skb_param
struct at the head of the {tcp,udp}_skb_cb structs, recent commit
971f10ec ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
reordered the tcp_skb_cb struct and invalidated this IPCB() trick.
This patch fixes the problem by creating a new function,
cipso_v4_optptr(), which locates the CIPSO option inside the IP header
without calling IPCB(). Unfortunately, this isn't as fast as a simple
lookup so some additional tweaks were made to limit the use of this
new function.
Cc: <stable@vger.kernel.org> # 3.18
Reported-by: Casey Schaufler <casey@schaufler-ca.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Tested-by: Casey Schaufler <casey@schaufler-ca.com>
Packetization Layer Path MTU Discovery works separately beside
Path MTU Discovery at IP level, different net namespace has
various requirements on which one to chose, e.g., a virutalized
container instance would require TCP PMTU to probe an usable
effective mtu for underlying tunnel, while the host would
employ classical ICMP based PMTU to function.
Hence making TCP PMTU mechanism per net namespace to decouple
two functionality. Furthermore the probe base MSS should also
be configured separately for each namespace.
Signed-off-by: Fan Du <fan.du@intel.com>
If a server has enabled Fast Open and it receives a pure SYN-data
packet (without a Fast Open option), it won't accept the data but it
incorrectly returns a SYN-ACK with a Fast Open cookie and also
increments the SNMP stat LINUX_MIB_TCPFASTOPENPASSIVEFAIL.
This patch makes the server include a Fast Open cookie in SYN-ACK
only if the SYN has some Fast Open option (i.e., when client
requests or presents a cookie).
We set the outer mode protocol too early. As a result, the
local error handler might dispatch to the wrong address family
and report the error to a wrong socket type. We fix this by
setting the outer protocol to the skb after we accessed the
inner mode for the last time, right before we do the atcual
encapsulation where we switch finally to the outer mode.
Reported-by: Chris Ruehl <chris.ruehl@gtsys.com.hk>
Tested-by: Chris Ruehl <chris.ruehl@gtsys.com.hk>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Receive Flow Steering is a nice solution but suffers from
hash collisions when a mix of connected and unconnected traffic
is received on the host, when flow hash table is populated.
Also, clearing flow in inet_release() makes RFS not very good
for short lived flows, as many packets can follow close().
(FIN , ACK packets, ...)
This patch extends the information stored into global hash table
to not only include cpu number, but upper part of the hash value.
I use a 32bit value, and dynamically split it in two parts.
For host with less than 64 possible cpus, this gives 6 bits for the
cpu number, and 26 (32-6) bits for the upper part of the hash.
Since hash bucket selection use low order bits of the hash, we have
a full hash match, if /proc/sys/net/core/rps_sock_flow_entries is big
enough.
If the hash found in flow table does not match, we fallback to RPS (if
it is enabled for the rxqueue).
This means that a packet for an non connected flow can avoid the
IPI through a unrelated/victim CPU.
This also means we no longer have to clear the table at socket
close time, and this helps short lived flows performance.
Acked-by: Tom Herbert <therbert@google.com>
encap.sport and encap.dport are __be16, use nla_{get,put}_be16 instead
of nla_{get,put}_u16.
Fixes the sparse warnings:
warning: incorrect type in assignment (different base types)
expected restricted __be32 [addressable] [usertype] o_key
got restricted __be16 [addressable] [usertype] i_flags
expected restricted __be16 [usertype] sport
got unsigned short
expected restricted __be16 [usertype] dport
got unsigned short
warning: incorrect type in argument 3 (different base types)
expected unsigned short [unsigned] [usertype] value
got restricted __be16 [usertype] sport
got restricted __be16 [usertype] dport
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Ensure that in state FIN_WAIT2 or TIME_WAIT, where the connection is
represented by a tcp_timewait_sock, we rate limit dupacks in response
to incoming packets (a) with TCP timestamps that fail PAWS checks, or
(b) with sequence numbers that are out of the acceptable window.
We do not send a dupack in response to out-of-window packets if it has
been less than sysctl_tcp_invalid_ratelimit (default 500ms) since we
last sent a dupack in response to an out-of-window packet.
Reported-by: Avery Fay <avery@mixpanel.com>
Ensure that in state ESTABLISHED, where the connection is represented
by a tcp_sock, we rate limit dupacks in response to incoming packets
(a) with TCP timestamps that fail PAWS checks, or (b) with sequence
numbers or ACK numbers that are out of the acceptable window.
There is already a similar (although global) rate-limiting mechanism
for "challenge ACKs". When deciding whether to send a challence ACK,
we first consult the new per-connection rate limit, and then the
global rate limit.
In the SYN_RECV state, where the TCP connection is represented by
tcp_request_sock, we now rate-limit SYNACKs in response to a client's
retransmitted SYNs: we do not send a SYNACK in response to client SYN
if it has been less than sysctl_tcp_invalid_ratelimit (default 500ms)
since we last sent a SYNACK in response to a client's retransmitted
SYN.
This allows the vast majority of legitimate client connections to
proceed unimpeded, even for the most aggressive platforms, iOS and
MacOS, which actually retransmit SYNs 1-second intervals for several
times in a row. They use SYN RTO timeouts following the progression:
1,1,1,1,1,2,4,8,16,32.
Helpers for mitigating ACK loops by rate-limiting dupacks sent in
response to incoming out-of-window packets.
This patch includes:
- rate-limiting logic
- sysctl to control how often we allow dupacks to out-of-window packets
- SNMP counter for cases where we rate-limited our dupack sending
The rate-limiting logic in this patch decides to not send dupacks in
response to out-of-window segments if (a) they are SYNs or pure ACKs
and (b) the remote endpoint is sending them faster than the configured
rate limit.
We rate-limit our responses rather than blocking them entirely or
resetting the connection, because legitimate connections can rely on
dupacks in response to some out-of-window segments. For example, zero
window probes are typically sent with a sequence number that is below
the current window, and ZWPs thus expect to thus elicit a dupack in
response.
We allow dupacks in response to TCP segments with data, because these
may be spurious retransmissions for which the remote endpoint wants to
receive DSACKs. This is safe because segments with data can't
realistically be part of ACK loops, which by their nature consist of
each side sending pure/data-less ACKs to each other.
The dupack interval is controlled by a new sysctl knob,
tcp_invalid_ratelimit, given in milliseconds, in case an administrator
needs to dial this upward in the face of a high-rate DoS attack. The
name and units are chosen to be analogous to the existing analogous
knob for ICMP, icmp_ratelimit.
The default value for tcp_invalid_ratelimit is 500ms, which allows at
most one such dupack per 500ms. This is chosen to be 2x faster than
the 1-second minimum RTO interval allowed by RFC 6298 (section 2, rule
2.4). We allow the extra 2x factor because network delay variations
can cause packets sent at 1 second intervals to be compressed and
arrive much closer.
drivers/net/vxlan.c
drivers/vhost/net.c
include/linux/if_vlan.h
net/core/dev.c
The net/core/dev.c conflict was the overlap of one commit marking an
existing function static whilst another was adding a new function.
In the include/linux/if_vlan.h case, the type used for a local
variable was changed in 'net', whereas the function got rewritten
to fix a stacked vlan bug in 'net-next'.
In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next'
overlapped with an endainness fix for VHOST 1.0 in 'net'.
In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter
in 'net-next' whereas in 'net' there was a bug fix to pass in the
correct network namespace pointer in calls to this function.
More iov_iter work from Al Viro.
When we added pacing to TCP, we decided to let sch_fq take care
of actual pacing.
All TCP had to do was to compute sk->pacing_rate using simple formula:
sk->pacing_rate = 2 * cwnd * mss / rtt
It works well for senders (bulk flows), but not very well for receivers
or even RPC :
cwnd on the receiver can be less than 10, rtt can be around 100ms, so we
can end up pacing ACK packets, slowing down the sender.
Really, only the sender should pace, according to its own logic.
Instead of adding a new bit in skb, or call yet another flow
dissection, we tweak skb->truesize to a small value (2), and
we instruct sch_fq to use new helper and not pace pure ack.
Note this also helps TCP small queue, as ack packets present
in qdisc/NIC do not prevent sending a data packet (RPC workload)
This helps to reduce tx completion overhead, ack packets can use regular
sock_wfree() instead of tcp_wfree() which is a bit more expensive.
This has no impact in the case packets are sent to loopback interface,
as we do not coalesce ack packets (were we would detect skb->truesize
lie)
In case netem (with a delay) is used, skb_orphan_partial() also sets
skb->truesize to 1.
This patch is a combination of two patches we used for about one year at
Google.
This patch adds skb_remcsum_process and skb_gro_remcsum_process to
perform the appropriate adjustments to the skb when receiving
Updated vxlan and gue to use these functions.
Tested: Ran TCP_RR and TCP_STREAM netperf for VXLAN and GUE, did
not see any change in performance.
That takes care of the majority of ->sendmsg() instances - most of them
via memcpy_to_msg() or assorted getfrag() callbacks. One place where we
still keep memcpy_fromiovecend() is tipc - there we potentially read the
same data over and over; separate patch, that...
patch is actually smaller than it seems to be - most of it is unindenting
the inner loop body in tcp_sendmsg() itself...
the bit in tcp_input.c is going to get reverted very soon - that's what
memcpy_from_msg() will become, but not in this commit; let's keep it
reasonably contained...
There's one potentially subtle change here: in case of short copy from
userland, mainline tcp_send_syn_data() discards the skb it has allocated
and falls back to normal path, where we'll send as much as possible after
rereading the same data again. This patch trims SYN+data skb instead -
that way we don't need to copy from the same place twice.
... instead of storing its ->mgs_iter.iov there
Switch from passing msg->iov_iter.iov to passing msg itself
