path: root/net/ipv4
2015-10-01net: gso: use feature flag argument in all protocol gso handlersFlorian Westphal
[ Upstream commit 1e16aa3ddf863c6b9f37eddf52503230a62dedb3 ] skb_gso_segment() has a 'features' argument representing offload features available to the output path. A few handlers, e.g. GRE, instead re-fetch the features of skb->dev and use those instead of the provided ones when handing encapsulation/tunnels. Depending on dev->hw_enc_features of the output device skb_gso_segment() can then return NULL even when the caller has disabled all GSO feature bits, as segmentation of inner header thinks device will take care of segmentation. This e.g. affects the tbf scheduler, which will silently drop GRE-encap GSO skbs that did not fit the remaining token quota as the segmentation does not work when device supports corresponding hw offload capabilities. Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> [jay.vosburgh: backported to 3.14. ] Signed-off-by: Jay Vosburgh <jay.vosburgh@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-01udp: fix dst races with multicast early demuxEric Dumazet
[ Upstream commit 10e2eb878f3ca07ac2f05fa5ca5e6c4c9174a27a ] Multicast dst are not cached. They carry DST_NOCACHE. As mentioned in commit f8864972126899 ("ipv4: fix dst race in sk_dst_get()"), these dst need special care before caching them into a socket. Caching them is allowed only if their refcnt was not 0, ie we must use atomic_inc_not_zero() Also, we must use READ_ONCE() to fetch sk->sk_rx_dst, as mentioned in commit d0c294c53a771 ("tcp: prevent fetching dst twice in early demux code") Fixes: 421b3885bf6d ("udp: ipv4: Add udp early demux") Tested-by: Gregory Hoggarth <Gregory.Hoggarth@alliedtelesis.co.nz> Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Gregory Hoggarth <Gregory.Hoggarth@alliedtelesis.co.nz> Reported-by: Alex Gartrell <agartrell@fb.com> Cc: Michal Kubeček <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-01inet: frags: fix defragmented packet's IP header for af_packetEdward Hyunkoo Jee
[ Upstream commit 0848f6428ba3a2e42db124d41ac6f548655735bf ] When ip_frag_queue() computes positions, it assumes that the passed sk_buff does not contain L2 headers. However, when PACKET_FANOUT_FLAG_DEFRAG is used, IP reassembly functions can be called on outgoing packets that contain L2 headers. Also, IPv4 checksum is not corrected after reassembly. Fixes: 7736d33f4262 ("packet: Add pre-defragmentation support for ipv4 fanouts.") Signed-off-by: Edward Hyunkoo Jee <edjee@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-01ipv6: lock socket in ip6_datagram_connect()Eric Dumazet
[ Upstream commit 03645a11a570d52e70631838cb786eb4253eb463 ] ip6_datagram_connect() is doing a lot of socket changes without socket being locked. This looks wrong, at least for udp_lib_rehash() which could corrupt lists because of concurrent udp_sk(sk)->udp_portaddr_hash accesses. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-01ip_tunnel: fix ipv4 pmtu check to honor inner ip header dfTimo Teräs
[ Upstream commit fc24f2b2094366da8786f59f2606307e934cea17 ] Frag needed should be sent only if the inner header asked to not fragment. Currently fragmentation is broken if the tunnel has df set, but df was not asked in the original packet. The tunnel's df needs to be still checked to update internally the pmtu cache. Commit 23a3647bc4f93bac broke it, and this commit fixes the ipv4 df check back to the way it was. Fixes: 23a3647bc4f93bac ("ip_tunnels: Use skb-len to PMTU check.") Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Timo Teräs <timo.teras@iki.fi> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-10tcp: Do not call tcp_fastopen_reset_cipher from interrupt contextChristoph Paasch
[ Upstream commit dfea2aa654243f70dc53b8648d0bbdeec55a7df1 ] tcp_fastopen_reset_cipher really cannot be called from interrupt context. It allocates the tcp_fastopen_context with GFP_KERNEL and calls crypto_alloc_cipher, which allocates all kind of stuff with GFP_KERNEL. Thus, we might sleep when the key-generation is triggered by an incoming TFO cookie-request which would then happen in interrupt- context, as shown by enabling CONFIG_DEBUG_ATOMIC_SLEEP: [ 36.001813] BUG: sleeping function called from invalid context at mm/slub.c:1266 [ 36.003624] in_atomic(): 1, irqs_disabled(): 0, pid: 1016, name: packetdrill [ 36.004859] CPU: 1 PID: 1016 Comm: packetdrill Not tainted 4.1.0-rc7 #14 [ 36.006085] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140602_164612-nilsson.home.kraxel.org 04/01/2014 [ 36.008250] 00000000000004f2 ffff88007f8838a8 ffffffff8171d53a ffff880075a084a8 [ 36.009630] ffff880075a08000 ffff88007f8838c8 ffffffff810967d3 ffff88007f883928 [ 36.011076] 0000000000000000 ffff88007f8838f8 ffffffff81096892 ffff88007f89be00 [ 36.012494] Call Trace: [ 36.012953] <IRQ> [<ffffffff8171d53a>] dump_stack+0x4f/0x6d [ 36.014085] [<ffffffff810967d3>] ___might_sleep+0x103/0x170 [ 36.015117] [<ffffffff81096892>] __might_sleep+0x52/0x90 [ 36.016117] [<ffffffff8118e887>] kmem_cache_alloc_trace+0x47/0x190 [ 36.017266] [<ffffffff81680d82>] ? tcp_fastopen_reset_cipher+0x42/0x130 [ 36.018485] [<ffffffff81680d82>] tcp_fastopen_reset_cipher+0x42/0x130 [ 36.019679] [<ffffffff81680f01>] tcp_fastopen_init_key_once+0x61/0x70 [ 36.020884] [<ffffffff81680f2c>] __tcp_fastopen_cookie_gen+0x1c/0x60 [ 36.022058] [<ffffffff816814ff>] tcp_try_fastopen+0x58f/0x730 [ 36.023118] [<ffffffff81671788>] tcp_conn_request+0x3e8/0x7b0 [ 36.024185] [<ffffffff810e3872>] ? __module_text_address+0x12/0x60 [ 36.025327] [<ffffffff8167b2e1>] tcp_v4_conn_request+0x51/0x60 [ 36.026410] [<ffffffff816727e0>] tcp_rcv_state_process+0x190/0xda0 [ 36.027556] [<ffffffff81661f97>] ? __inet_lookup_established+0x47/0x170 [ 36.028784] [<ffffffff8167c2ad>] tcp_v4_do_rcv+0x16d/0x3d0 [ 36.029832] [<ffffffff812e6806>] ? security_sock_rcv_skb+0x16/0x20 [ 36.030936] [<ffffffff8167cc8a>] tcp_v4_rcv+0x77a/0x7b0 [ 36.031875] [<ffffffff816af8c3>] ? iptable_filter_hook+0x33/0x70 [ 36.032953] [<ffffffff81657d22>] ip_local_deliver_finish+0x92/0x1f0 [ 36.034065] [<ffffffff81657f1a>] ip_local_deliver+0x9a/0xb0 [ 36.035069] [<ffffffff81657c90>] ? ip_rcv+0x3d0/0x3d0 [ 36.035963] [<ffffffff81657569>] ip_rcv_finish+0x119/0x330 [ 36.036950] [<ffffffff81657ba7>] ip_rcv+0x2e7/0x3d0 [ 36.037847] [<ffffffff81610652>] __netif_receive_skb_core+0x552/0x930 [ 36.038994] [<ffffffff81610a57>] __netif_receive_skb+0x27/0x70 [ 36.040033] [<ffffffff81610b72>] process_backlog+0xd2/0x1f0 [ 36.041025] [<ffffffff81611482>] net_rx_action+0x122/0x310 [ 36.042007] [<ffffffff81076743>] __do_softirq+0x103/0x2f0 [ 36.042978] [<ffffffff81723e3c>] do_softirq_own_stack+0x1c/0x30 This patch moves the call to tcp_fastopen_init_key_once to the places where a listener socket creates its TFO-state, which always happens in user-context (either from the setsockopt, or implicitly during the listen()-call) Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Fixes: 222e83d2e0ae ("tcp: switch tcp_fastopen key generation to net_get_random_once") Signed-off-by: Christoph Paasch <cpaasch@apple.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-22ipv4/udp: Verify multicast group is ours in upd_v4_early_demux()Shawn Bohrer
[ Upstream commit 6e540309326188f769e03bb4c6dd8ff6752930c2 ] 421b3885bf6d56391297844f43fb7154a6396e12 "udp: ipv4: Add udp early demux" introduced a regression that allowed sockets bound to INADDR_ANY to receive packets from multicast groups that the socket had not joined. For example a socket that had joined 224.168.2.9 could also receive packets from 225.168.2.9 despite not having joined that group if ip_early_demux is enabled. Fix this by calling ip_check_mc_rcu() in udp_v4_early_demux() to verify that the multicast packet is indeed ours. Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-22udp: fix behavior of wrong checksumsEric Dumazet
[ Upstream commit beb39db59d14990e401e235faf66a6b9b31240b0 ] We have two problems in UDP stack related to bogus checksums : 1) We return -EAGAIN to application even if receive queue is not empty. This breaks applications using edge trigger epoll() 2) Under UDP flood, we can loop forever without yielding to other processes, potentially hanging the host, especially on non SMP. This patch is an attempt to make things better. We might in the future add extra support for rt applications wanting to better control time spent doing a recv() in a hostile environment. For example we could validate checksums before queuing packets in socket receive queue. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-22ipv4: Avoid crashing in ip_errorEric W. Biederman
[ Upstream commit 381c759d9916c42959515ad34a6d467e24a88e93 ] ip_error does not check if in_dev is NULL before dereferencing it. IThe following sequence of calls is possible: CPU A CPU B ip_rcv_finish ip_route_input_noref() ip_route_input_slow() inetdev_destroy() dst_input() With the result that a network device can be destroyed while processing an input packet. A crash was triggered with only unicast packets in flight, and forwarding enabled on the only network device. The error condition was created by the removal of the network device. As such it is likely the that error code was -EHOSTUNREACH, and the action taken by ip_error (if in_dev had been accessible) would have been to not increment any counters and to have tried and likely failed to send an icmp error as the network device is going away. Therefore handle this weird case by just dropping the packet if !in_dev. It will result in dropping the packet sooner, and will not result in an actual change of behavior. Fixes: 251da4130115b ("ipv4: Cache ip_error() routes even when not forwarding.") Reported-by: Vittorio Gambaletta <linuxbugs@vittgam.net> Tested-by: Vittorio Gambaletta <linuxbugs@vittgam.net> Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-22tcp/ipv6: fix flow label setting in TIME_WAIT stateFlorent Fourcot
[ Upstream commit 21858cd02dabcf290564cbf4769b101eba54d7bb ] commit 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages send from TIME_WAIT") added the flow label in the last TCP packets. Unfortunately, it was not casted properly. This patch replace the buggy shift with be32_to_cpu/cpu_to_be32. Fixes: 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages") Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13ipv4: Missing sk_nulls_node_init() in ping_unhash().David S. Miller
[ Upstream commit a134f083e79fb4c3d0a925691e732c56911b4326 ] If we don't do that, then the poison value is left in the ->pprev backlink. This can cause crashes if we do a disconnect, followed by a connect(). Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Wen Xu <hotdog3645@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06tcp: avoid looping in tcp_send_fin()Eric Dumazet
[ Upstream commit 845704a535e9b3c76448f52af1b70e4422ea03fd ] Presence of an unbound loop in tcp_send_fin() had always been hard to explain when analyzing crash dumps involving gigantic dying processes with millions of sockets. Lets try a different strategy : In case of memory pressure, try to add the FIN flag to last packet in write queue, even if packet was already sent. TCP stack will be able to deliver this FIN after a timeout event. Note that this FIN being delivered by a retransmit, it also carries a Push flag given our current implementation. By checking sk_under_memory_pressure(), we anticipate that cooking many FIN packets might deplete tcp memory. In the case we could not allocate a packet, even with __GFP_WAIT allocation, then not sending a FIN seems quite reasonable if it allows to get rid of this socket, free memory, and not block the process from eventually doing other useful work. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06tcp: fix possible deadlock in tcp_send_fin()Eric Dumazet
[ Upstream commit d83769a580f1132ac26439f50068a29b02be535e ] Using sk_stream_alloc_skb() in tcp_send_fin() is dangerous in case a huge process is killed by OOM, and tcp_mem[2] is hit. To be able to free memory we need to make progress, so this patch allows FIN packets to not care about tcp_mem[2], if skb allocation succeeded. In a follow-up patch, we might abort tcp_send_fin() infinite loop in case TIF_MEMDIE is set on this thread, as memory allocator did its best getting extra memory already. This patch reverts d22e15371811 ("tcp: fix tcp fin memory accounting") Fixes: d22e15371811 ("tcp: fix tcp fin memory accounting") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06ip_forward: Drop frames with attached skb->skSebastian Pöhn
[ Upstream commit 2ab957492d13bb819400ac29ae55911d50a82a13 ] Initial discussion was: [FYI] xfrm: Don't lookup sk_policy for timewait sockets Forwarded frames should not have a socket attached. Especially tw sockets will lead to panics later-on in the stack. This was observed with TPROXY assigning a tw socket and broken policy routing (misconfigured). As a result frame enters forwarding path instead of input. We cannot solve this in TPROXY as it cannot know that policy routing is broken. v2: Remove useless comment Signed-off-by: Sebastian Poehn <sebastian.poehn@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29tcp: tcp_make_synack() should clear skb->tstampEric Dumazet
[ Upstream commit b50edd7812852d989f2ef09dcfc729690f54a42d ] I noticed tcpdump was giving funky timestamps for locally generated SYNACK messages on loopback interface. 11:42:46.938990 IP 127.0.0.1.48245 > 127.0.0.2.23850: S 945476042:945476042(0) win 43690 <mss 65495,nop,nop,sackOK,nop,wscale 7> 20:28:58.502209 IP 127.0.0.2.23850 > 127.0.0.1.48245: S 3160535375:3160535375(0) ack 945476043 win 43690 <mss 65495,nop,nop,sackOK,nop,wscale 7> This is because we need to clear skb->tstamp before entering lower stack, otherwise net_timestamp_check() does not set skb->tstamp. Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29tcp: fix FRTO undo on cumulative ACK of SACKed rangeNeal Cardwell
[ Upstream commit 666b805150efd62f05810ff0db08f44a2370c937 ] On processing cumulative ACKs, the FRTO code was not checking the SACKed bit, meaning that there could be a spurious FRTO undo on a cumulative ACK of a previously SACKed skb. The FRTO code should only consider a cumulative ACK to indicate that an original/unretransmitted skb is newly ACKed if the skb was not yet SACKed. The effect of the spurious FRTO undo would typically be to make the connection think that all previously-sent packets were in flight when they really weren't, leading to a stall and an RTO. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29tcp: prevent fetching dst twice in early demux codeMichal Kubeček
[ Upstream commit d0c294c53a771ae7e84506dfbd8c18c30f078735 ] On s390x, gcc 4.8 compiles this part of tcp_v6_early_demux() struct dst_entry *dst = sk->sk_rx_dst; if (dst) dst = dst_check(dst, inet6_sk(sk)->rx_dst_cookie); to code reading sk->sk_rx_dst twice, once for the test and once for the argument of ip6_dst_check() (dst_check() is inline). This allows ip6_dst_check() to be called with null first argument, causing a crash. Protect sk->sk_rx_dst access by ACCESS_ONCE() both in IPv4 and IPv6 TCP early demux code. Fixes: 41063e9dd119 ("ipv4: Early TCP socket demux.") Fixes: c7109986db3c ("ipv6: Early TCP socket demux") Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-19tcp: Fix crash in TCP Fast OpenBen Hutchings
Commit 355a901e6cf1 ("tcp: make connect() mem charging friendly") changed tcp_send_syn_data() to perform an open-coded copy of the 'syn' skb rather than using skb_copy_expand(). The open-coded copy does not cover the skb_shared_info::gso_segs field, so in the new skb it is left set to 0. When this commit was backported into stable branches between 3.10.y and 3.16.7-ckty inclusive, it triggered the BUG() in tcp_transmit_skb(). Since Linux 3.18 the GSO segment count is kept in the tcp_skb_cb::tcp_gso_segs field and tcp_send_syn_data() does copy the tcp_skb_cb structure to the new skb, so mainline and newer stable branches are not affected. Set skb_shared_info::gso_segs to the correct value of 1. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26tcp: make connect() mem charging friendlyEric Dumazet
[ Upstream commit 355a901e6cf1b2b763ec85caa2a9f04fbcc4ab4a ] While working on sk_forward_alloc problems reported by Denys Fedoryshchenko, we found that tcp connect() (and fastopen) do not call sk_wmem_schedule() for SYN packet (and/or SYN/DATA packet), so sk_forward_alloc is negative while connect is in progress. We can fix this by calling regular sk_stream_alloc_skb() both for the SYN packet (in tcp_connect()) and the syn_data packet in tcp_send_syn_data() Then, tcp_send_syn_data() can avoid copying syn_data as we simply can manipulate syn_data->cb[] to remove SYN flag (and increment seq) Instead of open coding memcpy_fromiovecend(), simply use this helper. This leaves in socket write queue clean fast clone skbs. This was tested against our fastopen packetdrill tests. Reported-by: Denys Fedoryshchenko <nuclearcat@nuclearcat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26tcp: fix tcp fin memory accountingJosh Hunt
[ Upstream commit d22e1537181188e5dc8cbc51451832625035bdc2 ] tcp_send_fin() does not account for the memory it allocates properly, so sk_forward_alloc can be negative in cases where we've sent a FIN: ss example output (ss -amn | grep -B1 f4294): tcp FIN-WAIT-1 0 1 192.168.0.1:45520 192.0.2.1:8080 skmem:(r0,rb87380,t0,tb87380,f4294966016,w1280,o0,bl0) Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26inet_diag: fix possible overflow in inet_diag_dump_one_icsk()Eric Dumazet
[ Upstream commit c8e2c80d7ec00d020320f905822bf49c5ad85250 ] inet_diag_dump_one_icsk() allocates too small skb. Add inet_sk_attr_size() helper right before inet_sk_diag_fill() so that it can be updated if/when new attributes are added. iproute2/ss currently does not use this dump_one() interface, this might explain nobody noticed this problem yet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18net: ping: Return EAFNOSUPPORT when appropriate.Lorenzo Colitti
[ Upstream commit 9145736d4862145684009d6a72a6e61324a9439e ] 1. For an IPv4 ping socket, ping_check_bind_addr does not check the family of the socket address that's passed in. Instead, make it behave like inet_bind, which enforces either that the address family is AF_INET, or that the family is AF_UNSPEC and the address is 0.0.0.0. 2. For an IPv6 ping socket, ping_check_bind_addr returns EINVAL if the socket family is not AF_INET6. Return EAFNOSUPPORT instead, for consistency with inet6_bind. 3. Make ping_v4_sendmsg and ping_v6_sendmsg return EAFNOSUPPORT instead of EINVAL if an incorrect socket address structure is passed in. 4. Make IPv6 ping sockets be IPv6-only. The code does not support IPv4, and it cannot easily be made to support IPv4 because the protocol numbers for ICMP and ICMPv6 are different. This makes connect(::ffff:192.0.2.1) fail with EAFNOSUPPORT instead of making the socket unusable. Among other things, this fixes an oops that can be triggered by: int s = socket(AF_INET, SOCK_DGRAM, IPPROTO_ICMP); struct sockaddr_in6 sin6 = { .sin6_family = AF_INET6, .sin6_addr = in6addr_any, }; bind(s, (struct sockaddr *) &sin6, sizeof(sin6)); Change-Id: If06ca86d9f1e4593c0d6df174caca3487c57a241 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18udp: only allow UFO for packets from SOCK_DGRAM socketsMichal Kubeček
[ Upstream commit acf8dd0a9d0b9e4cdb597c2f74802f79c699e802 ] If an over-MTU UDP datagram is sent through a SOCK_RAW socket to a UFO-capable device, ip_ufo_append_data() sets skb->ip_summed to CHECKSUM_PARTIAL unconditionally as all GSO code assumes transport layer checksum is to be computed on segmentation. However, in this case, skb->csum_start and skb->csum_offset are never set as raw socket transmit path bypasses udp_send_skb() where they are usually set. As a result, driver may access invalid memory when trying to calculate the checksum and store the result (as observed in virtio_net driver). Moreover, the very idea of modifying the userspace provided UDP header is IMHO against raw socket semantics (I wasn't able to find a document clearly stating this or the opposite, though). And while allowing CHECKSUM_NONE in the UFO case would be more efficient, it would be a bit too intrusive change just to handle a corner case like this. Therefore disallowing UFO for packets from SOCK_DGRAM seems to be the best option. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18ipv4: ip_check_defrag should not assume that skb_network_offset is zeroAlexander Drozdov
[ Upstream commit 3e32e733d1bbb3f227259dc782ef01d5706bdae0 ] ip_check_defrag() may be used by af_packet to defragment outgoing packets. skb_network_offset() of af_packet's outgoing packets is not zero. Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18ipv4: ip_check_defrag should correctly check return value of skb_copy_bitsAlexander Drozdov
[ Upstream commit fba04a9e0c869498889b6445fd06cbe7da9bb834 ] skb_copy_bits() returns zero on success and negative value on error, so it is needed to invert the condition in ip_check_defrag(). Fixes: 1bf3751ec90c ("ipv4: ip_check_defrag must not modify skb before unsharing") Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-26ipv4: tcp: get rid of ugly unicast_sockEric Dumazet
[ Upstream commit bdbbb8527b6f6a358dbcb70dac247034d665b8e4 ] In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock") I tried to address contention on a socket lock, but the solution I chose was horrible : commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside of TCP stack") addressed a selinux regression. commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1") took care of another regression. commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression. commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate") was another shot in the dark. Really, just use a proper socket per cpu, and remove the skb_orphan() call, to re-enable flow control. This solves a serious problem with FQ packet scheduler when used in hostile environments, as we do not want to allocate a flow structure for every RST packet sent in response to a spoofed packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-26tcp: ipv4: initialize unicast_sock sk_pacing_rateEric Dumazet
[ Upstream commit 811230cd853d62f09ed0addd0ce9a1b9b0e13fb5 ] When I added sk_pacing_rate field, I forgot to initialize its value in the per cpu unicast_sock used in ip_send_unicast_reply() This means that for sch_fq users, RST packets, or ACK packets sent on behalf of TIME_WAIT sockets might be sent to slowly or even dropped once we reach the per flow limit. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 95bd09eb2750 ("tcp: TSO packets automatic sizing") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-26ping: Fix race in free in receive pathsubashab@codeaurora.org
[ Upstream commit fc752f1f43c1c038a2c6ae58cc739ebb5953ccb0 ] An exception is seen in ICMP ping receive path where the skb destructor sock_rfree() tries to access a freed socket. This happens because ping_rcv() releases socket reference with sock_put() and this internally frees up the socket. Later icmp_rcv() will try to free the skb and as part of this, skb destructor is called and which leads to a kernel panic as the socket is freed already in ping_rcv(). -->|exception -007|sk_mem_uncharge -007|sock_rfree -008|skb_release_head_state -009|skb_release_all -009|__kfree_skb -010|kfree_skb -011|icmp_rcv -012|ip_local_deliver_finish Fix this incorrect free by cloning this skb and processing this cloned skb instead. This patch was suggested by Eric Dumazet Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-26udp_diag: Fix socket skipping within chainHerbert Xu
[ Upstream commit 86f3cddbc3037882414c7308973530167906b7e9 ] While working on rhashtable walking I noticed that the UDP diag dumping code is buggy. In particular, the socket skipping within a chain never happens, even though we record the number of sockets that should be skipped. As this code was supposedly copied from TCP, this patch does what TCP does and resets num before we walk a chain. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-26ipv4: try to cache dst_entries which would cause a redirectHannes Frederic Sowa
[ Upstream commit df4d92549f23e1c037e83323aff58a21b3de7fe0 ] Not caching dst_entries which cause redirects could be exploited by hosts on the same subnet, causing a severe DoS attack. This effect aggravated since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()"). Lookups causing redirects will be allocated with DST_NOCACHE set which will force dst_release to free them via RCU. Unfortunately waiting for RCU grace period just takes too long, we can end up with >1M dst_entries waiting to be released and the system will run OOM. rcuos threads cannot catch up under high softirq load. Attaching the flag to emit a redirect later on to the specific skb allows us to cache those dst_entries thus reducing the pressure on allocation and deallocation. This issue was discovered by Marcelo Leitner. Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Marcelo Leitner <mleitner@redhat.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-26ip: zero sockaddr returned on error queueWillem de Bruijn
[ Upstream commit f812116b174e59a350acc8e4856213a166a91222 ] The sockaddr is returned in IP(V6)_RECVERR as part of errhdr. That structure is defined and allocated on the stack as struct { struct sock_extended_err ee; struct sockaddr_in(6) offender; } errhdr; The second part is only initialized for certain SO_EE_ORIGIN values. Always initialize it completely. An MTU exceeded error on a SOCK_RAW/IPPROTO_RAW is one example that would return uninitialized bytes. Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Also verified that there is no padding between errhdr.ee and errhdr.offender that could leak additional kernel data. Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27tcp: Do not apply TSO segment limit to non-TSO packetsHerbert Xu
[ Upstream commit 843925f33fcc293d80acf2c5c8a78adf3344d49b ] Thomas Jarosch reported IPsec TCP stalls when a PMTU event occurs. In fact the problem was completely unrelated to IPsec. The bug is also reproducible if you just disable TSO/GSO. The problem is that when the MSS goes down, existing queued packet on the TX queue that have not been transmitted yet all look like TSO packets and get treated as such. This then triggers a bug where tcp_mss_split_point tells us to generate a zero-sized packet on the TX queue. Once that happens we're screwed because the zero-sized packet can never be removed by ACKs. Fixes: 1485348d242 ("tcp: Apply device TSO segment limit earlier") Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cheers, Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27gre: fix the inner mac header in nbma tunnel xmit pathTimo Teräs
[ Upstream commit 8a0033a947403569caeca45fa5e6f7ba60d51974 ] The NBMA GRE tunnels temporarily push GRE header that contain the per-packet NBMA destination on the skb via header ops early in xmit path. It is the later pulled before the real GRE header is constructed. The inner mac was thus set differently in nbma case: the GRE header has been pushed by neighbor layer, and mac header points to beginning of the temporary gre header (set by dev_queue_xmit). Now that the offloads expect mac header to point to the gre payload, fix the xmit patch to: - pull first the temporary gre header away - and reset mac header to point to gre payload This fixes tso to work again with nbma tunnels. Fixes: 14051f0452a2 ("gre: Use inner mac length when computing tunnel length") Signed-off-by: Timo Teräs <timo.teras@iki.fi> Cc: Tom Herbert <therbert@google.com> Cc: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16gre: Set inner mac header in gro completeTom Herbert
[ Upstream commit 6fb2a756739aa507c1fd5b8126f0bfc2f070dc46 ] Set the inner mac header to point to the GRE payload when doing GRO. This is needed if we proceed to send the packet through GRE GSO which now uses the inner mac header instead of inner network header to determine the length of encapsulation headers. Fixes: 14051f0452a2 ("gre: Use inner mac length when computing tunnel length") Reported-by: Wolfgang Walter <linux@stwm.de> Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16ip_tunnel: the lack of vti_link_ops' dellink() cause kernel paniclucien
[ Upstream commit 20ea60ca9952bd19d4b0d74719daba305aef5178 ] Now the vti_link_ops do not point the .dellink, for fb tunnel device (ip_vti0), the net_device will be removed as the default .dellink is unregister_netdevice_queue,but the tunnel still in the tunnel list, then if we add a new vti tunnel, in ip_tunnel_find(): hlist_for_each_entry_rcu(t, head, hash_node) { if (local == t->parms.iph.saddr && remote == t->parms.iph.daddr && link == t->parms.link && ==> type == t->dev->type && ip_tunnel_key_match(&t->parms, flags, key)) break; } the panic will happen, cause dev of ip_tunnel *t is null: [ 3835.072977] IP: [<ffffffffa04103fd>] ip_tunnel_find+0x9d/0xc0 [ip_tunnel] [ 3835.073008] PGD b2c21067 PUD b7277067 PMD 0 [ 3835.073008] Oops: 0000 [#1] SMP ..... [ 3835.073008] Stack: [ 3835.073008] ffff8800b72d77f0 ffffffffa0411924 ffff8800bb956000 ffff8800b72d78e0 [ 3835.073008] ffff8800b72d78a0 0000000000000000 ffffffffa040d100 ffff8800b72d7858 [ 3835.073008] ffffffffa040b2e3 0000000000000000 0000000000000000 0000000000000000 [ 3835.073008] Call Trace: [ 3835.073008] [<ffffffffa0411924>] ip_tunnel_newlink+0x64/0x160 [ip_tunnel] [ 3835.073008] [<ffffffffa040b2e3>] vti_newlink+0x43/0x70 [ip_vti] [ 3835.073008] [<ffffffff8150d4da>] rtnl_newlink+0x4fa/0x5f0 [ 3835.073008] [<ffffffff812f68bb>] ? nla_strlcpy+0x5b/0x70 [ 3835.073008] [<ffffffff81508fb0>] ? rtnl_link_ops_get+0x40/0x60 [ 3835.073008] [<ffffffff8150d11f>] ? rtnl_newlink+0x13f/0x5f0 [ 3835.073008] [<ffffffff81509cf4>] rtnetlink_rcv_msg+0xa4/0x270 [ 3835.073008] [<ffffffff8126adf5>] ? sock_has_perm+0x75/0x90 [ 3835.073008] [<ffffffff81509c50>] ? rtnetlink_rcv+0x30/0x30 [ 3835.073008] [<ffffffff81529e39>] netlink_rcv_skb+0xa9/0xc0 [ 3835.073008] [<ffffffff81509c48>] rtnetlink_rcv+0x28/0x30 .... modprobe ip_vti ip link del ip_vti0 type vti ip link add ip_vti0 type vti rmmod ip_vti do that one or more times, kernel will panic. fix it by assigning ip_tunnel_dellink to vti_link_ops' dellink, in which we skip the unregister of fb tunnel device. do the same on ip6_vti. Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06net/ping: handle protocol mismatching scenarioJane Zhou
commit 91a0b603469069cdcce4d572b7525ffc9fd352a6 upstream. ping_lookup() may return a wrong sock if sk_buff's and sock's protocols dont' match. For example, sk_buff's protocol is ETH_P_IPV6, but sock's sk_family is AF_INET, in that case, if sk->sk_bound_dev_if is zero, a wrong sock will be returned. the fix is to "continue" the searching, if no matching, return NULL. Cc: "David S. Miller" <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: netdev@vger.kernel.org Signed-off-by: Jane Zhou <a17711@motorola.com> Signed-off-by: Yiwei Zhao <gbjc64@motorola.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06ipv4: Fix incorrect error code when adding an unreachable routePanu Matilainen
[ Upstream commit 49dd18ba4615eaa72f15c9087dea1c2ab4744cf5 ] Trying to add an unreachable route incorrectly returns -ESRCH if if custom FIB rules are present: [root@localhost ~]# ip route add 74.125.31.199 dev eth0 via 1.2.3.4 RTNETLINK answers: Network is unreachable [root@localhost ~]# ip rule add to 55.66.77.88 table 200 [root@localhost ~]# ip route add 74.125.31.199 dev eth0 via 1.2.3.4 RTNETLINK answers: No such process [root@localhost ~]# Commit 83886b6b636173b206f475929e58fac75c6f2446 ("[NET]: Change "not found" return value for rule lookup") changed fib_rules_lookup() to use -ESRCH as a "not found" code internally, but for user space it should be translated into -ENETUNREACH. Handle the translation centrally in ipv4-specific fib_lookup(), leaving the DECnet case alone. On a related note, commit b7a71b51ee37d919e4098cd961d59a883fd272d8 ("ipv4: removed redundant conditional") removed a similar translation from ip_route_input_slow() prematurely AIUI. Fixes: b7a71b51ee37 ("ipv4: removed redundant conditional") Signed-off-by: Panu Matilainen <pmatilai@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14ipv4: dst_entry leak in ip_send_unicast_reply()Vasily Averin
[ Upstream commit 4062090e3e5caaf55bed4523a69f26c3265cc1d2 ] ip_setup_cork() called inside ip_append_data() steals dst entry from rt to cork and in case errors in __ip_append_data() nobody frees stolen dst entry Fixes: 2e77d89b2fa8 ("net: avoid a pair of dst_hold()/dst_release() in ip_append_data()") Signed-off-by: Vasily Averin <vvs@parallels.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14gre: Use inner mac length when computing tunnel lengthTom Herbert
[ Upstream commit 14051f0452a2c26a3f4791e6ad6a435e8f1945ff ] Currently, skb_inner_network_header is used but this does not account for Ethernet header for ETH_P_TEB. Use skb_inner_mac_header which handles TEB and also should work with IP encapsulation in which case inner mac and inner network headers are the same. Tested: Ran TCP_STREAM over GRE, worked as expected. Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14tcp: md5: do not use alloc_percpu()Eric Dumazet
[ Upstream commit 349ce993ac706869d553a1816426d3a4bfda02b1 ] percpu tcp_md5sig_pool contains memory blobs that ultimately go through sg_set_buf(). -> sg_set_page(sg, virt_to_page(buf), buflen, offset_in_page(buf)); This requires that whole area is in a physically contiguous portion of memory. And that @buf is not backed by vmalloc(). Given that alloc_percpu() can use vmalloc() areas, this does not fit the requirements. Replace alloc_percpu() by a static DEFINE_PER_CPU() as tcp_md5sig_pool is small anyway, there is no gain to dynamically allocate it. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 765cf9976e93 ("tcp: md5: remove one indirection level in tcp_md5sig_pool") Reported-by: Crestez Dan Leonard <cdleonard@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14ipv4: fix a potential use after free in ip_tunnel_core.cLi RongQing
[ Upstream commit 1245dfc8cadb258386fcd27df38215a0eccb1f17 ] pskb_may_pull() maybe change skb->data and make eth pointer oboslete, so set eth after pskb_may_pull() Fixes:3d7b46cd("ip_tunnel: push generic protocol handling to ip_tunnel module") Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14ipv4: fix nexthop attlen check in fib_nh_matchJiri Pirko
[ Upstream commit f76936d07c4eeb36d8dbb64ebd30ab46ff85d9f7 ] fib_nh_match does not match nexthops correctly. Example: ip route add 172.16.10/24 nexthop via 192.168.122.12 dev eth0 \ nexthop via 192.168.122.13 dev eth0 ip route del 172.16.10/24 nexthop via 192.168.122.14 dev eth0 \ nexthop via 192.168.122.15 dev eth0 Del command is successful and route is removed. After this patch applied, the route is correctly matched and result is: RTNETLINK answers: No such process Please consider this for stable trees as well. Fixes: 4e902c57417c4 ("[IPv4]: FIB configuration using struct fib_config") Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: fixing TLP's FIN recoveryPer Hurtig
[ Upstream commit bef1909ee3ed1ca39231b260a8d3b4544ecd0c8f ] Fix to a problem observed when losing a FIN segment that does not contain data. In such situations, TLP is unable to recover from *any* tail loss and instead adds at least PTO ms to the retransmission process, i.e., RTO = RTO + PTO. Signed-off-by: Per Hurtig <per.hurtig@kau.se> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Nandita Dukkipati <nanditad@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15xfrm: Generate blackhole routes only from route lookup functionsSteffen Klassert
[ Upstream commit f92ee61982d6da15a9e49664ecd6405a15a2ee56 ] Currently we genarate a blackhole route route whenever we have matching policies but can not resolve the states. Here we assume that dst_output() is called to kill the balckholed packets. Unfortunately this assumption is not true in all cases, so it is possible that these packets leave the system unwanted. We fix this by generating blackhole routes only from the route lookup functions, here we can guarantee a call to dst_output() afterwards. Fixes: 2774c131b1d ("xfrm: Handle blackhole route creation via afinfo.") Reported-by: Konstantinos Kolelis <k.kolelis@sirrix.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: fix ssthresh and undo for consecutive short FRTO episodesNeal Cardwell
[ Upstream commit 0c9ab09223fe9922baeb22546c9a90d774a4bde6 ] Fix TCP FRTO logic so that it always notices when snd_una advances, indicating that any RTO after that point will be a new and distinct loss episode. Previously there was a very specific sequence that could cause FRTO to fail to notice a new loss episode had started: (1) RTO timer fires, enter FRTO and retransmit packet 1 in write queue (2) receiver ACKs packet 1 (3) FRTO sends 2 more packets (4) RTO timer fires again (should start a new loss episode) The problem was in step (3) above, where tcp_process_loss() returned early (in the spot marked "Step 2.b"), so that it never got to the logic to clear icsk_retransmits. Thus icsk_retransmits stayed non-zero. Thus in step (4) tcp_enter_loss() would see the non-zero icsk_retransmits, decide that this RTO is not a new episode, and decide not to cut ssthresh and remember the current cwnd and ssthresh for undo. There were two main consequences to the bug that we have observed. First, ssthresh was not decreased in step (4). Second, when there was a series of such FRTO (1-4) sequences that happened to be followed by an FRTO undo, we would restore the cwnd and ssthresh from before the entire series started (instead of the cwnd and ssthresh from before the most recent RTO). This could result in cwnd and ssthresh being restored to values much bigger than the proper values. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: fix tcp_release_cb() to dispatch via address family for mtu_reduced()Neal Cardwell
[ Upstream commit 4fab9071950c2021d846e18351e0f46a1cffd67b ] Make sure we use the correct address-family-specific function for handling MTU reductions from within tcp_release_cb(). Previously AF_INET6 sockets were incorrectly always using the IPv6 code path when sometimes they were handling IPv4 traffic and thus had an IPv4 dst. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Diagnosed-by: Willem de Bruijn <willemb@google.com> Fixes: 563d34d057862 ("tcp: dont drop MTU reduction indications") Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15tcp: don't use timestamp from repaired skb-s to calculate RTT (v2)Andrey Vagin
[ Upstream commit 9d186cac7ffb1831e9f34cb4a3a8b22abb9dd9d4 ] We don't know right timestamp for repaired skb-s. Wrong RTT estimations isn't good, because some congestion modules heavily depends on it. This patch adds the TCPCB_REPAIRED flag, which is included in TCPCB_RETRANS. Thanks to Eric for the advice how to fix this issue. This patch fixes the warning: [ 879.562947] WARNING: CPU: 0 PID: 2825 at net/ipv4/tcp_input.c:3078 tcp_ack+0x11f5/0x1380() [ 879.567253] CPU: 0 PID: 2825 Comm: socket-tcpbuf-l Not tainted 3.16.0-next-20140811 #1 [ 879.567829] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 879.568177] 0000000000000000 00000000c532680c ffff880039643d00 ffffffff817aa2d2 [ 879.568776] 0000000000000000 ffff880039643d38 ffffffff8109afbd ffff880039d6ba80 [ 879.569386] ffff88003a449800 000000002983d6bd 0000000000000000 000000002983d6bc [ 879.569982] Call Trace: [ 879.570264] [<ffffffff817aa2d2>] dump_stack+0x4d/0x66 [ 879.570599] [<ffffffff8109afbd>] warn_slowpath_common+0x7d/0xa0 [ 879.570935] [<ffffffff8109b0ea>] warn_slowpath_null+0x1a/0x20 [ 879.571292] [<ffffffff816d0a05>] tcp_ack+0x11f5/0x1380 [ 879.571614] [<ffffffff816d10bd>] tcp_rcv_established+0x1ed/0x710 [ 879.571958] [<ffffffff816dc9da>] tcp_v4_do_rcv+0x10a/0x370 [ 879.572315] [<ffffffff81657459>] release_sock+0x89/0x1d0 [ 879.572642] [<ffffffff816c81a0>] do_tcp_setsockopt.isra.36+0x120/0x860 [ 879.573000] [<ffffffff8110a52e>] ? rcu_read_lock_held+0x6e/0x80 [ 879.573352] [<ffffffff816c8912>] tcp_setsockopt+0x32/0x40 [ 879.573678] [<ffffffff81654ac4>] sock_common_setsockopt+0x14/0x20 [ 879.574031] [<ffffffff816537b0>] SyS_setsockopt+0x80/0xf0 [ 879.574393] [<ffffffff817b40a9>] system_call_fastpath+0x16/0x1b [ 879.574730] ---[ end trace a17cbc38eb8c5c00 ]--- v2: moving setting of skb->when for repaired skb-s in tcp_write_xmit, where it's set for other skb-s. Fixes: 431a91242d8d ("tcp: timestamp SYN+DATA messages") Fixes: 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution") Cc: Eric Dumazet <edumazet@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-14tcp: Fix integer-overflow in TCP vegasChristoph Paasch
[ Upstream commit 1f74e613ded11517db90b2bd57e9464d9e0fb161 ] In vegas we do a multiplication of the cwnd and the rtt. This may overflow and thus their result is stored in a u64. However, we first need to cast the cwnd so that actually 64-bit arithmetic is done. Then, we need to do do_div to allow this to be used on 32-bit arches. Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Neal Cardwell <ncardwell@google.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Laight <David.Laight@ACULAB.COM> Cc: Doug Leith <doug.leith@nuim.ie> Fixes: 8d3a564da34e (tcp: tcp_vegas cong avoid fix) Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-14tcp: Fix integer-overflows in TCP venoChristoph Paasch
[ Upstream commit 45a07695bc64b3ab5d6d2215f9677e5b8c05a7d0 ] In veno we do a multiplication of the cwnd and the rtt. This may overflow and thus their result is stored in a u64. However, we first need to cast the cwnd so that actually 64-bit arithmetic is done. A first attempt at fixing 76f1017757aa0 ([TCP]: TCP Veno congestion control) was made by 159131149c2 (tcp: Overflow bug in Vegas), but it failed to add the required cast in tcp_veno_cong_avoid(). Fixes: 76f1017757aa0 ([TCP]: TCP Veno congestion control) Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-14ip_tunnel(ipv4): fix tunnels with "local any remote $remote_ip"Dmitry Popov
[ Upstream commit 95cb5745983c222867cc9ac593aebb2ad67d72c0 ] Ipv4 tunnels created with "local any remote $ip" didn't work properly since 7d442fab0 (ipv4: Cache dst in tunnels). 99% of packets sent via those tunnels had src addr = 0.0.0.0. That was because only dst_entry was cached, although fl4.saddr has to be cached too. Every time ip_tunnel_xmit used cached dst_entry (tunnel_rtable_get returned non-NULL), fl4.saddr was initialized with tnl_params->saddr (= 0 in our case), and wasn't changed until iptunnel_xmit(). This patch adds saddr to ip_tunnel->dst_cache, fixing this issue. Reported-by: Sergey Popov <pinkbyte@gentoo.org> Signed-off-by: Dmitry Popov <ixaphire@qrator.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
