In order to perform a proper universal hash on a vector of integers,
we have to use different universal hashes on each vector element.
Which means we need 4 different hash randoms for ipv6.
Using /proc/net/nf_conntrack has been deprecated in favour of the
conntrack(8) tool.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Prepare the ECN match for augmentation by an IPv6 counterpart. Since
no symbol dependencies to ipv6.ko are added, having a single ecn match
module is the more so welcome.
net/bluetooth/l2cap_core.c
Just two overlapping changes, one added an initialization of
a local variable, and another change added a new local variable.
The NAT range to nlattr conversation callbacks and helpers are entirely
dead code and are also useless since there are no NAT ranges in conntrack
context, they are only used for initially selecting a tuple. The final NAT
information is contained in the selected tuples of the conntrack entry.
The packet size check originates from a time when UDP helpers could
accidentally mangle incorrect packets (NEWNAT) and is unnecessary
nowadays since the conntrack helpers invoke the NAT helpers for the
proper packet directly.
The inner tuple that is extracted from the packet is unused. The code also
doesn't have any useful side-effects like verifying the packet does contain
enough data to extract the inner tuple since conntrack already does the
same, so remove it.
The only remaining user of NAT protocol module reference counting is NAT
ctnetlink support. Since this is a fairly short sequence of code, convert
over to use RCU and remove module reference counting.
Module unregistration is already protected by RCU using synchronize_rcu(),
so no further changes are necessary.
Use nf_conntrack_hash_rnd in NAT bysource hash to avoid hash chain attacks.
Export the NAT definitions to userspace. So far userspace (specifically,
iptables) has been copying the headers files from include/net. Also
rename some structures and definitions in preparation for IPv6 NAT.
Since these have never been officially exported, this doesn't affect
existing userspace code.
Chris Boot reported crashes occurring in ipv6_select_ident().
[ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>]
ipv6_select_ident+0x31/0xa7
[ 461.578229] Call Trace:
[ 461.580742] <IRQ>
[ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2
[ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155
[ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b
[ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e
[nf_conntrack_ipv6]
[ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543
[ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a
[bridge]
[ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459
[ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76
[bridge]
[ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f
[bridge]
[ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.677299] [<ffffffffa0379215>] ?
nf_bridge_update_protocol+0x20/0x20 [bridge]
[ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack]
[ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56
[bridge]
[ 461.704616] [<ffffffffa0379031>] ?
nf_bridge_push_encap_header+0x1c/0x26 [bridge]
[ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95
[bridge]
[ 461.719490] [<ffffffffa037900a>] ?
nf_bridge_pull_encap_header+0x1c/0x27 [bridge]
[ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge]
[ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56
[bridge]
This is caused by bridge netfilter special dst_entry (fake_rtable), a
special shared entry, where attaching an inetpeer makes no sense.
Problem is present since commit 87c48fa3b46 (ipv6: make fragment
identifications less predictable)
Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and
__ip_select_ident() fallback to the 'no peer attached' handling.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Acked-by: David Miller <davem@davemloft.net>
Commit 2c8cec5c10b (ipv4: Cache learned PMTU information in inetpeer)
removed IP route cache garbage collector a bit too soon, as this gc was
responsible for expired routes cleanup, releasing their neighbour
reference.
As pointed out by Robert Gladewitz, recent kernels can fill and exhaust
their neighbour cache.
Reintroduce the garbage collection, since we'll have to wait our
neighbour lookups become refcount-less to not depend on this stuff.
Reported-by: Robert Gladewitz <gladewitz@gmx.de>
to record the state of SACK/FACK and DSACK for better readability and maintenance.
Signed-off-by: Vijay Subramanian <subramanian.vijay@gmail.com>
previous commit 3fb72f1e6e6165c5f495e8dc11c5bbd14c73385c
makes IP-Config wait for carrier on at least one network device.
Before waiting (predefined value 120s), check that at least one device
was successfully brought up. Otherwise (e.g. buggy bootloader
which does not set the MAC address) there is no point in waiting
for carrier.
Cc: Micha Nelissen <micha@neli.hopto.org>
Cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
(Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false).
Cc: netdev@vger.kernel.org
DaveM said:
Please, this kind of stuff rots forever and not using bool properly
drives me crazy.
Joe Perches <joe@perches.com> gave me the spatch script:
bool b;
-b = 0
+b = false
bool b;
-b = 1
+b = true
I merely installed coccinelle, read the documentation and took credit.
The sk address is used as a cookie between dump/get_exact calls.
It will be required for unix socket sdumping, so move it from
inet_diag to sock_diag.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
I've made a mistake when fixing the sock_/inet_diag aliases :(
1. The sock_diag layer should request the family-based alias,
not just the IPPROTO_IP one;
2. The inet_diag layer should request for AF_INET+protocol alias,
not just the protocol one.
Thus fix this.
drivers/net/ethernet/freescale/fsl_pq_mdio.c
net/batman-adv/translation-table.c
net/ipv6/route.c
We should only dereference the pointer if it's valid, not the other way
round.
net/ipv4/sysctl_net_ipv4.c:78:6: warning: symbol 'inet_get_ping_group_range_table'
was not declared. Should it be static?
net/ipv4/sysctl_net_ipv4.c:119:31: warning: incorrect type in argument 2
(different signedness)
net/ipv4/sysctl_net_ipv4.c:119:31: expected int *range
net/ipv4/sysctl_net_ipv4.c:119:31: got unsigned int *<noident>
This patch introduces kmem.tcp.max_usage_in_bytes file, living in the
kmem_cgroup filesystem. The root cgroup will display a value equal
to RESOURCE_MAX. This is to avoid introducing any locking schemes in
the network paths when cgroups are not being actively used.
All others, will see the maximum memory ever used by this cgroup.
Signed-off-by: Glauber Costa <glommer@parallels.com>
Reviewed-by: Hiroyouki Kamezawa <kamezawa.hiroyu@jp.fujitsu.com>
CC: David S. Miller <davem@davemloft.net>
CC: Eric W. Biederman <ebiederm@xmission.com>
This patch introduces kmem.tcp.failcnt file, living in the
kmem_cgroup filesystem. Following the pattern in the other
memcg resources, this files keeps a counter of how many times
allocation failed due to limits being hit in this cgroup.
The root cgroup will always show a failcnt of 0.
This patch introduces kmem.tcp.usage_in_bytes file, living in the
kmem_cgroup filesystem. It is a simple read-only file that displays the
amount of kernel memory currently consumed by the cgroup.
This patch uses the "tcp.limit_in_bytes" field of the kmem_cgroup to
effectively control the amount of kernel memory pinned by a cgroup.
This value is ignored in the root cgroup, and in all others,
caps the value specified by the admin in the net namespaces'
view of tcp_sysctl_mem.
If namespaces are being used, the admin is allowed to set a
value bigger than cgroup's maximum, the same way it is allowed
to set pretty much unlimited values in a real box.
This patch allows each namespace to independently set up
its levels for tcp memory pressure thresholds. This patch
alone does not buy much: we need to make this values
per group of process somehow. This is achieved in the
patches that follows in this patchset.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
This patch introduces memory pressure controls for the tcp
protocol. It uses the generic socket memory pressure code
introduced in earlier patches, and fills in the
necessary data in cg_proto struct.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com>
This patch replaces all uses of struct sock fields' memory_pressure,
memory_allocated, sockets_allocated, and sysctl_mem to acessor
macros. Those macros can either receive a socket argument, or a mem_cgroup
argument, depending on the context they live in.
Since we're only doing a macro wrapping here, no performance impact at all is
expected in the case where we don't have cgroups disabled.
CC: Eric Dumazet <eric.dumazet@gmail.com>
Same fix as 731abb9cb2 for ipip and sit tunnel.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in
ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice
will now create a valid name, however the tunnel keeps a copy of the
name in the private parms structure. Fix this by copying the name back
after register_netdevice has successfully returned.
This shows up if you do a simple tunnel add, followed by a tunnel show:
$ sudo ip tunnel add mode ipip remote 10.2.20.211
$ ip tunnel
tunl0: ip/ip remote any local any ttl inherit nopmtudisc
tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit
$ sudo ip tunnel add mode sit remote 10.2.20.212
$ ip tunnel
sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16
sit%d: ioctl 89f8 failed: No such device
sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit
Cc: stable@vger.kernel.org
Signed-off-by: Ted Feng <artisdom@gmail.com>
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE)
Wrap the udp6 lookup into the proper ifdef-s.
Eric Dumazet reported, that when inet_diag is built-in the udp_diag also goes
built-in and when ipv6 is a module the udp6 lookup symbol is not found.
LD .tmp_vmlinux1
net/built-in.o: In function `udp_dump_one':
udp_diag.c:(.text+0xa2b40): undefined reference to `__udp6_lib_lookup'
make: *** [.tmp_vmlinux1] Erreur 1
Fix this by making udp diag build mode depend on both -- inet diag and ipv6.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Copy-s/tcp/udp/-paste from TCP bits.
Do the same as TCP does -- iterate the given udp_table, filter
sockets with bytecode and dump sockets into reply message.
The same filtering as for TCP applies, though only some of the
state bits really matter.
Do the same as TCP does -- lookup a socket in the given udp_table,
check cookie, fill the reply message with existing inet socket dumping
helper and send one back.
Introduce the transport level diag handler module for UDP (and UDP-lite)
sockets and register (empty for now) callbacks in the inet_diag module.
The UDP diag get_exact handler will require them to find a
socket by provided net, [sd]addr-s, [sd]ports and device.
Introduce two callbacks in inet_diag_handler -- one for dumping all
sockets (with filters) and the other one for dumping a single sk.
Replace direct calls to icsk handlers with indirect calls to callbacks
provided by handlers.
Make existing TCP and DCCP handlers use provided helpers for icsk-s.
The UDP diag module will provide its own.
The existing inet_csk_diag_fill dumps the inet connection sock info
into the netlink inet_diag_message. Prepare this routine to be able
to dump only the inet_sock part of a socket if the icsk part is missing.
This will be used by UDP diag module when dumping UDP sockets.
The upcoming UDP module will require exactly this ability, so just
move the existing code to provide one.
Similar to previous patch: the 1st part locks the inet handler
and will get generalized and the 2nd one dumps icsk-s and will
be used by TCP and DCCP handlers.
The 1st part locks the inet handler and the 2nd one dump the
inet connection sock.
In the next patches the 1st part will be generalized to call
the socket dumping routine indirectly (i.e. TCP/UDP/DCCP) and
the 2nd part will be used by TCP and DCCP handlers.
The netlink diag susbsys stores sk address bits in the nl message
as a "cookie" and uses one when dumps details about particular
socket.
The same will be required for udp diag module, so introduce a heler
in inet_diag module
There's an info_size value stored on inet_diag_handler, but for existing
code this value is effectively constant, so just use sizeof(struct tcp_info)
where required.
This patch moves the sock_ code from inet_diag.c to generic sock_diag.c
file and provides necessary request_module-s calls and a pointer on
inet_diag_compat dumping routine.
