path: root/net/ipv4
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-15[TCP]: Fix up sysctl_tcp_mem initialization.John Heffner
Fix up tcp_mem initial settings to take into account the size of the hash entries (different on SMP and non-SMP systems). Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-15[NETFILTER]: Use pskb_trim in {ip,ip6,nfnetlink}_queuePatrick McHardy
Based on patch by James D. Nurmi: I've got some code very dependant on nfnetlink_queue, and turned up a large number of warns coming from skb_trim. While it's quite possibly my code, having not seen it on older kernels made me a bit suspect. Anyhow, based on some googling I turned up this thread: http://lkml.org/lkml/2006/8/13/56 And believe the issue to be related, so attached is a small patch to the kernel -- not sure if this is completely correct, but for anyone else hitting the WARN_ON(1) in skbuff.h, it might be helpful.. Signed-off-by: James D. Nurmi <jdnurmi@gmail.com> Ported to ip6_queue and nfnetlink_queue and added return value checks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-10[IPVS]: More endianness fixed.Julian Anastasov
- make sure port in FTP data is in network order (in fact it was looking buggy for big endian boxes before Viro's changes) - htonl -> htons for port Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-07[TCP]: Don't use highmem in tcp hash size calculation.John Heffner
This patch removes consideration of high memory when determining TCP hash table sizes. Taking into account high memory results in tcp_mem values that are too large. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-01[TCP]: Set default congestion control when no sysctl.Stephen Hemminger
The setting of the default congestion control was buried in the sysctl code so it would not be done properly if SYSCTL was not enabled. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-30[NetLabel]: protect the CIPSOv4 socket option from setsockopt()Paul Moore
This patch makes two changes to protect applications from either removing or tampering with the CIPSOv4 IP option on a socket. The first is the requirement that applications have the CAP_NET_RAW capability to set an IPOPT_CIPSO option on a socket; this prevents untrusted applications from setting their own CIPSOv4 security attributes on the packets they send. The second change is to SELinux and it prevents applications from setting any IPv4 options when there is an IPOPT_CIPSO option already present on the socket; this prevents applications from removing CIPSOv4 security attributes from the packets they send. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-30[NETFILTER]: ip_tables: compat code module refcounting fixDmitry Mishin
This patch fixes bug in iptables modules refcounting on compat error way. As we are getting modules in check_compat_entry_size_and_hooks(), in case of later error, we should put them all in translate_compat_table(), not in the compat_copy_entry_from_user() or compat_copy_match_from_user(), as it is now. Signed-off-by: Dmitry Mishin <dim@openvz.org> Acked-by: Vasily Averin <vvs@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-30[NETFILTER]: ip_tables: compat error way cleanupVasily Averin
This patch adds forgotten compat_flush_offset() call to error way of translate_compat_table(). May lead to table corruption on the next compat_do_replace(). Signed-off-by: Vasily Averin <vvs@openvz.org> Acked-by: Dmitry Mishin <dim@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-30[NETFILTER]: Missed and reordered checks in {arp,ip,ip6}_tablesDmitry Mishin
There is a number of issues in parsing user-provided table in translate_table(). Malicious user with CAP_NET_ADMIN may crash system by passing special-crafted table to the *_tables. The first issue is that mark_source_chains() function is called before entry content checks. In case of standard target, mark_source_chains() function uses t->verdict field in order to determine new position. But the check, that this field leads no further, than the table end, is in check_entry(), which is called later, than mark_source_chains(). The second issue, that there is no check that target_offset points inside entry. If so, *_ITERATE_MATCH macro will follow further, than the entry ends. As a result, we'll have oops or memory disclosure. And the third issue, that there is no check that the target is completely inside entry. Results are the same, as in previous issue. Signed-off-by: Dmitry Mishin <dim@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-30[NET]: fix uaccess handlingHeiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-25[TCP] H-TCP: fix integer overflowGavin McCullagh
When using H-TCP with a single flow on a 500Mbit connection (or less actually), alpha can exceed 65000, so alpha needs to be a u32. Signed-off-by: Gavin McCullagh <gavin.mccullagh@nuim.ie> Signed-off-by: Doug Leith <doug.leith@nuim.ie> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-25[TCP] cubic: scaling errorStephen Hemminger
Doug Leith observed a discrepancy between the version of CUBIC described in the papers and the version in 2.6.18. A math error related to scaling causes Cubic to grow too slowly. Patch is from "Sangtae Ha" <sha2@ncsu.edu>. I validated that it does fix the problems. See the following to show behavior over 500ms 100 Mbit link. Sender (2.6.19-rc3) --- Bridge (2.6.18-rt7) ------- Receiver (2.6.19-rc3) 1G [netem] 100M http://developer.osdl.org/shemminger/tcp/2.6.19-rc3/cubic-orig.png http://developer.osdl.org/shemminger/tcp/2.6.19-rc3/cubic-fix.png Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-24[IPV4] ipconfig: fix RARP ic_servaddr breakageAl Viro
memcpy 4 bytes to address of auto unsigned long variable followed by comparison with u32 is a bloody bad idea. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-20[TCP]: One NET_INC_STATS() could be NET_INC_STATS_BH in tcp_v4_err()Eric Dumazet
I believe this NET_INC_STATS() call can be replaced by NET_INC_STATS_BH(), a little bit cheaper. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-20[NETFILTER]: Missing check for CAP_NET_ADMIN in iptables compat layerBjörn Steinbrink
The 32bit compatibility layer has no CAP_NET_ADMIN check in compat_do_ipt_get_ctl, which for example allows to list the current iptables rules even without having that capability (the non-compat version requires it). Other capabilities might be required to exploit the bug (eg. CAP_NET_RAW to get the nfnetlink socket?), so a plain user can't exploit it, but a setup actually using the posix capability system might very well hit such a constellation of granted capabilities. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[TCP]: Bound TSO defer timeJohn Heffner
This patch limits the amount of time you will defer sending a TSO segment to less than two clock ticks, or the time between two acks, whichever is longer. On slow links, deferring causes significant bursts. See attached plots, which show RTT through a 1 Mbps link with a 100 ms RTT and ~100 ms queue for (a) non-TSO, (b) currnet TSO, and (c) patched TSO. This burstiness causes significant jitter, tends to overflow queues early (bad for short queues), and makes delay-based congestion control more difficult. Deferring by a couple clock ticks I believe will have a relatively small impact on performance. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[IPv4] fib: Remove unused fib_config membersThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15[NET]: reduce sizeof(struct inet_peer), cleanup, change in peer_check_expire()Eric Dumazet
1) shrink struct inet_peer on 64 bits platforms.
2006-10-15NetLabel: the CIPSOv4 passthrough mapping does not pass categories correctlyPaul Moore
The CIPSO passthrough mapping had a problem when sending categories which would cause no or incorrect categories to be sent on the wire with a packet. This patch fixes the problem which was a simple off-by-one bug. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-15NetLabel: only deref the CIPSOv4 standard map fields when using standard mappingPaul Moore
Fix several places in the CIPSO code where it was dereferencing fields which did not have valid pointers by moving those pointer dereferences into code blocks where the pointers are valid. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-15[NETFILTER]: ctnetlink: Remove debugging messagesPablo Neira Ayuso
Remove (compilation-breaking) debugging messages introduced at early development stage. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15[NETFILTER]: ipt_ECN/ipt_TOS: fix incorrect checksum updatePatrick McHardy
Even though the tos field is only a single byte large, the values need to be converted to net-endian for the checkum update so they are in the corrent byte position. Also fix incorrect endian annotations. Reported by Stephane Chazelas <Stephane_Chazelas@yahoo.fr> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15[NETFILTER]: arp_tables: missing unregistration on module unloadPatrick McHardy
2006-10-12[NET]: Do not memcmp() over pad bytes of struct flowi.David S. Miller
They are not necessarily initialized to zero by the compiler, for example when using run-time initializers of automatic on-stack variables. Noticed by Eric Dumazet and Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[NET]: Use typesafe inet_twsk() inline function instead of cast.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[NET]: Use hton{l,s}() for non-initializers.YOSHIFUJI Hideaki
2006-10-11[TCP]: Use TCPOLEN_TSTAMP_ALIGNED macro instead of magic number.YOSHIFUJI Hideaki
2006-10-11IPsec: correct semantics for SELinux policy matchingVenkat Yekkirala
Currently when an IPSec policy rule doesn't specify a security context, it is assumed to be "unlabeled" by SELinux, and so the IPSec policy rule fails to match to a flow that it would otherwise match to, unless one has explicitly added an SELinux policy rule allowing the flow to "polmatch" to the "unlabeled" IPSec policy rules. In the absence of such an explicitly added SELinux policy rule, the IPSec policy rule fails to match and so the packet(s) flow in clear text without the otherwise applicable xfrm(s) applied. The above SELinux behavior violates the SELinux security notion of "deny by default" which should actually translate to "encrypt by default" in the above case. This was first reported by Evgeniy Polyakov and the way James Morris was seeing the problem was when connecting via IPsec to a confined service on an SELinux box (vsftpd), which did not have the appropriate SELinux policy permissions to send packets via IPsec. With this patch applied, SELinux "polmatching" of flows Vs. IPSec policy rules will only come into play when there's a explicit context specified for the IPSec policy rule (which also means there's corresponding SELinux policy allowing appropriate domains/flows to polmatch to this context). Secondly, when a security module is loaded (in this case, SELinux), the security_xfrm_policy_lookup() hook can return errors other than access denied, such as -EINVAL. We were not handling that correctly, and in fact inverting the return logic and propagating a false "ok" back up to xfrm_lookup(), which then allowed packets to pass as if they were not associated with an xfrm policy. The solution for this is to first ensure that errno values are correctly propagated all the way back up through the various call chains from security_xfrm_policy_lookup(), and handled correctly. Then, flow_cache_lookup() is modified, so that if the policy resolver fails (typically a permission denied via the security module), the flow cache entry is killed rather than having a null policy assigned (which indicates that the packet can pass freely). This also forces any future lookups for the same flow to consult the security module (e.g. SELinux) for current security policy (rather than, say, caching the error on the flow cache entry). This patch: Fix the selinux side of things. This makes sure SELinux polmatching of flow contexts to IPSec policy rules comes into play only when an explicit context is associated with the IPSec policy rule. Also, this no longer defaults the context of a socket policy to the context of the socket since the "no explicit context" case is now handled properly. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-11NetLabel: fix a cache race conditionpaul.moore@hp.com
Testing revealed a problem with the NetLabel cache where a cached entry could be freed while in use by the LSM layer causing an oops and other problems. This patch fixes that problem by introducing a reference counter to the cache entry so that it is only freed when it is no longer in use. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-10[PATCH] ptrdiff_t is %t, not %zAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[TCP]: Kill warning in tcp_clean_rtx_queue().David S. Miller
GCC can't tell we always initialize 'tv' in all the cases we actually use it, so explicitly set it up with zeros. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[UDP]: Fix MSG_PROBE crashHerbert Xu
UDP tracks corking status through the pending variable. The IP layer also tracks it through the socket write queue. It is possible for the two to get out of sync when MSG_PROBE is used. This patch changes UDP to check the write queue to ensure that the two stay in sync. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[NETFILTER]: ipt_REJECT: remove largely duplicate route_reverse functionPatrick McHardy
Use ip_route_me_harder instead, which now allows to specify how we wish the packet to be routed. Based on patch by Simon Horman <horms@verge.net.au>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[NETFILTER]: Honour source routing for LVS-NATSimon Horman
For policy routing, packets originating from this machine itself may be routed differently to packets passing through. We want this packet to be routed as if it came from this machine itself. So re-compute the routing information using ip_route_me_harder(). This patch is derived from work by Ken Brownfield Cc: Ken Brownfield <krb@irridia.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[NETFILTER]: add type parameter to ip_route_me_harderSimon Horman
By adding a type parameter to ip_route_me_harder() the expensive call to inet_addr_type() can be avoided in some cases. A followup patch where ip_route_me_harder() is called from within ip_vs_out() is one such example. Signed-off-By: Simon Horman <horms@verge.net.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Still more typo fixesMatt LaPlante
2006-10-03more misc typo fixesMatt LaPlante
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: switch to using uts namespacesSerge E. Hallyn
Replace references to system_utsname to the per-process uts namespace where appropriate. This includes things like uname. Changes: Per Eric Biederman's comments, use the per-process uts namespace for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c [jdike@addtoit.com: UML fix] [clg@fr.ibm.com: cleanup] [akpm@osdl.org: build fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Kprobes: Make kprobe modules more portableAnanth N Mavinakayanahalli
In an effort to make kprobe modules more portable, here is a patch that: o Introduces the "symbol_name" field to struct kprobe. The symbol->address resolution now happens in the kernel in an architecture agnostic manner. 64-bit powerpc users no longer have to specify the ".symbols" o Introduces the "offset" field to struct kprobe to allow a user to specify an offset into a symbol. o The legacy mechanism of specifying the kprobe.addr is still supported. However, if both the kprobe.addr and kprobe.symbol_name are specified, probe registration fails with an -EINVAL. o The symbol resolution code uses kallsyms_lookup_name(). So CONFIG_KPROBES now depends on CONFIG_KALLSYMS o Apparantly kprobe modules were the only legitimate out-of-tree user of the kallsyms_lookup_name() EXPORT. Now that the symbol resolution happens in-kernel, remove the EXPORT as suggested by Christoph Hellwig o Modify tcp_probe.c that uses the kprobe interface so as to make it work on multiple platforms (in its earlier form, the code wouldn't work, say, on powerpc) Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[NetLabel]: audit fixups due to delayed feedbackPaul Moore
Fix some issues Steve Grubb had with the way NetLabel was using the audit subsystem. This should make NetLabel more consistent with other kernel generated audit messages specifying configuration changes. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NetLabel]: add audit support for configuration changesPaul Moore
This patch adds audit support to NetLabel, including six new audit message types shown below. #define AUDIT_MAC_UNLBL_ACCEPT 1406 #define AUDIT_MAC_UNLBL_DENY 1407 #define AUDIT_MAC_CIPSOV4_ADD 1408 #define AUDIT_MAC_CIPSOV4_DEL 1409 #define AUDIT_MAC_MAP_ADD 1410 #define AUDIT_MAC_MAP_DEL 1411 Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[TCP]: Fix and simplify microsecond rtt samplingJohn Heffner
This changes the microsecond RTT sampling so that samples are taken in the same way that RTT samples are taken for the RTO calculator: on the last segment acknowledged, and only when the segment hasn't been retransmitted. Signed-off-by: John Heffner <jheffner@psc.edu> Acked-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[TCP] tcp-lp: prevent chance for oopsWong Hoi Sing Edison
This patch fix the chance for tcp_lp_remote_hz_estimator return 0, if 0 < rhz < 64. It also make sure the flag LP_VALID_RHZ is set correctly. Signed-off-by: Wong Hoi Sing Edison <hswong3i@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPVS] bug: endianness breakage in ip_vs_ftpAl Viro
(p[3]<<24) | (p[2]<<16) | (p[1]<<8) | p[0] is not a valid way to spell get_unaligned((__be32 *)p Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
