path: root/net/ipv4/xfrm4_input.c
2007-02-13[IPSEC]: Changing API of xfrm4_tunnel_register.Kazunori MIYAZAWA
This patch changes xfrm4_tunnel register and deregister interface to prepare for solving the conflict of device tunnels with inter address family IPsec tunnel. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[XFRM]: xfrm_parse_spi() annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[INET]: Move no-tunnel ICMP error to tunnel4/tunnel6Herbert Xu
This patch moves the sending of ICMP messages when there are no IPv4/IPv6 tunnels present to tunnel4/tunnel6 respectively. Please note that for now if xfrm4_tunnel/xfrm6_tunnel is loaded then no ICMP messages will ever be sent. This is similar to how we handle AH/ESP/IPCOMP. This move fixes the bug where we always send an ICMP message when there is no ip6_tunnel device present for a given packet even if it is later handled by IPsec. It also causes ICMP messages to be sent when no IPIP tunnel is present. I've decided to use the "port unreachable" ICMP message over the current value of "address unreachable" (and "protocol unreachable" by GRE) because it is not ambiguous unlike the other ones which can be triggered by other conditions. There seems to be no standard specifying what value must be used so this change should be OK. In fact we should change GRE to use this value as well. Incidentally, this patch also fixes a fairly serious bug in xfrm6_tunnel where we don't check whether the embedded IPv6 header is present before dereferencing it for the inside source address. This patch is inspired by a previous patch by Hugo Santos <hsantos@av.it.pt>. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[IPSEC]: Check x->encap before dereferencing itHerbert Xu
We need to dereference x->encap before dereferencing it for encap_type. If it's absent then the encap_type is zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-01[IPSEC]: Kill unused decap state structureHerbert Xu
This patch removes the *_decap_state structures which were previously used to share state between input/post_input. This is no longer needed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-01[IPSEC]: Kill unused decap state argumentHerbert Xu
This patch removes the decap_state argument from the xfrm input hook. Previously this function allowed the input hook to share state with the post_input hook. The latter has since been removed. The only purpose for it now is to check the encap type. However, it is easier and better to move the encap type check to the generic xfrm_rcv function. This allows us to get rid of the decap state argument altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV4/6]: Netfilter IPsec input hooksPatrick McHardy
When the innermost transform uses transport mode the decapsulated packet is not visible to netfilter. Pass the packet through the PRE_ROUTING and LOCAL_IN hooks again before handing it to upper layer protocols to make netfilter-visibility symetrical to the output path. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
