path: root/net/ipv4/udp_diag.c
2012-04-25udp_diag: implement idiag_get_info for udp/udplite to get queue informationShan Wei
When we use netlink to monitor queue information for udp socket, idiag_rqueue and idiag_wqueue of inet_diag_msg are returned with 0. Keep consistent with netstat, just return back allocated rmem/wmem size. Signed-off-by: Shan Wei <davidshan@tencent.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17net: kill duplicate included headerShan Wei
For net part, remove duplicate included header. Signed-off-by: Shan Wei <davidshan@tencent.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-11inet_diag: Rename inet_diag_req into inet_diag_req_v2Pavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16sock_diag: Generalize requests cookies managementsPavel Emelyanov
The sk address is used as a cookie between dump/get_exact calls. It will be required for unix socket sdumping, so move it from inet_diag to sock_diag. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16sock_diag: Fix module netlink aliasesPavel Emelyanov
I've made a mistake when fixing the sock_/inet_diag aliases :( 1. The sock_diag layer should request the family-based alias, not just the IPPROTO_IP one; 2. The inet_diag layer should request for AF_INET+protocol alias, not just the protocol one. Thus fix this. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-10udp_diag: Fix the !ipv6 casePavel Emelyanov
Wrap the udp6 lookup into the proper ifdef-s. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-09udp_diag: Implement the dump-all functionalityPavel Emelyanov
Do the same as TCP does -- iterate the given udp_table, filter sockets with bytecode and dump sockets into reply message. The same filtering as for TCP applies, though only some of the state bits really matter. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-09udp_diag: Implement the get_exact dumping functionalityPavel Emelyanov
Do the same as TCP does -- lookup a socket in the given udp_table, check cookie, fill the reply message with existing inet socket dumping helper and send one back. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-09udp_diag: Basic skeletonPavel Emelyanov
Introduce the transport level diag handler module for UDP (and UDP-lite) sockets and register (empty for now) callbacks in the inet_diag module. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
