path: root/net/ipv4/tcp_vegas.c
2014-09-01tcp: whitespace fixesstephen hemminger
Fix places where there is space before tab, long lines, and awkward if(){, double spacing etc. Add blank line after declaration/initialization. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-30tcp: Fix integer-overflow in TCP vegasChristoph Paasch
In vegas we do a multiplication of the cwnd and the rtt. This may overflow and thus their result is stored in a u64. However, we first need to cast the cwnd so that actually 64-bit arithmetic is done. Then, we need to do do_div to allow this to be used on 32-bit arches. Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Neal Cardwell <ncardwell@google.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Laight <David.Laight@ACULAB.COM> Cc: Doug Leith <doug.leith@nuim.ie> Fixes: 8d3a564da34e (tcp: tcp_vegas cong avoid fix) Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-03tcp: remove in_flight parameter from cong_avoid() methodsEric Dumazet
Commit e114a710aa505 ("tcp: fix cwnd limited checking to improve congestion control") obsoleted in_flight parameter from tcp_is_cwnd_limited() and its callers. This patch does the removal as promised. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-26tcp: switch rtt estimations to usec resolutionEric Dumazet
Upcoming congestion controls for TCP require usec resolution for RTT estimations. Millisecond resolution is simply not enough these days. FQ/pacing in DC environments also require this change for finer control and removal of bimodal behavior due to the current hack in tcp_update_pacing_rate() for 'small rtt' TCP_CONG_RTT_STAMP is no longer needed. As Julian Anastasov pointed out, we need to keep user compatibility : tcp_metrics used to export RTT and RTTVAR in msec resolution, so we added RTT_US and RTTVAR_US. An iproute2 patch is needed to use the new attributes if provided by the kernel. In this example ss command displays a srtt of 32 usecs (10Gbit link) lpk51:~# ./ss -i dst lpk52 Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port tcp ESTAB 0 1 10.246.11.51:42959 10.246.11.52:64614 cubic wscale:6,6 rto:201 rtt:0.032/0.001 ato:40 mss:1448 cwnd:10 send 3620.0Mbps pacing_rate 7240.0Mbps unacked:1 rcv_rtt:993 rcv_space:29559 Updated iproute2 ip command displays : lpk51:~# ./ip tcp_metrics | grep 10.246.11.52 10.246.11.52 age 561.914sec cwnd 10 rtt 274us rttvar 213us source 10.246.11.51 Old binary displays : lpk51:~# ip tcp_metrics | grep 10.246.11.52 10.246.11.52 age 561.914sec cwnd 10 rtt 250us rttvar 125us source 10.246.11.51 With help from Julian Anastasov, Stephen Hemminger and Yuchung Cheng Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Yuchung Cheng <ycheng@google.com> Cc: Larry Brakmo <brakmo@google.com> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-13tcp: remove unused min_cwnd member of tcp_congestion_opsStanislav Fomichev
Commit 684bad110757 "tcp: use PRR to reduce cwin in CWR state" removed all calls to min_cwnd, so we can safely remove it. Also, remove tcp_reno_min_cwnd because it was only used for min_cwnd. Signed-off-by: Stanislav Fomichev <stfomichev@yandex-team.ru> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-04tcp: properly handle stretch acks in slow startYuchung Cheng
Slow start now increases cwnd by 1 if an ACK acknowledges some packets, regardless the number of packets. Consequently slow start performance is highly dependent on the degree of the stretch ACKs caused by receiver or network ACK compression mechanisms (e.g., delayed-ACK, GRO, etc). But slow start algorithm is to send twice the amount of packets of packets left so it should process a stretch ACK of degree N as if N ACKs of degree 1, then exits when cwnd exceeds ssthresh. A follow up patch will use the remainder of the N (if greater than 1) to adjust cwnd in the congestion avoidance phase. In addition this patch retires the experimental limited slow start (LSS) feature. LSS has multiple drawbacks but questionable benefit. The fractional cwnd increase in LSS requires a loop in slow start even though it's rarely used. Configuring such an increase step via a global sysctl on different BDPS seems hard. Finally and most importantly the slow start overshoot concern is now better covered by the Hybrid slow start (hystart) enabled by default. Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-10tcp: mark tcp_congestion_ops read_mostlyStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25tcp: tcp_vegas ssthresh bugfixDoug Leith
This patch fixes ssthresh accounting issues in tcp_vegas when cwnd decreases Signed-off-by: Doug Leith <doug.leith@nuim.ie> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09tcp: tcp_vegas cong avoid fix Doug Leith
This patch addresses a book-keeping issue in tcp_vegas.c. At present tcp_vegas does separate book-keeping of cwnd based on packet sequence numbers. A mismatch can develop between this book-keeping and tp->snd_cwnd due, for example, to delayed acks acking multiple packets. When vegas transitions to reno operation (e.g. following loss), then this mismatch leads to incorrect behaviour (akin to a cwnd backoff). This seems mostly to affect operation at low cwnds where delayed acking can lead to a significant fraction of cwnd being covered by a single ack, leading to the book-keeping mismatch. This patch modifies the congestion avoidance update to avoid the need for separate book-keeping while leaving vegas congestion avoidance functionally unchanged. A secondary advantage of this modification is that the use of fixed-point (via V_PARAM_SHIFT) and 64 bit arithmetic is no longer necessary, simplifying the code. Some example test measurements with the patched code (confirming no functional change in the congestion avoidance algorithm) can be seen at: http://www.hamilton.ie/doug/vegaspatch/ Signed-off-by: Doug Leith <doug.leith@nuim.ie> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04tcp: tcp_vegas ssthresh bug fixDoug Leith
This patch fixes a bug in tcp_vegas.c. At the moment this code leaves ssthresh untouched. However, this means that the vegas congestion control algorithm is effectively unable to reduce cwnd below the ssthresh value (if the vegas update lowers the cwnd below ssthresh, then slow start is activated to raise it back up). One example where this matters is when during slow start cwnd overshoots the link capacity and a flow then exits slow start with ssthresh set to a value above where congestion avoidance would like to adjust it. Signed-off-by: Doug Leith <doug.leith@nuim.ie> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-01net: fix returning void-valued expression warningsHarvey Harrison
drivers/net/8390.c:37:2: warning: returning void-valued expression drivers/net/bnx2.c:1635:3: warning: returning void-valued expression drivers/net/xen-netfront.c:1806:2: warning: returning void-valued expression net/ipv4/tcp_hybla.c:105:3: warning: returning void-valued expression net/ipv4/tcp_vegas.c:171:3: warning: returning void-valued expression net/ipv4/tcp_veno.c:123:3: warning: returning void-valued expression net/sysctl_net.c:85:2: warning: returning void-valued expression Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-30tcp: Overflow bug in VegasLachlan Andrew
From: Lachlan Andrew <lachlan.andrew@gmail.com> There is an overflow bug in net/ipv4/tcp_vegas.c for large BDPs (e.g. 400Mbit/s, 400ms). The multiplication (old_wnd * vegas->baseRTT) << V_PARAM_SHIFT overflows a u32. [ Fix tcp_veno.c too, it has similar calculations. -DaveM ] Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Cong.ctrl modules: remove unused good_ack from cong_avoidIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-29[TCP] vegas: Fix a bug in disabling slow start by gamma parameter.Xiaoliang (David) Wei
TCP Vegas implementation has a bug in the process of disabling slow-start with gamma parameter. The bug may lead to extreme unfairness in the presence of early packet loss. See details in: http://www.cs.caltech.edu/~weixl/technical/ns2linux/known_linux/index.html#vegas Switch the order of "if (tp->snd_cwnd <= tp->snd_ssthresh)" statement and "if (diff > gamma)" statement to eliminate the problem. Signed-off-by: Xiaoliang (David) Wei <davidwei79@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[TCP]: congestion control API pass RTT in microsecondsStephen Hemminger
This patch changes the API for the callback that is done after an ACK is received. It solves a couple of issues: * Some congestion controls want higher resolution value of RTT (controlled by TCP_CONG_RTT_SAMPLE flag). These don't really want a ktime, but all compute a RTT in microseconds. * Other congestion control could use RTT at jiffies resolution. To keep API consistent the units should be the same for both cases, just the resolution should change. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-18[TCP]: remove unused argument to cong_avoid opStephen Hemminger
None of the existing TCP congestion controls use the rtt value pased in the ca_ops->cong_avoid interface. Which is lucky because seq_rtt could have been -1 when handling a duplicate ack. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-15[TCP]: Congestion control API RTT sampling fixIlpo Järvinen
Commit 164891aadf1721fca4dce473bb0e0998181537c6 broke RTT sampling of congestion control modules. Inaccurate timestamps could be fed to them without providing any way for them to identify such cases. Previously RTT sampler was called only if FLAG_RETRANS_DATA_ACKED was not set filtering inaccurate timestamps nicely. In addition, the new behavior could give an invalid timestamp (zero) to RTT sampler if only skbs with TCPCB_RETRANS were ACKed. This solves both problems. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Fix linkage errors on i386.YOSHIFUJI Hideaki
To avoid raw division, use ktime_to_timeval() to get usec. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP] TCP YEAH: Use vegas dont copy it.Stephen Hemminger
Rather than using a copy of vegas code, the YEAH code should just have it exported so there is common code. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Congestion control API update.Stephen Hemminger
Do some simple changes to make congestion control API faster/cleaner. * use ktime_t rather than timeval * merge rtt sampling into existing ack callback this means one indirect call versus two per ack. * use flags bits to store options/settings Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP] vegas: Use type safe netlink interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[TCP] Vegas: Increase default alpha to 2 and beta to 4.David S. Miller
This helps Vegas cope better with delayed ACKs, see analysis at: http://www.cs.caltech.edu/%7Eweixl/technical/ns2linux/known_linux/index.html#vegas Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[TCP] Congestion control (modulo lp, bic): use BUILD_BUG_ONAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-04[TCP] tcp_vegas: Fix slow startThomas Young
Vegas' slow start was only adding one MSS per RTT rather than one for every ack. Slow start behavior should now match Reno. Signed-off-by: Thomas Young <tyo@ee.mu.oz.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-06[TCP] Vegas: Remove extra call to tcp_vegas_rtt_calcThomas Young
Remove unneeded call to tcp_vegas_rtt_calc. The more accurate microsecond value has already been registered prior to calling tcp_vegas_cong_avoid. Signed-off-by: Thomas Young <tyo@ee.mu.oz.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-06[TCP] Vegas: stop resetting rtt every ackThomas Young
Move the resetting of rtt measurements to inside the once per RTT block of code. Signed-off-by: Thomas Young <tyo@ee.mu.oz.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[PATCH] TCP: fix vegas buildJeff Garzik
Recent TCP changes broke the build. Signed-off-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[TCP]: add tcp_slow_start helperStephen Hemminger
Move all the code that does linear TCP slowstart to one inline function to ease later patch to add ABC support. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET_DIAG]: Rename tcp_diag.[ch] to inet_diag.[ch]Arnaldo Carvalho de Melo
Next changeset will introduce net/ipv4/tcp_diag.c, moving the code that was put transitioanlly in inet_diag.c. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCPDIAG]: Just rename everything to inet_diagArnaldo Carvalho de Melo
Next changeset will rename tcp_diag.[ch] to inet_diag.[ch]. I'm taking this longer route so as to easy review, making clear the changes made all along the way. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Move TCP congestion avoidance members to icskArnaldo Carvalho de Melo
This changeset basically moves tcp_sk()->{ca_ops,ca_state,etc} to inet_csk(), minimal renaming/moving done in this changeset to ease review. Most of it is just changes of struct tcp_sock * to struct sock * parameters. With this we move to a state closer to two interesting goals: 1. Generalisation of net/ipv4/tcp_diag.c, becoming inet_diag.c, being used for any INET transport protocol that has struct inet_hashinfo and are derived from struct inet_connection_sock. Keeps the userspace API, that will just not display DCCP sockets, while newer versions of tools can support DCCP. 2. INET generic transport pluggable Congestion Avoidance infrastructure, using the current TCP CA infrastructure with DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add TCP Vegas congestion control module.Stephen Hemminger
TCP Vegas code modified for the new TCP infrastructure. Vegas now uses microsecond resolution timestamps for better estimation of performance over higher speed links. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
