This patch changes the default initial receive window to 10 mss
(defined constant). The default window is limited to the maximum
of 10*1460 and 2*mss (when mss > 1460).
draft-ietf-tcpm-initcwnd-00 is a proposal to the IETF that recommends
increasing TCP's initial congestion window to 10 mss or about 15KB.
Leading up to this proposal were several large-scale live Internet
experiments with an initial congestion window of 10 mss (IW10), where
we showed that the average latency of HTTP responses improved by
approximately 10%. This was accompanied by a slight increase in
retransmission rate (0.5%), most of which is coming from applications
opening multiple simultaneous connections. To understand the extreme
worst case scenarios, and fairness issues (IW10 versus IW3), we further
conducted controlled testbed experiments. We came away finding minimal
negative impact even under low link bandwidths (dial-ups) and small
buffers. These results are extremely encouraging to adopting IW10.
However, an initial congestion window of 10 mss is useless unless a TCP
receiver advertises an initial receive window of at least 10 mss.
Fortunately, in the large-scale Internet experiments we found that most
widely used operating systems advertised large initial receive windows
of 64KB, allowing us to experiment with a wide range of initial
congestion windows. Linux systems were among the few exceptions that
advertised a small receive window of 6KB. The purpose of this patch is
to fix this shortcoming.
References:
1. A comprehensive list of all IW10 references to date.
http://code.google.com/speed/protocols/tcpm-IW10.html
2. Paper describing results from large-scale Internet experiments with IW10.
http://ccr.sigcomm.org/drupal/?q=node/621
3. Controlled testbed experiments under worst case scenarios and a
fairness study.
http://www.ietf.org/proceedings/79/slides/tcpm-0.pdf
4. Raw test data from testbed experiments (Linux senders/receivers)
with initial congestion and receive windows of both 10 mss.
http://research.csc.ncsu.edu/netsrv/?q=content/iw10
5. Internet-Draft. Increasing TCP's Initial Window.
https://datatracker.ietf.org/doc/draft-ietf-tcpm-initcwnd/
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Make all RTAX_ADVMSS metric accesses go through a new helper function,
dst_metric_advmss().
Leave the actual default metric as "zero" in the real metric slot,
and compute the actual default value dynamically via a new dst_ops
AF specific callback.
For stacked IPSEC routes, we use the advmss of the path which
preserves existing behavior.
Unlike ipv4/ipv6, DecNET ties the advmss to the mtu and thus updates
advmss on pmtu updates. This inconsistency in advmss handling
results in more raw metric accesses than I wish we ended up with.
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
Make sure sysctl_tcp_cookie_size is read once in
tcp_cookie_size_check(), or we might return an illegal value to caller
if sysctl_tcp_cookie_size is changed by another cpu.
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: William Allen Simpson <william.allen.simpson@gmail.com>
sysctl_tcp_tso_win_divisor might be set to zero while one cpu runs in
tcp_tso_should_defer(). Make sure we dont allow a divide by zero by
reading sysctl_tcp_tso_win_divisor exactly once.
The bug has to do with boundary checks on the initial receive window.
If the initial receive window falls between init_cwnd and the
receive window specified by the user, the initial window is incorrectly
brought down to init_cwnd. The correct behavior is to allow it to
remain unchanged.
TCP_BASE_MSS is defined, but not used.
commit 5d424d5a introduce this macro, so use
it to initial sysctl_tcp_base_mss.
commit 5d424d5a674f782d0659a3b66d951f412901faee
Author: John Heffner <jheffner@psc.edu>
Date: Mon Mar 20 17:53:41 2006 -0800
[TCP]: MTU probing
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
In dev_pick_tx, don't do work in calculating queue
index or setting
the index in the sock unless the device has more than one queue. This
allows the sock to be set only with a queue index of a multi-queue
device which is desirable if device are stacked like in a tunnel.
We also allow the mapping of a socket to queue to be changed. To
maintain in order packet transmission a flag (ooo_okay) has been
added to the sk_buff structure. If a transport layer sets this flag
on a packet, the transmit queue can be changed for the socket.
Presumably, the transport would set this if there was no possbility
of creating OOO packets (for instance, there are no packets in flight
for the socket). This patch includes the modification in TCP output
for setting this flag.
Signed-off-by: Tom Herbert <therbert@google.com>
The current tcp_connect code completely ignores errors from sending an skb.
This makes sense in many situations (like -ENOBUFFS) but I want to be able to
immediately fail connections if they are denied by the SELinux netfilter hook.
Netfilter does not normally return ECONNREFUSED when it drops a packet so we
respect that error code as a final and fatal error that can not be recovered.
Based-on-patch-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Eric Paris <eparis@redhat.com>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
Thanks to Ilpo Jarvinen, this updates also the initial window
setting for tcp_output with regard to RFC 5681.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Via setsockopt it is possible to reduce the socket RX buffer
(SO_RCVBUF). TCP method to select the initial window and window scaling
option in tcp_select_initial_window() currently misbehaves and do not
consider a reduced RX socket buffer via setsockopt.
Even though the server's RX buffer is reduced via setsockopt() to 256
byte (Initial Window 384 byte => 256 * 2 - (256 * 2 / 4)) the window
scale option is still 7:
192.168.1.38.40676 > 78.47.222.210.5001: Flags [S], seq 2577214362, win 5840, options [mss 1460,sackOK,TS val 338417 ecr 0,nop,wscale 0], length 0
78.47.222.210.5001 > 192.168.1.38.40676: Flags [S.], seq 1570631029, ack 2577214363, win 384, options [mss 1452,sackOK,TS val 2435248895 ecr 338417,nop,wscale 7], length 0
192.168.1.38.40676 > 78.47.222.210.5001: Flags [.], ack 1, win 5840, options [nop,nop,TS val 338421 ecr 2435248895], length 0
Within tcp_select_initial_window() the original space argument - a
representation of the rx buffer size - is expanded during
tcp_select_initial_window(). Only sysctl_tcp_rmem[2], sysctl_rmem_max
and window_clamp are considered to calculate the initial window.
This patch adjust the window_clamp argument if the user explicitly
reduce the receive buffer.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
drivers/vhost/net.c
net/bridge/br_device.c
Fix merge conflict in drivers/vhost/net.c with guidance from
Stephen Rothwell.
Revert the effects of net-2.6 commit 573201f36fd9c7c6d5218cdcd9948cee700b277d
since net-next-2.6 has fixes that make bridge netpoll work properly thus
we don't need it disabled.
It can happen that there are no packets in queue while calling
tcp_xmit_retransmit_queue(). tcp_write_queue_head() then returns
NULL and that gets deref'ed to get sacked into a local var.
There is no work to do if no packets are outstanding so we just
exit early.
This oops was introduced by 08ebd1721ab8fd (tcp: remove tp->lost_out
guard to make joining diff nicer).
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Reported-by: Lennart Schulte <lennart.schulte@nets.rwth-aachen.de>
Tested-by: Lennart Schulte <lennart.schulte@nets.rwth-aachen.de>
CodingStyle cleanups
EXPORT_SYMBOL should immediately follow the symbol declaration.
We can pass a gfp argument to tso_fragment() and avoid GFP_ATOMIC
allocations sometimes.
unify tcp flag macros: TCPHDR_FIN, TCPHDR_SYN, TCPHDR_RST, TCPHDR_PSH,
TCPHDR_ACK, TCPHDR_URG, TCPHDR_ECE and TCPHDR_CWR. TCBCB_FLAG_* are replaced
with the corresponding TCPHDR_*.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
include/net/tcp.h | 24 ++++++-------
net/ipv4/tcp.c | 8 ++--
net/ipv4/tcp_input.c | 2 -
net/ipv4/tcp_output.c | 59 ++++++++++++++++-----------------
net/netfilter/nf_conntrack_proto_tcp.c | 32 ++++++-----------
net/netfilter/xt_TCPMSS.c | 4 --
6 files changed, 58 insertions(+), 71 deletions(-)
Commit 33ad798c924b4a (tcp: options clean up) introduced a problem
if MD5+SACK+timestamps were used in initial SYN message.
Some stacks (old linux for example) try to negotiate MD5+SACK+TSTAMP
sessions, but since 40 bytes of tcp options space are not enough to
store all the bits needed, we chose to disable timestamps in this case.
We send a SYN-ACK _without_ timestamp option, but socket has timestamps
enabled and all further outgoing messages contain a TS block, all with
the initial timestamp of the remote peer.
Fix is to really disable timestamps option for the whole session.
Reported-by: Bijay Singh <Bijay.Singh@guavus.com>
TCP-MD5 sessions have intermittent failures, when route cache is
invalidated. ip_queue_xmit() has to find a new route, calls
sk_setup_caps(sk, &rt->u.dst), destroying the
sk->sk_route_caps &= ~NETIF_F_GSO_MASK
that MD5 desperately try to make all over its way (from
tcp_transmit_skb() for example)
So we send few bad packets, and everything is fine when
tcp_transmit_skb() is called again for this socket.
Since ip_queue_xmit() is at a lower level than TCP-MD5, I chose to use a
socket field, sk_route_nocaps, containing bits to mask on sk_route_caps.
Reported-by: Bhaskar Dutta <bhaskie@gmail.com>
Account for TSO segments of an skb in TCP_MIB_OUTSEGS counter. Without
doing this, the counter can be off by orders of magnitude from the
actual number of segments sent.
Sparse can help us find endianness bugs, but we need to make some
cleanups to be able to more easily spot real bugs.
As Herbert Xu said: we should be able to simply replace ipfragok
with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function)
has droped ipfragok and set local_df value properly.
The patch kills the ipfragok parameter of .queue_xmit().
Back in commit 04a0551c87363f100b04d28d7a15a632b70e18e7
("loopback: Drop obsolete ip_summed setting") we stopped
setting CHECKSUM_UNNECESSARY in the loopback xmit.
This is because such a setting was a lie since it implies that the
checksum field of the packet is properly filled in.
Instead what happens normally is that CHECKSUM_PARTIAL is set and
skb->csum is calculated as needed.
But this was only happening for TCP data packets (via the
skb->ip_summed assignment done in tcp_sendmsg()). It doesn't
happen for non-data packets like ACKs etc.
Fix this by setting skb->ip_summed in the common non-data packet
constructor. It already is setting skb->csum to zero.
But this reminds us that we still have things like ip_output.c's
ip_dev_loopback_xmit() which sets skb->ip_summed to the value
CHECKSUM_UNNECESSARY, which Herbert's patch teaches us is not
valid. So we'll have to address that at some point too.
inet: Remove unused send_check length argument
This patch removes the unused length argument from the send_check
function in struct inet_connection_sock_af_ops.
Tested-by: Yinghai <yinghai.lu@oracle.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Commit 4957faad (TCPCT part 1g: Responder Cookie => Initiator), part
of TCP_COOKIE_TRANSACTION implementation, forgot to correctly size
synack skb in case user data must be included.
Many thanks to Mika Pentillä for spotting this error.
Reported-by: Penttillä Mika <mika.penttila@ixonos.com>
Add rtnetlink init_rcvwnd to set the TCP initial receive window size
advertised by passive and active TCP connections.
The current Linux TCP implementation limits the advertised TCP initial
receive window to the one prescribed by slow start. For short lived
TCP connections used for transaction type of traffic (i.e. http
requests), bounding the advertised TCP initial receive window results
in increased latency to complete the transaction.
Support for setting initial congestion window is already supported
using rtnetlink init_cwnd, but the feature is useless without the
ability to set a larger TCP initial receive window.
The rtnetlink init_rcvwnd allows increasing the TCP initial receive
window, allowing TCP connection to advertise larger TCP receive window
than the ones bounded by slow start.
Signed-off-by: Laurent Chavey <chavey@google.com>
tcp_push checks tcp_send_head and calls __tcp_push_pending_frames,
which again checks tcp_send_head, and this unnecessary check is
done for every other caller of __tcp_push_pending_frames.
Remove tcp_send_head check in __tcp_push_pending_frames and add
the check to tcp_push_pending_frames. Other functions call
__tcp_push_pending_frames only when tcp_send_head would evaluate
to true.
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com>
Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
It creates a regression, triggering badness for SYN_RECV
sockets, for example:
[19148.022102] Badness at net/ipv4/inet_connection_sock.c:293
[19148.022570] NIP: c02a0914 LR: c02a0904 CTR: 00000000
[19148.023035] REGS: eeecbd30 TRAP: 0700 Not tainted (2.6.32)
[19148.023496] MSR: 00029032 <EE,ME,CE,IR,DR> CR: 24002442 XER: 00000000
[19148.024012] TASK = eee9a820[1756] 'privoxy' THREAD: eeeca000
This is likely caused by the change in the 'estab' parameter
passed to tcp_parse_options() when invoked by the functions
in net/ipv4/tcp_minisocks.c
But even if that is fixed, the ->conn_request() changes made in
this patch series is fundamentally wrong. They try to use the
listening socket's 'dst' to probe the route settings. The
listening socket doesn't even have a route, and you can't
get the right route (the child request one) until much later
after we setup all of the state, and it must be done by hand.
This stuff really isn't ready, so the best thing to do is a
full revert. This reverts the following commits:
f55017a93f1a74d50244b1254b9a2bd7ac9bbf7d
022c3f7d82f0f1c68018696f2f027b87b9bb45c2
1aba721eba1d84a2defce45b950272cee1e6c72a
cda42ebd67ee5fdf09d7057b5a4584d36fe8a335
345cda2fd695534be5a4494f1b59da9daed33663
dc343475ed062e13fc260acccaab91d7d80fd5b2
05eaade2782fb0c90d3034fd7a7d5a16266182bb
6a2a2d6bf8581216e08be15fcb563cfd6c430e1e
Otherwise:
ERROR: "sysctl_tcp_cookie_size" [net/ipv6/ipv6.ko] undefined!
make[1]: *** [__modpost] Error 1
net/ipv4/tcp_output.c: In function ‘tcp_make_synack’:
net/ipv4/tcp_output.c:2488: warning: cast from pointer to integer of different size
Parse incoming TCP_COOKIE option(s).
Calculate <SYN,ACK> TCP_COOKIE option.
Send optional <SYN,ACK> data.
This is a significantly revised implementation of an earlier (year-old)
patch that no longer applies cleanly, with permission of the original
author (Adam Langley):
http://thread.gmane.org/gmane.linux.network/102586
Requires:
TCPCT part 1a: add request_values parameter for sending SYNACK
TCPCT part 1b: generate Responder Cookie secret
TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONS
TCPCT part 1d: define TCP cookie option, extend existing struct's
TCPCT part 1e: implement socket option TCP_COOKIE_TRANSACTIONS
TCPCT part 1f: Initiator Cookie => Responder
Signed-off-by: William.Allen.Simpson@gmail.com
Calculate and format <SYN> TCP_COOKIE option.
Requires:
Define sysctl (tcp_cookie_size) to turn on and off the cookie option
default globally, instead of a compiled configuration option.
Define per socket option (TCP_COOKIE_TRANSACTIONS) for setting constant
data values, retrieving variable cookie values, and other facilities.
Move inline tcp_clear_options() unchanged from net/tcp.h to linux/tcp.h,
near its corresponding struct tcp_options_received (prior to changes).
This is a straightforward re-implementation of an earlier (year-old)
These functions will also be used in subsequent patches that implement
additional features.
Requires:
net: TCP_MSS_DEFAULT, TCP_MSS_DESIRED
Add optional function parameters associated with sending SYNACK.
These parameters are not needed after sending SYNACK, and are not
used for retransmission. Avoids extending struct tcp_request_sock,
and avoids allocating kernel memory.
Also affects DCCP as it uses common struct request_sock_ops,
but this parameter is currently reserved for future use.
On Sun, 2009-11-22 at 16:31 -0800, David Miller wrote:
> It should be of the form:
> if (x &&
> y)
> or:
> if (x && y)
> Fix patches, rather than complaints, for existing cases where things
> do not follow this pattern are certainly welcome.
Also collapsed some multiple tabs to single space.
Add and use no window scale bit in the features field.
Note that this is not the same as setting a window scale of 0
as would happen with window limit on route.
Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com>
Sigend-off-by: Ori Finkelman <ori@comsleep.com>
Sigend-off-by: Yony Amit <yony@comsleep.com>
Implement querying and acting upon the no timestamp bit in the feature
field.
Implement querying and acting upon the no sack bit in the features
field.
In order to have better cache layouts of struct sock (separate zones
for rx/tx paths), we need this preliminary patch.
Goal is to transfert fields used at lookup time in the first
read-mostly cache line (inside struct sock_common) and move sk_refcnt
to a separate cache line (only written by rx path)
This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr,
sport and id fields. This allows a future patch to define these
fields as macros, like sk_refcnt, without name clashes.
Acknowledge TCP window scale support by inserting the proper option in SYN/ACK
and SYN headers even if our window scale is zero.
This fixes the following observed behavior:
1. Client sends a SYN with TCP window scaling option and non zero window scale
value to a Linux box.
2. Linux box notes large receive window from client.
3. Linux decides on a zero value of window scale for its part.
4. Due to compare against requested window scale size option, Linux does not to
send windows scale TCP option header on SYN/ACK at all.
With the following result:
Client box thinks TCP window scaling is not supported, since SYN/ACK had no
TCP window scale option, while Linux thinks that TCP window scaling is
supported (and scale might be non zero), since SYN had TCP window scale
option and we have a mismatched idea between the client and server
regarding window sizes.
Probably it also fixes up the following bug (not observed in practice):
1. Linux box opens TCP connection to some server.
2. Linux decides on zero value of window scale.
3. Due to compare against computed window scale size option, Linux does
not to set windows scale TCP option header on SYN.
With the expected result that the server OS does not use window scale option
due to not receiving such an option in the SYN headers, leading to suboptimal
performance.
Signed-off-by: Ori Finkelman <ori@comsleep.com>
This fixed a lockdep warning which appeared when doing stress
memory tests over NFS:
inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage.
page reclaim => nfs_writepage => tcp_sendmsg => lock sk_lock
mount_root => nfs_root_data => tcp_close => lock sk_lock =>
tcp_send_fin => alloc_skb_fclone => page reclaim
David raised a concern that if the allocation fails in tcp_send_fin(), and it's
GFP_ATOMIC, we are going to yield() (which sleeps) and loop endlessly waiting
for the allocation to succeed.
But fact is, the original GFP_KERNEL also sleeps. GFP_ATOMIC+yield() looks
weird, but it is no worse the implicit sleep inside GFP_KERNEL. Both could
loop endlessly under memory pressure.
CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
CC: David S. Miller <davem@davemloft.net>
CC: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
drivers/net/wireless/iwmc3200wifi/netdev.c
net/wireless/scan.c
While looking for something else I spent some time adding
one liner comments to the tcp_output.c functions that
didn't have any. That makes the comments more consistent.
I hope I documented everything right.
No code changes.
v2: Incorporated feedback from Ilpo.
v3: Change style of one liner comments, add a few more comments.
Fix MD5 signature checking so that an IPv4 active open
to an IPv6 socket can succeed. In particular, use the
correct address family's signature generation function
for the SYN/ACK.
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Signed-off-by: John Dykstra <john.dykstra1@gmail.com>
If a socket starts out on a non-TSO route, and then switches to
a TSO route, then the tail on the tx queue can morph into a TSO
packet, causing mischief because the rest of the stack does not
expect a partially linear TSO packet.
This patch fixes this by ensuring that skb->ip_summed is set to
CHECKSUM_PARTIAL before declaring a packet as TSO.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
This should be very safe compared with full enabled, so I see
no reason why it shouldn't be done right away. As ECN can only
be negotiated if the SYN sending party is also supporting it,
somebody in the loop probably knows what he/she is doing. If
SYN does not ask for ECN, the server side SYN-ACK is identical
to what it is without ECN. Thus it's quite safe.
The chosen value is safe w.r.t to existing configs which
choose to currently set manually either 0 or 1 but
silently upgrades those who have not explicitly requested
ECN off.
Whether to just enable both sides comes up time to time but
unless that gets done now we can at least make the servers
aware of ECN already. As there are some known problems to occur
if ECN is enabled, it's currently questionable whether there's
any real gain from enabling clients as servers mostly won't
support it anyway (so we'd hit just the negative sides). After
enabling the servers and getting that deployed, the client end
enable really has some potential gain too.
Just noticed while doing some new work that the recent
mid-wq adjustment logic will misbehave when FACK is not
in use (happens either due sysctl'ed off or auto-detected
reordering) because I forgot the relevant TCPCB tagbit.
