path: root/net/ipv4/tcp_input.c
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-02-21tcp: undo_retrans counter fixesYuchung Cheng
Fix a bug that undo_retrans is incorrectly decremented when undo_marker is not set or undo_retrans is already 0. This happens when sender receives more DSACK ACKs than packets retransmitted during the current undo phase. This may also happen when sender receives DSACK after the undo operation is completed or cancelled. Fix another bug that undo_retrans is incorrectly incremented when sender retransmits an skb and tcp_skb_pcount(skb) > 1 (TSO). This case is rare but not impossible. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-02tcp: Increase the initial congestion window to 10.David S. Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Nandita Dukkipati <nanditad@google.com>
2011-01-25TCP: fix a bug that triggers large number of TCP RST by mistakeJerry Chu
This patch fixes a bug that causes TCP RST packets to be generated on otherwise correctly behaved applications, e.g., no unread data on close,..., etc. To trigger the bug, at least two conditions must be met: 1. The FIN flag is set on the last data packet, i.e., it's not on a separate, FIN only packet. 2. The size of the last data chunk on the receive side matches exactly with the size of buffer posted by the receiver, and the receiver closes the socket without any further read attempt. This bug was first noticed on our netperf based testbed for our IW10 proposal to IETF where a large number of RST packets were observed. netperf's read side code meets the condition 2 above 100%. Before the fix, tcp_data_queue() will queue the last skb that meets condition 1 to sk_receive_queue even though it has fully copied out (skb_copy_datagram_iovec()) the data. Then if condition 2 is also met, tcp_recvmsg() often returns all the copied out data successfully without actually consuming the skb, due to a check "if ((chunk = len - tp->ucopy.len) != 0) {" and "len -= chunk;" after tcp_prequeue_process() that causes "len" to become 0 and an early exit from the big while loop. I don't see any reason not to free the skb whose data have been fully consumed in tcp_data_queue(), regardless of the FIN flag. We won't get there if MSG_PEEK is on. Am I missing some arcane cases related to urgent data? Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-23tcp: cleanup of cwnd initialization in tcp_init_metrics()Jiri Kosina
Commit 86bcebafc5e7f5 ("tcp: fix >2 iw selection") fixed a case when congestion window initialization has been mistakenly omitted by introducing cwnd label and putting backwards goto from the end of the function. This makes the code unnecessarily tricky to read and understand on a first sight. Shuffle the code around a little bit to make it more obvious. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-09net: Abstract away all dst_entry metrics accesses.David S. Miller
Use helper functions to hide all direct accesses, especially writes, to dst_entry metrics values. This will allow us to: 1) More easily change how the metrics are stored. 2) Implement COW for metrics. In particular this will help us put metrics into the inetpeer cache if that is what we end up doing. We can make the _metrics member a pointer instead of an array, initially have it point at the read-only metrics in the FIB, and then on the first set grab an inetpeer entry and point the _metrics member there. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2010-11-10net: avoid limits overflowEric Dumazet
Robin Holt tried to boot a 16TB machine and found some limits were reached : sysctl_tcp_mem[2], sysctl_udp_mem[2] We can switch infrastructure to use long "instead" of "int", now atomic_long_t primitives are available for free. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Robin Holt <holt@sgi.com> Reviewed-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-17tcp: sack lost marking fixesIlpo Järvinen
When only fast rexmit should be done, tcp_mark_head_lost marks L too far. Also, sacked_upto below 1 is perfectly valid number, the packets == 0 then needs to be trapped elsewhere. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06TCP: Fix setting of snd_ssthresh in tcp_mtu_probe_successJohn Heffner
This looks like a simple typo that has gone unnoticed for some time. The impact is relatively low but it's clearly wrong. Signed-off-by: John Heffner <johnwheffner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-09-29tcp: tcp_enter_quickack_mode can be staticstephen hemminger
Function only used in tcp_input.c Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27tcp: fix TSO FACK loss marking in tcp_mark_head_lostYuchung Cheng
When TCP uses FACK algorithm to mark lost packets in tcp_mark_head_lost(), if the number of packets in the (TSO) skb is greater than the number of packets that should be marked lost, TCP incorrectly exits the loop and marks no packets lost in the skb. This underestimates tp->lost_out and affects the recovery/retransmission. This patch fargments the skb and marks the correct amount of packets lost. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/qlcnic/qlcnic_init.c net/ipv4/ip_output.c
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-20tcp: Fix race in tcp_pollTom Marshall
If a RST comes in immediately after checking sk->sk_err, tcp_poll will return POLLIN but not POLLOUT. Fix this by checking sk->sk_err at the end of tcp_poll. Additionally, ensure the correct order of operations on SMP machines with memory barriers. Signed-off-by: Tom Marshall <tdm.code@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-30tcp/dccp: Consolidate common code for RFC 3390 conversionGerrit Renker
This patch consolidates initial-window code common to TCP and CCID-2: * TCP uses RFC 3390 in a packet-oriented manner (tcp_input.c) and * CCID-2 uses RFC 3390 in packet-oriented manner (RFC 4341). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-07tcp: no md5sig option size check bugDmitry Popov
tcp_parse_md5sig_option doesn't check md5sig option (TCPOPT_MD5SIG) length, but tcp_v[46]_inbound_md5_hash assume that it's at least 16 bytes long. Signed-off-by: Dmitry Popov <dp@highloadlab.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15tcp: unify tcp flag macrosChangli Gao
unify tcp flag macros: TCPHDR_FIN, TCPHDR_SYN, TCPHDR_RST, TCPHDR_PSH, TCPHDR_ACK, TCPHDR_URG, TCPHDR_ECE and TCPHDR_CWR. TCBCB_FLAG_* are replaced with the corresponding TCPHDR_*. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/tcp.h | 24 ++++++------- net/ipv4/tcp.c | 8 ++-- net/ipv4/tcp_input.c | 2 - net/ipv4/tcp_output.c | 59 ++++++++++++++++----------------- net/netfilter/nf_conntrack_proto_tcp.c | 32 ++++++----------- net/netfilter/xt_TCPMSS.c | 4 -- 6 files changed, 58 insertions(+), 71 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31net/ipv4/tcp_input.c: fix compilation breakage when FASTRETRANS_DEBUG > 1Joe Perches
Commit: c720c7e8383aff1cb219bddf474ed89d850336e3 missed these. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary semicolons after switch statementsJoe Perches
Also added an explicit break; to avoid a fallthrough in net/ipv4/tcp_input.c Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28net: ip_queue_rcv_skb() helperEric Dumazet
When queueing a skb to socket, we can immediately release its dst if target socket do not use IP_CMSG_PKTINFO. tcp_data_queue() can drop dst too. This to benefit from a hot cache line and avoid the receiver, possibly on another cpu, to dirty this cache line himself. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13net: sk_dst_cache RCUificationEric Dumazet
With latest CONFIG_PROVE_RCU stuff, I felt more comfortable to make this work. sk->sk_dst_cache is currently protected by a rwlock (sk_dst_lock) This rwlock is readlocked for a very small amount of time, and dst entries are already freed after RCU grace period. This calls for RCU again :) This patch converts sk_dst_lock to a spinlock, and use RCU for readers. __sk_dst_get() is supposed to be called with rcu_read_lock() or if socket locked by user, so use appropriate rcu_dereference_check() condition (rcu_read_lock_held() || sock_owned_by_user(sk)) This patch avoids two atomic ops per tx packet on UDP connected sockets, for example, and permits sk_dst_lock to be much less dirtied. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24net: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19tcp: Fix tcp_mark_head_lost() with packets == 0Lennart Schulte
A packet is marked as lost in case packets == 0, although nothing should be done. This results in a too early retransmitted packet during recovery in some cases. This small patch fixes this issue by returning immediately. Signed-off-by: Lennart Schulte <lennart.schulte@nets.rwth-aachen.de> Signed-off-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18net: TCP thin dupackAndreas Petlund
This patch enables fast retransmissions after one dupACK for TCP if the stream is identified as thin. This will reduce latencies for thin streams that are not able to trigger fast retransmissions due to high packet interarrival time. This mechanism is only active if enabled by iocontrol or syscontrol and the stream is identified as thin. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-10tcp: fix ICMP-RTO warDamian Lukowski
Make sure, that TCP has a nonzero RTT estimation after three-way handshake. Currently, a listening TCP has a value of 0 for srtt, rttvar and rto right after the three-way handshake is completed with TCP timestamps disabled. This will lead to corrupt RTO recalculation and retransmission flood when RTO is recalculated on backoff reversion as introduced in "Revert RTO on ICMP destination unreachable" (f1ecd5d9e7366609d640ff4040304ea197fbc618). This behaviour can be provoked by connecting to a server which "responds first" (like SMTP) and rejecting every packet after the handshake with dest-unreachable, which will lead to softirq load on the server (up to 30% per socket in some tests). Thanks to Ilpo Jarvinen for providing debug patches and to Denys Fedoryshchenko for reporting and testing. Changes since v3: Removed bad characters in patchfile. Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15tcp: Revert per-route SACK/DSACK/TIMESTAMP changes.David S. Miller
It creates a regression, triggering badness for SYN_RECV sockets, for example: [19148.022102] Badness at net/ipv4/inet_connection_sock.c:293 [19148.022570] NIP: c02a0914 LR: c02a0904 CTR: 00000000 [19148.023035] REGS: eeecbd30 TRAP: 0700 Not tainted (2.6.32) [19148.023496] MSR: 00029032 <EE,ME,CE,IR,DR> CR: 24002442 XER: 00000000 [19148.024012] TASK = eee9a820[1756] 'privoxy' THREAD: eeeca000 This is likely caused by the change in the 'estab' parameter passed to tcp_parse_options() when invoked by the functions in net/ipv4/tcp_minisocks.c But even if that is fixed, the ->conn_request() changes made in this patch series is fundamentally wrong. They try to use the listening socket's 'dst' to probe the route settings. The listening socket doesn't even have a route, and you can't get the right route (the child request one) until much later after we setup all of the state, and it must be done by hand. This stuff really isn't ready, so the best thing to do is a full revert. This reverts the following commits: f55017a93f1a74d50244b1254b9a2bd7ac9bbf7d 022c3f7d82f0f1c68018696f2f027b87b9bb45c2 1aba721eba1d84a2defce45b950272cee1e6c72a cda42ebd67ee5fdf09d7057b5a4584d36fe8a335 345cda2fd695534be5a4494f1b59da9daed33663 dc343475ed062e13fc260acccaab91d7d80fd5b2 05eaade2782fb0c90d3034fd7a7d5a16266182bb 6a2a2d6bf8581216e08be15fcb563cfd6c430e1e Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08tcp: fix retrans_stamp advancing in error casesIlpo Järvinen
It can happen, that tcp_retransmit_skb fails due to some error. In such cases we might end up into a state where tp->retrans_out is zero but that's only because we removed the TCPCB_SACKED_RETRANS bit from a segment but couldn't retransmit it because of the error that happened. Therefore some assumptions that retrans_out checks are based do not necessarily hold, as there still can be an old retransmission but that is only visible in TCPCB_EVER_RETRANS bit. As retransmission happen in sequential order (except for some very rare corner cases), it's enough to check the head skb for that bit. Main reason for all this complexity is the fact that connection dying time now depends on the validity of the retrans_stamp, in particular, that successive retransmissions of a segment must not advance retrans_stamp under any conditions. It seems after quick thinking that this has relatively low impact as eventually TCP will go into CA_Loss and either use the existing check for !retrans_stamp case or send a retransmission successfully, setting a new base time for the dying timer (can happen only once). At worst, the dying time will be approximately the double of the intented time. In addition, tcp_packet_delayed() will return wrong result (has some cc aspects but due to rarity of these errors, it's hardly an issue). One of retrans_stamp clearing happens indirectly through first going into CA_Open state and then a later ACK lets the clearing to happen. Thus tcp_try_keep_open has to be modified too. Thanks to Damian Lukowski <damian@tvk.rwth-aachen.de> for hinting that this possibility exists (though the particular case discussed didn't after all have it happening but was just a debug patch artifact). Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1g: Responder Cookie => InitiatorWilliam Allen Simpson
Parse incoming TCP_COOKIE option(s). Calculate <SYN,ACK> TCP_COOKIE option. Send optional <SYN,ACK> data. This is a significantly revised implementation of an earlier (year-old) patch that no longer applies cleanly, with permission of the original author (Adam Langley): http://thread.gmane.org/gmane.linux.network/102586 Requires: TCPCT part 1a: add request_values parameter for sending SYNACK TCPCT part 1b: generate Responder Cookie secret TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONS TCPCT part 1d: define TCP cookie option, extend existing struct's TCPCT part 1e: implement socket option TCP_COOKIE_TRANSACTIONS TCPCT part 1f: Initiator Cookie => Responder Signed-off-by: William.Allen.Simpson@gmail.com Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23net/ipv4: Move && and || to end of previous lineJoe Perches
On Sun, 2009-11-22 at 16:31 -0800, David Miller wrote: > It should be of the form: > if (x && > y) > > or: > if (x && y) > > Fix patches, rather than complaints, for existing cases where things > do not follow this pattern are certainly welcome. Also collapsed some multiple tabs to single space. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13net: TCP_MSS_DEFAULT, TCP_MSS_DESIREDWilliam Allen Simpson
Define two symbols needed in both kernel and user space. Remove old (somewhat incorrect) kernel variant that wasn't used in most cases. Default should apply to both RMSS and SMSS (RFC2581). Replace numeric constants with defined symbols. Stand-alone patch, originally developed for TCPCT. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04tcp: Use defaults when no route options are availableGilad Ben-Yossef
Trying to parse the option of a SYN packet that we have no route entry for should just use global wide defaults for route entry options. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Tested-by: Valdis.Kletnieks@vt.edu Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow disabling of DSACK TCP option per routeGilad Ben-Yossef
Add and use no DSCAK bit in the features field. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow to turn off TCP window scale opt per routeGilad Ben-Yossef
Add and use no window scale bit in the features field. Note that this is not the same as setting a window scale of 0 as would happen with window limit on route. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow disabling TCP timestamp options per routeGilad Ben-Yossef
Implement querying and acting upon the no timestamp bit in the feature field. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Add the no SACK route option featureGilad Ben-Yossef
Implement querying and acting upon the no sack bit in the features field. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow tcp_parse_options to consult dst entryGilad Ben-Yossef
We need tcp_parse_options to be aware of dst_entry to take into account per dst_entry TCP options settings Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28net: Corrected spelling error heurestics->heuristicsAndreas Petlund
Corrected a spelling error in a function name. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15tcp: fix ssthresh u16 leftoverIlpo Järvinen
It was once upon time so that snd_sthresh was a 16-bit quantity. ...That has not been true for long period of time. I run across some ancient compares which still seem to trust such legacy. Put all that magic into a single place, I hopefully found all of them. Compile tested, though linking of allyesconfig is ridiculous nowadays it seems. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01Revert Backoff [v3]: Revert RTO on ICMP destination unreachableDamian Lukowski
Here, an ICMP host/network unreachable message, whose payload fits to TCP's SND.UNA, is taken as an indication that the RTO retransmission has not been lost due to congestion, but because of a route failure somewhere along the path. With true congestion, a router won't trigger such a message and the patched TCP will operate as standard TCP. This patch reverts one RTO backoff, if an ICMP host/network unreachable message, whose payload fits to TCP's SND.UNA, arrives. Based on the new RTO, the retransmission timer is reset to reflect the remaining time, or - if the revert clocked out the timer - a retransmission is sent out immediately. Backoffs are only reverted, if TCP is in RTO loss recovery, i.e. if there have been retransmissions and reversible backoffs, already. Changes from v2: 1) Renaming of skb in tcp_v4_err() moved to another patch. 2) Reintroduced tcp_bound_rto() and __tcp_set_rto(). 3) Fixed code comments. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29tcp: fix loop in ofo handling code and reduce its complexityIlpo Järvinen
Somewhat luckily, I was looking into these parts with very fine comb because I've made somewhat similar changes on the same area (conflicts that arose weren't that lucky though). The loop was very much overengineered recently in commit 915219441d566 (tcp: Use SKB queue and list helpers instead of doing it by-hand), while it basically just wants to know if there are skbs after 'skb'. Also it got broken because skb1 = skb->next got translated into skb1 = skb1->next (though abstracted) improperly. Note that 'skb1' is pointing to previous sk_buff than skb or NULL if at head. Two things went wrong: - We'll kfree 'skb' on the first iteration instead of the skbuff following 'skb' (it would require required SACK reneging to recover I think). - The list head case where 'skb1' is NULL is checked too early and the loop won't execute whereas it previously did. Conclusion, mostly revert the recent changes which makes the cset very messy looking but using proper accessor in the previous-like version. The effective changes against the original can be viewed with: git-diff 915219441d566f1da0caa0e262be49b666159e17^ \ net/ipv4/tcp_input.c | sed -n -e '57,70 p' Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-28tcp: Use SKB queue and list helpers instead of doing it by-hand.David S. Miller
2009-05-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/net/tcp.h
2009-05-04tcp: Fix tcp_prequeue() to get correct rto_min valueSatoru SATOH
tcp_prequeue() refers to the constant value (TCP_RTO_MIN) regardless of the actual value might be tuned. The following patches fix this and make tcp_prequeue get the actual value returns from tcp_rto_min(). Signed-off-by: Satoru SATOH <satoru.satoh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-04tcp: extend ECN sysctl to allow server-side only ECNIlpo Järvinen
This should be very safe compared with full enabled, so I see no reason why it shouldn't be done right away. As ECN can only be negotiated if the SYN sending party is also supporting it, somebody in the loop probably knows what he/she is doing. If SYN does not ask for ECN, the server side SYN-ACK is identical to what it is without ECN. Thus it's quite safe. The chosen value is safe w.r.t to existing configs which choose to currently set manually either 0 or 1 but silently upgrades those who have not explicitly requested ECN off. Whether to just enable both sides comes up time to time but unless that gets done now we can at least make the servers aware of ECN already. As there are some known problems to occur if ECN is enabled, it's currently questionable whether there's any real gain from enabling clients as servers mostly won't support it anyway (so we'd hit just the negative sides). After enabling the servers and getting that deployed, the client end enable really has some potential gain too. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
