Robin Holt tried to boot a 16TB machine and found some limits were
reached : sysctl_tcp_mem[2], sysctl_udp_mem[2]
We can switch infrastructure to use long "instead" of "int", now
atomic_long_t primitives are available for free.
Reported-by: Robin Holt <holt@sgi.com>
Reviewed-by: Robin Holt <holt@sgi.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
When only fast rexmit should be done, tcp_mark_head_lost marks
L too far. Also, sacked_upto below 1 is perfectly valid number,
the packets == 0 then needs to be trapped elsewhere.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
This looks like a simple typo that has gone unnoticed for some time. The
impact is relatively low but it's clearly wrong.
Signed-off-by: John Heffner <johnwheffner@gmail.com>
net/ipv4/Kconfig
net/ipv4/tcp_timer.c
Function only used in tcp_input.c
When TCP uses FACK algorithm to mark lost packets in
tcp_mark_head_lost(), if the number of packets in the (TSO) skb is
greater than the number of packets that should be marked lost, TCP
incorrectly exits the loop and marks no packets lost in the skb. This
underestimates tp->lost_out and affects the recovery/retransmission.
This patch fargments the skb and marks the correct amount of packets
lost.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
drivers/net/qlcnic/qlcnic_init.c
net/ipv4/ip_output.c
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
If a RST comes in immediately after checking sk->sk_err, tcp_poll will
return POLLIN but not POLLOUT. Fix this by checking sk->sk_err at the end
of tcp_poll. Additionally, ensure the correct order of operations on SMP
machines with memory barriers.
Signed-off-by: Tom Marshall <tdm.code@gmail.com>
This patch consolidates initial-window code common to TCP and CCID-2:
* TCP uses RFC 3390 in a packet-oriented manner (tcp_input.c) and
* CCID-2 uses RFC 3390 in packet-oriented manner (RFC 4341).
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
tcp_parse_md5sig_option doesn't check md5sig option (TCPOPT_MD5SIG)
length, but tcp_v[46]_inbound_md5_hash assume that it's at least 16
bytes long.
Signed-off-by: Dmitry Popov <dp@highloadlab.com>
CodingStyle cleanups
EXPORT_SYMBOL should immediately follow the symbol declaration.
unify tcp flag macros: TCPHDR_FIN, TCPHDR_SYN, TCPHDR_RST, TCPHDR_PSH,
TCPHDR_ACK, TCPHDR_URG, TCPHDR_ECE and TCPHDR_CWR. TCBCB_FLAG_* are replaced
with the corresponding TCPHDR_*.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
include/net/tcp.h | 24 ++++++-------
net/ipv4/tcp.c | 8 ++--
net/ipv4/tcp_input.c | 2 -
net/ipv4/tcp_output.c | 59 ++++++++++++++++-----------------
net/netfilter/nf_conntrack_proto_tcp.c | 32 ++++++-----------
net/netfilter/xt_TCPMSS.c | 4 --
6 files changed, 58 insertions(+), 71 deletions(-)
Commit: c720c7e8383aff1cb219bddf474ed89d850336e3 missed these.
Also added an explicit break; to avoid
a fallthrough in net/ipv4/tcp_input.c
When queueing a skb to socket, we can immediately release its dst if
target socket do not use IP_CMSG_PKTINFO.
tcp_data_queue() can drop dst too.
This to benefit from a hot cache line and avoid the receiver, possibly
on another cpu, to dirty this cache line himself.
With latest CONFIG_PROVE_RCU stuff, I felt more comfortable to make this
work.
sk->sk_dst_cache is currently protected by a rwlock (sk_dst_lock)
This rwlock is readlocked for a very small amount of time, and dst
entries are already freed after RCU grace period. This calls for RCU
again :)
This patch converts sk_dst_lock to a spinlock, and use RCU for readers.
__sk_dst_get() is supposed to be called with rcu_read_lock() or if
socket locked by user, so use appropriate rcu_dereference_check()
condition (rcu_read_lock_held() || sock_owned_by_user(sk))
This patch avoids two atomic ops per tx packet on UDP connected sockets,
for example, and permits sk_dst_lock to be much less dirtied.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Frans Pop <elendil@planet.nl>
A packet is marked as lost in case packets == 0, although nothing should be done.
This results in a too early retransmitted packet during recovery in some cases.
This small patch fixes this issue by returning immediately.
Signed-off-by: Lennart Schulte <lennart.schulte@nets.rwth-aachen.de>
Signed-off-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de>
This patch enables fast retransmissions after one dupACK for
TCP if the stream is identified as thin. This will reduce
latencies for thin streams that are not able to trigger fast
retransmissions due to high packet interarrival time. This
mechanism is only active if enabled by iocontrol or syscontrol
and the stream is identified as thin.
Signed-off-by: Andreas Petlund <apetlund@simula.no>
Make sure, that TCP has a nonzero RTT estimation after three-way
handshake. Currently, a listening TCP has a value of 0 for srtt,
rttvar and rto right after the three-way handshake is completed
with TCP timestamps disabled.
This will lead to corrupt RTO recalculation and retransmission
flood when RTO is recalculated on backoff reversion as introduced
in "Revert RTO on ICMP destination unreachable"
(f1ecd5d9e7366609d640ff4040304ea197fbc618).
This behaviour can be provoked by connecting to a server which
"responds first" (like SMTP) and rejecting every packet after
the handshake with dest-unreachable, which will lead to softirq
load on the server (up to 30% per socket in some tests).
Thanks to Ilpo Jarvinen for providing debug patches and to
Denys Fedoryshchenko for reporting and testing.
Changes since v3: Removed bad characters in patchfile.
Reported-by: Denys Fedoryshchenko <denys@visp.net.lb>
Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de>
It creates a regression, triggering badness for SYN_RECV
sockets, for example:
[19148.022102] Badness at net/ipv4/inet_connection_sock.c:293
[19148.022570] NIP: c02a0914 LR: c02a0904 CTR: 00000000
[19148.023035] REGS: eeecbd30 TRAP: 0700 Not tainted (2.6.32)
[19148.023496] MSR: 00029032 <EE,ME,CE,IR,DR> CR: 24002442 XER: 00000000
[19148.024012] TASK = eee9a820[1756] 'privoxy' THREAD: eeeca000
This is likely caused by the change in the 'estab' parameter
passed to tcp_parse_options() when invoked by the functions
in net/ipv4/tcp_minisocks.c
But even if that is fixed, the ->conn_request() changes made in
this patch series is fundamentally wrong. They try to use the
listening socket's 'dst' to probe the route settings. The
listening socket doesn't even have a route, and you can't
get the right route (the child request one) until much later
after we setup all of the state, and it must be done by hand.
This stuff really isn't ready, so the best thing to do is a
full revert. This reverts the following commits:
f55017a93f1a74d50244b1254b9a2bd7ac9bbf7d
022c3f7d82f0f1c68018696f2f027b87b9bb45c2
1aba721eba1d84a2defce45b950272cee1e6c72a
cda42ebd67ee5fdf09d7057b5a4584d36fe8a335
345cda2fd695534be5a4494f1b59da9daed33663
dc343475ed062e13fc260acccaab91d7d80fd5b2
05eaade2782fb0c90d3034fd7a7d5a16266182bb
6a2a2d6bf8581216e08be15fcb563cfd6c430e1e
It can happen, that tcp_retransmit_skb fails due to some error.
In such cases we might end up into a state where tp->retrans_out
is zero but that's only because we removed the TCPCB_SACKED_RETRANS
bit from a segment but couldn't retransmit it because of the error
that happened. Therefore some assumptions that retrans_out checks
are based do not necessarily hold, as there still can be an old
retransmission but that is only visible in TCPCB_EVER_RETRANS bit.
As retransmission happen in sequential order (except for some very
rare corner cases), it's enough to check the head skb for that bit.
Main reason for all this complexity is the fact that connection dying
time now depends on the validity of the retrans_stamp, in particular,
that successive retransmissions of a segment must not advance
retrans_stamp under any conditions. It seems after quick thinking that
this has relatively low impact as eventually TCP will go into CA_Loss
and either use the existing check for !retrans_stamp case or send a
retransmission successfully, setting a new base time for the dying
timer (can happen only once). At worst, the dying time will be
approximately the double of the intented time. In addition,
tcp_packet_delayed() will return wrong result (has some cc aspects
but due to rarity of these errors, it's hardly an issue).
One of retrans_stamp clearing happens indirectly through first going
into CA_Open state and then a later ACK lets the clearing to happen.
Thus tcp_try_keep_open has to be modified too.
Thanks to Damian Lukowski <damian@tvk.rwth-aachen.de> for hinting
that this possibility exists (though the particular case discussed
didn't after all have it happening but was just a debug patch
artifact).
Parse incoming TCP_COOKIE option(s).
Calculate <SYN,ACK> TCP_COOKIE option.
Send optional <SYN,ACK> data.
This is a significantly revised implementation of an earlier (year-old)
patch that no longer applies cleanly, with permission of the original
author (Adam Langley):
http://thread.gmane.org/gmane.linux.network/102586
Requires:
TCPCT part 1a: add request_values parameter for sending SYNACK
TCPCT part 1b: generate Responder Cookie secret
TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONS
TCPCT part 1d: define TCP cookie option, extend existing struct's
TCPCT part 1e: implement socket option TCP_COOKIE_TRANSACTIONS
TCPCT part 1f: Initiator Cookie => Responder
Signed-off-by: William.Allen.Simpson@gmail.com
On Sun, 2009-11-22 at 16:31 -0800, David Miller wrote:
> It should be of the form:
> if (x &&
> y)
> or:
> if (x && y)
> Fix patches, rather than complaints, for existing cases where things
> do not follow this pattern are certainly welcome.
Also collapsed some multiple tabs to single space.
Define two symbols needed in both kernel and user space.
Remove old (somewhat incorrect) kernel variant that wasn't used in
most cases. Default should apply to both RMSS and SMSS (RFC2581).
Replace numeric constants with defined symbols.
Stand-alone patch, originally developed for TCPCT.
Trying to parse the option of a SYN packet that we have
no route entry for should just use global wide defaults
for route entry options.
Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com>
Tested-by: Valdis.Kletnieks@vt.edu
Add and use no DSCAK bit in the features field.
Sigend-off-by: Ori Finkelman <ori@comsleep.com>
Sigend-off-by: Yony Amit <yony@comsleep.com>
Add and use no window scale bit in the features field.
Note that this is not the same as setting a window scale of 0
as would happen with window limit on route.
Implement querying and acting upon the no timestamp bit in the feature
field.
Implement querying and acting upon the no sack bit in the features
field.
We need tcp_parse_options to be aware of dst_entry to
take into account per dst_entry TCP options settings
Corrected a spelling error in a function name.
It was once upon time so that snd_sthresh was a 16-bit quantity.
...That has not been true for long period of time. I run across
some ancient compares which still seem to trust such legacy.
Put all that magic into a single place, I hopefully found all
of them.
Compile tested, though linking of allyesconfig is ridiculous
nowadays it seems.
Here, an ICMP host/network unreachable message, whose payload fits to
TCP's SND.UNA, is taken as an indication that the RTO retransmission has
not been lost due to congestion, but because of a route failure
somewhere along the path.
With true congestion, a router won't trigger such a message and the
patched TCP will operate as standard TCP.
This patch reverts one RTO backoff, if an ICMP host/network unreachable
message, whose payload fits to TCP's SND.UNA, arrives.
Based on the new RTO, the retransmission timer is reset to reflect the
remaining time, or - if the revert clocked out the timer - a retransmission
is sent out immediately.
Backoffs are only reverted, if TCP is in RTO loss recovery, i.e. if
there have been retransmissions and reversible backoffs, already.
Changes from v2:
1) Renaming of skb in tcp_v4_err() moved to another patch.
2) Reintroduced tcp_bound_rto() and __tcp_set_rto().
3) Fixed code comments.
Somewhat luckily, I was looking into these parts with very fine
comb because I've made somewhat similar changes on the same
area (conflicts that arose weren't that lucky though). The loop
was very much overengineered recently in commit 915219441d566
(tcp: Use SKB queue and list helpers instead of doing it
by-hand), while it basically just wants to know if there are
skbs after 'skb'.
Also it got broken because skb1 = skb->next got translated into
skb1 = skb1->next (though abstracted) improperly. Note that
'skb1' is pointing to previous sk_buff than skb or NULL if at
head. Two things went wrong:
- We'll kfree 'skb' on the first iteration instead of the
skbuff following 'skb' (it would require required SACK reneging
to recover I think).
- The list head case where 'skb1' is NULL is checked too early
and the loop won't execute whereas it previously did.
Conclusion, mostly revert the recent changes which makes the
cset very messy looking but using proper accessor in the
previous-like version.
The effective changes against the original can be viewed with:
git-diff 915219441d566f1da0caa0e262be49b666159e17^ \
net/ipv4/tcp_input.c | sed -n -e '57,70 p'
include/net/tcp.h
tcp_prequeue() refers to the constant value (TCP_RTO_MIN) regardless of
the actual value might be tuned. The following patches fix this and make
tcp_prequeue get the actual value returns from tcp_rto_min().
Signed-off-by: Satoru SATOH <satoru.satoh@gmail.com>
This should be very safe compared with full enabled, so I see
no reason why it shouldn't be done right away. As ECN can only
be negotiated if the SYN sending party is also supporting it,
somebody in the loop probably knows what he/she is doing. If
SYN does not ask for ECN, the server side SYN-ACK is identical
to what it is without ECN. Thus it's quite safe.
The chosen value is safe w.r.t to existing configs which
choose to currently set manually either 0 or 1 but
silently upgrades those who have not explicitly requested
ECN off.
Whether to just enable both sides comes up time to time but
unless that gets done now we can at least make the servers
aware of ECN already. As there are some known problems to occur
if ECN is enabled, it's currently questionable whether there's
any real gain from enabling clients as servers mostly won't
support it anyway (so we'd hit just the negative sides). After
enabling the servers and getting that deployed, the client end
enable really has some potential gain too.
A long-standing feature in tcp_init_metrics() is such that
any of its goto reset prevents call to tcp_init_cwnd().
Discard incoming packets whose ack field iincludes data not yet sent.
This is consistent with RFC 793 Section 3.9.
Change tcp_ack() to distinguish between too-small and too-large ack
field values. Keep segments with too-large ack fields out of the fast
path, and change slow path to discard them.
Reported-by: Oliver Zheng <mailinglists+netdev@oliverzheng.com>
Signed-off-by: John Dykstra <john.dykstra1@gmail.com>
tcp_sack_swap seems unnecessary so I pushed swap to the caller.
Also removed comment that seemed then pointless, and added include
when not already there. Compile tested.
There's very little need for most of the callsites to get
tp->xmit_goal_size updated. That will cost us divide as is,
so slice the function in two. Also, the only users of the
tp->xmit_goal_size are directly behind tcp_current_mss(),
so there's no need to store that variable into tcp_sock
at all! The drop of xmit_goal_size currently leaves 16-bit
hole and some reorganization would again be necessary to
change that (but I'm aiming to fill that hole with u16
xmit_goal_size_segs to cache the results of the remaining
divide to get that tso on regression).
Bring xmit_goal_size parts into tcp.c
Cc: Evgeniy Polyakov <zbr@ioremap.net>
It seems that no variables clash such that we couldn't do
the check just once later on. Therefore move it.
Also kill dead obvious comment, dead argument and add
unlikely since this mtu probe does not happen too often.
Wow, it was quite tricky to merge that stream of negations
but I think I finally got it right:
check & replace_ts_recent:
(s32)(rcv_tsval - ts_recent) >= 0 => 0
(s32)(ts_recent - rcv_tsval) <= 0 => 0
discard:
(s32)(ts_recent - rcv_tsval) > TCP_PAWS_WINDOW => 1
(s32)(ts_recent - rcv_tsval) <= TCP_PAWS_WINDOW => 0
I toggled the return values of tcp_paws_check around since
the old encoding added yet-another negation making tracking
of truth-values really complicated.
