path: root/net/ipv4/tcp_htcp.c
2007-04-25[TCP]: Congestion control API update.Stephen Hemminger
Do some simple changes to make congestion control API faster/cleaner. * use ktime_t rather than timeval * merge rtt sampling into existing ack callback this means one indirect call versus two per ack. * use flags bits to store options/settings Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[TCP]: cleanup of htcp (resend)Stephen Hemminger
Minor non-invasive cleanups: * white space around operators and line wrapping * use const * use __read_mostly Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP] htcp: Better packing of struct htcp.David S. Miller
Based upon a patch by Joe Perches. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-25[TCP] H-TCP: fix integer overflowGavin McCullagh
When using H-TCP with a single flow on a 500Mbit connection (or less actually), alpha can exceed 65000, so alpha needs to be a u32. Signed-off-by: Gavin McCullagh <gavin.mccullagh@nuim.ie> Signed-off-by: Doug Leith <doug.leith@nuim.ie> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[TCP] Congestion control (modulo lp, bic): use BUILD_BUG_ONAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TCP]: Minimum congestion window consolidation.Stephen Hemminger
Many of the TCP congestion methods all just use ssthresh as the minimum congestion window on decrease. Rather than duplicating the code, just have that be the default if that handle in the ops structure is not set. Minor behaviour change to TCP compound. It probably wants to use this (ssthresh) as lower bound, rather than ssthresh/2 because the latter causes undershoot on loss. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TCP] H-TCP: Better time accountingBaruch Even
Instead of estimating the time since the last congestion event, count it directly. Signed-off-by: Baruch Even <baruch@ev-en.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TCP] H-TCP: Account for delayed-ACKsBaruch Even
Account for delayed-ACKs in H-TCP. Delayed-ACKs cause H-TCP to be less aggressive than its design calls for. It is especially true when the receiver is a Linux machine where the average delayed ack is over 3 packets with values of 7 not unheard of. Signed-off-By: Baruch Even <baruch@ev-en.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TCP] H-TCP: Use msecs_to_jiffiesBaruch Even
Use functions to calculate jiffies from milliseconds and not the old, crude method of dividing HZ by a value. Ensures more accurate values even in the face of strange HZ values. Signed-off-By: Baruch Even <baruch@ev-en.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-30[TCP] H-TCP: Fix accountingBaruch Even
This fixes the accounting in H-TCP, the ccount variable is also adjusted a few lines above this one. This line was not supposed to be there and wasn't there in the patches originally submitted, the four patches submitted were merged to one and in that merge the bug was introduced. Signed-Off-By: Baruch Even <baruch@ev-en.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: add tcp_slow_start helperStephen Hemminger
Move all the code that does linear TCP slowstart to one inline function to ease later patch to add ABC support. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: fix congestion window update when using TSO deferalStephen Hemminger
TCP peformance with TSO over networks with delay is awful. On a 100Mbit link with 150ms delay, we get 4Mbits/sec with TSO and 50Mbits/sec without TSO. The problem is with TSO, we intentionally do not keep the maximum number of packets in flight to fill the window, we hold out to until we can send a MSS chunk. But, we also don't update the congestion window unless we have filled, as per RFC2861. This patch replaces the check for the congestion window being full with something smarter that accounts for TSO. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Move TCP congestion avoidance members to icskArnaldo Carvalho de Melo
This changeset basically moves tcp_sk()->{ca_ops,ca_state,etc} to inet_csk(), minimal renaming/moving done in this changeset to ease review. Most of it is just changes of struct tcp_sock * to struct sock * parameters. With this we move to a state closer to two interesting goals: 1. Generalisation of net/ipv4/tcp_diag.c, becoming inet_diag.c, being used for any INET transport protocol that has struct inet_hashinfo and are derived from struct inet_connection_sock. Keeps the userspace API, that will just not display DCCP sockets, while newer versions of tools can support DCCP. 2. INET generic transport pluggable Congestion Avoidance infrastructure, using the current TCP CA infrastructure with DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add H-TCP congestion control module.Baruch Even
H-TCP is a congestion control algorithm developed at the Hamilton Institute, by Douglas Leith and Robert Shorten. It is extending the standard Reno algorithm with mode switching is thus a relatively simple modification. H-TCP is defined in a layered manner as it is still a research platform. The basic form includes the modification of beta according to the ratio of maxRTT to min RTT and the alpha=2*factor*(1-beta) relation, where factor is dependant on the time since last congestion. The other layers improve convergence by adding appropriate factors to alpha. The following patch implements the H-TCP algorithm in it's basic form. Signed-Off-By: Baruch Even <baruch@ev-en.org> Signed-off-by: David S. Miller <davem@davemloft.net>
