path: root/net/ipv4/tcp.c
2008-07-18mib: put tcp statistics on struct netPavel Emelyanov
Proc temporary uses stats from init_net. BTW, TCP_XXX_STATS are beautiful (w/o do { } while (0) facing) again :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to NET_ADD_STATS_USERPavel Emelyanov
Done with NET_XXX_STATS macros :) To be continued... Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to NET_INC_STATS_USERPavel Emelyanov
2008-07-16mib: add net to NET_INC_STATS_BHPavel Emelyanov
2008-07-16mib: add net to NET_INC_STATSPavel Emelyanov
2008-07-16sock: add net to prot->enter_memory_pressure callbackPavel Emelyanov
The tcp_enter_memory_pressure calls NET_INC_STATS, but doesn't have where to get the net from. I decided to add a sk argument, not the net itself, only to factor all the required sock_net(sk) calls inside the enter_memory_pressure callback itself. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to TCP_DEC_STATSPavel Emelyanov
2008-07-16mib: add net to TCP_INC_STATS_BHPavel Emelyanov
Same as before - the sock is always there to get the net from, but there are also some places with the net already saved on the stack. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to TCP_INC_STATSPavel Emelyanov
Fortunately (almost) all the TCP code has a sock to get the net from :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16net/ipv4/tcp.c: Fix use of PULLHUP instead of POLLHUP in comments.Will Newton
Change PULLHUP to POLLHUP in tcp_poll comments and clean up another comment for grammar and coding style. Signed-off-by: Will Newton <will.newton@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wan/hdlc_fr.c drivers/net/wireless/iwlwifi/iwl-4965.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2008-07-03tcp: fix a size_t < 0 comparison in tcp_read_sockOctavian Purdila
<used> should be of type int (not size_t) since recv_actor can return negative values and it is also used in a < 0 comparison. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03tcp: net/ipv4/tcp.c needs linux/scatterlist.hAndrew Morton
alpha: net/ipv4/tcp.c: In function 'tcp_calc_md5_hash': net/ipv4/tcp.c:2479: error: implicit declaration of function 'sg_init_table' net/ipv4/tcp.c:2482: error: implicit declaration of function 'sg_set_buf' net/ipv4/tcp.c:2507: error: implicit declaration of function 'sg_mark_end' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl4965-base.c
2008-06-27tcp: calculate tcp_mem based on low memory instead of all memoryMiquel van Smoorenburg
The tcp_mem array which contains limits on the total amount of memory used by TCP sockets is calculated based on nr_all_pages. On a 32 bits x86 system, we should base this on the number of lowmem pages. Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-12tcp: Revert 'process defer accept as established' changes.David S. Miller
This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87 ("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38 ("tcp: Fix slab corruption with ipv6 and tcp6fuzz"). This change causes several problems, first reported by Ingo Molnar as a distcc-over-loopback regression where connections were getting stuck. Ilpo Järvinen first spotted the locking problems. The new function added by this code, tcp_defer_accept_check(), only has the child socket locked, yet it is modifying state of the parent listening socket. Fixing that is non-trivial at best, because we can't simply just grab the parent listening socket lock at this point, because it would create an ABBA deadlock. The normal ordering is parent listening socket --> child socket, but this code path would require the reverse lock ordering. Next is a problem noticed by Vitaliy Gusev, he noted: ---------------------------------------- >--- a/net/ipv4/tcp_timer.c >+++ b/net/ipv4/tcp_timer.c >@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data) > goto death; > } > >+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) { >+ tcp_send_active_reset(sk, GFP_ATOMIC); >+ goto death; Here socket sk is not attached to listening socket's request queue. tcp_done() will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should release this sk) as socket is not DEAD. Therefore socket sk will be lost for freeing. ---------------------------------------- Finally, Alexey Kuznetsov argues that there might not even be any real value or advantage to these new semantics even if we fix all of the bugs: ---------------------------------------- Hiding from accept() sockets with only out-of-order data only is the only thing which is impossible with old approach. Is this really so valuable? My opinion: no, this is nothing but a new loophole to consume memory without control. ---------------------------------------- So revert this thing for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11Merge branch 'net-next-2.6-misc-20080612a' of ↵David S. Miller
git://git.linux-ipv6.org/gitroot/yoshfuji/linux-2.6-next
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12tcp md5sig: Share most of hash calcucaltion bits between IPv4 and IPv6.YOSHIFUJI Hideaki
We can share most part of the hash calculation code because the only difference between IPv4 and IPv6 is their pseudo headers. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-06-04tcp: Fix for race due to temporary drop of the socket lock in skb_splice_bits.Octavian Purdila
skb_splice_bits temporary drops the socket lock while iterating over the socket queue in order to break a reverse locking condition which happens with sendfile. This, however, opens a window of opportunity for tcp_collapse() to aggregate skbs and thus potentially free the current skb used in skb_splice_bits and tcp_read_sock. This patch fixes the problem by (re-)getting the same "logical skb" after the lock has been temporary dropped. Based on idea and initial patch from Evgeniy Polyakov. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21tcp: Trivial fix to correct function name in a comment in net/ipv4/tcp.cSatoru SATOH
This is a trivial fix to correct function name in a comment in net/ipv4/tcp.c. Signed-off-by: Satoru SATOH <satoru.satoh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-23Merge branch 'master' of ../net-2.6/David S. Miller
Conflicts: net/ipv6/ndisc.c
2008-03-22[TCP]: Let skbs grow over a page on fast peersHerbert Xu
While testing the virtio-net driver on KVM with TSO I noticed that TSO performance with a 1500 MTU is significantly worse compared to the performance of non-TSO with a 16436 MTU. The packet dump shows that most of the packets sent are smaller than a page. Looking at the code this actually is quite obvious as it always stop extending the packet if it's the first packet yet to be sent and if it's larger than the MSS. Since each extension is bound by the page size, this means that (given a 1500 MTU) we're very unlikely to construct packets greater than a page, provided that the receiver and the path is fast enough so that packets can always be sent immediately. The fix is also quite obvious. The push calls inside the loop is just an optimisation so that we don't end up doing all the sending at the end of the loop. Therefore there is no specific reason why it has to do so at MSS boundaries. For TSO, the most natural extension of this optimisation is to do the pushing once the skb exceeds the TSO size goal. This is what the patch does and testing with KVM shows that the TSO performance with a 1500 MTU easily surpasses that of a 16436 MTU and indeed the packet sizes sent are generally larger than 16436. I don't see any obvious downsides for slower peers or connections, but it would be prudent to test this extensively to ensure that those cases don't regress. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - process as establishedPatrick McManus
Change TCP_DEFER_ACCEPT implementation so that it transitions a connection to ESTABLISHED after handshake is complete instead of leaving it in SYN-RECV until some data arrvies. Place connection in accept queue when first data packet arrives from slow path. Benefits: - established connection is now reset if it never makes it to the accept queue - diagnostic state of established matches with the packet traces showing completed handshake - TCP_DEFER_ACCEPT timeouts are expressed in seconds and can now be enforced with reasonable accuracy instead of rounding up to next exponential back-off of syn-ack retry. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03[SOCK] proto: Add hashinfo member to struct protoArnaldo Carvalho de Melo
This way we can remove TCP and DCCP specific versions of sk->sk_prot->get_port: both v4 and v6 use inet_csk_get_port sk->sk_prot->hash: inet_hash is directly used, only v6 need a specific version to deal with mapped sockets sk->sk_prot->unhash: both v4 and v6 use inet_hash directly struct inet_connection_sock_af_ops also gets a new member, bind_conflict, so that inet_csk_get_port can find the per family routine. Now only the lookup routines receive as a parameter a struct inet_hashtable. With this we further reuse code, reducing the difference among INET transport protocols. Eventually work has to be done on UDP and SCTP to make them share this infrastructure and get as a bonus inet_diag interfaces so that iproute can be used with these protocols. net-2.6/net/ipv4/inet_hashtables.c: struct proto | +8 struct inet_connection_sock_af_ops | +8 2 structs changed __inet_hash_nolisten | +18 __inet_hash | -210 inet_put_port | +8 inet_bind_bucket_create | +1 __inet_hash_connect | -8 5 functions changed, 27 bytes added, 218 bytes removed, diff: -191 net-2.6/net/core/sock.c: proto_seq_show | +3 1 function changed, 3 bytes added, diff: +3 net-2.6/net/ipv4/inet_connection_sock.c: inet_csk_get_port | +15 1 function changed, 15 bytes added, diff: +15 net-2.6/net/ipv4/tcp.c: tcp_set_state | -7 1 function changed, 7 bytes removed, diff: -7 net-2.6/net/ipv4/tcp_ipv4.c: tcp_v4_get_port | -31 tcp_v4_hash | -48 tcp_v4_destroy_sock | -7 tcp_v4_syn_recv_sock | -2 tcp_unhash | -179 5 functions changed, 267 bytes removed, diff: -267 net-2.6/net/ipv6/inet6_hashtables.c: __inet6_hash | +8 1 function changed, 8 bytes added, diff: +8 net-2.6/net/ipv4/inet_hashtables.c: inet_unhash | +190 inet_hash | +242 2 functions changed, 432 bytes added, diff: +432 vmlinux: 16 functions changed, 485 bytes added, 492 bytes removed, diff: -7 /home/acme/git/net-2.6/net/ipv6/tcp_ipv6.c: tcp_v6_get_port | -31 tcp_v6_hash | -7 tcp_v6_syn_recv_sock | -9 3 functions changed, 47 bytes removed, diff: -47 /home/acme/git/net-2.6/net/dccp/proto.c: dccp_destroy_sock | -7 dccp_unhash | -179 dccp_hash | -49 dccp_set_state | -7 dccp_done | +1 5 functions changed, 1 bytes added, 242 bytes removed, diff: -241 /home/acme/git/net-2.6/net/dccp/ipv4.c: dccp_v4_get_port | -31 dccp_v4_request_recv_sock | -2 2 functions changed, 33 bytes removed, diff: -33 /home/acme/git/net-2.6/net/dccp/ipv6.c: dccp_v6_get_port | -31 dccp_v6_hash | -7 dccp_v6_request_recv_sock | +5 3 functions changed, 5 bytes added, 38 bytes removed, diff: -33 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Uninline tcp_set_stateIlpo Järvinen
net/ipv4/tcp.c: tcp_close_state | -226 tcp_done | -145 tcp_close | -564 tcp_disconnect | -141 4 functions changed, 1076 bytes removed, diff: -1076 net/ipv4/tcp_input.c: tcp_fin | -86 tcp_rcv_state_process | -164 2 functions changed, 250 bytes removed, diff: -250 net/ipv4/tcp_ipv4.c: tcp_v4_connect | -209 1 function changed, 209 bytes removed, diff: -209 net/ipv4/arp.c: arp_ignore | +5 1 function changed, 5 bytes added, diff: +5 net/ipv6/tcp_ipv6.c: tcp_v6_connect | -158 1 function changed, 158 bytes removed, diff: -158 net/sunrpc/xprtsock.c: xs_sendpages | -2 1 function changed, 2 bytes removed, diff: -2 net/dccp/ccids/ccid3.c: ccid3_update_send_interval | +7 1 function changed, 7 bytes added, diff: +7 net/ipv4/tcp.c: tcp_set_state | +238 1 function changed, 238 bytes added, diff: +238 built-in.o: 12 functions changed, 250 bytes added, 1695 bytes removed, diff: -1445 I've no explanation why some unrelated changes seem to occur consistently as well (arp_ignore, ccid3_update_send_interval; I checked the arp_ignore asm and it seems to be due to some reordered of operation order causing some extra opcodes to be generated). Still, the benefits are pretty obvious from the codiff's results. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Remove TCPCB_URG & TCPCB_AT_TAIL as unnecessaryIlpo Järvinen
The snd_up check should be enough. I suspect this has been there to provide a minor optimization in clean_rtx_queue which used to have a small if (!->sacked) block which could skip snd_up check among the other work. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET] CORE: Introducing new memory accounting interface.Hideo Aoki
This patch introduces new memory accounting functions for each network protocol. Most of them are renamed from memory accounting functions for stream protocols. At the same time, some stream memory accounting functions are removed since other functions do same thing. Renaming: sk_stream_free_skb() -> sk_wmem_free_skb() __sk_stream_mem_reclaim() -> __sk_mem_reclaim() sk_stream_mem_reclaim() -> sk_mem_reclaim() sk_stream_mem_schedule -> __sk_mem_schedule() sk_stream_pages() -> sk_mem_pages() sk_stream_rmem_schedule() -> sk_rmem_schedule() sk_stream_wmem_schedule() -> sk_wmem_schedule() sk_charge_skb() -> sk_mem_charge() Removeing sk_stream_rfree(): consolidates into sock_rfree() sk_stream_set_owner_r(): consolidates into skb_set_owner_r() sk_stream_mem_schedule() The following functions are added. sk_has_account(): check if the protocol supports accounting sk_mem_uncharge(): do the opposite of sk_mem_charge() In addition, to achieve consolidation, updating sk_wmem_queued is removed from sk_mem_charge(). Next, to consolidate memory accounting functions, this patch adds memory accounting calls to network core functions. Moreover, present memory accounting call is renamed to new accounting call. Finally we replace present memory accounting calls with new interface in TCP and SCTP. Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Hideo Aoki <haoki@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Use BUILD_BUG_ON for tcp_skb_cb size checkingPavel Emelyanov
The sizeof(struct tcp_skb_cb) should not be less than the sizeof(skb->cb). This is checked in net/ipv4/tcp.c, but this check can be made more gracefully. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Eliminate unused argument from sk_stream_alloc_pskbPavel Emelyanov
The 3rd argument is always zero (according to grep :) Eliminate it and merge the function with sk_stream_alloc_skb. This saves 44 more bytes, and together with the previous patch we have: add/remove: 1/0 grow/shrink: 0/8 up/down: 183/-751 (-568) function old new delta sk_stream_alloc_skb - 183 +183 ip_rt_init 529 525 -4 arp_ignore 112 107 -5 __inet_lookup_listener 284 274 -10 tcp_sendmsg 2583 2481 -102 tcp_sendpage 1449 1300 -149 tso_fragment 417 258 -159 tcp_fragment 1149 988 -161 __tcp_push_pending_frames 1998 1837 -161 Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Uninline the sk_stream_alloc_pskbPavel Emelyanov
This function seems too big for inlining. Indeed, it saves half-a-kilo when uninlined: add/remove: 1/0 grow/shrink: 0/7 up/down: 195/-719 (-524) function old new delta sk_stream_alloc_pskb - 195 +195 ip_rt_init 529 525 -4 __inet_lookup_listener 284 274 -10 tcp_sendmsg 2583 2486 -97 tcp_sendpage 1449 1305 -144 tso_fragment 417 267 -150 tcp_fragment 1149 992 -157 __tcp_push_pending_frames 1998 1841 -157 Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Make tcp_splice_data_recv() static.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Splice receive support.Jens Axboe
Support for network splice receive. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07[INET]: Remove per bucket rwlock in tcp/dccp ehash table.Eric Dumazet
As done two years ago on IP route cache table (commit 22c047ccbc68fa8f3fa57f0e8f906479a062c426) , we can avoid using one lock per hash bucket for the huge TCP/DCCP hash tables. On a typical x86_64 platform, this saves about 2MB or 4MB of ram, for litle performance differences. (we hit a different cache line for the rwlock, but then the bucket cache line have a better sharing factor among cpus, since we dirty it less often). For netstat or ss commands that want a full scan of hash table, we perform fewer memory accesses. Using a 'small' table of hashed rwlocks should be more than enough to provide correct SMP concurrency between different buckets, without using too much memory. Sizing of this table depends on num_possible_cpus() and various CONFIG settings. This patch provides some locking abstraction that may ease a future work using a different model for TCP/DCCP table. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-30[TCP]: Saner thash_entries default with much memory.Jean Delvare
On systems with a very large amount of memory, the heuristics in alloc_large_system_hash() result in a very large TCP established hash table: 16 millions of entries for a 128 GB ia64 system. This makes reading from /proc/net/tcp pretty slow (well over a second) and as a result netstat is slow on these machines. I know that /proc/net/tcp is deprecated in favor of tcp_diag, however at the moment netstat only knows of the former. I am skeptical that such a large TCP established hash is often needed. Just because a system has a lot of memory doesn't imply that it will have several millions of concurrent TCP connections. Thus I believe that we should put an arbitrary high limit to the size of the TCP established hash by default. Users who really need a bigger hash can always use the thash_entries boot parameter to get more. I propose 2 millions of entries as the arbitrary high limit. This makes /proc/net/tcp reasonably fast on the system in question (0.2 s) while being still large enough for me to be confident that network performance won't suffer. This is just one way to limit the hash size, there are others; I am not familiar enough with the TCP code to decide which is best. Thus, I would welcome the proposals of alternatives. [ 2 million is still too large, thus I've modified the limit in the change to be '512 * 1024'. -DaveM ] Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[TCP]: Return useful listenq info in tcp_info and INET_DIAG_INFO.Rick Jones
Return some useful information such as the maximum listen backlog and the current listen backlog in the tcp_info structure and INET_DIAG_INFO. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: DIV_ROUND_UP cleanup (part two)Ilpo Järvinen
Hopefully captured all single statement cases under net/. I'm not too sure if there is some policy about #includes that are "guaranteed" (ie., in the current tree) to be available through some other #included header, so I just added linux/kernel.h to each changed file that didn't #include it previously. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP]: Move sack_ok access to obviously named funcs & cleanupIlpo Järvinen
Previously code had IsReno/IsFack defined as macros that were local to tcp_input.c though sack_ok field has user elsewhere too for the same purpose. This changes them to static inlines as preferred according the current coding style and unifies the access to sack_ok across multiple files. Magic bitops of sack_ok for FACK and DSACK are also abstracted to functions with appropriate names. Note: - One sack_ok = 1 remains but that's self explanary, i.e., it enables sack - Couple of !IsReno cases are changed to tcp_is_sack - There were no users for IsDSack => I dropped it Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-02[TCP]: Invoke tcp_sendmsg() directly, do not use inet_sendmsg().David S. Miller
As discovered by Evegniy Polyakov, if we try to sendmsg after a connection reset, we can do incredibly stupid things. The core issue is that inet_sendmsg() tries to autobind the socket, but we should never do that for TCP. Instead we should just go straight into TCP's sendmsg() code which will do all of the necessary state and pending socket error checks. TCP's sendpage already directly vectors to tcp_sendpage(), so this merely brings sendmsg() in line with that. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11I/OAT: warning fixAndrew Morton
net/ipv4/tcp.c: In function 'tcp_recvmsg': net/ipv4/tcp.c:1111: warning: unused variable 'available' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Leech <christopher.leech@intel.com>
2007-07-11I/OAT: Only offload copies for TCP when there will be a context switchChris Leech
The performance wins come with having the DMA copy engine doing the copies in parallel with the context switch. If there is enough data ready on the socket at recv time just use a regular copy. Signed-off-by: Chris Leech <christopher.leech@intel.com>
2007-06-23[TCP] tcp_read_sock: Allow recv_actor() return return negative error value.Jens Axboe
tcp_read_sock() currently assumes that the recv_actor() only returns number of bytes copied. For network splice receive, we may have to return an error in some cases. So allow the actor to return a negative error value. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[TCP]: Use default 32768-61000 outgoing port range in all cases.Mark Glines
This diff changes the default port range used for outgoing connections, from "use 32768-61000 in most cases, but use N-4999 on small boxes (where N is a multiple of 1024, depending on just *how* small the box is)" to just "use 32768-61000 in all cases". I don't believe there are any drawbacks to this change, and it keeps outgoing connection ports farther away from the mess of IANA-registered ports. Signed-off-by: Mark Glines <mark@glines.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[TCP]: Consolidate checking for tcp orphan count being too big.Pavel Emelianov
tcp_out_of_resources() and tcp_close() perform the same checking of number of orphan sockets. Move this code into common place. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[TCP]: zero out rx_opt in tcp_disconnect()Srinivas Aji
When the server drops its connection, NFS client reconnects using the same socket after disconnecting. If the new connection's SYN,ACK doesn't contain the TCP timestamp option and the old connection's did, tp->tcp_header_len is recomputed assuming no timestamp header but tp->rx_opt.tstamp_ok remains set. Then tcp_build_and_update_options() adds in a timestamp option past the end of the allocated TCP header, overwriting TCP data, or when the data is in skb_shinfo(skb)->frags[], overwriting skb_shinfo(skb) causing a crash soon after. (The issue was debugged from such a crash.) Similarly, wscale_ok and sack_ok also get set based on the SYN,ACK packet but not reset on disconnect, since they are zeroed out at initialization. The patch zeroes out the entire tp->rx_opt struct in tcp_disconnect() to avoid this sort of problem. Signed-off-by: Srinivas Aji <Aji_Srinivas@emc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[TCP]: Update references in two old commentsGerrit Renker
This updates references to drafts in comments which must be about 10 years old. Internet draft draft-ietf-tcpimpl-prob-03.txt expired in 1998 and was replaced by RFC 2525 in March 1999. Section 3.10 of the draft maps almost identically into section 2.17 of RFC 2525: both are entitled "Failure to RST on close with data pending", the differences in text body amount to a typo and minor sentence change. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
