path: root/net/ipv4/tcp.c
2008-01-28[TCP]: Remove TCPCB_URG & TCPCB_AT_TAIL as unnecessaryIlpo Järvinen
The snd_up check should be enough. I suspect this has been there to provide a minor optimization in clean_rtx_queue which used to have a small if (!->sacked) block which could skip snd_up check among the other work. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET] CORE: Introducing new memory accounting interface.Hideo Aoki
This patch introduces new memory accounting functions for each network protocol. Most of them are renamed from memory accounting functions for stream protocols. At the same time, some stream memory accounting functions are removed since other functions do same thing. Renaming: sk_stream_free_skb() -> sk_wmem_free_skb() __sk_stream_mem_reclaim() -> __sk_mem_reclaim() sk_stream_mem_reclaim() -> sk_mem_reclaim() sk_stream_mem_schedule -> __sk_mem_schedule() sk_stream_pages() -> sk_mem_pages() sk_stream_rmem_schedule() -> sk_rmem_schedule() sk_stream_wmem_schedule() -> sk_wmem_schedule() sk_charge_skb() -> sk_mem_charge() Removeing sk_stream_rfree(): consolidates into sock_rfree() sk_stream_set_owner_r(): consolidates into skb_set_owner_r() sk_stream_mem_schedule() The following functions are added. sk_has_account(): check if the protocol supports accounting sk_mem_uncharge(): do the opposite of sk_mem_charge() In addition, to achieve consolidation, updating sk_wmem_queued is removed from sk_mem_charge(). Next, to consolidate memory accounting functions, this patch adds memory accounting calls to network core functions. Moreover, present memory accounting call is renamed to new accounting call. Finally we replace present memory accounting calls with new interface in TCP and SCTP. Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Hideo Aoki <haoki@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Use BUILD_BUG_ON for tcp_skb_cb size checkingPavel Emelyanov
The sizeof(struct tcp_skb_cb) should not be less than the sizeof(skb->cb). This is checked in net/ipv4/tcp.c, but this check can be made more gracefully. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Eliminate unused argument from sk_stream_alloc_pskbPavel Emelyanov
The 3rd argument is always zero (according to grep :) Eliminate it and merge the function with sk_stream_alloc_skb. This saves 44 more bytes, and together with the previous patch we have: add/remove: 1/0 grow/shrink: 0/8 up/down: 183/-751 (-568) function old new delta sk_stream_alloc_skb - 183 +183 ip_rt_init 529 525 -4 arp_ignore 112 107 -5 __inet_lookup_listener 284 274 -10 tcp_sendmsg 2583 2481 -102 tcp_sendpage 1449 1300 -149 tso_fragment 417 258 -159 tcp_fragment 1149 988 -161 __tcp_push_pending_frames 1998 1837 -161 Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Uninline the sk_stream_alloc_pskbPavel Emelyanov
This function seems too big for inlining. Indeed, it saves half-a-kilo when uninlined: add/remove: 1/0 grow/shrink: 0/7 up/down: 195/-719 (-524) function old new delta sk_stream_alloc_pskb - 195 +195 ip_rt_init 529 525 -4 __inet_lookup_listener 284 274 -10 tcp_sendmsg 2583 2486 -97 tcp_sendpage 1449 1305 -144 tso_fragment 417 267 -150 tcp_fragment 1149 992 -157 __tcp_push_pending_frames 1998 1841 -157 Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Make tcp_splice_data_recv() static.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Splice receive support.Jens Axboe
Support for network splice receive. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07[INET]: Remove per bucket rwlock in tcp/dccp ehash table.Eric Dumazet
As done two years ago on IP route cache table (commit 22c047ccbc68fa8f3fa57f0e8f906479a062c426) , we can avoid using one lock per hash bucket for the huge TCP/DCCP hash tables. On a typical x86_64 platform, this saves about 2MB or 4MB of ram, for litle performance differences. (we hit a different cache line for the rwlock, but then the bucket cache line have a better sharing factor among cpus, since we dirty it less often). For netstat or ss commands that want a full scan of hash table, we perform fewer memory accesses. Using a 'small' table of hashed rwlocks should be more than enough to provide correct SMP concurrency between different buckets, without using too much memory. Sizing of this table depends on num_possible_cpus() and various CONFIG settings. This patch provides some locking abstraction that may ease a future work using a different model for TCP/DCCP table. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-30[TCP]: Saner thash_entries default with much memory.Jean Delvare
On systems with a very large amount of memory, the heuristics in alloc_large_system_hash() result in a very large TCP established hash table: 16 millions of entries for a 128 GB ia64 system. This makes reading from /proc/net/tcp pretty slow (well over a second) and as a result netstat is slow on these machines. I know that /proc/net/tcp is deprecated in favor of tcp_diag, however at the moment netstat only knows of the former. I am skeptical that such a large TCP established hash is often needed. Just because a system has a lot of memory doesn't imply that it will have several millions of concurrent TCP connections. Thus I believe that we should put an arbitrary high limit to the size of the TCP established hash by default. Users who really need a bigger hash can always use the thash_entries boot parameter to get more. I propose 2 millions of entries as the arbitrary high limit. This makes /proc/net/tcp reasonably fast on the system in question (0.2 s) while being still large enough for me to be confident that network performance won't suffer. This is just one way to limit the hash size, there are others; I am not familiar enough with the TCP code to decide which is best. Thus, I would welcome the proposals of alternatives. [ 2 million is still too large, thus I've modified the limit in the change to be '512 * 1024'. -DaveM ] Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[TCP]: Return useful listenq info in tcp_info and INET_DIAG_INFO.Rick Jones
Return some useful information such as the maximum listen backlog and the current listen backlog in the tcp_info structure and INET_DIAG_INFO. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: DIV_ROUND_UP cleanup (part two)Ilpo Järvinen
Hopefully captured all single statement cases under net/. I'm not too sure if there is some policy about #includes that are "guaranteed" (ie., in the current tree) to be available through some other #included header, so I just added linux/kernel.h to each changed file that didn't #include it previously. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP]: Move sack_ok access to obviously named funcs & cleanupIlpo Järvinen
Previously code had IsReno/IsFack defined as macros that were local to tcp_input.c though sack_ok field has user elsewhere too for the same purpose. This changes them to static inlines as preferred according the current coding style and unifies the access to sack_ok across multiple files. Magic bitops of sack_ok for FACK and DSACK are also abstracted to functions with appropriate names. Note: - One sack_ok = 1 remains but that's self explanary, i.e., it enables sack - Couple of !IsReno cases are changed to tcp_is_sack - There were no users for IsDSack => I dropped it Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-02[TCP]: Invoke tcp_sendmsg() directly, do not use inet_sendmsg().David S. Miller
As discovered by Evegniy Polyakov, if we try to sendmsg after a connection reset, we can do incredibly stupid things. The core issue is that inet_sendmsg() tries to autobind the socket, but we should never do that for TCP. Instead we should just go straight into TCP's sendmsg() code which will do all of the necessary state and pending socket error checks. TCP's sendpage already directly vectors to tcp_sendpage(), so this merely brings sendmsg() in line with that. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11I/OAT: warning fixAndrew Morton
net/ipv4/tcp.c: In function 'tcp_recvmsg': net/ipv4/tcp.c:1111: warning: unused variable 'available' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Leech <christopher.leech@intel.com>
2007-07-11I/OAT: Only offload copies for TCP when there will be a context switchChris Leech
The performance wins come with having the DMA copy engine doing the copies in parallel with the context switch. If there is enough data ready on the socket at recv time just use a regular copy. Signed-off-by: Chris Leech <christopher.leech@intel.com>
2007-06-23[TCP] tcp_read_sock: Allow recv_actor() return return negative error value.Jens Axboe
tcp_read_sock() currently assumes that the recv_actor() only returns number of bytes copied. For network splice receive, we may have to return an error in some cases. So allow the actor to return a negative error value. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[TCP]: Use default 32768-61000 outgoing port range in all cases.Mark Glines
This diff changes the default port range used for outgoing connections, from "use 32768-61000 in most cases, but use N-4999 on small boxes (where N is a multiple of 1024, depending on just *how* small the box is)" to just "use 32768-61000 in all cases". I don't believe there are any drawbacks to this change, and it keeps outgoing connection ports farther away from the mess of IANA-registered ports. Signed-off-by: Mark Glines <mark@glines.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[TCP]: Consolidate checking for tcp orphan count being too big.Pavel Emelianov
tcp_out_of_resources() and tcp_close() perform the same checking of number of orphan sockets. Move this code into common place. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[TCP]: zero out rx_opt in tcp_disconnect()Srinivas Aji
When the server drops its connection, NFS client reconnects using the same socket after disconnecting. If the new connection's SYN,ACK doesn't contain the TCP timestamp option and the old connection's did, tp->tcp_header_len is recomputed assuming no timestamp header but tp->rx_opt.tstamp_ok remains set. Then tcp_build_and_update_options() adds in a timestamp option past the end of the allocated TCP header, overwriting TCP data, or when the data is in skb_shinfo(skb)->frags[], overwriting skb_shinfo(skb) causing a crash soon after. (The issue was debugged from such a crash.) Similarly, wscale_ok and sack_ok also get set based on the SYN,ACK packet but not reset on disconnect, since they are zeroed out at initialization. The patch zeroes out the entire tp->rx_opt struct in tcp_disconnect() to avoid this sort of problem. Signed-off-by: Srinivas Aji <Aji_Srinivas@emc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[TCP]: Update references in two old commentsGerrit Renker
This updates references to drafts in comments which must be about 10 years old. Internet draft draft-ietf-tcpimpl-prob-03.txt expired in 1998 and was replaced by RFC 2525 in March 1999. Section 3.10 of the draft maps almost identically into section 2.17 of RFC 2525: both are entitled "Failure to RST on close with data pending", the differences in text body amount to a typo and minor sentence change. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Sed magic converts func(sk, tp, ...) -> func(sk, ...)Ilpo Järvinen
This is (mostly) automated change using magic: sed -e '/struct sock \*sk/ N' -e '/struct sock \*sk/ N' -e '/struct sock \*sk/ N' -e '/struct sock \*sk/ N' -e 's|struct sock \*sk,[\n\t ]*struct tcp_sock \*tp\([^{]*\n{\n\)| struct sock \*sk\1\tstruct tcp_sock *tp = tcp_sk(sk);\n|g' -e 's|struct sock \*sk, struct tcp_sock \*tp| struct sock \*sk|g' -e 's|sk, tp\([^-]\)|sk\1|g' Fixed four unused variable (tp) warnings that were introduced. In addition, manually added newlines after local variables and tweaked function arguments positioning. $ gcc --version gcc (GCC) 4.1.1 20060525 (Red Hat 4.1.1-1) ... $ codiff -fV built-in.o.old built-in.o.new net/ipv4/route.c: rt_cache_flush | +14 1 function changed, 14 bytes added net/ipv4/tcp.c: tcp_setsockopt | -5 tcp_sendpage | -25 tcp_sendmsg | -16 3 functions changed, 46 bytes removed net/ipv4/tcp_input.c: tcp_try_undo_recovery | +3 tcp_try_undo_dsack | +2 tcp_mark_head_lost | -12 tcp_ack | -15 tcp_event_data_recv | -32 tcp_rcv_state_process | -10 tcp_rcv_established | +1 7 functions changed, 6 bytes added, 69 bytes removed, diff: -63 net/ipv4/tcp_output.c: update_send_head | -9 tcp_transmit_skb | +19 tcp_cwnd_validate | +1 tcp_write_wakeup | -17 __tcp_push_pending_frames | -25 tcp_push_one | -8 tcp_send_fin | -4 7 functions changed, 20 bytes added, 63 bytes removed, diff: -43 built-in.o.new: 18 functions changed, 40 bytes added, 178 bytes removed, diff: -138 Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Uninline tcp_done().Andi Kleen
The function is quite big and has several call sites and nothing to collapse by compiler optimization on inlining. Besides it's nicer to read in a in .c file. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: tcp_memory_pressure and tcp_socket are__read_mostly candidatesEric Dumazet
tcp_memory_pressure and tcp_socket currently share a cache line with tcp_memory_allocated, tcp_sockets_allocated. (Very hot cache line) It makes sense to declare these variables as __read_mostly, to avoid false sharing on SMP. ffffffff8081d9c0 B tcp_orphan_count ffffffff8081d9c4 B tcp_memory_allocated ffffffff8081d9c8 B tcp_sockets_allocated ffffffff8081d9cc B tcp_memory_pressure ffffffff8081d9d0 b tcp_md5sig_users ffffffff8081d9d8 b tcp_md5sig_pool ffffffff8081d9e0 b warntime.31570 ffffffff8081d9e8 b tcp_socket Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce tcp_hdr(), remove skb->h.thArnaldo Carvalho de Melo
2007-04-25[TCP]: Abstract out all write queue operations.David S. Miller
This allows the write queue implementation to be changed, for example, to one which allows fast interval searching. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-16[TCP]: Fix tcp_mem[] initialization.John Heffner
Change tcp_mem initialization function. The fraction of total memory is now a continuous function of memory size, and independent of page size. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-26[TCP]: Fix MD5 signature pool locking.David S. Miller
The locking calls assumed that these code paths were only invoked in software interrupt context, but that isn't true. Therefore we need to use spin_{lock,unlock}_bh() throughout. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NET]: change layout of ehash tableEric Dumazet
ehash table layout is currently this one : First half of this table is used by sockets not in TIME_WAIT state Second half of it is used by sockets in TIME_WAIT state. This is non optimal because of for a given hash or socket, the two chain heads are located in separate cache lines. Moreover the locks of the second half are never used. If instead of this halving, we use two list heads in inet_ehash_bucket instead of only one, we probably can avoid one cache miss, and reduce ram usage, particularly if sizeof(rwlock_t) is big (various CONFIG_DEBUG_SPINLOCK, CONFIG_DEBUG_LOCK_ALLOC settings). So we still halves the table but we keep together related chains to speedup lookups and socket state change. In this patch I did not try to align struct inet_ehash_bucket, but a future patch could try to make this structure have a convenient size (a power of two or a multiple of L1_CACHE_SIZE). I guess rwlock will just vanish as soon as RCU is plugged into ehash :) , so maybe we dont need to scratch our heads to align the bucket... Note : In case struct inet_ehash_bucket is not a power of two, we could probably change alloc_large_system_hash() (in case it use __get_free_pages()) to free the unused space. It currently allocates a big zone, but the last quarter of it could be freed. Again, this should be a temporary 'problem'. Patch tested on ipv4 tcp only, but should be OK for IPV6 and DCCP. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[TCP]: Fix oops caused by __tcp_put_md5sig_pool()David S. Miller
It should call tcp_free_md5sig_pool() not __tcp_free_md5sig_pool() so that it does proper refcounting. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Possible cleanups.Adrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global functions statis: - ipv4/tcp.c: __tcp_alloc_md5sig_pool() - ipv4/tcp_ipv4.c: tcp_v4_reqsk_md5_lookup() - ipv4/udplite.c: udplite_rcv() - ipv4/udplite.c: udplite_err() - make the following needlessly global structs static: - ipv4/tcp_ipv4.c: tcp_request_sock_ipv4_ops - ipv4/tcp_ipv4.c: tcp_sock_ipv4_specific - ipv6/tcp_ipv6.c: tcp_request_sock_ipv6_ops - net/ipv{4,6}/udplite.c: remove inline's from static functions (gcc should know best when to inline them) Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: Tidy up skb_entailArnaldo Carvalho de Melo
Heck, it even saves us some few bytes: [acme@newtoy net-2.6.20]$ codiff -f /tmp/tcp.o.before ../OUTPUT/qemu/net-2.6.20/net/ipv4/tcp.o /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv4/tcp.c: tcp_sendpage | -7 tcp_sendmsg | -5 2 functions changed, 12 bytes removed [acme@newtoy net-2.6.20]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[NET]: Annotate callers of csum_fold() in net/*Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: MD5 Signature Option (RFC2385) support.YOSHIFUJI Hideaki
Based on implementation by Rick Payne. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-15[TCP]: Fix up sysctl_tcp_mem initialization.John Heffner
Fix up tcp_mem initial settings to take into account the size of the hash entries (different on SMP and non-SMP systems). Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-07[TCP]: Don't use highmem in tcp hash size calculation.John Heffner
This patch removes consideration of high memory when determining TCP hash table sizes. Taking into account high memory results in tcp_mem values that are too large. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[TCP]: Send ACKs each 2nd received segment.Alexey Kuznetsov
It does not affect either mss-sized connections (obviously) or connections controlled by Nagle (because there is only one small segment in flight). The idea is to record the fact that a small segment arrives on a connection, where one small segment has already been received and still not-ACKed. In this case ACK is forced after tcp_recvmsg() drains receive buffer. In other words, it is a "soft" each-2nd-segment ACK, which is enough to preserve ACK clock even when ABC is enabled. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Use SLAB_PANICAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET/IPV4/IPV6]: Change some sysctl variables to __read_mostlyBrian Haley
Change net/core, ipv4 and ipv6 sysctl variables to __read_mostly. Couldn't actually measure any performance increase while testing (.3% I consider noise), but seems like the right thing to do. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: Fix more per-cpu typosAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[TCP]: Process linger2 timeout consistently.David S. Miller
Based upon guidance from Alexey Kuznetsov. When linger2 is active, we check to see if the fin_wait2 timeout is longer than the timewait. If it is, we schedule the keepalive timer for the difference between the timewait timeout and the fin_wait2 timeout. When this orphan socket is seen by tcp_keepalive_timer() it will try to transform this fin_wait2 socket into a fin_wait2 mini-socket, again if linger2 is active. Not all paths were setting this initial keepalive timer correctly. The tcp input path was doing it correctly, but tcp_close() wasn't, potentially making the socket linger longer than it really needs to. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-03[NET]: Verify gso_type too in gso_segmentHerbert Xu
We don't want nasty Xen guests to pass a TCPv6 packet in with gso_type set to TCPv4 or even UDP (or a packet that's both TCP and UDP). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IPV6]: Added GSO support for TCPv6 [NET]: Generalise TSO-specific bits from skb_setup_caps [IPV6]: Added GSO support for TCPv6 [IPV6]: Remove redundant length check on input [NETFILTER]: SCTP conntrack: fix crash triggered by packet without chunks [TG3]: Update version and reldate [TG3]: Add TSO workaround using GSO [TG3]: Turn on hw fix for ASF problems [TG3]: Add rx BD workaround [TG3]: Add tg3_netif_stop() in vlan functions [TCP]: Reset gso_segs if packet is dodgy
