path: root/net/ipv4/route.c
2011-06-09net: pmtu_expires fixesEric Dumazet
commit 2c8cec5c10bc (ipv4: Cache learned PMTU information in inetpeer) added some racy peer->pmtu_expires accesses. As its value can be changed by another cpu/thread, we should be more careful, reading its value once. Add peer_pmtu_expired() and peer_pmtu_cleaned() helpers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22ipv4: Give backtrace in ip_rt_bug().Dave Jones
Add a stack backtrace to the ip_rt_bug path for debugging Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18ipv4: Pass explicit destination address to rt_bind_peer().David S. Miller
2011-05-18ipv4: Kill RT_CACHE_DEBUGDavid S. Miller
It's way past it's usefulness. And this gets rid of a bunch of stray ->rt_{dst,src} references. Even the comment documenting the macro was inaccurate (stated default was 1 when it's 0). If reintroduced, it should be done properly, with dynamic debug facilities. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16ipv4: Trivial rt->rt_src conversions in net/ipv4/route.cDavid S. Miller
At these points we have a fully filled in value via the IP header the form of ip_hdr(skb)->saddr Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13ipv4: Remove route key identity dependencies in ip_rt_get_source().David S. Miller
Pass in the sk_buff so that we can fetch the necessary keys from the packet header when working with input routes. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-04ipv4: Pass explicit saddr/daddr args to ipmr_get_route().David S. Miller
This eliminates the need to use rt->rt_{src,dst}. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-03ipv4: Renamt struct rtable's rt_tos to rt_key_tos.David S. Miller
To more accurately reflect that it is purely a routing cache lookup key and is used in no other context. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-02ipv4: Make sure flowi4->{saddr,daddr} are always set.David S. Miller
Slow path output route resolution always makes sure that ->{saddr,daddr} are set, and also if we trigger into IPSEC resolution we initialize them as well, because xfrm_lookup() expects them to be fully resolved. But if we hit the fast path and flowi4->flowi4_proto is zero, we won't do this initialization. Therefore, move the IPSEC path initialization to the route cache lookup fast path to make sure these are always set. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28ipv4: Use caller's on-stack flowi as-is in output route lookups.David S. Miller
2011-04-28net: Use non-zero allocations in dst_alloc().David S. Miller
Make dst_alloc() and it's users explicitly initialize the entire entry. The zero'ing done by kmem_cache_zalloc() was almost entirely redundant. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28net: Make dst_alloc() take more explicit initializations.David S. Miller
Now the dst->dev, dev->obsolete, and dst->flags values can be specified as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Resolved logic conflicts causing a build failure due to drivers/net/r8169.c changes using a patch from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-25net: provide cow_metrics() methods to blackhole dst_opsHeld Bernhard
Since commit 62fa8a846d7d (net: Implement read-only protection and COW'ing of metrics.) the kernel throws an oops. [ 101.620985] BUG: unable to handle kernel NULL pointer dereference at (null) [ 101.621050] IP: [< (null)>] (null) [ 101.621084] PGD 6e53c067 PUD 3dd6a067 PMD 0 [ 101.621122] Oops: 0010 [#1] SMP [ 101.621153] last sysfs file: /sys/devices/virtual/ppp/ppp/uevent [ 101.621192] CPU 2 [ 101.621206] Modules linked in: l2tp_ppp pppox ppp_generic slhc l2tp_netlink l2tp_core deflate zlib_deflate twofish_x86_64 twofish_common des_generic cbc ecb sha1_generic hmac af_key iptable_filter snd_pcm_oss snd_mixer_oss snd_seq snd_seq_device loop snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_intel snd_hda_codec snd_pcm snd_timer snd i2c_i801 iTCO_wdt psmouse soundcore snd_page_alloc evdev uhci_hcd ehci_hcd thermal [ 101.621552] [ 101.621567] Pid: 5129, comm: openl2tpd Not tainted 2.6.39-rc4-Quad #3 Gigabyte Technology Co., Ltd. G33-DS3R/G33-DS3R [ 101.621637] RIP: 0010:[<0000000000000000>] [< (null)>] (null) [ 101.621684] RSP: 0018:ffff88003ddeba60 EFLAGS: 00010202 [ 101.621716] RAX: ffff88003ddb5600 RBX: ffff88003ddb5600 RCX: 0000000000000020 [ 101.621758] RDX: ffffffff81a69a00 RSI: ffffffff81b7ee61 RDI: ffff88003ddb5600 [ 101.621800] RBP: ffff8800537cd900 R08: 0000000000000000 R09: ffff88003ddb5600 [ 101.621840] R10: 0000000000000005 R11: 0000000000014b38 R12: ffff88003ddb5600 [ 101.621881] R13: ffffffff81b7e480 R14: ffffffff81b7e8b8 R15: ffff88003ddebad8 [ 101.621924] FS: 00007f06e4182700(0000) GS:ffff88007fd00000(0000) knlGS:0000000000000000 [ 101.621971] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 101.622005] CR2: 0000000000000000 CR3: 0000000045274000 CR4: 00000000000006e0 [ 101.622046] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 101.622087] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 101.622129] Process openl2tpd (pid: 5129, threadinfo ffff88003ddea000, task ffff88003de9a280) [ 101.622177] Stack: [ 101.622191] ffffffff81447efa ffff88007d3ded80 ffff88003de9a280 ffff88007d3ded80 [ 101.622245] 0000000000000001 ffff88003ddebbb8 ffffffff8148d5a7 0000000000000212 [ 101.622299] ffff88003dcea000 ffff88003dcea188 ffffffff00000001 ffffffff81b7e480 [ 101.622353] Call Trace: [ 101.622374] [<ffffffff81447efa>] ? ipv4_blackhole_route+0x1ba/0x210 [ 101.622415] [<ffffffff8148d5a7>] ? xfrm_lookup+0x417/0x510 [ 101.622450] [<ffffffff8127672a>] ? extract_buf+0x9a/0x140 [ 101.622485] [<ffffffff8144c6a0>] ? __ip_flush_pending_frames+0x70/0x70 [ 101.622526] [<ffffffff8146fbbf>] ? udp_sendmsg+0x62f/0x810 [ 101.622562] [<ffffffff813f98a6>] ? sock_sendmsg+0x116/0x130 [ 101.622599] [<ffffffff8109df58>] ? find_get_page+0x18/0x90 [ 101.622633] [<ffffffff8109fd6a>] ? filemap_fault+0x12a/0x4b0 [ 101.622668] [<ffffffff813fb5c4>] ? move_addr_to_kernel+0x64/0x90 [ 101.622706] [<ffffffff81405d5a>] ? verify_iovec+0x7a/0xf0 [ 101.622739] [<ffffffff813fc772>] ? sys_sendmsg+0x292/0x420 [ 101.622774] [<ffffffff810b994a>] ? handle_pte_fault+0x8a/0x7c0 [ 101.622810] [<ffffffff810b76fe>] ? __pte_alloc+0xae/0x130 [ 101.622844] [<ffffffff810ba2f8>] ? handle_mm_fault+0x138/0x380 [ 101.622880] [<ffffffff81024af9>] ? do_page_fault+0x189/0x410 [ 101.622915] [<ffffffff813fbe03>] ? sys_getsockname+0xf3/0x110 [ 101.622952] [<ffffffff81450c4d>] ? ip_setsockopt+0x4d/0xa0 [ 101.622986] [<ffffffff813f9932>] ? sockfd_lookup_light+0x22/0x90 [ 101.623024] [<ffffffff814b61fb>] ? system_call_fastpath+0x16/0x1b [ 101.623060] Code: Bad RIP value. [ 101.623090] RIP [< (null)>] (null) [ 101.623125] RSP <ffff88003ddeba60> [ 101.623146] CR2: 0000000000000000 [ 101.650871] ---[ end trace ca3856a7d8e8dad4 ]--- [ 101.651011] __sk_free: optmem leakage (160 bytes) detected. The oops happens in dst_metrics_write_ptr() include/net/dst.h:124: return dst->ops->cow_metrics(dst, p); dst->ops->cow_metrics is NULL and causes the oops. Provide cow_metrics() methods, like we did in commit 214f45c91bb (net: provide default_advmss() methods to blackhole dst_ops) Signed-off-by: Held Bernhard <berny156@gmx.de> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14ipv4: Call fib_select_default() only when actually necessary.David S. Miller
fib_select_default() is a complete NOP, and completely pointless to invoke, when we have no more than 1 default route installed. And this is far and away the common case. So remember how many prefixlen==0 routes we have in the routing table, and elide the call when we have no more than one of those. This cuts output route creation time by 157 cycles on Niagara2+. In order to add the new int to fib_table, we have to correct the type of ->tb_data[] to unsigned long, otherwise the private area will be unaligned on 64-bit systems. Signed-off-by: David S. Miller <davem@davemloft.net> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) net: Add support for SMSC LAN9530, LAN9730 and LAN89530 mlx4_en: Restoring RX buffer pointer in case of failure mlx4: Sensing link type at device initialization ipv4: Fix "Set rt->rt_iif more sanely on output routes." MAINTAINERS: add entry for Xen network backend be2net: Fix suspend/resume operation be2net: Rename some struct members for clarity pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev dsa/mv88e6131: add support for mv88e6085 switch ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2) be2net: Fix a potential crash during shutdown. bna: Fix for handling firmware heartbeat failure can: mcp251x: Allow pass IRQ flags through platform data. smsc911x: fix mac_lock acquision before calling smsc911x_mac_read iwlwifi: accept EEPROM version 0x423 for iwl6000 rt2x00: fix cancelling uninitialized work rtlwifi: Fix some warnings/bugs p54usb: IDs for two new devices wl12xx: fix potential buffer overflow in testmode nvs push zd1211rw: reset rx idle timer from tasklet ...
2011-04-10fib_validate_source(): pass sk_buff instead of markMichael Smith
This makes sk_buff available for other use in fib_validate_source(). Signed-off-by: Michael Smith <msmith@cbnco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07ipv4: Fix "Set rt->rt_iif more sanely on output routes."OGAWA Hirofumi
Commit 1018b5c01636c7c6bda31a719bda34fc631db29a ("Set rt->rt_iif more sanely on output routes.") breaks rt_is_{output,input}_route. This became the cause to return "IP_PKTINFO's ->ipi_ifindex == 0". To fix it, this does: 1) Add "int rt_route_iif;" to struct rtable 2) For input routes, always set rt_route_iif to same value as rt_iif 3) For output routes, always set rt_route_iif to zero. Set rt_iif as it is done currently. 4) Change rt_is_{output,input}_route() to test rt_route_iif Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-24ipv4: Invalidate nexthop cache nh_saddr more correctly.David S. Miller
Any operation that: 1) Brings up an interface 2) Adds an IP address to an interface 3) Deletes an IP address from an interface can potentially invalidate the nh_saddr value, requiring it to be recomputed. Perform the recomputation lazily using a generation ID. Reported-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-23ipv4: fix ip_rt_update_pmtu()Eric Dumazet
commit 2c8cec5c10bc (Cache learned PMTU information in inetpeer) added an extra inet_putpeer() call in ip_rt_update_pmtu(). This results in various problems, since we can free one inetpeer, while it is still in use. Ref: http://www.spinics.net/lists/netdev/msg159121.html Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15net_sched: fix ip_tos2prioDan Siemon
ECN support incorrectly maps ECN BESTEFFORT packets to TC_PRIO_FILLER (1) instead of TC_PRIO_BESTEFFORT (0) This means ECN enabled flows are placed in pfifo_fast/prio low priority band, giving ECN enabled flows [ECT(0) and CE codepoints] higher drop probabilities. This is rather unfortunate, given we would like ECN being more widely used. Ref : http://www.coverfire.com/archives/2011/03/13/pfifo_fast-and-ecn/ Signed-off-by: Dan Siemon <dan@coverfire.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Dave Täht <d@taht.net> Cc: Jonathan Morton <chromatix99@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-13ipv4: Fix PMTU update.Hiroaki SHIMODA
On current net-next-2.6, when Linux receives ICMP Type: 3, Code: 4 (Destination unreachable (Fragmentation needed)), icmp_unreach -> ip_rt_frag_needed (peer->pmtu_expires is set here) -> tcp_v4_err -> do_pmtu_discovery -> ip_rt_update_pmtu (peer->pmtu_expires is already set, so check_peer_pmtu is skipped.) -> check_peer_pmtu check_peer_pmtu is skipped and MTU is not updated. To fix this, let check_peer_pmtu execute unconditionally. And some minor fixes 1) Avoid potential peer->pmtu_expires set to be zero. 2) In check_peer_pmtu, argument of time_before is reversed. 3) check_peer_pmtu expects peer->pmtu_orig is initialized as zero, but not initialized. Signed-off-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv4: Use flowi4 in public route lookup interfaces.David S. Miller
2011-03-12ipv4: Use struct flowi4 internally in routing lookups.David S. Miller
We will change the externally visible APIs next. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv4: Pass ipv4 flow objects into fib_lookup() paths.David S. Miller
To start doing these conversions, we need to add some temporary flow4_* macros which will eventually go away when all the protocol code paths are changed to work on AF specific flowi objects. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-10ipv4: Kill flowi arg to fib_select_multipath()David S. Miller
Completely unused. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-10ipv4: Remove unnecessary test from ip_mkroute_input()David S. Miller
fl->oif will always be zero on the input path, so there is no reason to test for that. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-10ipv4: Remove redundant RCU locking in ip_check_mc().David S. Miller
All callers are under rcu_read_lock() protection already. Rename to ip_check_mc_rcu() to make it even more clear. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09ipv4: Optimize flow initialization in input route lookup.David S. Miller
Like in commit 44713b67db10c774f14280c129b0d5fd13c70cf2 ("ipv4: Optimize flow initialization in output route lookup." we can optimize the on-stack flow setup to only initialize the members which are actually used. Otherwise we bzero the entire structure, then initialize explicitly the first half of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-04ipv4: Remove flowi from struct rtable.David S. Miller
The only necessary parts are the src/dst addresses, the interface indexes, the TOS, and the mark. The rest is unnecessary bloat, which amounts to nearly 50 bytes on 64-bit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-04ipv4: Set rt->rt_iif more sanely on output routes.David S. Miller
rt->rt_iif is only ever inspected on input routes, for example DCCP uses this to populate a route lookup flow key when generating replies to another packet. Therefore, setting it to anything other than zero on output routes makes no sense. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-04ipv4: Get peer more cheaply in rt_init_metrics().David S. Miller
We know this is a new route object, so doing atomics and stuff makes no sense at all. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-04ipv4: Optimize flow initialization in output route lookup.David S. Miller
We burn a lot of useless cycles, cpu store buffer traffic, and memory operations memset()'ing the on-stack flow used to perform output route lookups in __ip_route_output_key(). Only the first half of the flow object members even matter for output route lookups in this context, specifically: FIB rules matching cares about: dst, src, tos, iif, oif, mark FIB trie lookup cares about: dst FIB semantic match cares about: tos, scope, oif Therefore only initialize these specific members and elide the memset entirely. On Niagara2 this kills about ~300 cycles from the output route lookup path. Likely, we can take things further, since all callers of output route lookups essentially throw away the on-stack flow they use. So they don't care if we use it as a scratch-pad to compute the final flow key. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2011-03-02ipv4: ip_route_output_key() is better as an inline.David S. Miller
This avoid a stack frame at zero cost. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02xfrm: Return dst directly from xfrm_lookup()David S. Miller
2011-03-01xfrm: Handle blackhole route creation via afinfo.David S. Miller
That way we don't have to potentially do this in every xfrm_lookup() caller. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01xfrm: Kill XFRM_LOOKUP_WAIT flag.David S. Miller
This can be determined from the flow flags instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Kill can_sleep arg to ip_route_output_flow()David S. Miller
This boolean state is now available in the flow flags. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Make final arg to ip_route_output_flow to be boolean "can_sleep"David S. Miller
Since that is what the current vague "flags" argument means. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/e1000e/netdev.c net/xfrm/xfrm_policy.c
2011-02-18net: provide default_advmss() methods to blackhole dst_opsEric Dumazet
Commit 0dbaee3b37e118a (net: Abstract default ADVMSS behind an accessor.) introduced a possible crash in tcp_connect_init(), when dst->default_advmss() is called from dst_metric_advmss() Reported-by: George Spelvin <linux@horizon.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17ipv4: Use const'ify fib_result deep in the route call chains.David S. Miller
The only troublesome bit here is __mkroute_output which wants to override res->fi and res->type, compute those in local variables instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: Add initial_ref arg to dst_alloc().David S. Miller
This allows avoiding multiple writes to the initial __refcnt. The most simplest cases of wanting an initial reference of "1" in ipv4 and ipv6 have been converted, the rest have been left along and kept at the existing "0". Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17ipv4: Consolidate ipv4 dst allocation logic.David S. Miller
This also allows us to combine all the dst->flags settings and avoid read/modify/write sequences to this struct member. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17ipv4: Move rcu_read_{lock,unlock}() into ip_route_output_slow().David S. Miller
Simplifies tail of __ip_route_output_key(). Signed-off-by: David S. Miller <davem@davemloft.net>
