path: root/net/ipv4/route.c
2006-07-03[PATCH] lockdep: fix RT_HASH_LOCK_SZIngo Molnar
On lockdep we have a quite big spinlock_t, so keep the size down. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: prove spinlock rwlock locking correctnessIngo Molnar
Use the lock validator framework to prove spinlock and rwlock locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Define __raw_get_cpu_var and use itPaul Mackerras
There are several instances of per_cpu(foo, raw_smp_processor_id()), which is semantically equivalent to __get_cpu_var(foo) but without the warning that smp_processor_id() can give if CONFIG_DEBUG_PREEMPT is enabled. For those architectures with optimized per-cpu implementations, namely ia64, powerpc, s390, sparc64 and x86_64, per_cpu() turns into more and slower code than __get_cpu_var(), so it would be preferable to use __get_cpu_var on those platforms. This defines a __raw_get_cpu_var(x) macro which turns into per_cpu(x, raw_smp_processor_id()) on architectures that use the generic per-cpu implementation, and turns into __get_cpu_var(x) on the architectures that have an optimized per-cpu implementation. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-17[IPV4]: ip_route_input panic fixStephen Hemminger
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=6388 The bug is caused by ip_route_input dereferencing skb->nh.protocol of the dummy skb passed dow from inet_rtm_getroute (Thanks Thomas for seeing it). It only happens if the route requested is for a multicast IP address. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[PATCH] for_each_possible_cpu: network codesKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu under /net Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[IPV4]: Aggregate route entries with different TOS valuesIlia Sotnikov
When we get an ICMP need-to-frag message, the original TOS value in the ICMP payload cannot be used as a key to look up the routes to update. This is because the TOS field may have been modified by routers on the way. Similarly, ip_rt_redirect should also ignore the TOS as the router that gave us the message may have modified the TOS value. The patch achieves this objective by aggregating entries with different TOS values (but are otherwise identical) into the same bucket. This makes it easy to update them at the same time when an ICMP message is received. In future we should use a twin-hashing scheme where teh aggregation occurs at the entry level. That is, the TOS goes back into the hash for normal lookups while ICMP lookups will end up with a node that gives us a list that contains all other route entries that differ only by TOS. Signed-off-by: Ilia Sotnikov <hostcc@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-23[IPV4]: Fix garbage collection of multipath route entriesSuresh Bhogavilli
When garbage collecting route cache entries of multipath routes in rt_garbage_collect(), entries were deleted from the hash bucket 'i' while holding a spin lock on bucket 'k' resulting in a system hang. Delete entries, if any, from bucket 'k' instead. Signed-off-by: Suresh Bhogavilli <sbhogavilli@verisign.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[IPV4]: RT_CACHE_STAT_INC() warning fixAndrew Morton
BUG: using smp_processor_id() in preemptible [00000001] code: rpc.statd/2408 And it _is_ a bug, but I guess we don't care enough to add preempt_disable(). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[IPV4]: rt_cache_stat can be statically definedEric Dumazet
Using __get_cpu_var(obj) is slightly faster than per_cpu_ptr(obj, raw_smp_processor_id()). 1) Smaller code and memory use For static and small objects, DEFINE_PER_CPU(type, object) is preferred over a alloc_percpu() : Better and smaller code to access them, and no extra memory (storing the pointer, and the percpu array of pointers) x86_64 code before patch mov 1237577(%rip),%rax # ffffffff803e5990 <rt_cache_stat> not %rax # part of per_cpu machinery mov %gs:0x3c,%edx # get cpu number movslq %edx,%rdx # extend 32 bits cpu number to 64 bits mov (%rax,%rdx,8),%rax # get the pointer for this cpu incl 0x38(%rax) x86_64 code after patch mov $per_cpu__rt_cache_stat,%rdx mov %gs:0x48,%rax # get percpu data offset incl 0x38(%rax,%rdx,1) 2) False sharing avoidance for SMP : For a small NR_CPUS, the array of per cpu pointers allocated in alloc_percpu() can be <= 32 bytes. This let slab code gives a part of a cache line. If the other part of this 64 bytes (or 128 bytes) cache line is used by a mostly written object, we can have false sharing and expensive per_cpu_ptr() operations. Size of rt_cache_stat is 64 bytes, so this patch is not a danger of a too big increase of bss (in UP mode) or static per_cpu data for SMP (PERCPU_ENOUGH_ROOM is currently 32768 bytes) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[NET]: Add const markers to various variables.Arjan van de Ven
the patch below marks various variables const in net/; the goal is to move them to the .rodata section so that they can't false-share cachelines with things that get written to, as well as potentially helping gcc a bit with optimisations. (these were found using a gcc patch to warn about such variables) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[IPV4] tcp/route: Another look at hash table sizesMike Stroyan
The tcp_ehash hash table gets too big on systems with really big memory. It is worse on systems with pages larger than 4KB. It wastes memory that could be better used. It also makes the netstat command slow because reading /proc/net/tcp and /proc/net/tcp6 needs to go through the full hash table. The default value should not be larger for larger page sizes. It seems that the effect of page size is an unintended error dating back a long time. I also wonder if the default value really should be a larger fraction of memory for systems with more memory. While systems with really big ram can afford more space for hash tables, it is not clear to me that they benefit from increasing the allocation ratio for this table. The amount of memory allocated is determined by net/ipv4/tcp.c:tcp_init and mm/page_alloc.c:alloc_large_system_hash. tcp_init calls alloc_large_system_hash passing parameters- bucketsize=sizeof(struct tcp_ehash_bucket) numentries=thash_entries scale=(num_physpages >= 128 * 1024) ? (25-PAGE_SHIFT) : (27-PAGE_SHIFT) limit=0 On i386, PAGE_SHIFT is 12 for a page size of 4K On ia64, PAGE_SHIFT defaults to 14 for a page size of 16K The num_physpages test above makes the allocation take a larger fraction of the total memory on systems with larger memory. The threshold size for a i386 system is 512MB. For an ia64 system with 16KB pages the threshold is 2GB. For smaller memory systems- On i386, scale = (27 - 12) = 15 On ia64, scale = (27 - 14) = 13 For larger memory systems- On i386, scale = (25 - 12) = 13 On ia64, scale = (25 - 14) = 11 For the rest of this discussion, I'll just track the larger memory case. The default behavior has numentries=thash_entries=0, so the allocated size is determined by either scale or by the default limit of 1/16 of total memory. In alloc_large_system_hash- | numentries = (flags & HASH_HIGHMEM) ? nr_all_pages : nr_kernel_pages; | numentries += (1UL << (20 - PAGE_SHIFT)) - 1; | numentries >>= 20 - PAGE_SHIFT; | numentries <<= 20 - PAGE_SHIFT; At this point, numentries is pages for all of memory, rounded up to the nearest megabyte boundary. | /* limit to 1 bucket per 2^scale bytes of low memory */ | if (scale > PAGE_SHIFT) | numentries >>= (scale - PAGE_SHIFT); | else | numentries <<= (PAGE_SHIFT - scale); On i386, numentries >>= (13 - 12), so numentries is 1/8196 of bytes of total memory. On ia64, numentries <<= (14 - 11), so numentries is 1/2048 of bytes of total memory. | log2qty = long_log2(numentries); | | do { | size = bucketsize << log2qty; bucketsize is 16, so size is 16 times numentries, rounded down to a power of two. On i386, size is 1/512 of bytes of total memory. On ia64, size is 1/128 of bytes of total memory. For smaller systems the results are On i386, size is 1/2048 of bytes of total memory. On ia64, size is 1/512 of bytes of total memory. The large page effect can be removed by just replacing the use of PAGE_SHIFT with a constant of 12 in the calls to alloc_large_system_hash. That makes them more like the other uses of that function from fs/inode.c and fs/dcache.c Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-08[IPV4]: Fix refcount damaging in net/ipv4/route.cJulian Anastasov
One such place that can damage the dst refcnts is route.c with CONFIG_IP_ROUTE_MULTIPATH_CACHED enabled, i don't see the user's .config. In this new code i see that rt_intern_hash is called before dst->refcnt is set to 1, dst is the 2nd arg to rt_intern_hash. Arg 2 of rt_intern_hash must come with refcnt 1 as it is added to table or dropped depending on error/add/update. One such example is ip_mkroute_input where __mkroute_input return rth with refcnt 0 which is provided to rt_intern_hash. ip_mkroute_output looks like a 2nd such place. Appending untested patch for comments and review. The idea is to put previous reference as we are going to return next result/error. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Export symbols needed by the current DCCP codeArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4]: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - xfrm4_state.c: xfrm4_state_fini - remove the following unneeded EXPORT_SYMBOL's: - ip_output.c: ip_finish_output - ip_output.c: sysctl_ip_default_ttl - fib_frontend.c: ip_dev_find - inetpeer.c: inet_peer_idlock - ip_options.c: ip_options_compile - ip_options.c: ip_options_undo - net/core/request_sock.c: sysctl_max_syn_backlog Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-11[IPV4]: Prevent oops when printing martian sourceOlaf Kirch
In some cases, we may be generating packets with a source address that qualifies as martian. This can happen when we're in the middle of setting up the network, and netfilter decides to reject a packet with an RST. The IPv4 routing code would try to print a warning and oops, because locally generated packets do not have a valid skb->mac.raw pointer at this point. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[IPV4]: Bug fix in rt_check_expire()Eric Dumazet
- rt_check_expire() fixes (an overflow occured if size of the hash was >= 65536) reminder of the bugfix: The rt_check_expire() has a serious problem on machines with large route caches, and a standard HZ value of 1000. With default values, ie ip_rt_gc_interval = 60*HZ = 60000 ; the loop count : for (t = ip_rt_gc_interval << rt_hash_log; t >= 0; overflows (t is a 31 bit value) as soon rt_hash_log is >= 16 (65536 slots in route cache hash table). In this case, rt_check_expire() does nothing at all Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[IPV4]: Use the fancy alloc_large_system_hash() function for route hash tableEric Dumazet
- rt hash table allocated using alloc_large_system_hash() function. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[NET]: Hashed spinlocks in net/ipv4/route.cEric Dumazet
- Locking abstraction - Spinlocks moved out of rt hash table : Less memory (50%) used by rt hash table. it's a win even on UP. - Sizing of spinlocks table depends on NR_CPUS Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[IPV4]: Snmpv2 Mib IP counter ipInAddrErrors supportDietmar Eggemann
I followed Thomas' proposal to see every martian destination as a case where the ipInAddrErrors counter has to be incremented. There are two advantages by doing so: (1) The relation between the ipInReceive counter and all the other ipInXXX counters is more accurate in the case the RTN_UNICAST code check fails and (2) it makes the code in ip_route_input_slow easier. Signed-off-by: Dietmar Eggemann <dietmar.eggemann@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[IPV4]: Fix route.c gcc4 warningsChuck Short
Signed-off by: Chuck Short <zulcss@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Correctly set NLM_F_MULTI without checking the pidJamal Hadi Salim
This patch rectifies some rtnetlink message builders that derive the flags from the pid. It is now explicit like the other cases which get it right. Also fixes half a dozen dumpers which did not set NLM_F_MULTI at all. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-28[NET]: /proc/net/stat/* header cleanupOlaf Rempel
Signed-off-by: Olaf Rempel <razzor@kopf-tisch.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-28[IPV4]: Incorrect permissions on route flush sysctlDave Jones
This has been brought up before.. http://lkml.org/lkml/2000/1/21/116 but didnt seem to get resolved. This morning I got someone file a bugzilla about it breaking sysctl(8). Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[NET]: skbuff: remove old NET_CALLER macroStephen Hemminger
Here is a revised alternative that uses BUG_ON/WARN_ON (as suggested by Herbert Xu) to eliminate NET_CALLER. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
