CC [M] net/ipv4/ipvs/ip_vs_conn.o
/pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c: In
function 'ip_vs_conn_new':
/pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c:606:
warning: implicit declaration of function 'net_ratelimit'
function 'ip_vs_random_dropentry':
/pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c:810:
warning: implicit declaration of function 'net_random'
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
The attached patch (against current -GIT) is a cleanup patch which does
following:
o lookup debug messages shifted back to 9
o added more informational value to flags and refcnt since those
entries can be in multiple referenced structures
o cleanup 80 char violation
It's the prepatch to the session pool implementation and helps very much
to debug and monitor important variables and structures regarding the
threshold limitation and persistency without the thousands of lookup
messages which noone is interested in.
Signed-off-by: Horms <horms@verge.net.au>
To help in reducing the number of include dependencies, several files were
touched as they were getting needed headers indirectly for stuff they use.
Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had
linux/dccp.h include twice.
the patch below marks various variables const in net/; the goal is to
move them to the .rodata section so that they can't false-share
cachelines with things that get written to, as well as potentially
helping gcc a bit with optimisations. (these were found using a gcc
patch to warn about such variables)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
ip_vs_ftp when loaded can create NAT connections with unknown client
port for passive FTP. For such expectations we lookup with cport=0 on
incoming packet but it matches the format of the persistence templates
causing packets to other persistent virtual servers to be forwarded to
real server without creating connection. Later the reply packets are
treated as foreign and not SNAT-ed.
This patch changes the connection lookup for packets from clients:
* introduce IP_VS_CONN_F_TEMPLATE connection flag to mark the
connection as template
* create new connection lookup function just for templates -
ip_vs_ct_in_get
* make sure ip_vs_conn_in_get hits only connections with
IP_VS_CONN_F_NO_CPORT flag set when s_port is 0. By this way
we avoid returning template when looking for cport=0 (ftp)
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Agostino di Salle noticed that persistent templates are not
invalidated due to buggy optimization.
This patch puts mostly read only data in the right section
(read_mostly), to help sharing of these data between CPUS without
memory ping pongs.
On one of my production machine, tcp_statistics was sitting in a
heavily modified cache line, so *every* SNMP update had to force a
reload.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
An addition to the last ipvs changes that move
update_defense_level/si_meminfo to keventd:
- ip_vs_random_dropentry now runs in process context and should use _bh
locks to protect from softirqs
- update_defense_level still needs _bh locks after si_meminfo is called,
for the same purpose
In an smp system, it is possible for an connection timer to expire, calling
ip_vs_conn_expire while the connection table is being flushed, before
ct_write_lock_bh is acquired.
Since the list iterator loop in ip_vs_con_flush releases and re-acquires the
spinlock (even though it doesn't re-enable softirqs), it is possible for the
expiration function to modify the connection list, while it is being traversed
in ip_vs_conn_flush.
The result is that the next pointer gets set to NULL, and subsequently
dereferenced, resulting in an oops.
Signed-off-by: Neil Horman <nhorman@redhat.com>
Acked-by: JulianAnastasov
infrastructure for it.
Let it rip!
