path: root/net/ipv4/ipip.c
2012-01-12net: reintroduce missing rcu_assign_pointer() callsEric Dumazet
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTER) did a lot of incorrect changes, since it did a complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x, y). We miss needed barriers, even on x86, when y is not NULL. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/freescale/fsl_pq_mdio.c net/batman-adv/translation-table.c net/ipv6/route.c
2011-12-12ipip, sit: copy parms.name after register_netdeviceTed Feng
Same fix as 731abb9cb2 for ipip and sit tunnel. Commit 1c5cae815d removed an explicit call to dev_alloc_name in ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice will now create a valid name, however the tunnel keeps a copy of the name in the private parms structure. Fix this by copying the name back after register_netdevice has successfully returned. This shows up if you do a simple tunnel add, followed by a tunnel show: $ sudo ip tunnel add mode ipip remote 10.2.20.211 $ ip tunnel tunl0: ip/ip remote any local any ttl inherit nopmtudisc tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit $ sudo ip tunnel add mode sit remote 10.2.20.212 $ ip tunnel sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16 sit%d: ioctl 89f8 failed: No such device sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit Cc: stable@vger.kernel.org Signed-off-by: Ted Feng <artisdom@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-08net: better pcpu data alignmentEric Dumazet
Tunnels can force an alignment of their percpu data to reduce number of cache lines used in fast path, or read in .ndo_get_stats() percpu_alloc() is a very fine grained allocator, so any small hole will be used anyway. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-05net: call dev_alloc_name from register_netdeviceJiri Pirko
Force dev_alloc_name() to be called from register_netdevice() by dev_get_valid_name(). That allows to remove multiple explicit dev_alloc_name() calls. The possibility to call dev_alloc_name in advance remains. This also fixes veth creation regresion caused by 84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743 Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-04ipv4: Use flowi4->{daddr,saddr} in ipip_tunnel_xmit().David S. Miller
Instead of rt->rt_{dst,src} Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-03ipv4: Make caller provide on-stack flow key to ip_route_output_ports().David S. Miller
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv4: Create and use route lookup helpers.David S. Miller
The idea here is this minimizes the number of places one has to edit in order to make changes to how flows are defined and used. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_cmn.c
2011-03-10net: don't allow CAP_NET_ADMIN to load non-netdev kernel modulesVasiliy Kulikov
Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't allow anybody load any module not related to networking. This patch restricts an ability of autoloading modules to netdev modules with explicit aliases. This fixes CVE-2011-1019. Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior of loading netdev modules by name (without any prefix) for processes with CAP_SYS_MODULE to maintain the compatibility with network scripts that use autoloading netdev modules by aliases like "eth0", "wlan0". Currently there are only three users of the feature in the upstream kernel: ipip, ip_gre and sit. root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) -- root@albatros:~# grep Cap /proc/$$/status CapInh: 0000000000000000 CapPrm: fffffff800001000 CapEff: fffffff800001000 CapBnd: fffffff800001000 root@albatros:~# modprobe xfs FATAL: Error inserting xfs (/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted root@albatros:~# lsmod | grep xfs root@albatros:~# ifconfig xfs xfs: error fetching interface information: Device not found root@albatros:~# lsmod | grep xfs root@albatros:~# lsmod | grep sit root@albatros:~# ifconfig sit sit: error fetching interface information: Device not found root@albatros:~# lsmod | grep sit root@albatros:~# ifconfig sit0 sit0 Link encap:IPv6-in-IPv4 NOARP MTU:1480 Metric:1 root@albatros:~# lsmod | grep sit sit 10457 0 tunnel4 2957 1 sit For CAP_SYS_MODULE module loading is still relaxed: root@albatros:~# grep Cap /proc/$$/status CapInh: 0000000000000000 CapPrm: ffffffffffffffff CapEff: ffffffffffffffff CapBnd: ffffffffffffffff root@albatros:~# ifconfig xfs xfs: error fetching interface information: Device not found root@albatros:~# lsmod | grep xfs xfs 745319 0 Reference: https://lkml.org/lkml/2011/2/24/203 Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01ipip: add module alias for tunl0 tunnel devicestephen hemminger
If ipip is built as a module the 'ip tunnel add' command would fail because the ipip module was not being autoloaded. Adding an alias for the tunl0 device name cause dev_load() to autoload it when needed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27tunnels: Fix tunnels change rcu protectionPavel Emelyanov
After making rcu protection for tunnels (ipip, gre, sit and ip6) a bug was introduced into the SIOCCHGTUNNEL code. The tunnel is first unlinked, then addresses change, then it is linked back probably into another bucket. But while changing the parms, the hash table is unlocked to readers and they can lookup the improper tunnel. Respective commits are b7285b79 (ipip: get rid of ipip_lock), 1507850b (gre: get rid of ipgre_lock), 3a43be3c (sit: get rid of ipip6_lock) and 94767632 (ip6tnl: get rid of ip6_tnl_lock). The quick fix is to wait for quiescent state to pass after unlinking, but if it is inappropriate I can invent something better, just let me know. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: add a core netdev->rx_dropped counterEric Dumazet
In various situations, a device provides a packet to our stack and we drop it before it enters protocol stack : - softnet backlog full (accounted in /proc/net/softnet_stat) - bad vlan tag (not accounted) - unknown/unregistered protocol (not accounted) We can handle a per-device counter of such dropped frames at core level, and automatically adds it to the device provided stats (rx_dropped), so that standard tools can be used (ifconfig, ip link, cat /proc/net/dev) This is a generalization of commit 8990f468a (net: rx_dropped accounting), thus reverting it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29ipip: enable lockless xmitsEric Dumazet
IPIP tunnels can benefit from lockless xmits, using NETIF_F_LLTX Bench on a 16 cpus machine (dual E5540 cpus), 16 threads sending 10000000 UDP frames via one ipip tunnel (size:200 bytes per frame) Before patch : real 2m53.321s user 0m10.277s sys 46m0.597s After patch: real 0m32.063s user 0m9.237s sys 8m16.255s Last problem to solve is the contention on dst : 16118.00 28.3% __ip_route_output_key vmlinux 6135.00 10.8% dst_release vmlinux 3220.00 5.6% ip_finish_output vmlinux 2149.00 3.8% ip_route_output_flow vmlinux 1575.00 2.8% ip_append_data vmlinux 1481.00 2.6% ip_push_pending_frames vmlinux 1349.00 2.4% __xfrm_lookup vmlinux 1216.00 2.1% csum_partial_copy_generic vmlinux 1208.00 2.1% udp_sendmsg vmlinux Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29ipip: fix percpu stats accountingEric Dumazet
commit 3c97af99a5aa1 (ipip: percpu stats accounting) forgot the fallback tunnel case (tunl0), and can crash pretty fast. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27ipip: percpu stats accountingEric Dumazet
Maintain per_cpu tx_bytes, tx_packets, rx_bytes, rx_packets. Other seldom used fields are kept in netdev->stats structure, possibly unsafe. This is a preliminary work to support lockless transmit path, and correct RX stats, that are already unsafe. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-20net: rx_dropped accountingEric Dumazet
Under load, netif_rx() can drop incoming packets but administrators dont have a chance to spot which device needs some tuning (RPS activation for example) This patch adds rx_dropped accounting in vlans and tunnels. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ipip: get rid of ipip_lockEric Dumazet
As RTNL is held while doing tunnels inserts and deletes, we can remove ipip_lock spinlock. My initial RCU conversion was conservative and converted the rwlock to spinlock, with no RTNL requirement. Use appropriate rcu annotations and modern lockdep checks as well. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-30net: struct xfrm_tunnel in read_mostly sectionEric Dumazet
tunnel4_handlers chain being scanned for each incoming packet, make sure it doesnt share an often dirtied cache line. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Introduce skb_tunnel_rx() helperEric Dumazet
skb rxhash should be cleared when a skb is handled by a tunnel before being delivered again, so that correct packet steering can take place. There are other cleanups and accounting that we can factorize in a new helper, skb_tunnel_rx() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-16tunnels: fix netns vs proto registration orderingAlexey Dobriyan
Same stuff as in ip_gre patch: receive hook can be called before netns setup is done, oopsing in net_generic(). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Simplify ipip pernet operations.Eric W. Biederman
Take advantage of the new pernet automatic storage management, and stop using compatibility network namespace functions. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18netns: net_identifiers should be read_mostlyEric Dumazet
2009-11-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/can/usb/ems_usb.c
2009-11-06ipip: Fix handling of DF packets when pmtudisc is OFFHerbert Xu
RFC 2003 requires the outer header to have DF set if DF is set on the inner header, even when PMTU discovery is off for the tunnel. Our implementation does exactly that. For this to work properly the IPIP gateway also needs to engate in PMTU when the inner DF bit is set. As otherwise the original host would not be able to carry out its PMTU successfully since part of the path is only visible to the gateway. Unfortunately when the tunnel PMTU discovery setting is off, we do not collect the necessary soft state, resulting in blackholes when the original host tries to perform PMTU discovery. This problem is not reproducible on the IPIP gateway itself as the inner packet usually has skb->local_df set. This is not correctly cleared (an unrelated bug) when the packet passes through the tunnel, which allows fragmentation to occur. For hosts behind the IPIP gateway it is readily visible with a simple ping. This patch fixes the problem by performing PMTU discovery for all packets with the inner DF bit set, regardless of the PMTU discovery setting on the tunnel itself. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28ipip: Optimize multiple unregistrationEric Dumazet
Speedup module unloading by factorizing synchronize_rcu() calls Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24ipip: convert hash tables locking to RCUEric Dumazet
IPIP tunnels use one rwlock to protect their hash tables. This locking scheme can be converted to RCU for free, since netdevice already must wait for a RCU grace period at dismantle time. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05tunnels: Optimize tx pathEric Dumazet
We currently dirty a cache line to update tunnel device stats (tx_packets/tx_bytes). We better use the txq->tx_bytes/tx_packets counters that already are present in cpu cache, in the cache line shared with txq->_xmit_lock This patch extends IPTUNNEL_XMIT() macro to use txq pointer provided by the caller. Also &tunnel->dev->stats can be replaced by &dev->stats Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24tunnel: eliminate recursion fieldEric Dumazet
It seems recursion field from "struct ip_tunnel" is not anymore needed. recursion prevention is done at the upper level (in dev_queue_xmit()), since we use HARD_TX_LOCK protection for tunnels. This avoids a cache line ping pong on "struct ip_tunnel" : This structure should be now mostly read on xmit and receive paths. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert pseudo-devices to netdev_tx_tStephen Hemminger
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->rtable accessorEric Dumazet
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb Delete skb->rtable field Setting rtable is not allowed, just set dst instead as rtable is an alias. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: unset IFF_XMIT_DST_RELEASE in ipip_tunnel_setup()Eric Dumazet
ipip_tunnel_xmit() might need skb->dst, so tell dev_hard_start_xmit() to no release it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24ipip: used time_before for comparing jiffiesWei Yongjun
The functions time_before is more robust for comparing jiffies against other values. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-22ip: ipip compile warningStephen Hemminger
Get rid of compile warning about non-const format Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-23net: fix tunnels in netns after ndo_ changesAlexey Dobriyan
dev_net_set() should be the very first thing after alloc_netdev(). "ndo_" changes turned simple assignment (which is OK to do before netns assignment) into quite non-trivial operation (which is not OK, init_net was used). This leads to incomplete initialisation of tunnel device in netns. BUG: unable to handle kernel NULL pointer dereference at 00000004 IP: [<c02efdb5>] ip6_tnl_exit_net+0x37/0x4f *pde = 00000000 Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC last sysfs file: /sys/class/net/lo/operstate Pid: 10, comm: netns Not tainted (2.6.28-rc6 #1) EIP: 0060:[<c02efdb5>] EFLAGS: 00010246 CPU: 0 EIP is at ip6_tnl_exit_net+0x37/0x4f EAX: 00000000 EBX: 00000020 ECX: 00000000 EDX: 00000003 ESI: c5caef30 EDI: c782bbe8 EBP: c7909f50 ESP: c7909f48 DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 Process netns (pid: 10, ti=c7908000 task=c7905780 task.ti=c7908000) Stack: c03e75e0 c7390bc8 c7909f60 c0245448 c7390bd8 c7390bf0 c7909fa8 c012577a 00000000 00000002 00000000 c0125736 c782bbe8 c7909f90 c0308fe3 c782bc04 c7390bd4 c0245406 c084b718 c04f0770 c03ad785 c782bbe8 c782bc04 c782bc0c Call Trace: [<c0245448>] ? cleanup_net+0x42/0x82 [<c012577a>] ? run_workqueue+0xd6/0x1ae [<c0125736>] ? run_workqueue+0x92/0x1ae [<c0308fe3>] ? schedule+0x275/0x285 [<c0245406>] ? cleanup_net+0x0/0x82 [<c0125ae1>] ? worker_thread+0x81/0x8d [<c0128344>] ? autoremove_wake_function+0x0/0x33 [<c0125a60>] ? worker_thread+0x0/0x8d [<c012815c>] ? kthread+0x39/0x5e [<c0128123>] ? kthread+0x0/0x5e [<c0103b9f>] ? kernel_thread_helper+0x7/0x10 Code: db e8 05 ff ff ff 89 c6 e8 dc 04 f6 ff eb 08 8b 40 04 e8 38 89 f5 ff 8b 44 9e 04 85 c0 75 f0 43 83 fb 20 75 f2 8b 86 84 00 00 00 <8b> 40 04 e8 1c 89 f5 ff e8 98 04 f6 ff 89 f0 e8 f8 63 e6 ff 5b EIP: [<c02efdb5>] ip6_tnl_exit_net+0x37/0x4f SS:ESP 0068:c7909f48 ---[ end trace 6c2f2328fccd3e0c ]--- Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20ipip: convert to net_device_opsStephen Hemminger
Convert to network device ops. Needed to change to directly call the init routine since two sides share same ops. In the process found by inspection a device ref count leak if register_netdevice failed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: clean up net/ipv4/ipip.c raw.c tcp.c tcp_minisocks.c tcp_yeah.c ↵Jianjun Kong
xfrm4_policy.c Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
2008-05-21net: The world is not perfect patch.Rami Rosen
Unless there will be any objection here, I suggest consider the following patch which simply removes the code for the -DI_WISH_WORLD_WERE_PERFECT in the three methods which use it. The compilation errors we get when using -DI_WISH_WORLD_WERE_PERFECT show that this code was not built and not used for really a long time. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
