Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
Do not initialize list twice.
list_replace_init() already takes care of initializing list.
We don't need to initialize it with LIST_HEAD() beforehand.
Signed-off-by: xiao jin <jin.xiao@intel.com>
Reviewed-by: David Cohen <david.a.cohen@linux.intel.com>
Mostly scripted conversion of the smp_mb__* barriers.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org
inetpeer_invalidate_family defined but never used
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Weilong Chen <chenweilong@huawei.com>
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
When jiffies wraps around (for example, 5 minutes after the boot, see
INITIAL_JIFFIES) and peer has just been created, now - peer->rate_last can be
< XRLIM_BURST_FACTOR * timeout, so token is not set to the maximum value, thus
some icmp packets can be unexpectedly dropped.
Fix this case by initializing last_rate to 60 seconds in the past.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Initalizers for deferrable delayed_work are confused.
* __DEFERRED_WORK_INITIALIZER()
* DECLARE_DEFERRED_WORK()
* INIT_DELAYED_WORK_DEFERRABLE()
Rename them to
* __DEFERRABLE_WORK_INITIALIZER()
* DECLARE_DEFERRABLE_WORK()
* INIT_DEFERRABLE_WORK()
This patch doesn't cause any functional changes.
Maintaining this in the inetpeer entries was not the right way to do
this at all.
With help from Lin Ming.
No need to use cmpxchg() in inetpeer_invalidate_tree() since we hold
base lock.
Also use correct rcu annotations to remove sparse errors
(CONFIG_SPARSE_RCU_POINTER=y)
net/ipv4/inetpeer.c:144:19: error: incompatible types in comparison
expression (different address spaces)
net/ipv4/inetpeer.c:149:20: error: incompatible types in comparison
net/ipv4/inetpeer.c:595:10: error: incompatible types in comparison
Cc: Steffen Klassert <steffen.klassert@secunet.com>
This implementation can deal with having many inetpeer roots, which is
a necessary prerequisite for per-FIB table rooted peer tables.
Each family (AF_INET, AF_INET6) has a sequence number which we bump
when we get a family invalidation request.
Each peer lookup cheaply checks whether the flush sequence of the
root we are using is out of date, and if so flushes it and updates
the sequence number.
Otherwise we reference potentially non-existing members when
ipv6 is disabled.
We only need one interface for this operation, since we always know
which inetpeer root we want to flush.
Instead of net/ipv4/inetpeer.c
now inetpeer doesn't support namespace,the information will
be leaking across namespace.
this patch move the global vars v4_peers and v6_peers to
netns_ipv4 and netns_ipv6 as a field peers.
add struct pernet_operations inetpeer_ops to initial pernet
inetpeer data.
and change family_to_base and inet_getpeer to support namespace.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
commit 5faa5df1fa2024 (inetpeer: Invalidate the inetpeer tree along with
the routing cache) added a race :
Before freeing an inetpeer, we must respect a RCU grace period, and make
sure no user will attempt to increase refcnt.
inetpeer_invalidate_tree() waits for a RCU grace period before inserting
inetpeer tree into gc_list and waking the worker. At that time, no
concurrent lookup can find a inetpeer in this tree.
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
As we invalidate the inetpeer tree along with the routing cache now,
we don't need a genid to reset the redirect handling when the routing
cache is flushed.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
We initialize the routing metrics with the values cached on the
inetpeer in rt_init_metrics(). So if we have the metrics cached on the
inetpeer, we ignore the user configured fib_metrics.
To fix this issue, we replace the old tree with a fresh initialized
inet_peer_base. The old tree is removed later with a delayed work queue.
kmemcheck complains that ->redirect_genid doesn't get initialized.
Presumably it should be set to zero.
make C=2 CF="-D__CHECK_ENDIAN__" M=net
And fix flowi4_init_output() prototype for sport
Computers have become a lot faster since we compromised on the
partial MD4 hash which we use currently for performance reasons.
MD5 is a much safer choice, and is inline with both RFC1948 and
other ISS generators (OpenBSD, Solaris, etc.)
Furthermore, only having 24-bits of the sequence number be truly
unpredictable is a very serious limitation. So the periodic
regeneration and 8-bit counter have been removed. We compute and
use a full 32-bit sequence number.
For ipv6, DCCP was found to use a 32-bit truncated initial sequence
number (it needs 43-bits) and that is fixed here as well.
Reported-by: Dan Kaminsky <dan@doxpara.com>
Tested-by: Willy Tarreau <w@1wt.eu>
IPv6 fragment identification generation is way beyond what we use for
IPv4 : It uses a single generator. Its not scalable and allows DOS
attacks.
Now inetpeer is IPv6 aware, we can use it to provide a more secure and
scalable frag ident generator (per destination, instead of system wide)
This patch :
1) defines a new secure_ipv6_id() helper
2) extends inet_getid() to provide 32bit results
3) extends ipv6_select_ident() with a new dest parameter
Reported-by: Fernando Gont <fernando@gont.com.ar>
We currently can free inetpeer entries too early :
[ 782.636674] WARNING: kmemcheck: Caught 32-bit read from uninitialized memory (f130f44c)
[ 782.636677] 1f7b13c100000000000000000000000002000000000000000000000000000000
[ 782.636686] i i i i u u u u i i i i u u u u i i i i u u u u u u u u u u u u
[ 782.636694] ^
[ 782.636696]
[ 782.636698] Pid: 4638, comm: ssh Not tainted 3.0.0-rc5+ #270 Hewlett-Packard HP Compaq 6005 Pro SFF PC/3047h
[ 782.636702] EIP: 0060:[<c13fefbb>] EFLAGS: 00010286 CPU: 0
[ 782.636707] EIP is at inet_getpeer+0x25b/0x5a0
[ 782.636709] EAX: 00000002 EBX: 00010080 ECX: f130f3c0 EDX: f0209d30
[ 782.636711] ESI: 0000bc87 EDI: 0000ea60 EBP: f0209ddc ESP: c173134c
[ 782.636712] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 782.636714] CR0: 8005003b CR2: f0beca80 CR3: 30246000 CR4: 000006d0
[ 782.636716] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 782.636717] DR6: ffff4ff0 DR7: 00000400
[ 782.636718] [<c13fbf76>] rt_set_nexthop.clone.45+0x56/0x220
[ 782.636722] [<c13fc449>] __ip_route_output_key+0x309/0x860
[ 782.636724] [<c141dc54>] tcp_v4_connect+0x124/0x450
[ 782.636728] [<c142ce43>] inet_stream_connect+0xa3/0x270
[ 782.636731] [<c13a8da1>] sys_connect+0xa1/0xb0
[ 782.636733] [<c13a99dd>] sys_socketcall+0x25d/0x2a0
[ 782.636736] [<c149deb8>] sysenter_do_call+0x12/0x28
[ 782.636738] [<ffffffff>] 0xffffffff
Andi Kleen and Tim Chen reported huge contention on inetpeer
unused_peers.lock, on memcached workload on a 40 core machine, with
disabled route cache.
It appears we constantly flip peers refcnt between 0 and 1 values, and
we must insert/remove peers from unused_peers.list, holding a contended
spinlock.
Remove this list completely and perform a garbage collection on-the-fly,
at lookup time, using the expired nodes we met during the tree
traversal.
This removes a lot of code, makes locking more standard, and obsoletes
two sysctls (inet_peer_gc_mintime and inet_peer_gc_maxtime). This also
removes two pointers in inet_peer structure.
There is still a false sharing effect because refcnt is in first cache
line of object [were the links and keys used by lookups are located], we
might move it at the end of inet_peer structure to let this first cache
line mostly read by cpus.
CC: Andi Kleen <andi@firstfloor.org>
CC: Tim Chen <tim.c.chen@linux.intel.com>
Several crashes in cleanup_once() were reported in recent kernels.
Commit d6cc1d642de9 (inetpeer: various changes) added a race in
unlink_from_unused().
One way to avoid taking unused_peers.lock before doing the list_empty()
test is to catch 0->1 refcnt transitions, using full barrier atomic
operations variants (atomic_cmpxchg() and atomic_inc_return()) instead
of previous atomic_inc() and atomic_add_unless() variants.
We then call unlink_from_unused() only for the owner of the 0->1
transition.
Add a new atomic_add_unless_return() static helper
With help from Arun Sharma.
Refs: https://bugzilla.kernel.org/show_bug.cgi?id=32772
Reported-by: Arun Sharma <asharma@fb.com>
Reported-by: Maximilian Engelhardt <maxi@daemonizer.de>
Reported-by: Yann Dupont <Yann.Dupont@univ-nantes.fr>
Reported-by: Denys Fedoryshchenko <denys@visp.net.lb>
On 64bit arches, we use 752 bytes of stack when cleanup_once() is called
from inet_getpeer().
Lets share the avl stack to save ~376 bytes.
Before patch :
# objdump -d net/ipv4/inetpeer.o | scripts/checkstack.pl
0x000006c3 unlink_from_pool [inetpeer.o]: 376
0x00000721 unlink_from_pool [inetpeer.o]: 376
0x00000cb1 inet_getpeer [inetpeer.o]: 376
0x00000e6d inet_getpeer [inetpeer.o]: 376
0x0004 inet_initpeers [inetpeer.o]: 112
# size net/ipv4/inetpeer.o
5320 432 21 5773 168d net/ipv4/inetpeer.o
After patch :
0x00000c11 inet_getpeer [inetpeer.o]: 376
0x00000dcd inet_getpeer [inetpeer.o]: 376
0x00000ab9 peer_check_expire [inetpeer.o]: 328
0x00000b7f peer_check_expire [inetpeer.o]: 328
5163 432 21 5616 15f0 net/ipv4/inetpeer.o
Cc: Scot Doyle <lkml@scotdoyle.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
Reviewed-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
After commit 7b46ac4e77f3224a (inetpeer: Don't disable BH for initial
fast RCU lookup.), we should use call_rcu() to wait proper RCU grace
period.
On current net-next-2.6, when Linux receives ICMP Type: 3, Code: 4
(Destination unreachable (Fragmentation needed)),
icmp_unreach
-> ip_rt_frag_needed
(peer->pmtu_expires is set here)
-> tcp_v4_err
-> do_pmtu_discovery
-> ip_rt_update_pmtu
(peer->pmtu_expires is already set,
so check_peer_pmtu is skipped.)
-> check_peer_pmtu
check_peer_pmtu is skipped and MTU is not updated.
To fix this, let check_peer_pmtu execute unconditionally.
And some minor fixes
1) Avoid potential peer->pmtu_expires set to be zero.
2) In check_peer_pmtu, argument of time_before is reversed.
3) check_peer_pmtu expects peer->pmtu_orig is initialized as zero,
but not initialized.
Signed-off-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
If modifications on other cpus are ok, then modifications to
the tree during lookup done by the local cpu are ok too.
David noticed :
Eric, I was profiling the non-routing-cache case and something that
stuck out is the case of calling inet_getpeer() with create==0.
If an entry is not found, we have to redo the lookup under a spinlock
to make certain that a concurrent writer rebalancing the tree does
not "hide" an existing entry from us.
This makes the case of a create==0 lookup for a not-present entry
really expensive. It is on the order of 600 cpu cycles on my
Niagara2.
I added a hack to not do the relookup under the lock when create==0
and it now costs less than 300 cycles.
This is now a pretty common operation with the way we handle COW'd
metrics, so I think it's definitely worth optimizing.
One solution is to use a seqlock instead of a spinlock to protect struct
inet_peer_base.
After a failed avl tree lookup, we can easily detect if a writer did
some changes during our lookup. Taking the lock and redo the lookup is
only necessary in this case.
Note: Add one private rcu_deref_locked() macro to place in one spot the
access to spinlock included in seqlock.
Validity of the cached PMTU information is indicated by it's
expiration value being non-zero, just as per dst->expires.
The scheme we will use is that we will remember the pre-ICMP value
held in the metrics or route entry, and then at expiration time
we will restore that value.
In this way PMTU expiration does not kill off the cached route as is
done currently.
Redirect information is permanent, or at least until another redirect
is received.
Future changes will add caching information, and some of
these new elements will be addresses.
Since the family is implicit via the ->daddr.family member,
replicating the family in ever address we store is entirely
redundant.
Like metrics, the ICMP rate limiting bits are cached state about
a destination. So move it into the inet_peer entries.
If an inet_peer cannot be bound (the reason is memory allocation
failure or similar), the policy is to allow.
Set the RTAX_LOCKED metric to INETPEER_METRICS_NEW (basically,
all ones) on fresh inetpeer entries.
This way code can determine if default metrics have been loaded
in from a routing table entry already.
Family was hard-coded to AF_INET but should be daddr->family.
This fixes crashes when unlinking ipv6 peer entries, since the
unlink code was looking up the base pointer properly.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
They are verboten these days.
They are only allowed on cached ipv6 routes.
Add the ipv6 peer tree instance, and adapt remaining
direct references to 'v4_peers' as needed.
Now v4 and v6 addresses will both work properly.
And make an inet_getpeer_v4() helper, update callers.
Currently only the v4 aspect is used, but this will change.
Instead of directly accessing "peer", change to code to
operate using a "struct inet_peer_base *" pointer.
This will facilitate the addition of a seperate tree for
ipv6 peer entries.
Adds __rcu annotations to inetpeer
(struct inet_peer)->avl_left
(struct inet_peer)->avl_right
This is a tedious cleanup, but removes one smp_wmb() from link_to_pool()
since we now use more self documenting rcu_assign_pointer().
Note the use of RCU_INIT_POINTER() instead of rcu_assign_pointer() in
all cases we dont need a memory barrier.
Addition of rcu_head to struct inet_peer added 16bytes on 64bit arches.
Thats a bit unfortunate, since old size was exactly 64 bytes.
This can be solved, using an union between this rcu_head an four fields,
that are normally used only when a refcount is taken on inet_peer.
rcu_head is used only when refcnt=-1, right before structure freeing.
Add a inet_peer_refcheck() function to check this assertion for a while.
We can bring back SLAB_HWCACHE_ALIGN qualifier in kmem cache creation.
Followup of commit aa1039e73cc2 (inetpeer: RCU conversion)
Unused inet_peer entries have a null refcnt.
Using atomic_inc_not_zero() in rcu lookups is not going to work for
them, and slow path is taken.
Fix this using -1 marker instead of 0 for deleted entries.
inetpeer currently uses an AVL tree protected by an rwlock.
It's possible to make most lookups use RCU
1) Add a struct rcu_head to struct inet_peer
2) add a lookup_rcu_bh() helper to perform lockless and opportunistic
lookup. This is a normal function, not a macro like lookup().
3) Add a limit to number of links followed by lookup_rcu_bh(). This is
needed in case we fall in a loop.
4) add an smp_wmb() in link_to_pool() right before node insert.
5) make unlink_from_pool() use atomic_cmpxchg() to make sure it can take
last reference to an inet_peer, since lockless readers could increase
refcount, even while we hold peers.lock.
6) Delay struct inet_peer freeing after rcu grace period so that
lookup_rcu_bh() cannot crash.
7) inet_getpeer() first attempts lockless lookup.
Note this lookup can fail even if target is in AVL tree, but a
concurrent writer can let tree in a non correct form.
If this attemps fails, lock is taken a regular lookup is performed
again.
8) convert peers.lock from rwlock to a spinlock
9) Remove SLAB_HWCACHE_ALIGN when peer_cachep is created, because
rcu_head adds 16 bytes on 64bit arches, doubling effective size (64 ->
128 bytes)
In a future patch, this is probably possible to revert this part, if rcu
field is put in an union to share space with rid, ip_id_count, tcp_ts &
tcp_ts_stamp. These fields being manipulated only with refcnt > 0.
Try to reduce cache line contentions in peer management, to reduce IP
defragmentation overhead.
- peer_fake_node is marked 'const' to make sure its not modified.
(tested with CONFIG_DEBUG_RODATA=y)
- Group variables in two structures to reduce number of dirtied cache
lines. One named "peers" for avl tree root, its number of entries, and
associated lock. (candidate for RCU conversion)
- A second one named "unused_peers" for unused list and its lock
- Add a !list_empty() test in unlink_from_unused() to avoid taking lock
when entry is not unused.
- Use atomic_dec_and_lock() in inet_putpeer() to avoid taking lock in
some cases.
