[ Upstream commit 56e2c94f055d328f5f6b0a5c1721cca2f2d4e0a1 ]
We currently check current frags memory usage only when
a new frag queue is created. This allows attackers to first
consume the memory budget (default : 4 MB) creating thousands
of frag queues, then sending tiny skbs to exceed high_thresh
limit by 2 to 3 order of magnitude.
Note that before commit 648700f76b03 ("inet: frags: use rhashtables
for reassembly units"), work queue could be starved under DOS,
getting no cpu cycles.
After commit 648700f76b03, only the per frag queue timer can eventually
remove an incomplete frag queue and its skbs.
Fixes: b13d3cbfb8e8 ("inet: frag: move eviction of queues to work queue")
Reported-by: Jann Horn <jannh@google.com>
Cc: Florian Westphal <fw@strlen.de>
Cc: Peter Oskolkov <posk@google.com>
Cc: Paolo Abeni <pabeni@redhat.com>
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit a560002437d3646dafccecb1bf32d1685112ddda ]
inet_evict_bucket() iterates global list, and
several tasks may call it in parallel. All of
them hash the same fq->list_evictor to different
lists, which leads to list corruption.
This patch makes fq be hashed to expired list
only if this has not been made yet by another
task. Since inet_frag_alloc() allocates fq
using kmem_cache_zalloc(), we may rely on
list_evictor is initially unhashed.
The problem seems to exist before async
pernet_operations, as there was possible to have
exit method to be executed in parallel with
inet_frags::frags_work, so I add two Fixes tags.
This also may go to stable.
Fixes: d1fe19444d82 "inet: frag: don't re-use chainlist for evictor"
Fixes: f84c6821aa54 "net: Convert pernet_subsys, registered from inet_init()"
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
[ Upstream commit fb452a1aa3fd4034d7999e309c5466ff2d7005aa ]
This reverts commit 6d7b857d541ecd1d9bd997c97242d4ef94b19de2.
There is a bug in fragmentation codes use of the percpu_counter API,
that can cause issues on systems with many CPUs.
The frag_mem_limit() just reads the global counter (fbc->count),
without considering other CPUs can have upto batch size (130K) that
haven't been subtracted yet. Due to the 3MBytes lower thresh limit,
this become dangerous at >=24 CPUs (3*1024*1024/130000=24).
The correct API usage would be to use __percpu_counter_compare() which
does the right thing, and takes into account the number of (online)
CPUs and batch size, to account for this and call __percpu_counter_sum()
when needed.
We choose to revert the use of the lib/percpu_counter API for frag
memory accounting for several reasons:
1) On systems with CPUs > 24, the heavier fully locked
__percpu_counter_sum() is always invoked, which will be more
expensive than the atomic_t that is reverted to.
Given systems with more than 24 CPUs are becoming common this doesn't
seem like a good option. To mitigate this, the batch size could be
decreased and thresh be increased.
2) The add_frag_mem_limit+sub_frag_mem_limit pairs happen on the RX
CPU, before SKBs are pushed into sockets on remote CPUs. Given
NICs can only hash on L2 part of the IP-header, the NIC-RXq's will
likely be limited. Thus, a fair chance that atomic add+dec happen
on the same CPU.
Revert note that commit 1d6119baf061 ("net: fix percpu memory leaks")
removed init_frag_mem_limit() and instead use inet_frags_init_net().
After this revert, inet_frags_uninit_net() becomes empty.
Fixes: 6d7b857d541e ("net: use lib/percpu_counter API for fragmentation mem accounting")
Fixes: 1d6119baf061 ("net: fix percpu memory leaks")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Before commit 6d7b857d541e ("net: use lib/percpu_counter API for
fragmentation mem accounting"), setting the reassembly high threshold
to 0 prevented fragment reassembly as first fragment would be always
evicted before second could be added to the queue. While inefficient,
some users apparently relied on this method.
Since the commit mentioned above, a percpu counter is used for
reassembly memory accounting and high batch size avoids taking slow path
in most common scenarios. As a result, a whole full sized packet can be
reassembled without the percpu counter's main counter changing its value
so that even with high_thresh set to 0, fragmented packets can be still
reassembled and processed.
Add explicit check preventing reassembly if high threshold is zero.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
The only user was removed in commit
029f7f3b8701cc7a ("netfilter: ipv6: nf_defrag: avoid/free clone operations").
This patch fixes following problems :
1) percpu_counter_init() can return an error, therefore
init_frag_mem_limit() must propagate this error so that
inet_frags_init_net() can do the same up to its callers.
2) If ip[46]_frags_ns_ctl_register() fail, we must unwind
properly and free the percpu_counter.
Without this fix, we leave freed object in percpu_counters
global list (if CONFIG_HOTPLUG_CPU) leading to crashes.
This bug was detected by KASAN and syzkaller tool
(http://github.com/google/syzkaller)
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
We can simply remove the INET_FRAG_EVICTED flag to avoid all the flags
race conditions with the evictor and use a participation test for the
evictor list, when we're at that point (after inet_frag_kill) in the
timer there're 2 possible cases:
1. The evictor added the entry to its evictor list while the timer was
waiting for the chainlock
or
2. The timer unchained the entry and the evictor won't see it
In both cases we should be able to see list_evictor correctly due
to the sync on the chainlock.
Joint work with Florian Westphal.
Tested-by: Frank Schreuder <fschreuder@transip.nl>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Frank reports 'NMI watchdog: BUG: soft lockup' errors when
load is high. Instead of (potentially) unbounded restarts of the
eviction process, just skip to the next entry.
One caveat is that, when a netns is exiting, a timer may still be running
by the time inet_evict_bucket returns.
We use the frag memory accounting to wait for outstanding timers,
so that when we free the percpu counter we can be sure no running
timer will trip over it.
Reported-and-tested-by: Frank Schreuder <fschreuder@transip.nl>
Followup patch will call it after inet_frag_queue was freed, so q->net
doesn't work anymore (but netf = q->net; free(q); mem_limit(netf) would).
commit 65ba1f1ec0eff ("inet: frags: fix a race between inet_evict_bucket
and inet_frag_kill") describes the bug, but the fix doesn't work reliably.
Problem is that ->flags member can be set on other cpu without chainlock
being held by that task, i.e. the RMW-Cycle can clear INET_FRAG_EVICTED
bit after we put the element on the evictor private list.
We can crash when walking the 'private' evictor list since an element can
be deleted from list underneath the evictor.
Join work with Nikolay Alexandrov.
Reported-by: Johan Schuijt <johan@transip.nl>
Signed-off-by: Nikolay Alexandrov <nikolay@cumulusnetworks.com>
The ipv4 code uses a mixture of coding styles. In some instances check
for NULL pointer is done as x == NULL and sometimes as !x. !x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
Use the more common dynamic_debug capable net_dbg_ratelimited
and remove the LIMIT_NETDEBUG macro.
All messages are still ratelimited.
Some KERN_<LEVEL> uses are changed to KERN_DEBUG.
This may have some negative impact on messages that were
emitted at KERN_INFO that are not not enabled at all unless
DEBUG is defined or dynamic_debug is enabled. Even so,
these messages are now _not_ emitted by default.
This also eliminates the use of the net_msg_warn sysctl
"/proc/sys/net/core/warnings". For backward compatibility,
the sysctl is not removed, but it has no function. The extern
declaration of net_msg_warn is removed from sock.h and made
static in net/core/sysctl_net_core.c
Miscellanea:
o Update the sysctl documentation
o Remove the embedded uses of pr_fmt
o Coalesce format fragments
o Realign arguments
The WARN_ON in inet_evict_bucket can be triggered by a valid case:
inet_frag_kill and inet_evict_bucket can be running in parallel on the
same queue which means that there has been at least one more ref added
by a previous inet_frag_find call, but inet_frag_kill can delete the
timer before inet_evict_bucket which will cause the WARN_ON() there to
trigger since we'll have refcnt!=1. Now, this case is valid because the
queue is being "killed" for some reason (removed from the chain list and
its timer deleted) so it will get destroyed in the end by one of the
inet_frag_put() calls which reaches 0 i.e. refcnt is still valid.
CC: Florian Westphal <fw@strlen.de>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Patrick McLean <chutzpah@gentoo.org>
Reported-by: Patrick McLean <chutzpah@gentoo.org>
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
When the evictor is running it adds some chosen frags to a local list to
be evicted once the chain lock has been released but at the same time
the *frag_queue can be running for some of the same queues and it
may call inet_frag_kill which will wait on the chain lock and
will then delete the queue from the wrong list since it was added in the
eviction one. The fix is simple - check if the queue has the evict flag
set under the chain lock before deleting it, this is safe because the
evict flag is set only under that lock and having the flag set also means
that the queue has been detached from the chain list, so no need to delete
it again.
An important note to make is that we're safe w.r.t refcnt because
inet_frag_kill and inet_evict_bucket will sync on the del_timer operation
where only one of the two can succeed (or if the timer is executing -
none of them), the cases are:
1. inet_frag_kill succeeds in del_timer
- then the timer ref is removed, but inet_evict_bucket will not add
this queue to its expire list but will restart eviction in that chain
2. inet_evict_bucket succeeds in del_timer
- then the timer ref is kept until the evictor "expires" the queue, but
inet_frag_kill will remove the initial ref and will set
INET_FRAG_COMPLETE which will make the frag_expire fn just to remove
its ref.
In the end all of the queue users will do an inet_frag_put and the one
that reaches 0 will free it. The refcount balance should be okay.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Tested-by: Patrick McLean <chutzpah@gentoo.org>
Reviewed-by: Florian Westphal <fw@strlen.de>
Use kmem_cache to allocate/free inet_frag_queue objects since they're
all the same size per inet_frags user and are alloced/freed in high volumes
thus making it a perfect case for kmem_cache.
Now that we have INET_FRAG_EVICTED we might as well use it to stop
sending icmp messages in the "frag_expire" functions instead of
stripping INET_FRAG_FIRST_IN from their flags when evicting.
Also fix the comment style in ip6_expire_frag_queue().
Fix a couple of functions' declaration alignments.
The last_in field has been used to store various flags different from
first/last frag in so give it a more descriptive name: flags.
rehash is rare operation, don't force readers to take
the read-side rwlock.
Instead, we only have to detect the (rare) case where
the secret was altered while we are trying to insert
a new inetfrag queue into the table.
If it was changed, drop the bucket lock and recompute
the hash to get the 'new' chain bucket that we have to
insert into.
Joint work with Nikolay Aleksandrov.
merge functionality into the eviction workqueue.
Instead of rebuilding every n seconds, take advantage of the upper
hash chain length limit.
If we hit it, mark table for rebuild and schedule workqueue.
To prevent frequent rebuilds when we're completely overloaded,
don't rebuild more than once every 5 seconds.
ipfrag_secret_interval sysctl is now obsolete and has been marked as
deprecated, it still can be changed so scripts won't be broken but it
won't have any effect. A comment is left above each unused secret_timer
variable to avoid confusion.
no longer used.
The 'nqueues' counter is protected by the lru list lock,
once thats removed this needs to be converted to atomic
counter. Given this isn't used for anything except for
reporting it to userspace via /proc, just remove it.
We still report the memory currently used by fragment
reassembly queues.
When the high_thresh limit is reached we try to toss the 'oldest'
incomplete fragment queues until memory limits are below the low_thresh
value. This happens in softirq/packet processing context.
This has two drawbacks:
1) processors might evict a queue that was about to be completed
by another cpu, because they will compete wrt. resource usage and
resource reclaim.
2) LRU list maintenance is expensive.
But when constantly overloaded, even the 'least recently used' element is
recent, so removing 'lru' queue first is not 'fairer' than removing any
other fragment queue.
This moves eviction out of the fast path:
When the low threshold is reached, a work queue is scheduled
which then iterates over the table and removes the queues that exceed
the memory limits of the namespace. It sets a new flag called
INET_FRAG_EVICTED on the evicted queues so the proper counters will get
incremented when the queue is forcefully expired.
When the high threshold is reached, no more fragment queues are
created until we're below the limit again.
The LRU list is now unused and will be removed in a followup patch.
Suggested-by: Eric Dumazet <edumazet@google.com>
First step to move eviction handling into a work queue.
We lose two spots that accounted evicted fragments in MIB counters.
Accounting will be restored since the upcoming work-queue evictor
invokes the frag queue timer callbacks instead.
hide actual hash size from individual users: The _find
function will now fold the given hash value into the required range.
Quoting Alexander Aring:
While fragmentation and unloading of 6lowpan module I got this kernel Oops
after few seconds:
BUG: unable to handle kernel paging request at f88bbc30
Modules linked in: ipv6 [last unloaded: 6lowpan]
Call Trace:
[<c012af4c>] ? call_timer_fn+0x54/0xb3
[<c012aef8>] ? process_timeout+0xa/0xa
[<c012b66b>] run_timer_softirq+0x140/0x15f
Problem is that incomplete frags are still around after unload; when
their frag expire timer fires, we get crash.
When a netns is removed (also done when unloading module), inet_frag
calls the evictor with 'force' argument to purge remaining frags.
The evictor loop terminates when accounted memory ('work') drops to 0
or the lru-list becomes empty. However, the mem accounting is done
via percpu counters and may not be accurate, i.e. loop may terminate
prematurely.
Alter evictor to only stop once the lru list is empty when force is
requested.
Reported-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de>
Reported-by: Alexander Aring <alex.aring@gmail.com>
Tested-by: Alexander Aring <alex.aring@gmail.com>
I stumbled upon this very serious bug while hunting for another one,
it's a very subtle race condition between inet_frag_evictor,
inet_frag_intern and the IPv4/6 frag_queue and expire functions
(basically the users of inet_frag_kill/inet_frag_put).
What happens is that after a fragment has been added to the hash chain
but before it's been added to the lru_list (inet_frag_lru_add) in
inet_frag_intern, it may get deleted (either by an expired timer if
the system load is high or the timer sufficiently low, or by the
fraq_queue function for different reasons) before it's added to the
lru_list, then after it gets added it's a matter of time for the
evictor to get to a piece of memory which has been freed leading to a
number of different bugs depending on what's left there.
I've been able to trigger this on both IPv4 and IPv6 (which is normal
as the frag code is the same), but it's been much more difficult to
trigger on IPv4 due to the protocol differences about how fragments
are treated.
The setup I used to reproduce this is: 2 machines with 4 x 10G bonded
in a RR bond, so the same flow can be seen on multiple cards at the
same time. Then I used multiple instances of ping/ping6 to generate
fragmented packets and flood the machines with them while running
other processes to load the attacked machine.
*It is very important to have the _same flow_ coming in on multiple CPUs
concurrently. Usually the attacked machine would die in less than 30
minutes, if configured properly to have many evictor calls and timeouts
it could happen in 10 minutes or so.
An important point to make is that any caller (frag_queue or timer) of
inet_frag_kill will remove both the timer refcount and the
original/guarding refcount thus removing everything that's keeping the
frag from being freed at the next inet_frag_put. All of this could
happen before the frag was ever added to the LRU list, then it gets
added and the evictor uses a freed fragment.
An example for IPv6 would be if a fragment is being added and is at
the stage of being inserted in the hash after the hash lock is
released, but before inet_frag_lru_add executes (or is able to obtain
the lru lock) another overlapping fragment for the same flow arrives
at a different CPU which finds it in the hash, but since it's
overlapping it drops it invoking inet_frag_kill and thus removing all
guarding refcounts, and afterwards freeing it by invoking
inet_frag_put which removes the last refcount added previously by
inet_frag_find, then inet_frag_lru_add gets executed by
inet_frag_intern and we have a freed fragment in the lru_list.
The fix is simple, just move the lru_add under the hash chain locked
region so when a removing function is called it'll have to wait for
the fragment to be added to the lru_list, and then it'll remove it (it
works because the hash chain removal is done before the lru_list one
and there's no window between the two list adds when the frag can get
dropped). With this fix applied I couldn't kill the same machine in 24
hours with the same setup.
Fixes: 3ef0eb0db4bf ("net: frag, move LRU list maintenance outside of
rwlock")
CC: Jesper Dangaard Brouer <brouer@redhat.com>
CC: David S. Miller <davem@davemloft.net>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
All fragmentation hash secrets now get initialized by their
corresponding hash function with net_get_random_once. Thus we can
eliminate the initial seeding.
Also provide a comment that hash secret seeding happens at the first
call to the corresponding hashing function.
Cc: Eric Dumazet <edumazet@google.com>
Pull networking updates from David Miller:
"This is a re-do of the net-next pull request for the current merge
window. The only difference from the one I made the other day is that
this has Eliezer's interface renames and the timeout handling changes
made based upon your feedback, as well as a few bug fixes that have
trickeled in.
Highlights:
1) Low latency device polling, eliminating the cost of interrupt
handling and context switches. Allows direct polling of a network
device from socket operations, such as recvmsg() and poll().
Currently ixgbe, mlx4, and bnx2x support this feature.
Full high level description, performance numbers, and design in
commit 0a4db187a999 ("Merge branch 'll_poll'")
From Eliezer Tamir.
2) With the routing cache removed, ip_check_mc_rcu() gets exercised
more than ever before in the case where we have lots of multicast
addresses. Use a hash table instead of a simple linked list, from
Eric Dumazet.
3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from
Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski,
Marek Puzyniak, Michal Kazior, and Sujith Manoharan.
4) Support reporting the TUN device persist flag to userspace, from
Pavel Emelyanov.
5) Allow controlling network device VF link state using netlink, from
Rony Efraim.
6) Support GRE tunneling in openvswitch, from Pravin B Shelar.
7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from
Daniel Borkmann and Eric Dumazet.
8) Allow controlling of TCP quickack behavior on a per-route basis,
from Cong Wang.
9) Several bug fixes and improvements to vxlan from Stephen
Hemminger, Pravin B Shelar, and Mike Rapoport. In particular,
support receiving on multiple UDP ports.
10) Major cleanups, particular in the area of debugging and cookie
lifetime handline, to the SCTP protocol code. From Daniel
Borkmann.
11) Allow packets to cross network namespaces when traversing tunnel
devices. From Nicolas Dichtel.
12) Allow monitoring netlink traffic via AF_PACKET sockets, in a
manner akin to how we monitor real network traffic via ptype_all.
From Daniel Borkmann.
13) Several bug fixes and improvements for the new alx device driver,
from Johannes Berg.
14) Fix scalability issues in the netem packet scheduler's time queue,
by using an rbtree. From Eric Dumazet.
15) Several bug fixes in TCP loss recovery handling, from Yuchung
Cheng.
16) Add support for GSO segmentation of MPLS packets, from Simon
Horman.
17) Make network notifiers have a real data type for the opaque
pointer that's passed into them. Use this to properly handle
network device flag changes in arp_netdev_event(). From Jiri
Pirko and Timo Teräs.
18) Convert several drivers over to module_pci_driver(), from Peter
Huewe.
19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a
O(1) calculation instead. From Eric Dumazet.
20) Support setting of explicit tunnel peer addresses in ipv6, just
like ipv4. From Nicolas Dichtel.
21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet.
22) Prevent a single high rate flow from overruning an individual cpu
during RX packet processing via selective flow shedding. From
Willem de Bruijn.
23) Don't use spinlocks in TCP md5 signing fast paths, from Eric
Dumazet.
24) Don't just drop GSO packets which are above the TBF scheduler's
burst limit, chop them up so they are in-bounds instead. Also
from Eric Dumazet.
25) VLAN offloads are missed when configured on top of a bridge, fix
from Vlad Yasevich.
26) Support IPV6 in ping sockets. From Lorenzo Colitti.
27) Receive flow steering targets should be updated at poll() time
too, from David Majnemer.
28) Fix several corner case regressions in PMTU/redirect handling due
to the routing cache removal, from Timo Teräs.
29) We have to be mindful of ipv4 mapped ipv6 sockets in
upd_v6_push_pending_frames(). From Hannes Frederic Sowa.
30) Fix L2TP sequence number handling bugs, from James Chapman."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits)
drivers/net: caif: fix wrong rtnl_is_locked() usage
drivers/net: enic: release rtnl_lock on error-path
vhost-net: fix use-after-free in vhost_net_flush
net: mv643xx_eth: do not use port number as platform device id
net: sctp: confirm route during forward progress
virtio_net: fix race in RX VQ processing
virtio: support unlocked queue poll
net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit
Documentation: Fix references to defunct linux-net@vger.kernel.org
net/fs: change busy poll time accounting
net: rename low latency sockets functions to busy poll
bridge: fix some kernel warning in multicast timer
sfc: Fix memory leak when discarding scattered packets
sit: fix tunnel update via netlink
dt:net:stmmac: Add dt specific phy reset callback support.
dt:net:stmmac: Add support to dwmac version 3.610 and 3.710
dt:net:stmmac: Allocate platform data only if its NULL.
net:stmmac: fix memleak in the open method
ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available
net: ipv6: fix wrong ping_v6_sendmsg return value
The global variable num_physpages is scheduled to be removed, so use
totalram_pages instead of num_physpages at runtime.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
This patch removes an empty ifdef from inet_frag_intern()
in net/ipv4/inet_fragment.c.
commit b67bfe0d42cac56c512dd5da4b1b347a23f4b70a
(hlist: drop the node parameter from iterators) removed hlist from
net/ipv4/inet_fragment.c, but did not remove the enclosing ifdef command,
which is now empty.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
This patch fixes race between inet_frag_lru_move() and inet_frag_lru_add()
which was introduced in commit 3ef0eb0db4bf92c6d2510fe5c4dc51852746f206
("net: frag, move LRU list maintenance outside of rwlock")
One cpu already added new fragment queue into hash but not into LRU.
Other cpu found it in hash and tries to move it to the end of LRU.
This leads to NULL pointer dereference inside of list_move_tail().
Another possible race condition is between inet_frag_lru_move() and
inet_frag_lru_del(): move can happens after deletion.
This patch initializes LRU list head before adding fragment into hash and
inet_frag_lru_move() doesn't touches it if it's empty.
I saw this kernel oops two times in a couple of days.
[119482.128853] BUG: unable to handle kernel NULL pointer dereference at (null)
[119482.132693] IP: [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.136456] PGD 2148f6067 PUD 215ab9067 PMD 0
[119482.140221] Oops: 0000 [#1] SMP
[119482.144008] Modules linked in: vfat msdos fat 8021q fuse nfsd auth_rpcgss nfs_acl nfs lockd sunrpc ppp_async ppp_generic bridge slhc stp llc w83627ehf hwmon_vid snd_hda_codec_hdmi snd_hda_codec_realtek kvm_amd k10temp kvm snd_hda_intel snd_hda_codec edac_core radeon snd_hwdep ath9k snd_pcm ath9k_common snd_page_alloc ath9k_hw snd_timer snd soundcore drm_kms_helper ath ttm r8169 mii
[119482.152692] CPU 3
[119482.152721] Pid: 20, comm: ksoftirqd/3 Not tainted 3.9.0-zurg-00001-g9f95269 #132 To Be Filled By O.E.M. To Be Filled By O.E.M./RS880D
[119482.161478] RIP: 0010:[<ffffffff812ede89>] [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.166004] RSP: 0018:ffff880216d5db58 EFLAGS: 00010207
[119482.170568] RAX: 0000000000000000 RBX: ffff88020882b9c0 RCX: dead000000200200
[119482.175189] RDX: 0000000000000000 RSI: 0000000000000880 RDI: ffff88020882ba00
[119482.179860] RBP: ffff880216d5db58 R08: ffffffff8155c7f0 R09: 0000000000000014
[119482.184570] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88020882ba00
[119482.189337] R13: ffffffff81c8d780 R14: ffff880204357f00 R15: 00000000000005a0
[119482.194140] FS: 00007f58124dc700(0000) GS:ffff88021fcc0000(0000) knlGS:0000000000000000
[119482.198928] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[119482.203711] CR2: 0000000000000000 CR3: 00000002155f0000 CR4: 00000000000007e0
[119482.208533] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[119482.213371] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[119482.218221] Process ksoftirqd/3 (pid: 20, threadinfo ffff880216d5c000, task ffff880216d3a9a0)
[119482.223113] Stack:
[119482.228004] ffff880216d5dbd8 ffffffff8155dcda 0000000000000000 ffff000200000001
[119482.233038] ffff8802153c1f00 ffff880000289440 ffff880200000014 ffff88007bc72000
[119482.238083] 00000000000079d5 ffff88007bc72f44 ffffffff00000002 ffff880204357f00
[119482.243090] Call Trace:
[119482.248009] [<ffffffff8155dcda>] ip_defrag+0x8fa/0xd10
[119482.252921] [<ffffffff815a8013>] ipv4_conntrack_defrag+0x83/0xe0
[119482.257803] [<ffffffff8154485b>] nf_iterate+0x8b/0xa0
[119482.262658] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40
[119482.267527] [<ffffffff815448e4>] nf_hook_slow+0x74/0x130
[119482.272412] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40
[119482.277302] [<ffffffff8155d068>] ip_rcv+0x268/0x320
[119482.282147] [<ffffffff81519992>] __netif_receive_skb_core+0x612/0x7e0
[119482.286998] [<ffffffff81519b78>] __netif_receive_skb+0x18/0x60
[119482.291826] [<ffffffff8151a650>] process_backlog+0xa0/0x160
[119482.296648] [<ffffffff81519f29>] net_rx_action+0x139/0x220
[119482.301403] [<ffffffff81053707>] __do_softirq+0xe7/0x220
[119482.306103] [<ffffffff81053868>] run_ksoftirqd+0x28/0x40
[119482.310809] [<ffffffff81074f5f>] smpboot_thread_fn+0xff/0x1a0
[119482.315515] [<ffffffff81074e60>] ? lg_local_lock_cpu+0x40/0x40
[119482.320219] [<ffffffff8106d870>] kthread+0xc0/0xd0
[119482.324858] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40
[119482.329460] [<ffffffff816c32dc>] ret_from_fork+0x7c/0xb0
[119482.334057] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40
[119482.338661] Code: 00 00 55 48 8b 17 48 b9 00 01 10 00 00 00 ad de 48 8b 47 08 48 89 e5 48 39 ca 74 29 48 b9 00 02 20 00 00 00 ad de 48 39 c8 74 7a <4c> 8b 00 4c 39 c7 75 53 4c 8b 42 08 4c 39 c7 75 2b 48 89 42 08
[119482.343787] RIP [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.348675] RSP <ffff880216d5db58>
[119482.353493] CR2: 0000000000000000
Oops happened on this path:
ip_defrag() -> ip_frag_queue() -> inet_frag_lru_move() -> list_move_tail() -> __list_del_entry()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
This patch implements per hash bucket locking for the frag queue
hash. This removes two write locks, and the only remaining write
lock is for protecting hash rebuild. This essentially reduce the
readers-writer lock to a rebuild lock.
This patch is part of "net: frag performance followup"
http://thread.gmane.org/gmane.linux.network/263644
of which two patches have already been accepted:
Same test setup as previous:
(http://thread.gmane.org/gmane.linux.network/257155)
Two 10G interfaces, on seperate NUMA nodes, are under-test, and uses
Ethernet flow-control. A third interface is used for generating the
DoS attack (with trafgen).
Notice, I have changed the frag DoS generator script to be more
efficient/deadly. Before it would only hit one RX queue, now its
sending packets causing multi-queue RX, due to "better" RX hashing.
Test types summary (netperf UDP_STREAM):
Test-20G64K == 2x10G with 65K fragments
Test-20G3F == 2x10G with 3x fragments (3*1472 bytes)
Test-20G64K+DoS == Same as 20G64K with frag DoS
Test-20G3F+DoS == Same as 20G3F with frag DoS
Test-20G64K+MQ == Same as 20G64K with Multi-Queue frag DoS
Test-20G3F+MQ == Same as 20G3F with Multi-Queue frag DoS
When I rebased this-patch(03) (on top of net-next commit a210576c) and
removed the _bh spinlock, I saw a performance regression. BUT this
was caused by some unrelated change in-between. See tests below.
Test (A) is what I reported before for patch-02, accepted in commit 1b5ab0de.
Test (B) verifying-retest of commit 1b5ab0de corrospond to patch-02.
Test (C) is what I reported before for this-patch
Test (D) is net-next master HEAD (commit a210576c), which reveals some
(unknown) performance regression (compared against test (B)).
Test (D) function as a new base-test.
Performance table summary (in Mbit/s):
(#) Test-type: 20G64K 20G3F 20G64K+DoS 20G3F+DoS 20G64K+MQ 20G3F+MQ
(A) Patch-02 : 18848.7 13230.1 4103.04 5310.36 130.0 440.2
(B) 1b5ab0de : 18841.5 13156.8 4101.08 5314.57 129.0 424.2
(C) Patch-03v1: 18838.0 13490.5 4405.11 6814.72 196.6 461.6
(D) a210576c : 18321.5 11250.4 3635.34 5160.13 119.1 405.2
(E) with _bh : 17247.3 11492.6 3994.74 6405.29 166.7 413.6
(F) without bh: 17471.3 11298.7 3818.05 6102.11 165.7 406.3
Test (E) and (F) is this-patch(03), with(V1) and without(V2) the _bh spinlocks.
I cannot explain the slow down for 20G64K (but its an artificial
"lab-test" so I'm not worried). But the other results does show
improvements. And test (E) "with _bh" version is slightly better.
V2:
- By analysis from Hannes Frederic Sowa and Eric Dumazet, we don't
need the spinlock _bh versions, as Netfilter currently does a
local_bh_disable() before entering inet_fragment.
- Fold-in desc from cover-mail
V3:
- Drop the chain_len counter per hash bucket.
Move the protection of netns_frags.nqueues updates under the LRU_lock,
instead of the write lock. As they are located on the same cacheline,
and this is also needed when transitioning to use per hash bucket locking.
The LRU list is protected by its own lock, since commit 3ef0eb0db4
(net: frag, move LRU list maintenance outside of rwlock), and
no-longer by a read_lock.
This makes it possible, to remove the inet_frag_queue, which is about
to be "evicted", from the LRU list head. This avoids the problem, of
several CPUs grabbing the same frag queue.
Note, cannot remove the inet_frag_lru_del() call in fq_unlink()
called by inet_frag_kill(), because inet_frag_kill() is also used in
other situations. Thus, we use list_del_init() to allow this
double list_del to work.
use by ipv6
This patch just moves some code arround to make the ip4_frag_ecn_table
and IPFRAG_ECN_* constants accessible from the other reassembly engines. I
also renamed ip4_frag_ecn_table to ip_frag_ecn_table.
Cc: Jesper Dangaard Brouer <jbrouer@redhat.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch introduces a constant limit of the fragment queue hash
table bucket list lengths. Currently the limit 128 is choosen somewhat
arbitrary and just ensures that we can fill up the fragment cache with
empty packets up to the default ip_frag_high_thresh limits. It should
just protect from list iteration eating considerable amounts of cpu.
If we reach the maximum length in one hash bucket a warning is printed.
This is implemented on the caller side of inet_frag_find to distinguish
between the different users of inet_fragment.c.
I dropped the out of memory warning in the ipv4 fragment lookup path,
because we already get a warning by the slab allocator.
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Updating the fragmentation queues LRU (Least-Recently-Used) list,
required taking the hash writer lock. However, the LRU list isn't
tied to the hash at all, so we can use a separate lock for it.
Original-idea-by: Florian Westphal <fw@strlen.de>
Replace the per network namespace shared atomic "mem" accounting
variable, in the fragmentation code, with a lib/percpu_counter.
Getting percpu_counter to scale to the fragmentation code usage
requires some tweaks.
At first view, percpu_counter looks superfast, but it does not
scale on multi-CPU/NUMA machines, because the default batch size
is too small, for frag code usage. Thus, I have adjusted the
batch size by using __percpu_counter_add() directly, instead of
percpu_counter_sub() and percpu_counter_add().
The batch size is increased to 130.000, based on the largest 64K
fragment memory usage. This does introduce some imprecise
memory accounting, but its does not need to be strict for this
use-case.
It is also essential, that the percpu_counter, does not
share cacheline with other writers, to make this scale.
This change is primarily a preparation to ease the extension of memory
limit tracking.
The change does reduce the number atomic operation, during freeing of
a frag queue. This does introduce a some performance improvement, as
these atomic operations are at the core of the performance problems
seen on NUMA systems.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Michal Kubeček <mkubecek@suse.cz>
Signed-off-by: Cong Wang <amwang@redhat.com>
add struct net as a parameter of inet_getpeer_v[4,6],
use net to replace &init_net.
and modify some places to provide net for inet_getpeer_v[4,6]
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
CodingStyle cleanups
EXPORT_SYMBOL should immediately follow the symbol declaration.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Impact: Attribute function with __releases(...)
Fix this sparse warning:
net/ipv4/inet_fragment.c:276:35: warning: context imbalance in 'inet_frag_find' - unexpected unlock
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Removes legacy reinvent-the-wheel type thing. The generic
machinery integrates much better to automated debugging aids
such as kerneloops.org (and others), and is unambiguous due to
better naming. Non-intuively BUG_TRAP() is actually equal to
WARN_ON() rather than BUG_ON() though some might actually be
promoted to BUG_ON() but I left that to future.
I could make at least one BUILD_BUG_ON conversion.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
The problem is that while we work w/o the inet_frags.lock even
read-locked the secret rebuild timer may occur (on another CPU, since
BHs are still disabled in the inet_frag_find) and change the rnd seed
for ipv4/6 fragments.
It was caused by my patch fd9e63544cac30a34c951f0ec958038f0529e244
([INET]: Omit double hash calculations in xxx_frag_intern) late
in the 2.6.24 kernel, so this should probably be queued to -stable.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/s2io.c
Based upon a lockdep trace from Dave Jones.
