path: root/net/ipv4/inet_diag.c
2016-09-08net: inet: diag: expose the socket mark to privileged processes.Lorenzo Colitti
This adds the capability for a process that has CAP_NET_ADMIN on a socket to see the socket mark in socket dumps. Commit a52e95abf772 ("net: diag: allow socket bytecode filters to match socket marks") recently gave privileged processes the ability to filter socket dumps based on mark. This patch is complementary: it ensures that the mark is also passed to userspace in the socket's netlink attributes. It is useful for tools like ss which display information about sockets. Tested: https://android-review.googlesource.com/270210 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-24net: diag: allow socket bytecode filters to match socket marksLorenzo Colitti
This allows a privileged process to filter by socket mark when dumping sockets via INET_DIAG_BY_FAMILY. This is useful on systems that use mark-based routing such as Android. The ability to filter socket marks requires CAP_NET_ADMIN, which is consistent with other privileged operations allowed by the SOCK_DIAG interface such as the ability to destroy sockets and the ability to inspect BPF filters attached to packet sockets. Tested: https://android-review.googlesource.com/261350 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Acked-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-24net: diag: slightly refactor the inet_diag_bc_audit error checks.Lorenzo Colitti
This simplifies the code a bit and also allows inet_diag_bc_audit to send to userspace an error that isn't EINVAL. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Acked-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-28net: diag: Add support to filter on device indexDavid Ahern
Add support to inet_diag facility to filter sockets based on device index. If an interface index is in the filter only sockets bound to that index (sk_bound_dev_if) are returned. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-26sock_diag: align nlattr properly when neededNicolas Dichtel
I also fix the value of INET_DIAG_MAX. It's wrong since commit 8f840e47f190 which is only in net-next right now, thus I didn't make a separate patch. Fixes: 8f840e47f190 ("sctp: add the sctp_diag.c file") Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-21net: use jiffies_to_msecs to replace EXPIRES_IN_MS in inet/sctp_diagXin Long
EXPIRES_IN_MS macro comes from net/ipv4/inet_diag.c and dates back to before jiffies_to_msecs() has been introduced. Now we can remove it and use jiffies_to_msecs(). Suggested-by: Jakub Sitnicki <jkbs@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Acked-by: Jakub Sitnicki <jkbs@redhat.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-15sctp: export some functions for sctp_diag in inet_diagXin Long
inet_diag_msg_common_fill is used to fill the diag msg common info, we need to use it in sctp_diag as well, so export it. inet_diag_msg_attrs_fill is used to fill some common attrs info between sctp diag and tcp diag. v2->v3: - do not need to define and export inet_diag_get_handler any more. cause all the functions in it are in sctp_diag.ko, we just call them in sctp_diag.ko. - add inet_diag_msg_attrs_fill to make codes clear. Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-04tcp/dccp: do not touch listener sk_refcnt under synfloodEric Dumazet
When a SYNFLOOD targets a non SO_REUSEPORT listener, multiple cpus contend on sk->sk_refcnt and sk->sk_wmem_alloc changes. By letting listeners use SOCK_RCU_FREE infrastructure, we can relax TCP_LISTEN lookup rules and avoid touching sk_refcnt Note that we still use SLAB_DESTROY_BY_RCU rules for other sockets, only listeners are impacted by this change. Peak performance under SYNFLOOD is increased by ~33% : On my test machine, I could process 3.2 Mpps instead of 2.4 Mpps Most consuming functions are now skb_set_owner_w() and sock_wfree() contending on sk->sk_wmem_alloc when cooking SYNACK and freeing them. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-04tcp/dccp: use rcu locking in inet_diag_find_one_icsk()Eric Dumazet
RX packet processing holds rcu_read_lock(), so we can remove pairs of rcu_read_lock()/rcu_read_unlock() in lookup functions if inet_diag also holds rcu before calling them. This is needed anyway as __inet_lookup_listener() and inet6_lookup_listener() will soon no longer increment refcount on the found listener. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-14net: diag: add a scheduling point in inet_diag_dump_icsk()Eric Dumazet
On loaded TCP servers, looking at millions of sockets can hold cpu for many seconds, if the lookup condition is very narrow. (eg : ss dst 1.2.3.4 ) Better add a cond_resched() to allow other processes to access the cpu. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-11inet: refactor inet[6]_lookup functions to take skbCraig Gallek
This is a preliminary step to allow fast socket lookup of SO_REUSEPORT groups. Doing so with a BPF filter will require access to the skb in question. This change plumbs the skb (and offset to payload data) through the call stack to the listening socket lookup implementations where it will be used in a following patch. Signed-off-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-20net: diag: support v4mapped sockets in inet_diag_find_one_icsk()Eric Dumazet
Lorenzo reported that we could not properly find v4mapped sockets in inet_diag_find_one_icsk(). This patch fixes the issue. Reported-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-15net: diag: Support SOCK_DESTROY for inet sockets.Lorenzo Colitti
This passes the SOCK_DESTROY operation to the underlying protocol diag handler, or returns -EOPNOTSUPP if that handler does not define a destroy operation. Most of this patch is just renaming functions. This is not strictly necessary, but it would be fairly counterintuitive to have the code to destroy inet sockets be in a function whose name starts with inet_diag_get. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-15net: diag: split inet_diag_dump_one_icsk into twoLorenzo Colitti
Currently, inet_diag_dump_one_icsk finds a socket and then dumps its information to userspace. Split it into a part that finds the socket and a part that dumps the information. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-03tcp/dccp: install syn_recv requests into ehash tableEric Dumazet
In this patch, we insert request sockets into TCP/DCCP regular ehash table (where ESTABLISHED and TIMEWAIT sockets are) instead of using the per listener hash table. ACK packets find SYN_RECV pseudo sockets without having to find and lock the listener. In nominal conditions, this halves pressure on listener lock. Note that this will allow for SO_REUSEPORT refinements, so that we can select a listener using cpu/numa affinities instead of the prior 'consistent hash', since only SYN packets will apply this selection logic. We will shrink listen_sock in the following patch to ease code review. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Ying Cai <ycai@google.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-03tcp: move qlen/young out of struct listen_sockEric Dumazet
qlen_inc & young_inc were protected by listener lock, while qlen_dec & young_dec were atomic fields. Everything needs to be atomic for upcoming lockless listener. Also move qlen/young in request_sock_queue as we'll get rid of struct listen_sock eventually. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-10net: inet_diag: always export IPV6_V6ONLY sockopt for listening socketsPhil Sutter
Reconsidering my commit 20462155 "net: inet_diag: export IPV6_V6ONLY sockopt", I am not happy with the limitations it causes for socket analysing code in userspace. Exporting the value only if it is set makes it hard for userspace to decide whether the option is not set or the kernel does not support exporting the option at all. >From an auditor's perspective, the interesting question for listening AF_INET6 sockets is: "Does it NOT have IPV6_V6ONLY set?" Because it is the unexpected case. This patch allows to answer this question reliably. Signed-off-by: Phil Sutter <phil@nwl.cc> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net: inet_diag: export IPV6_V6ONLY sockoptPhil Sutter
For AF_INET6 sockets, the value of struct ipv6_pinfo.ipv6only is exported to userspace. It indicates whether a socket bound to in6addr_any listens on IPv4 as well as IPv6. Since the socket is natively IPv6, it is not listed by e.g. 'ss -l -4'. This patch is accompanied by an appropriate one for iproute2 to enable the additional information in 'ss -e'. Signed-off-by: Phil Sutter <phil@nwl.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23inet_diag: Remove _bh suffix in inet_diag_dump_reqs().Hiroaki SHIMODA
inet_diag_dump_reqs() is called from inet_diag_dump_icsk() with BH disabled. So no need to disable BH in inet_diag_dump_reqs(). Signed-off-by: Hiroaki Shimoda <shimoda.hiroaki@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-21sock_diag: fetch source port from inet_sockCraig Gallek
When an inet_sock is destroyed, its source port (sk_num) is set to zero as part of the unhash procedure. In order to supply a source port as part of the NETLINK_SOCK_DIAG socket destruction broadcasts, the source port number must be read from inet_sport instead. Tested: ss -E Signed-off-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-15sock_diag: implement a get_info handler for inetCraig Gallek
This get_info handler will simply dispatch to the appropriate existing inet protocol handler. This patch also includes a new netlink attribute (INET_DIAG_PROTOCOL). This attribute is currently only used for multicast messages. Without this attribute, there is no way of knowing the IP protocol used by the socket information being broadcast. This attribute is not necessary in the 'dump' variant of this protocol (though it could easily be added) because dump requests are issued for specific family/protocol pairs. Tested: ss -E (note, the -E option has not yet been merged into the upstream version of ss). Signed-off-by: Craig Gallek <kraig@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-15sock_diag: specify info_size per inet protocolCraig Gallek
Previously, there was no clear distinction between the inet protocols that used struct tcp_info to report information and those that didn't. This change adds a specific size attribute to the inet_diag_handler struct which defines these interfaces. This will make dispatching sock_diag get_info requests identical for all inet protocols in a following patch. Tested: ss -au Tested: ss -at Signed-off-by: Craig Gallek <kraig@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-29tcp: prepare CC get_info() access from getsockopt()Eric Dumazet
We would like that optional info provided by Congestion Control modules using netlink can also be read using getsockopt() This patch changes get_info() to put this information in a buffer, instead of skb, like tcp_get_info(), so that following patch can reuse this common infrastructure. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-17inet_diag: fix access to tcp cc informationEric Dumazet
Two different problems are fixed here : 1) inet_sk_diag_fill() might be called without socket lock held. icsk->icsk_ca_ops can change under us and module be unloaded. -> Access to freed memory. Fix this using rcu_read_lock() to prevent module unload. 2) Some TCP Congestion Control modules provide information but again this is not safe against icsk->icsk_ca_ops change and nla_put() errors were ignored. Some sockets could not get the additional info if skb was almost full. Fix this by returning a status from get_info() handlers and using rcu protection as well. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-13tcp/dccp: get rid of central timewait timerEric Dumazet
Using a timer wheel for timewait sockets was nice ~15 years ago when memory was expensive and machines had a single processor. This does not scale, code is ugly and source of huge latencies (Typically 30 ms have been seen, cpus spinning on death_lock spinlock.) We can afford to use an extra 64 bytes per timewait sock and spread timewait load to all cpus to have better behavior. Tested: On following test, /proc/sys/net/ipv4/tcp_tw_recycle is set to 1 on the target (lpaa24) Before patch : lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 419594 lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 437171 While test is running, we can observe 25 or even 33 ms latencies. lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23 ... 1000 packets transmitted, 1000 received, 0% packet loss, time 20601ms rtt min/avg/max/mdev = 0.020/0.217/25.771/1.535 ms, pipe 2 lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23 ... 1000 packets transmitted, 1000 received, 0% packet loss, time 20702ms rtt min/avg/max/mdev = 0.019/0.183/33.761/1.441 ms, pipe 2 After patch : About 90% increase of throughput : lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 810442 lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 800992 And latencies are kept to minimal values during this load, even if network utilization is 90% higher : lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23 ... 1000 packets transmitted, 1000 received, 0% packet loss, time 19991ms rtt min/avg/max/mdev = 0.023/0.064/0.360/0.042 ms Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23net: convert syn_wait_lock to a spinlockEric Dumazet
This is a low hanging fruit, as we'll get rid of syn_wait_lock eventually. We hold syn_wait_lock for such small sections, that it makes no sense to use a read/write lock. A spin lock is simply faster. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c net/core/sysctl_net_core.c net/ipv4/inet_diag.c The be_main.c conflict resolution was really tricky. The conflict hunks generated by GIT were very unhelpful, to say the least. It split functions in half and moved them around, when the real actual conflict only existed solely inside of one function, that being be_map_pci_bars(). So instead, to resolve this, I checked out be_main.c from the top of net-next, then I applied the be_main.c changes from 'net' since the last time I merged. And this worked beautifully. The inet_diag.c and sysctl_net_core.c conflicts were simple overlapping changes, and were easily to resolve. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20inet: get rid of central tcp/dccp listener timerEric Dumazet
One of the major issue for TCP is the SYNACK rtx handling, done by inet_csk_reqsk_queue_prune(), fired by the keepalive timer of a TCP_LISTEN socket. This function runs for awful long times, with socket lock held, meaning that other cpus needing this lock have to spin for hundred of ms. SYNACK are sent in huge bursts, likely to cause severe drops anyway. This model was OK 15 years ago when memory was very tight. We now can afford to have a timer per request sock. Timer invocations no longer need to lock the listener, and can be run from all cpus in parallel. With following patch increasing somaxconn width to 32 bits, I tested a listener with more than 4 million active request sockets, and a steady SYNFLOOD of ~200,000 SYN per second. Host was sending ~830,000 SYNACK per second. This is ~100 times more what we could achieve before this patch. Later, we will get rid of the listener hash and use ehash instead. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18inet: request sock should init IPv6/IPv4 addressesEric Dumazet
In order to be able to use sk_ehashfn() for request socks, we need to initialize their IPv6/IPv4 addresses. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-16inet_diag: allow sk_diag_fill() to handle request socksEric Dumazet
inet_diag_fill_req() is renamed to inet_req_diag_fill() and moved up, so that it can be called fom sk_diag_fill() inet_diag_bc_sk() is ready to handle request socks. inet_twsk_diag_dump() is no longer needed. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-14inet_diag: factorize code in new inet_diag_msg_common_fill() helperEric Dumazet
Now the three type of sockets share a common base, we can factorize code in inet_diag_msg_common_fill(). inet_diag_entry no longer requires saddr_storage & daddr_storage and the extra copies. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-14inet_diag: adjust inet_sk_diag_fill() bug conditionEric Dumazet
inet_sk_diag_fill() only copes with non timewait and non request socks Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-14inet: fill request sock ir_iif for IPv4Eric Dumazet
Once request socks will be in ehash table, they will need to have a valid ir_iff field. This is currently true only for IPv6. This patch extends support for IPv4 as well. This means inet_diag_fill_req() can now properly use ir_iif, which is better for IPv6 link locals anyway, as request sockets and established sockets will propagate consistent netlink idiag_if. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-13inet_diag: fix possible overflow in inet_diag_dump_one_icsk()Eric Dumazet
inet_diag_dump_one_icsk() allocates too small skb. Add inet_sk_attr_size() helper right before inet_sk_diag_fill() so that it can be updated if/when new attributes are added. iproute2/ss currently does not use this dump_one() interface, this might explain nobody noticed this problem yet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-12inet: introduce ireq_familyEric Dumazet
Before inserting request socks into general hash table, fill their socket family. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-12inet: get_openreq4() & get_openreq6() do not need listenerEric Dumazet
ireq->ir_num contains local port, use it. Also, get_openreq4() dumping listen_sk->refcnt makes litle sense. inet_diag_fill_req() can also use ireq->ir_num Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-11net: add real socket cookiesEric Dumazet
A long standing problem in netlink socket dumps is the use of kernel socket addresses as cookies. 1) It is a security concern. 2) Sockets can be reused quite quickly, so there is no guarantee a cookie is used once and identify a flow. 3) request sock, establish sock, and timewait socks for a given flow have different cookies. Part of our effort to bring better TCP statistics requires to switch to a different allocator. In this patch, I chose to use a per network namespace 64bit generator, and to use it only in the case a socket needs to be dumped to netlink. (This might be refined later if needed) Note that I tried to carry cookies from request sock, to establish sock, then timewait sockets. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Eric Salo <salo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-10inet_diag: add const to inet_diag_req_v2Eric Dumazet
diag dumpers should not modify the request. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-10inet_diag: cleanupsEric Dumazet
Remove all inline keywords, add some const, and cleanup style. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-05inet_diag: remove duplicate code from inet_twsk_diag_dump()Eric Dumazet
timewait sockets now share a common base with established sockets. inet_twsk_diag_dump() can use inet_diag_bc_sk() instead of duplicating code, granted that inet_diag_bc_sk() does proper userlocks initialization. twsk_build_assert() will catch any future changes that could break the assumptions. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-18netlink: make nlmsg_end() and genlmsg_end() voidJohannes Berg
Contrary to common expectations for an "int" return, these functions return only a positive value -- if used correctly they cannot even return 0 because the message header will necessarily be in the skb. This makes the very common pattern of if (genlmsg_end(...) < 0) { ... } be a whole bunch of dead code. Many places also simply do return nlmsg_end(...); and the caller is expected to deal with it. This also commonly (at least for me) causes errors, because it is very common to write if (my_function(...)) /* error condition */ and if my_function() does "return nlmsg_end()" this is of course wrong. Additionally, there's not a single place in the kernel that actually needs the message length returned, and if anyone needs it later then it'll be very easy to just use skb->len there. Remove this, and make the functions void. This removes a bunch of dead code as described above. The patch adds lines because I did - return nlmsg_end(...); + nlmsg_end(...); + return 0; I could have preserved all the function's return values by returning skb->len, but instead I've audited all the places calling the affected functions and found that none cared. A few places actually compared the return value with <= 0 in dump functionality, but that could just be changed to < 0 with no change in behaviour, so I opted for the more efficient version. One instance of the error I've made numerous times now is also present in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't check for <0 or <=0 and thus broke out of the loop every single time. I've preserved this since it will (I think) have caused the messages to userspace to be formatted differently with just a single message for every SKB returned to userspace. It's possible that this isn't needed for the tools that actually use this, but I don't even know what they are so couldn't test that changing this behaviour would be acceptable. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13inet_diag: fix inet_diag_dump_icsk() to use correct state for timewait socketsNeal Cardwell
Fix inet_diag_dump_icsk() to reflect the fact that both TCP_TIME_WAIT and TCP_FIN_WAIT2 connections are represented by inet_timewait_sock (not just TIME_WAIT), and for such sockets the tw_substate field holds the real state, which can be either TCP_TIME_WAIT or TCP_FIN_WAIT2. This brings the inet_diag state-matching code in line with the field it uses to populate idiag_state. This is also analogous to the info exported in /proc/net/tcp, where get_tcp4_sock() exports sk->sk_state and get_timewait4_sock() exports tw->tw_substate. Before fixing this, (a) neither "ss -nemoi" nor "ss -nemoi state fin-wait-2" would return a socket in TCP_FIN_WAIT2; and (b) "ss -nemoi state time-wait" would also return sockets in state TCP_FIN_WAIT2. This is an old bug that predates 05dbc7b ("tcp/dccp: remove twchain"). Signed-off-by: Neal Cardwell <ncardwell@google.com> Cc: Eric Dumazet <edumazet@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19net: inet_diag: zero out uninitialized idiag_{src,dst} fieldsDaniel Borkmann
Jakub reported while working with nlmon netlink sniffer that parts of the inet_diag_sockid are not initialized when r->idiag_family != AF_INET6. That is, fields of r->id.idiag_src[1 ... 3], r->id.idiag_dst[1 ... 3]. In fact, it seems that we can leak 6 * sizeof(u32) byte of kernel [slab] memory through this. At least, in udp_dump_one(), we allocate a skb in ... rep = nlmsg_new(sizeof(struct inet_diag_msg) + ..., GFP_KERNEL); ... and then pass that to inet_sk_diag_fill() that puts the whole struct inet_diag_msg into the skb, where we only fill out r->id.idiag_src[0], r->id.idiag_dst[0] and leave the rest untouched: r->id.idiag_src[0] = inet->inet_rcv_saddr; r->id.idiag_dst[0] = inet->inet_daddr; struct inet_diag_msg embeds struct inet_diag_sockid that is correctly / fully filled out in IPv6 case, but for IPv4 not. So just zero them out by using plain memset (for this little amount of bytes it's probably not worth the extra check for idiag_family == AF_INET). Similarly, fix also other places where we fill that out. Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-17inet_diag: use sock_gen_put()Eric Dumazet
TCP listener refactoring, part 6 : Use sock_gen_put() from inet_diag_dump_one_icsk() for future SYN_RECV support. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-10inet: includes a sock_common in request_sockEric Dumazet
TCP listener refactoring, part 5 : We want to be able to insert request sockets (SYN_RECV) into main ehash table instead of the per listener hash table to allow RCU lookups and remove listener lock contention. This patch includes the needed struct sock_common in front of struct request_sock This means there is no more inet6_request_sock IPv6 specific structure. Following inet_request_sock fields were renamed as they became macros to reference fields from struct sock_common. Prefix ir_ was chosen to avoid name collisions. loc_port -> ir_loc_port loc_addr -> ir_loc_addr rmt_addr -> ir_rmt_addr rmt_port -> ir_rmt_port iif -> ir_iif Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-09ipv6: make lookups simpler and fasterEric Dumazet
TCP listener refactoring, part 4 : To speed up inet lookups, we moved IPv4 addresses from inet to struct sock_common Now is time to do the same for IPv6, because it permits us to have fast lookups for all kind of sockets, including upcoming SYN_RECV. Getting IPv6 addresses in TCP lookups currently requires two extra cache lines, plus a dereference (and memory stall). inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6 This patch is way bigger than its IPv4 counter part, because for IPv4, we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6, it's not doable easily. inet6_sk(sk)->daddr becomes sk->sk_v6_daddr inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr at the same offset. We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic macro. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-08tcp/dccp: remove twchainEric Dumazet
TCP listener refactoring, part 3 : Our goal is to hash SYN_RECV sockets into main ehash for fast lookup, and parallel SYN processing. Current inet_ehash_bucket contains two chains, one for ESTABLISH (and friend states) sockets, another for TIME_WAIT sockets only. As the hash table is sized to get at most one socket per bucket, it makes little sense to have separate twchain, as it makes the lookup slightly more complicated, and doubles hash table memory usage. If we make sure all socket types have the lookup keys at the same offsets, we can use a generic and faster lookup. It turns out TIME_WAIT and ESTABLISHED sockets already have common lookup fields for IPv4. [ INET_TW_MATCH() is no longer needed ] I'll provide a follow-up to factorize IPv6 lookup as well, to remove INET6_TW_MATCH() This way, SYN_RECV pseudo sockets will be supported the same. A new sock_gen_put() helper is added, doing either a sock_put() or inet_twsk_put() [ and will support SYN_RECV later ]. Note this helper should only be called in real slow path, when rcu lookup found a socket that was moved to another identity (freed/reused immediately), but could eventually be used in other contexts, like sock_edemux() Before patch : dmesg | grep "TCP established" TCP established hash table entries: 524288 (order: 11, 8388608 bytes) After patch : TCP established hash table entries: 524288 (order: 10, 4194304 bytes) Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-03tcp: shrink tcp6_timewait_sock by one cache lineEric Dumazet
While working on tcp listener refactoring, I found that it would really make things easier if sock_common could include the IPv6 addresses needed in the lookups, instead of doing very complex games to get their values (depending on sock being SYN_RECV, ESTABLISHED, TIME_WAIT) For this to happen, I need to be sure that tcp6_timewait_sock and tcp_timewait_sock consume same number of cache lines. This is possible if we only use 32bits for tw_ttd, as we remove one 32bit hole in inet_timewait_sock inet_tw_time_stamp() is defined and used, even if its current implementation looks like tcp_time_stamp : We might need finer resolution for tcp_time_stamp in the future. Before patch : sizeof(struct tcp6_timewait_sock) = 0xc8 After patch : sizeof(struct tcp6_timewait_sock) = 0xc0 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19netlink: rename ssk to sk in struct netlink_skb_paramsPatrick McHardy
Memory mapped netlink needs to store the receiving userspace socket when sending from the kernel to userspace. Rename 'ssk' to 'sk' to avoid confusion. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-12tcp: Tail loss probe (TLP)Nandita Dukkipati
This patch series implement the Tail loss probe (TLP) algorithm described in http://tools.ietf.org/html/draft-dukkipati-tcpm-tcp-loss-probe-01. The first patch implements the basic algorithm. TLP's goal is to reduce tail latency of short transactions. It achieves this by converting retransmission timeouts (RTOs) occuring due to tail losses (losses at end of transactions) into fast recovery. TLP transmits one packet in two round-trips when a connection is in Open state and isn't receiving any ACKs. The transmitted packet, aka loss probe, can be either new or a retransmission. When there is tail loss, the ACK from a loss probe triggers FACK/early-retransmit based fast recovery, thus avoiding a costly RTO. In the absence of loss, there is no change in the connection state. PTO stands for probe timeout. It is a timer event indicating that an ACK is overdue and triggers a loss probe packet. The PTO value is set to max(2*SRTT, 10ms) and is adjusted to account for delayed ACK timer when there is only one oustanding packet. TLP Algorithm On transmission of new data in Open state: -> packets_out > 1: schedule PTO in max(2*SRTT, 10ms). -> packets_out == 1: schedule PTO in max(2*RTT, 1.5*RTT + 200ms) -> PTO = min(PTO, RTO) Conditions for scheduling PTO: -> Connection is in Open state. -> Connection is either cwnd limited or no new data to send. -> Number of probes per tail loss episode is limited to one. -> Connection is SACK enabled. When PTO fires: new_segment_exists: -> transmit new segment. -> packets_out++. cwnd remains same. no_new_packet: -> retransmit the last segment. Its ACK triggers FACK or early retransmit based recovery. ACK path: -> rearm RTO at start of ACK processing. -> reschedule PTO if need be. In addition, the patch includes a small variation to the Early Retransmit (ER) algorithm, such that ER and TLP together can in principle recover any N-degree of tail loss through fast recovery. TLP is controlled by the same sysctl as ER, tcp_early_retrans sysctl. tcp_early_retrans==0; disables TLP and ER. ==1; enables RFC5827 ER. ==2; delayed ER. ==3; TLP and delayed ER. [DEFAULT] ==4; TLP only. The TLP patch series have been extensively tested on Google Web servers. It is most effective for short Web trasactions, where it reduced RTOs by 15% and improved HTTP response time (average by 6%, 99th percentile by 10%). The transmitted probes account for <0.5% of the overall transmissions. Signed-off-by: Nandita Dukkipati <nanditad@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
