Signed-off-by: Maciej Żenczykowski <maze@google.com>
commit 3ceca749668a52bd795585e0f71c6f0b04814f7b added a TOS attribute.
Unfortunately TOS and TCLASS are both present in a dual-stack v6 socket,
furthermore they can have different values. As such one cannot in a
sane way expose both through a single attribute.
Signed-off-by: Maciej Żenczyowski <maze@google.com>
CC: Murali Raja <muralira@google.com>
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: David S. Miller <davem@davemloft.net>
This patch exposes the tos value for the TCP sockets when the TOS flag
is requested in the ext_flags for the inet_diag request. This would mainly be
used to expose TOS values for both for TCP and UDP sockets. Currently it is
supported for TCP. When netlink support for UDP would be added the support
to expose the TOS values would alse be done. For IPV4 tos value is exposed
and for IPV6 tclass value is exposed.
Signed-off-by: Murali Raja <muralira@google.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
A malicious user or buggy application can inject code and trigger an
infinite loop in inet_diag_bc_audit()
Also make sure each instruction is aligned on 4 bytes boundary, to avoid
unaligned accesses.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
The message size allocated for rtnl ifinfo dumps was limited to
a single page. This is not enough for additional interface info
available with devices that support SR-IOV and caused a bug in
which VF info would not be displayed if more than approximately
40 VFs were created per interface.
Implement a new function pointer for the rtnl_register service that will
calculate the amount of data required for the ifinfo dump and allocate
enough data to satisfy the request.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
This reverts commit 0ab03c2b1478f2438d2c80204f7fef65b1bca9cf.
It breaks several things including the avahi daemon.
Due to NLM_F_DUMP is composed of two bits, NLM_F_ROOT | NLM_F_MATCH,
when doing "if (x & NLM_F_DUMP)", it tests for _either_ of the bits
being set. Because NLM_F_MATCH's value overlaps with NLM_F_EXCL,
non-dump requests with NLM_F_EXCL set are mistaken as dump requests.
Substitute the condition to test for _all_ bits being set.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
We were using nlmsg_find_attr() to look up the bytecode by attribute when
auditing, but then just using the first attribute when actually running
bytecode. So, if we received a message with two attribute elements, where only
the second had type INET_DIAG_REQ_BYTECODE, we would validate and run different
bytecode strings.
Fix this by consistently using nlmsg_find_attr everywhere.
Signed-off-by: Nelson Elhage <nelhage@ksplice.com>
Signed-off-by: Thomas Graf <tgraf@infradead.org>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The s-port should be compared.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
In order to have better cache layouts of struct sock (separate zones
for rx/tx paths), we need this preliminary patch.
Goal is to transfert fields used at lookup time in the first
read-mostly cache line (inside struct sock_common) and move sk_refcnt
to a separate cache line (only written by rx path)
This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr,
sport and id fields. This allows a future patch to define these
fields as macros, like sk_refcnt, without name clashes.
Storing the mask (size - 1) instead of the size allows fast path to be
a bit faster.
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
changed initial sk_wmem_alloc value.
We need to take into account this offset when reporting
sk_wmem_alloc to user, in PROC_FS files or various
ioctls (SIOCOUTQ/TIOCOUTQ)
These are later assigned to other values without being used meanwhile.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This is the last step to be able to perform full RCU lookups
in __inet_lookup() : After established/timewait tables, we
add RCU lookups to listening hash table.
The only trick here is that a socket of a given type (TCP ipv4,
TCP ipv6, ...) can now flight between two different tables
(established and listening) during a RCU grace period, so we
must use different 'nulls' end-of-chain values for two tables.
We define a large value :
#define LISTENING_NULLS_BASE (1U << 29)
So that slots in listening table are guaranteed to have different
end-of-chain values than slots in established table. A reader can
still detect it finished its lookup in the right chain.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
They are no longer a rwlocks.
This patch prepares RCU migration of listening_hash table for
TCP/DCCP protocols.
listening_hash table being small (32 slots per protocol), we add
a spinlock for each slot, instead of a single rwlock for whole table.
This should reduce hold time of readers, and writers concurrency.
RCU was added to UDP lookups, using a fast infrastructure :
- sockets kmem_cache use SLAB_DESTROY_BY_RCU and dont pay the
price of call_rcu() at freeing time.
- hlist_nulls permits to use few memory barriers.
This patch uses same infrastructure for TCP/DCCP established
and timewait sockets.
Thanks to SLAB_DESTROY_BY_RCU, no slowdown for applications
using short lived TCP connections. A followup patch, converting
rwlocks to spinlocks will even speedup this case.
__inet_lookup_established() is pretty fast now we dont have to
dirty a contended cache line (read_lock/read_unlock)
Only established and timewait hashtable are converted to RCU
(bind table and listen table are still using traditional locking)
Some code here depends on CONFIG_KMOD to not try to load
protocol modules or similar, replace by CONFIG_MODULES
where more than just request_module depends on CONFIG_KMOD
and and also use try_then_request_module in ebtables.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Skip quickly over empty buckets in inet_diag.
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Add a net argument to inet6_lookup and propagate it further.
Actually, this is tcp-v6 implementation of what was done for
tcp-v4 sockets in a previous patch.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Add a net argument to inet_lookup and propagate it further
into lookup calls. Plus tune the __inet_check_established.
The dccp and inet_diag, which use that lookup functions
pass the init_net into them.
Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=9825
The inet_diag_lock_handler function uses ERR_PTR to encode errors but
its callers were testing against NULL.
This only happens when the only inet_diag modular user, DCCP, is not
built into the kernel or available as a module.
Also there was a problem with not dropping the mutex lock when a handler
was not found, also fixed in this patch.
This caused an OOPS and ss would then hang on subsequent calls, as
&inet_diag_table_mutex was being left locked.
Thanks to spike at ml.yaroslavl.ru for report it after trying 'ss -d'
on a kernel that doesn't have DCCP available.
This bug was introduced in cset
d523a328fb0271e1a763e985a21f2488fd816e7e ("Fix inet_diag dead-lock
regression"), after 2.6.24-rc3, so just 2.6.24 seems to be affected.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Create a specific helper for netlink kernel socket disposal. This just
let the code look better and provides a ground for proper disposal
inside a namespace.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Tested-by: Alexey Dobriyan <adobriyan@openvz.org>
The inet_diag register fix broke inet_diag module loading because the
loaded module had to take the same mutex that's already held by the
loader in order to register the new handler.
This patch fixes it by introducing a separate mutex to protect the
handling of handlers.
The following race is possible when one cpu unregisters the handler
while other one is trying to receive a message and call this one:
CPU1: CPU2:
inet_diag_rcv() inet_diag_unregister()
mutex_lock(&inet_diag_mutex);
netlink_rcv_skb(skb, &inet_diag_rcv_msg);
if (inet_diag_table[nlh->nlmsg_type] ==
NULL) /* false handler is still registered */
netlink_dump_start(idiagnl, skb, nlh,
inet_diag_dump, NULL);
cb = kzalloc(sizeof(*cb), GFP_KERNEL);
/* sleep here freeing memory
* or preempt
* or sleep later on nlk->cb_mutex
spin_lock(&inet_diag_register_lock);
inet_diag_table[type] = NULL;
... spin_unlock(&inet_diag_register_lock);
synchronize_rcu();
/* CPU1 is sleeping - RCU quiescent
* state is passed
return;
/* inet_diag_dump is finally called: */
inet_diag_dump()
handler = inet_diag_table[cb->nlh->nlmsg_type];
BUG_ON(handler == NULL);
/* OOPS! While we slept the unregister has set
* handler to NULL :(
Grep showed, that the register/unregister functions are called
from init/fini module callbacks for tcp_/dccp_diag, so it's OK
to use the inet_diag_mutex to synchronize manipulations with the
inet_diag_table and the access to it.
Besides, as Herbert pointed out, asynchronous dumps should hold
this mutex as well, and thus, we provide the mutex as cb_mutex one.
As done two years ago on IP route cache table (commit
22c047ccbc68fa8f3fa57f0e8f906479a062c426) , we can avoid using one
lock per hash bucket for the huge TCP/DCCP hash tables.
On a typical x86_64 platform, this saves about 2MB or 4MB of ram, for
litle performance differences. (we hit a different cache line for the
rwlock, but then the bucket cache line have a better sharing factor
among cpus, since we dirty it less often). For netstat or ss commands
that want a full scan of hash table, we perform fewer memory accesses.
Using a 'small' table of hashed rwlocks should be more than enough to
provide correct SMP concurrency between different buckets, without
using too much memory. Sizing of this table depends on
num_possible_cpus() and various CONFIG settings.
This patch provides some locking abstraction that may ease a future
work using a different model for TCP/DCCP table.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
By adding module aliases to inet_diag, tcp_diag and dccp_diag, we let
them load automatically as needed. This makes tools like "ss" run
faster.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
This patch make processing netlink user -> kernel messages synchronious.
This change was inspired by the talk with Alexey Kuznetsov about current
netlink messages processing. He says that he was badly wrong when introduced
asynchronious user -> kernel communication.
The call netlink_unicast is the only path to send message to the kernel
netlink socket. But, unfortunately, it is also used to send data to the
user.
Before this change the user message has been attached to the socket queue
and sk->sk_data_ready was called. The process has been blocked until all
pending messages were processed. The bad thing is that this processing
may occur in the arbitrary process context.
This patch changes nlk->data_ready callback to get 1 skb and force packet
processing right in the netlink_unicast.
Kernel -> user path in netlink_unicast remains untouched.
EINTR processing for in netlink_run_queue was changed. It forces rtnl_lock
drop, but the process remains in the cycle until the message will be fully
processed. So, there is no need to use this kludges now.
Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
I was looking at Patrick's fix to inet_diag and it occured
to me that we're using a pointer argument to return values
unnecessarily in netlink_run_queue. Changing it to return
the value will allow the compiler to generate better code
since the value won't have to be memory-backed.
Each netlink socket will live in exactly one network namespace,
this includes the controlling kernel sockets.
This patch updates all of the existing netlink protocols
to only support the initial network namespace. Request
by clients in other namespaces will get -ECONREFUSED.
As they would if the kernel did not have the support for
that netlink protocol compiled in.
As each netlink protocol is updated to be multiple network
namespace safe it can register multiple kernel sockets
to acquire a presence in the rest of the network namespaces.
The implementation in af_netlink is a simple filter implementation
at hash table insertion and hash table look up time.
Hopefully captured all single statement cases under net/. I'm
not too sure if there is some policy about #includes that are
"guaranteed" (ie., in the current tree) to be available through
some other #included header, so I just added linux/kernel.h to
each changed file that didn't #include it previously.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
netlink_run_queue() doesn't handle multiple processes processing the
queue concurrently. Serialize queue processing in inet_diag to fix
a oops in netlink_rcv_skb caused by netlink_run_queue passing a
NULL for the skb.
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000054
[349587.500454] printing eip:
[349587.500457] c03318ae
[349587.500459] *pde = 00000000
[349587.500464] Oops: 0000 [#1]
[349587.500466] PREEMPT SMP
[349587.500474] Modules linked in: w83627hf hwmon_vid i2c_isa
[349587.500483] CPU: 0
[349587.500485] EIP: 0060:[<c03318ae>] Not tainted VLI
[349587.500487] EFLAGS: 00010246 (2.6.22.3 #1)
[349587.500499] EIP is at netlink_rcv_skb+0xa/0x7e
[349587.500506] eax: 00000000 ebx: 00000000 ecx: c148d2a0 edx: c0398819
[349587.500510] esi: 00000000 edi: c0398819 ebp: c7a21c8c esp: c7a21c80
[349587.500517] ds: 007b es: 007b fs: 00d8 gs: 0033 ss: 0068
[349587.500521] Process oidentd (pid: 17943, ti=c7a20000 task=cee231c0 task.ti=c7a20000)
[349587.500527] Stack: 00000000 c7a21cac f7c8ba78 c7a21ca4 c0331962 c0398819 f7c8ba00 0000004c
[349587.500542] f736f000 c7a21cb4 c03988e3 00000001 f7c8ba00 c7a21cc4 c03312a5 0000004c
[349587.500558] f7c8ba00 c7a21cd4 c0330681 f7c8ba00 e4695280 c7a21d00 c03307c6 7fffffff
[349587.500578] Call Trace:
[349587.500581] [<c010361a>] show_trace_log_lvl+0x1c/0x33
[349587.500591] [<c01036d4>] show_stack_log_lvl+0x8d/0xaa
[349587.500595] [<c010390e>] show_registers+0x1cb/0x321
[349587.500604] [<c0103bff>] die+0x112/0x1e1
[349587.500607] [<c01132d2>] do_page_fault+0x229/0x565
[349587.500618] [<c03c8d3a>] error_code+0x72/0x78
[349587.500625] [<c0331962>] netlink_run_queue+0x40/0x76
[349587.500632] [<c03988e3>] inet_diag_rcv+0x1f/0x2c
[349587.500639] [<c03312a5>] netlink_data_ready+0x57/0x59
[349587.500643] [<c0330681>] netlink_sendskb+0x24/0x45
[349587.500651] [<c03307c6>] netlink_unicast+0x100/0x116
[349587.500656] [<c0330f83>] netlink_sendmsg+0x1c2/0x280
[349587.500664] [<c02fcce9>] sock_sendmsg+0xba/0xd5
[349587.500671] [<c02fe4d1>] sys_sendmsg+0x17b/0x1e8
[349587.500676] [<c02fe92d>] sys_socketcall+0x230/0x24d
[349587.500684] [<c01028d2>] syscall_call+0x7/0xb
[349587.500691] =======================
[349587.500693] Code: f0 ff 4e 18 0f 94 c0 84 c0 0f 84 66 ff ff ff 89 f0 e8 86 e2 fc ff e9 5a ff ff ff f0 ff 40 10 eb be 55 89 e5 57 89 d7 56 89 c6 53 <8b> 50 54 83 fa 10 72 55 8b 9e 9c 00 00 00 31 c9 8b 03 83 f8 0f
Reported by Athanasius <link@miggy.org>
Switch cb_lock to mutex and allow netlink kernel users to override it
with a subsystem specific mutex for consistent locking in dump callbacks.
All netlink_dump_start users have been audited not to rely on any
side-effects of the previously used spinlock.
Now that all users of netlink_dump_start() use netlink_run_queue()
to process the receive queue, it is possible to return -EINTR from
netlink_dump_start() directly, therefore simplying the callers.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Makes use of netlink_run_queue() to process the receive queue and
converts inet_diag_rcv_msg() to use the type safe netlink interface.
For the common "(struct nlmsghdr *)skb->data" sequence, so that we reduce the
number of direct accesses to skb->data and for consistency with all the other
cast skb member helpers.
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes
on 64bit architectures, allowing us to combine the 4 bytes hole left by the
layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4
64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN...
Many calculations that previously required that skb->{transport,network,
mac}_header be first converted to a pointer now can be done directly, being
meaningful as offsets or pointers.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
ehash table layout is currently this one :
First half of this table is used by sockets not in TIME_WAIT state
Second half of it is used by sockets in TIME_WAIT state.
This is non optimal because of for a given hash or socket, the two chain heads
are located in separate cache lines.
Moreover the locks of the second half are never used.
If instead of this halving, we use two list heads in inet_ehash_bucket instead
of only one, we probably can avoid one cache miss, and reduce ram usage,
particularly if sizeof(rwlock_t) is big (various CONFIG_DEBUG_SPINLOCK,
CONFIG_DEBUG_LOCK_ALLOC settings). So we still halves the table but we keep
together related chains to speedup lookups and socket state change.
In this patch I did not try to align struct inet_ehash_bucket, but a future
patch could try to make this structure have a convenient size (a power of two
or a multiple of L1_CACHE_SIZE).
I guess rwlock will just vanish as soon as RCU is plugged into ehash :) , so
maybe we dont need to scratch our heads to align the bucket...
Note : In case struct inet_ehash_bucket is not a power of two, we could
probably change alloc_large_system_hash() (in case it use __get_free_pages())
to free the unused space. It currently allocates a big zone, but the last
quarter of it could be freed. Again, this should be a temporary 'problem'.
Patch tested on ipv4 tcp only, but should be OK for IPV6 and DCCP.
Currently netlink users BUG when the allocated skb for an event
notification is undersized. While this is certainly a kernel bug,
its not critical and crashing the kernel is too drastic, especially
when considering that these errors have appeared multiple times in
the past and it BUGs even if no listeners are present.
This patch replaces BUG by WARN_ON and changes the notification
functions to inform potential listeners of undersized allocations
using a unique error code (EMSGSIZE).
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
To be called from inet_diag_get_exact, also rename inet_diag_fill to
inet_csk_diag_fill, for consistency with inet_twsk_diag_fill.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
