[ Upstream commit 73f156a6e8c1074ac6327e0abd1169e95eb66463 ]
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
[ Upstream commit 52ad353a5344f1f700c5b777175bdfa41d3cd65a ]
The problem was triggered by these steps:
1) create socket, bind and then setsockopt for add mc group.
mreq.imr_multiaddr.s_addr = inet_addr("255.0.0.37");
mreq.imr_interface.s_addr = inet_addr("192.168.1.2");
setsockopt(sockfd, IPPROTO_IP, IP_ADD_MEMBERSHIP, &mreq, sizeof(mreq));
2) drop the mc group for this socket.
mreq.imr_interface.s_addr = inet_addr("0.0.0.0");
setsockopt(sockfd, IPPROTO_IP, IP_DROP_MEMBERSHIP, &mreq, sizeof(mreq));
3) and then drop the socket, I found the mc group was still used by the dev:
netstat -g
Interface RefCnt Group
eth2 1 255.0.0.37
Normally even though the IP_DROP_MEMBERSHIP return error, the mc group still need
to be released for the netdev when drop the socket, but this process was broken when
route default is NULL, the reason is that:
The ip_mc_leave_group() will choose the in_dev by the imr_interface.s_addr, if input addr
is NULL, the default route dev will be chosen, then the ifindex is got from the dev,
then polling the inet->mc_list and return -ENODEV, but if the default route dev is NULL,
the in_dev and ifIndex is both NULL, when polling the inet->mc_list, the mc group will be
released from the mc_list, but the dev didn't dec the refcnt for this mc group, so
when dropping the socket, the mc_list is NULL and the dev still keep this group.
v1->v2: According Hideaki's suggestion, we should align with IPv6 (RFC3493) and BSDs,
so I add the checking for the in_dev before polling the mc_list, make sure when
we remove the mc group, dec the refcnt to the real dev which was using the mc address.
The problem would never happened again.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
[ Upstream commit e2401654dd0f5f3fb7a8d80dad9554d73d7ca394 ]
It is possible for the timer handlers to run after the call to
ip_mc_down so use in_dev_put instead of __in_dev_put in the handler
function in order to do proper cleanup when the refcnt reaches 0.
Otherwise, the refcnt can reach zero without the in_device being
destroyed and we end up leaking a reference to the net_device and
see messages like the following,
unregister_netdevice: waiting for eth0 to become free. Usage count = 1
Tested on linux-3.4.43.
Signed-off-by: Salam Noureddine <noureddine@aristanetworks.com>
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ]
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
[ Upstream commit cf778b00e96df6d64f8e21b8395d1f8a859ecdc7 ]
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to
RCU_INIT_POINTER) did a lot of incorrect changes, since it did a
complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x,
y).
We miss needed barriers, even on x86, when y is not NULL.
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit a8c1f65c79cbbb2f7da782d4c9d15639a9b94b27 upstream.
Commit 5b7c84066733c5dfb0e4016d939757b38de189e4 ('ipv4: correct IGMP
behavior on v3 query during v2-compatibility mode') added yet another
case for query parsing, which can result in max_delay = 0. Substitute
a value of 1, as in the usual v3 case.
Reported-by: Simon McVittie <smcv@debian.org>
References: http://bugs.debian.org/654876
When add sources to interface failure, need to roll back the sfcount[MODE]
to before state. We need to match it corresponding.
Acked-by: David L Stevens <dlstevens@us.ibm.com>
Signed-off-by: Jun Zhao <mypopydev@gmail.com>
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
Should check use count of include mode filter instead of total number
of include mode filters.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
Remove no longer used operation.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
Convert array index from the loop bound to the loop index.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression e1,e2,ar;
for(e1 = 0; e1 < e2; e1++) { <...
ar[
- e2
+ e1
// </smpl>
In igmp_group_dropped() we call ip_mc_clear_src(), which resets the number
of source filters per mulitcast. However, igmp_group_dropped() is also
called on NETDEV_DOWN, NETDEV_PRE_TYPE_CHANGE and NETDEV_UNREGISTER, which
means that the group might get added back on NETDEV_UP, NETDEV_REGISTER and
NETDEV_POST_TYPE_CHANGE respectively, leaving us with broken source
filters.
To fix that, we must clear the source filters only when there are no users
in the ip_mc_list, i.e. in ip_mc_dec_group() and on device destroy.
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
The rcu callback ip_mc_socklist_reclaim() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ip_mc_socklist_reclaim).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback ip_sf_socklist_reclaim() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ip_sf_socklist_reclaim).
The rcu callback ip_mc_list_reclaim() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ip_mc_list_reclaim).
Instead of rt->rt_{src,dst}
Output route resolution never returns a route with rt_src set to zero
(which is INADDR_ANY).
Even if the flow key for the output route lookup specifies INADDR_ANY
for the source address, the output route resolution chooses a real
source address to use in the final route.
This test has existed forever in igmp_send_report() and David Stevens
simply copied over the erroneous test when implementing support for
IGMPv3.
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
The idea here is this minimizes the number of places one has to edit
in order to make changes to how flows are defined and used.
All callers are under rcu_read_lock() protection already.
Rename to ip_check_mc_rcu() to make it even more clear.
Instead of on the stack.
IGMP allocates MTU sized skbs. This may fail for large MTU (order-2
allocations), so add a fallback to try lower sizes.
Instead of iterating in_dev->mc_list from bonding driver, its better
to call a helper function provided by igmp.c
Details of implementation (locking) are private to igmp code.
ip_mc_rejoin_group(struct ip_mc_list *im) becomes
ip_mc_rejoin_groups(struct in_device *in_dev);
Use the macros defined for the members of flowi to clean the code up.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
net/ipv4/igmp.c: In function 'ip_mc_inc_group':
net/ipv4/igmp.c:1228: error: implicit declaration of function 'for_each_pmc_rtnl'
net/ipv4/igmp.c:1228: error: expected ';' before '{' token
net/ipv4/igmp.c: In function 'ip_mc_unmap':
net/ipv4/igmp.c:1333: error: expected ';' before 'igmp_group_dropped'
Move for_each_pmc_rcu and for_each_pmc_rtnl macro definitions
outside of multicast ifdef protection.
in_dev->mc_list is protected by one rwlock (in_dev->mc_list_lock).
This can easily be converted to a RCU protection.
Writers hold RTNL, so mc_list_lock is removed, not replaced by a
spinlock.
Cc: Cypher Wu <cypher.w@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
When we test rt->fl.iif against zero, we're seeing if it's
an output or an input route.
Make that explicit with some helper functions.
commit 8723e1b4ad9be4444 (inet: RCU changes in inetdev_by_index())
forgot one call site in ip_mc_drop_socket()
We should not decrease idev refcount after inetdev_by_index() call,
since refcount is not increased anymore.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Reported-by: Miles Lane <miles.lane@gmail.com>
Convert inetdev_by_index() to not increment in_dev refcount.
Callers hold RCU or RTNL, and should not decrement in_dev refcount.
We hold RTNL in ip_mc_find_dev(), no need to touch device refcount.
The IGMP specs states that if the system receives a
membership report, it shouldn't send another for the
next minute. However, if a link failure happens right
after that, the backup slave and the switch connected
to this slave will not know about the multicast and
the traffic will hang for about a minute.
This patch fixes it to rejoin multicast groups immediately
after a failover restoring the multicast traffic.
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
A recent patch to allow IGMPv2 responses to IGMPv3 queries
bypasses length checks for valid query lengths, incorrectly
resets the v2_seen timer, and does not support IGMPv1.
The following patch responds with a v2 report as required
by IGMPv2 while correcting the other problems introduced
by the patch.
Signed-Off-By: David L Stevens <dlstevens@us.ibm.com>
After all these years, it turns out that the
/proc/sys/net/ipv4/conf/*/force_igmp_version
parameter isn't fully implemented.
*Symptom*:
When set force_igmp_version to a value of 2, the kernel should only perform
multicast IGMPv2 operations (IETF rfc2236). An host-initiated Join message
will be sent as a IGMPv2 Join message. But if a IGMPv3 query message is
received, the host responds with a IGMPv3 join message. Per rfc3376 and
rfc2236, a IGMPv2 host should treat a IGMPv3 query as a IGMPv2 query and
respond with an IGMPv2 Join message.
*Consequences*:
This is an issue when a IGMPv3 capable switch is the querier and will only
issue IGMPv3 queries (which double as IGMPv2 querys) and there's an
intermediate switch that is only IGMPv2 capable. The intermediate switch
processes the initial v2 Join, but fails to recognize the IGMPv3 Join responses
to the Query, resulting in a dropped connection when the intermediate v2-only
switch times it out.
*Identifying issue in the kernel source*:
The issue is in this section of code (in net/ipv4/igmp.c), which is called when
an IGMP query is received (from mainline 2.6.36-rc3 gitweb):
A IGMPv3 query has a length >= 12 and no sources. This routine will exit after
line 880, setting the general query timer (random timeout between 0 and query
response time). This calls igmp_gq_timer_expire():
.. which only sends a v3 response. So if a v3 query is received, the kernel
always sends a v3 response.
IGMP queries happen once every 60 sec (per vlan), so the traffic is low. A
IGMPv3 query *is* a strict superset of a IGMPv2 query, so this patch properly
short circuit's the v3 behaviour.
One issue is that this does not address force_igmp_version=1. Then again, I've
never seen any IGMPv1 multicast equipment in the wild. However there is a lot
of v2-only equipment. If it's necessary to support the IGMPv1 case as well:
837 if (len == 8 || IGMP_V2_SEEN(in_dev) || IGMP_V1_SEEN(in_dev)) {
CodingStyle cleanups
EXPORT_SYMBOL should immediately follow the symbol declaration.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
in_dev_get() -> __in_dev_get_rcu() in a rcu protected function.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
net/mac80211/rate.c
Currently we treat IGMPv3 reports as if it were an IGMPv2/v1 report.
This is broken as IGMPv3 reports are formatted differently. So we
end up suppressing a bogus multicast group (which should be harmless
as long as the leading reserved field is zero).
In fact, IGMPv3 does not allow membership report suppression so
we should simply ignore IGMPv3 membership reports as a host.
This patch does exactly that. I kept the case statement for it
so people won't accidentally add it back thinking that we overlooked
this case.
Almost all igmp functions accessing inet->mc_list are protected by
rtnl_lock(), but there is one exception which is ip_mc_sf_allow(),
so there is a chance of either ip_mc_drop_socket or ip_mc_leave_group
remove an entry while ip_mc_sf_allow is running causing a crash.
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
We need to use next_det_device_rcu() in RCU protected section.
We also can avoid in_dev_get()/in_dev_put() overhead (code size mainly)
in rcu_read_lock() sections.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
