path: root/net/ipv4/icmp.c
2013-09-28ipv4: processing ancillary IP_TOS or IP_TTLFrancesco Fusco
If IP_TOS or IP_TTL are specified as ancillary data, then sendmsg() sends out packets with the specified TTL or TOS overriding the socket values specified with the traditional setsockopt(). The struct inet_cork stores the values of TOS, TTL and priority that are passed through the struct ipcm_cookie. If there are user-specified TOS (tos != -1) or TTL (ttl != 0) in the struct ipcm_cookie, these values are used to override the per-socket values. In case of TOS also the priority is changed accordingly. Two helper functions get_rttos and get_rtconn_flags are defined to take into account the presence of a user specified TOS value when computing RT_TOS and RT_CONN_FLAGS. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-03icmp: avoid allocating large struct on stackCong Wang
struct icmp_bxm is a large struct, reduce stack usage by allocating it on heap. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Joe Perches <joe@perches.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-03] icmp: fix icmp_unreach() comment.Rami Rosen
ICMP_PARAMETERPROB is handled by icmp_unreach(); This patch adds ICMP_PARAMETERPROB to the list of ICMP message types handled by icmp_unreach(). Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28ipv4: Correct comparisons and calculations using skb->tail and ↵Simon Horman
skb-transport_header This corrects an regression introduced by "net: Use 16bits for *_headers fields of struct skbuff" when NET_SKBUFF_DATA_USES_OFFSET is not set. In that case skb->tail will be a pointer whereas skb->transport_header will be an offset from head. This is corrected by using wrappers that ensure that comparisons and calculations are always made using pointers. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-25net: ipv6: Add IPv6 support to the ping socket.Lorenzo Colitti
This adds the ability to send ICMPv6 echo requests without a raw socket. The equivalent ability for ICMPv4 was added in 2011. Instead of having separate code paths for IPv4 and IPv6, make most of the code in net/ipv4/ping.c dual-stack and only add a few IPv6-specific bits (like the protocol definition) to a new net/ipv6/ping.c. Hopefully this will reduce divergence and/or duplication of bugs in the future. Caveats: - Setting options via ancillary data (e.g., using IPV6_PKTINFO to specify the outgoing interface) is not yet supported. - There are no separate security settings for IPv4 and IPv6; everything is controlled by /proc/net/ipv4/ping_group_range. - The proc interface does not yet display IPv6 ping sockets properly. Tested with a patched copy of ping6 and using raw socket calls. Compiles and works with all of CONFIG_IPV6={n,m,y}. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-29net: Add MIB counters for checksum errorsEric Dumazet
Add MIB counters for checksum errors in IP layer, and TCP/UDP/ICMP layers, to help diagnose problems. $ nstat -a | grep Csum IcmpInCsumErrors 72 0.0 TcpInCsumErrors 382 0.0 UdpInCsumErrors 463221 0.0 Icmp6InCsumErrors 75 0.0 Udp6InCsumErrors 173442 0.0 IpExtInCsumErrors 10884 0.0 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-22ipv4: fix error handling in icmp_protocol.Li Wei
Now we handle icmp errors in each transport protocol's err_handler, for icmp protocols, that is ping_err. Since this handler only care of those icmp errors triggered by echo request, errors triggered by echo reply(which sent by kernel) are sliently ignored. So wrap ping_err() with icmp_err() to deal with those icmp errors. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-26ipv4: avoid passing NULL to inet_putpeer() in icmpv4_xrlim_allow()Neal Cardwell
inet_getpeer_v4() can return NULL under OOM conditions, and while inet_peer_xrlim_allow() is OK with a NULL peer, inet_putpeer() will crash. This code path now uses the same idiom as the others from: 1d861aa4b3fb08822055345f480850205ffe6170 ("inet: Minimize use of cached route inetpeer."). Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-23ipv4: Prepare for change of rt->rt_iif encoding.David S. Miller
Use inet_iif() consistently, and for TCP record the input interface of cached RX dst in inet sock. rt->rt_iif is going to be encoded differently, so that we can legitimately cache input routes in the FIB info more aggressively. When the input interface is "use SKB device index" the rt->rt_iif will be set to zero. This forces us to move the TCP RX dst cache installation into the ipv4 specific code, and as well it should since doing the route caching for ipv6 is pointless at the moment since it is not inspected in the ipv6 input paths yet. Also, remove the unlikely on dst->obsolete, all ipv4 dsts have obsolete set to a non-zero value to force invocation of the check callback. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-23ipv4: Really ignore ICMP address requests/replies.David S. Miller
Alexey removed kernel side support for requests, and the only thing we do for replies is log a message if something doesn't look right. As Alexey's comment indicates, this belongs in userspace (if anywhere), and thus we can safely just get rid of this code. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12ipv4: Put proper checks into icmp_socket_deliver().David S. Miller
All handler->err() routines expect that we've done a pskb_may_pull() test to make sure that IP header length + 8 bytes can be safely pulled. Reported-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-11ipv4: Kill ip_rt_redirect().David S. Miller
No longer needed, as the protocol handlers now all properly propagate the redirect back into the routing code. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-11ipv4: Rearrange arguments to ip_rt_redirect()David S. Miller
Pass in the SKB rather than just the IP addresses, so that policy and other aspects can reside in ip_rt_redirect() rather then icmp_redirect(). Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-11ipv4: Deliver ICMP redirects to sockets too.David S. Miller
And thus, we can remove the ping_err() hack. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-11ipv4: Pull icmp socket delivery out into a helper function.David S. Miller
2012-07-10inet: Minimize use of cached route inetpeer.David S. Miller
Only use it in the absolutely required cases: 1) COW'ing metrics 2) ipv4 PMTU 3) ipv4 redirects Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-28ipv4: Create and use fib_compute_spec_dst() helper.David S. Miller
The specific destination is the host we direct unicast replies to. Usually this is the original packet source address, but if we are responding to a multicast or broadcast packet we have to use something different. Specifically we must use the source address we would use if we were to send a packet to the unicast source of the original packet. The routing cache precomputes this value, but we want to remove that precomputation because it creates a hard dependency on the expensive rpfilter source address validation which we'd like to make cheaper. There are only three places where this matters: 1) ICMP replies. 2) pktinfo CMSG 3) IP options Now there will be no real users of rt->rt_spec_dst and we can simply remove it altogether. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-19inet: Sanitize inet{,6} protocol demux.David S. Miller
Don't pretend that inet_protos[] and inet6_protos[] are hashes, thay are just a straight arrays. Remove all unnecessary hash masking. Document MAX_INET_PROTOS. Use RAW_HTABLE_SIZE when appropriate. Reported-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-11ipv4: Kill ip_rt_frag_needed().David S. Miller
There is zero point to this function. It's only real substance is to perform an extremely outdated BSD4.2 ICMP check, which we can safely remove. If you really have a MTU limited link being routed by a BSD4.2 derived system, here's a nickel go buy yourself a real router. The other actions of ip_rt_frag_needed(), checking and conditionally updating the peer, are done by the per-protocol handlers of the ICMP event. TCP, UDP, et al. have a handler which will receive this event and transmit it back into the associated route via dst_ops->update_pmtu(). This simplification is important, because it eliminates the one place where we do not have a proper route context in which to make an inetpeer lookup. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-08inet: Create and use rt{,6}_get_peer_create().David S. Miller
There's a lot of places that open-code rt{,6}_get_peer() only because they want to set 'create' to one. So add an rt{,6}_get_peer_create() for their sake. There were also a few spots open-coding plain rt{,6}_get_peer() and those are transformed here as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-12net: ipv4: Standardize prefixes for message loggingJoe Perches
Add #define pr_fmt(fmt) as appropriate. Add "IPv4: ", "TCP: ", and "IPsec: " to appropriate files. Standardize on "UDPLite: " for appropriate uses. Some prefixes were previously "UDPLITE: " and "UDP-Lite: ". Add KBUILD_MODNAME ": " to icmp and gre. Remove embedded prefixes as appropriate. Add missing "\n" to pr_info in gre.c. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-11net: Convert printks to pr_<level>Joe Perches
Use a more current kernel messaging style. Convert a printk block to print_hex_dump. Coalesce formats, align arguments. Use %s, __func__ instead of embedding function names. Some messages that were prefixed with <foo>_close are now prefixed with <foo>_fini. Some ah4 and esp messages are now not prefixed with "ip ". The intent of this patch is to later add something like #define pr_fmt(fmt) "IPv4: " fmt. to standardize the output messages. Text size is trivially reduced. (x86-32 allyesconfig) $ size net/ipv4/built-in.o* text data bss dec hex filename 887888 31558 249696 1169142 11d6f6 net/ipv4/built-in.o.new 887934 31558 249800 1169292 11d78c net/ipv4/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-13net: more accurate skb truesizeEric Dumazet
skb truesize currently accounts for sk_buff struct and part of skb head. kmalloc() roundings are also ignored. Considering that skb_shared_info is larger than sk_buff, its time to take it into account for better memory accounting. This patch introduces SKB_TRUESIZE(X) macro to centralize various assumptions into a single place. At skb alloc phase, we put skb_shared_info struct at the exact end of skb head, to allow a better use of memory (lowering number of reallocations), since kmalloc() gives us power-of-two memory blocks. Unless SLUB/SLUB debug is active, both skb->head and skb_shared_info are aligned to cache lines, as before. Note: This patch might trigger performance regressions because of misconfigured protocol stacks, hitting per socket or global memory limits that were previously not reached. But its a necessary step for a more accurate memory accounting. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Andi Kleen <ak@linux.intel.com> CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-22icmp: Fix regression in nexthop resolution during replies.David S. Miller
icmp_route_lookup() uses the wrong flow parameters if the reverse session route lookup isn't used. So do not commit to the re-decoded flow until we actually make a final decision to use a real route saved in 'rt2'. Reported-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18ipv4: Pass explicit destination address to rt_bind_peer().David S. Miller
2011-05-13net: ipv4: add IPPROTO_ICMP socket kindVasiliy Kulikov
This patch adds IPPROTO_ICMP socket kind. It makes it possible to send ICMP_ECHO messages and receive the corresponding ICMP_ECHOREPLY messages without any special privileges. In other words, the patch makes it possible to implement setuid-less and CAP_NET_RAW-less /bin/ping. In order not to increase the kernel's attack surface, the new functionality is disabled by default, but is enabled at bootup by supporting Linux distributions, optionally with restriction to a group or a group range (see below). Similar functionality is implemented in Mac OS X: http://www.manpagez.com/man/4/icmp/ A new ping socket is created with socket(PF_INET, SOCK_DGRAM, PROT_ICMP) Message identifiers (octets 4-5 of ICMP header) are interpreted as local ports. Addresses are stored in struct sockaddr_in. No port numbers are reserved for privileged processes, port 0 is reserved for API ("let the kernel pick a free number"). There is no notion of remote ports, remote port numbers provided by the user (e.g. in connect()) are ignored. Data sent and received include ICMP headers. This is deliberate to: 1) Avoid the need to transport headers values like sequence numbers by other means. 2) Make it easier to port existing programs using raw sockets. ICMP headers given to send() are checked and sanitized. The type must be ICMP_ECHO and the code must be zero (future extensions might relax this, see below). The id is set to the number (local port) of the socket, the checksum is always recomputed. ICMP reply packets received from the network are demultiplexed according to their id's, and are returned by recv() without any modifications. IP header information and ICMP errors of those packets may be obtained via ancillary data (IP_RECVTTL, IP_RETOPTS, and IP_RECVERR). ICMP source quenches and redirects are reported as fake errors via the error queue (IP_RECVERR); the next hop address for redirects is saved to ee_info (in network order). socket(2) is restricted to the group range specified in "/proc/sys/net/ipv4/ping_group_range". It is "1 0" by default, meaning that nobody (not even root) may create ping sockets. Setting it to "100 100" would grant permissions to the single group (to either make /sbin/ping g+s and owned by this group or to grant permissions to the "netadmins" group), "0 4294967295" would enable it for the world, "100 4294967295" would enable it for the users, but not daemons. The existing code might be (in the unlikely case anyone needs it) extended rather easily to handle other similar pairs of ICMP messages (Timestamp/Reply, Information Request/Reply, Address Mask Request/Reply etc.). Userspace ping util & patch for it: http://openwall.info/wiki/people/segoon/ping For Openwall GNU/*/Linux it was the last step on the road to the setuid-less distro. A revision of this patch (for RHEL5/OpenVZ kernels) is in use in Owl-current, such as in the 2011/03/12 LiveCD ISOs: http://mirrors.kernel.org/openwall/Owl/current/iso/ Initially this functionality was written by Pavel Kankovsky for Linux 2.4.32, but unfortunately it was never made public. All ping options (-b, -p, -Q, -R, -s, -t, -T, -M, -I), are tested with the patch. PATCH v3: - switched to flowi4. - minor changes to be consistent with raw sockets code. PATCH v2: - changed ping_debug() to pr_debug(). - removed CONFIG_IP_PING. - removed ping_seq_fops.owner field (unused for procfs). - switched to proc_net_fops_create(). - switched to %pK in seq_printf(). PATCH v1: - fixed checksumming bug. - CAP_NET_RAW may not create icmp sockets anymore. RFC v2: - minor cleanups. - introduced sysctl'able group range to restrict socket(2). Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-10ipv4: icmp: Eliminate remaining uses of rt->rt_srcDavid S. Miller
On input packets, rt->rt_src always equals ip_hdr(skb)->saddr Anything that mangles or otherwise changes the IP header must relookup the route found at skb_rtable(). Therefore this invariant must always hold true. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ipv4: Pass flow key down into ip_append_*().David S. Miller
This way rt->rt_dst accesses are unnecessary. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ipv4: Pass flow keys down into datagram packet building engine.David S. Miller
This way ip_output.c no longer needs rt->rt_{src,dst}. We already have these keys sitting, ready and waiting, on the stack or in a socket structure. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28inet: add RCU protection to inet->optEric Dumazet
We lack proper synchronization to manipulate inet->opt ip_options Problem is ip_make_skb() calls ip_setup_cork() and ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options), without any protection against another thread manipulating inet->opt. Another thread can change inet->opt pointer and free old one under us. Use RCU to protect inet->opt (changed to inet->inet_opt). Instead of handling atomic refcounts, just copy ip_options when necessary, to avoid cache line dirtying. We cant insert an rcu_head in struct ip_options since its included in skb->cb[], so this patch is large because I had to introduce a new ip_options_rcu structure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put fl4_* macros to struct flowi4 and use them again.David S. Miller
2011-03-12ipv4: Use flowi4 in public route lookup interfaces.David S. Miller
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-04ipv4: Remove flowi from struct rtable.David S. Miller
The only necessary parts are the src/dst addresses, the interface indexes, the TOS, and the mark. The rest is unnecessary bloat, which amounts to nearly 50 bytes on 64-bit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02xfrm: Return dst directly from xfrm_lookup()David S. Miller
2011-03-01ipv4: Make icmp route lookup code a bit clearer.David S. Miller
The route lookup code in icmp_send() is slightly tricky as a result of having to handle all of the requirements of RFC 4301 host relookups. Pull the route resolution into a seperate function, so that the error handling and route reference counting is hopefully easier to see and contained wholly within this new routine. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-04inetpeer: Move ICMP rate limiting state into inet_peer entries.David S. Miller
Like metrics, the ICMP rate limiting bits are cached state about a destination. So move it into the inet_peer entries. If an inet_peer cannot be bound (the reason is memory allocation failure or similar), the policy is to allow. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c net/core/net-sysfs.c net/ipv6/addrconf.c
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16xfrm: update flowi saddr in icmp_send if unsetUlrich Weber
otherwise xfrm_lookup will fail to find correct policy Signed-off-by: Ulrich Weber <uweber@astaro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-11ipv4: Make rt->fl.iif tests lest obscure.David S. Miller
When we test rt->fl.iif against zero, we're seeing if it's an output or an input route. Make that explicit with some helper functions. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19net: simplify flags for tx timestampingOliver Hartkopp
This patch removes the abstraction introduced by the union skb_shared_tx in the shared skb data. The access of the different union elements at several places led to some confusion about accessing the shared tx_flags e.g. in skb_orphan_try(). http://marc.info/?l=linux-netdev&m=128084897415886&w=2 Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
