path: root/net/ipv4/fib_frontend.c
2010-10-05fib: RCU conversion of fib_lookup()Eric Dumazet
fib_lookup() converted to be called in RCU protected context, no reference taken and released on a contended cache line (fib_clntref) fib_table_lookup() and fib_semantic_match() get an additional parameter. struct fib_info gets an rcu_head field, and is freed after an rcu grace period. Stress test : (Sending 160.000.000 UDP frames on same neighbour, IP route cache disabled, dual E5540 @2.53GHz, 32bit kernel, FIB_HASH) (about same results for FIB_TRIE) Before patch : real 1m31.199s user 0m13.761s sys 23m24.780s After patch: real 1m5.375s user 0m14.997s sys 15m50.115s Before patch Profile : 13044.00 15.4% __ip_route_output_key vmlinux 8438.00 10.0% dst_destroy vmlinux 5983.00 7.1% fib_semantic_match vmlinux 5410.00 6.4% fib_rules_lookup vmlinux 4803.00 5.7% neigh_lookup vmlinux 4420.00 5.2% _raw_spin_lock vmlinux 3883.00 4.6% rt_set_nexthop vmlinux 3261.00 3.9% _raw_read_lock vmlinux 2794.00 3.3% fib_table_lookup vmlinux 2374.00 2.8% neigh_resolve_output vmlinux 2153.00 2.5% dst_alloc vmlinux 1502.00 1.8% _raw_read_lock_bh vmlinux 1484.00 1.8% kmem_cache_alloc vmlinux 1407.00 1.7% eth_header vmlinux 1406.00 1.7% ipv4_dst_destroy vmlinux 1298.00 1.5% __copy_from_user_ll vmlinux 1174.00 1.4% dev_queue_xmit vmlinux 1000.00 1.2% ip_output vmlinux After patch Profile : 13712.00 15.8% dst_destroy vmlinux 8548.00 9.9% __ip_route_output_key vmlinux 7017.00 8.1% neigh_lookup vmlinux 4554.00 5.3% fib_semantic_match vmlinux 4067.00 4.7% _raw_read_lock vmlinux 3491.00 4.0% dst_alloc vmlinux 3186.00 3.7% neigh_resolve_output vmlinux 3103.00 3.6% fib_table_lookup vmlinux 2098.00 2.4% _raw_read_lock_bh vmlinux 2081.00 2.4% kmem_cache_alloc vmlinux 2013.00 2.3% _raw_spin_lock vmlinux 1763.00 2.0% __copy_from_user_ll vmlinux 1763.00 2.0% ip_output vmlinux 1761.00 2.0% ipv4_dst_destroy vmlinux 1631.00 1.9% eth_header vmlinux 1440.00 1.7% _raw_read_unlock_bh vmlinux Reference results, if IP route cache is enabled : real 0m29.718s user 0m10.845s sys 7m37.341s 25213.00 29.5% __ip_route_output_key vmlinux 9011.00 10.5% dst_release vmlinux 4817.00 5.6% ip_push_pending_frames vmlinux 4232.00 5.0% ip_finish_output vmlinux 3940.00 4.6% udp_sendmsg vmlinux 3730.00 4.4% __copy_from_user_ll vmlinux 3716.00 4.4% ip_route_output_flow vmlinux 2451.00 2.9% __xfrm_lookup vmlinux 2221.00 2.6% ip_append_data vmlinux 1718.00 2.0% _raw_spin_lock_bh vmlinux 1655.00 1.9% __alloc_skb vmlinux 1572.00 1.8% sock_wfree vmlinux 1345.00 1.6% kfree vmlinux Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05fib: cleanupsEric Dumazet
Code style cleanups before upcoming functional changes. C99 initializer for fib_props array. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-30ipv4: introduce __ip_dev_find()Eric Dumazet
ip_dev_find(net, addr) finds a device given an IPv4 source address and takes a reference on it. Introduce __ip_dev_find(), taking a third argument, to optionally take the device reference. Callers not asking the reference to be taken should be in an rcu_read_lock() protected section. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-28ipv4: Allow configuring subnets as local addressesTom Herbert
This patch allows a host to be configured to respond to any address in a specified range as if it were local, without actually needing to configure the address on an interface. This is done through routing table configuration. For instance, to configure a host to respond to any address in 10.1/16 received on eth0 as a local address we can do: ip rule add from all iif eth0 lookup 200 ip route add local 10.1/16 dev lo proto kernel scope host src 127.0.0.1 table 200 This host is now reachable by any 10.1/16 address (route lookup on input for packets received on eth0 can find the route). On output, the rule will not be matched so that this host can still send packets to 10.1/16 (not sent on loopback). Presumably, external routing can be configured to make sense out of this. To make this work, we needed to modify the logic in finding the interface which is assigned a given source address for output (dev_ip_find). We perform a normal fib_lookup instead of just a lookup on the local table, and in the lookup we ignore the input interface for matching. This patch is useful to implement IP-anycast for subnets of virtual addresses. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-07ipv4: Fix reverse path filtering with multipath routing.David S. Miller
Actually iterate over the next-hops to make sure we have a device match. Otherwise RP filtering is always elided when the route matched has multiple next-hops. Reported-by: Igor M Podlesny <for.poige@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03ipv4: add LINUX_MIB_IPRPFILTER snmp counterEric Dumazet
Christoph Lameter mentioned that packets could be dropped in input path because of rp_filter settings, without any SNMP counter being incremented. System administrator can have a hard time to track the problem. This patch introduces a new counter, LINUX_MIB_IPRPFILTER, incremented each time we drop a packet because Reverse Path Filter triggers. (We receive an IPv4 datagram on a given interface, and find the route to send an answer would use another interface) netstat -s | grep IPReversePathFilter IPReversePathFilter: 21714 Reported-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-25net: restore ip source validationJamal Hadi Salim
when using policy routing and the skb mark: there are cases where a back path validation requires us to use a different routing table for src ip validation than the one used for mapping ingress dst ip. One such a case is transparent proxying where we pretend to be the destination system and therefore the local table is used for incoming packets but possibly a main table would be used on outbound. Make the default behavior to allow the above and if users need to turn on the symmetry via sysctl src_valid_mark Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03ipv4 05/05: add sysctl to accept packets with local source addressesPatrick McHardy
commit 8ec1e0ebe26087bfc5c0394ada5feb5758014fc8 Author: Patrick McHardy <kaber@trash.net> Date: Thu Dec 3 12:16:35 2009 +0100 ipv4: add sysctl to accept packets with local source addresses Change fib_validate_source() to accept packets with a local source address when the "accept_local" sysctl is set for the incoming inet device. Combined with the previous patches, this allows to communicate between multiple local interfaces over the wire. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: NETDEV_UNREGISTER_PERNET -> NETDEV_UNREGISTER_BATCHEric W. Biederman
The motivation for an additional notifier in batched netdevice notification (rt_do_flush) only needs to be called once per batch not once per namespace. For further batching improvements I need a guarantee that the netdevices are unregistered in order allowing me to unregister an all of the network devices in a network namespace at the same time with the guarantee that the loopback device is really and truly unregistered last. Additionally it appears that we moved the route cache flush after the final synchronize_net, which seems wrong and there was no explanation. So I have restored the original location of the final synchronize_net. Cc: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18ipv4: factorize cache clearing for batched unregister operationsOctavian Purdila
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29net: Fix RPF to work with policy routingjamal
Policy routing is not looked up by mark on reverse path filtering. This fixes it. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05ipv4: fib table algorithm performance improvementStephen Hemminger
The FIB algorithim for IPV4 is set at compile time, but kernel goes through the overhead of function call indirection at runtime. Save some cycles by turning the indirect calls to direct calls to either hash or trie code. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18ipv4: cleanup: remove unnecessary include.Rami Rosen
There is no need for net/icmp.h header in net/ipv4/fib_frontend.c. This patch removes the #include net/icmp.h from it. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-22ip: add loose reverse path filteringStephen Hemminger
Extend existing reverse path filter option to allow strict or loose filtering. (See http://en.wikipedia.org/wiki/Reverse_path_filtering). For compatibility with existing usage, the value 1 is chosen for strict mode and 2 for loose mode. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: clean up net/ipv4/fib_frontend.c fib_hash.c ip_gre.cJianjun Kong
Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05netns: add namespace parameter to rt_cache_flushDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03route: Mark unused routing attributes as suchThomas Graf
Also removes an unused policy entry for an attribute which is only used in kernel->user direction. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-31[NETNS]: Lookup in FIB semantic hashes taking into account the namespace.Denis V. Lunev
The namespace is not available in the fib_sync_down_addr, add it as a parameter. Looking up a device by the pointer to it is OK. Looking up using a result from fib_trie/fib_hash table lookup is also safe. No need to fix that at all. So, just fix lookup by address and insertion to the hash table path. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPV4]: fib_sync_down rework.Denis V. Lunev
fib_sync_down can be called with an address and with a device. In reality it is called either with address OR with a device. The codepath inside is completely different, so lets separate it into two calls for these two cases. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPV4]: Fix memory leak on error path during FIB initialization.Denis V. Lunev
net->ipv4.fib_table_hash is not freed when fib4_rules_init failed. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_dev_find.Denis V. Lunev
in_dev_find() need a namespace to pass it to fib_get_table(), so add an argument. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to fib_select_default.Denis V. Lunev
Currently fib_select_default calls fib_get_table() with the init_net. Prepare it to provide a correct namespace to lookup default route. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Consolidate fib_select_default.Denis V. Lunev
The difference in the implementation of the fib_select_default when CONFIG_IP_MULTIPLE_TABLES is (not) defined looks negligible. Consolidate it and place into fib_frontend.c. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Pass correct namespace in fib_validate_source.Denis V. Lunev
Correct network namespace is available inside fib_validate_source. It can be obtained from the device passed in. The device is not NULL as in_device is obtained from it just above. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to fib_lookup.Denis V. Lunev
2008-01-28[IPV4]: Enable use of 240/4 address space.Jan Engelhardt
This short patch modifies the IPv4 networking to enable use of the 240.0.0.0/4 (aka "class-E") address space as propsed in the internet draft draft-fuller-240space-00.txt. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Namespace stop vs 'ip r l' race.Denis V. Lunev
During network namespace stop process kernel side netlink sockets belonging to a namespace should be closed. They should not prevent namespace to stop, so they do not increment namespace usage counter. Though this counter will be put during last sock_put. The raplacement of the correct netns for init_ns solves the problem only partial as socket to be stoped until proper stop is a valid netlink kernel socket and can be looked up by the user processes. This is not a problem until it resides in initial namespace (no processes inside this net), but this is not true for init_net. So, hold the referrence for a socket, remove it from lookup tables and only after that change namespace and perform a last put. Signed-off-by: Denis V. Lunev <den@openvz.org> Tested-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Consolidate kernel netlink socket destruction.Denis V. Lunev
Create a specific helper for netlink kernel socket disposal. This just let the code look better and provides a ground for proper disposal inside a namespace. Signed-off-by: Denis V. Lunev <den@openvz.org> Tested-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Memory leak on network namespace stop.Denis V. Lunev
Network namespace allocates 2 kernel netlink sockets, fibnl & rtnl. These sockets should be disposed properly, i.e. by sock_release. Plain sock_put is not enough. Signed-off-by: Denis V. Lunev <den@openvz.org> Tested-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: fib hash|trie initializationStephen Hemminger
Initialization of the slab cache's should be done when IP is initialized to make sure of available memory, and that code can be marked __init. Signed-off-by: Stephen Hemminger <stephen.hemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4] FIB: printk related cleanupsStephen Hemminger
printk related cleanups: * Get rid of unused printk wrappers. * Make bug checks into KERN_WARNING because KERN_DEBUG gets ignored * Turn one cryptic old message into something real * Make sure all messages have KERN_XXX Signed-off-by: Stephen Hemminger <stephen.hemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Enable routing configuration in non-initial namespace.Denis V. Lunev
I.e. remove the net != &init_net checks from the places, that now can handle other-than-init net namespace. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Replace init_net with the correct context in fib_frontend.cDenis V. Lunev
2008-01-28[NETNS]: Pass namespace through ip_rt_ioctl.Denis V. Lunev
... up to rtentry_to_fib_config Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Correctly fill fib_config data.Denis V. Lunev
2008-01-28[NETNS]: Provide correct namespace for fibnl netlink socket.Denis V. Lunev
This patch makes the netlink socket to be per namespace. That allows to have each namespace its own socket for routing queries. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Place fib tables into netns.Denis V. Lunev
The preparatory work has been done. All we need is to substitute fib_table_hash with net->ipv4.fib_table_hash. Netns context is available when required. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns to nl_info structure.Denis V. Lunev
nl_info is used to track the end-user destination of routing change notification. This is a natural object to hold a namespace on. Place it there and utilize the context in the appropriate places. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to inet_(dev_)add_type.Eric W. Biederman
The patch extends the inet_addr_type and inet_dev_addr_type with the network namespace pointer. That allows to access the different tables relatively to the network namespace. The modification of the signature function is reported in all the callers of the inet_addr_type using the pointer to the well known init_net. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to fib_get_table/fib_new_table.Denis V. Lunev
This patch extends the fib_get_table and the fib_new_table functions with the network namespace pointer. That will allow to access the table relatively from the network namespace. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Unify access to the routing tables.Denis V. Lunev
Replace the direct pointers to local and main tables with calls to fib_get_table() with appropriate argument. This doesn't introduce additional dereferences, but makes the access to fib tables uniform in any (CONFIG_IP_MULTIPLE_TABLES) case. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Refactor fib initialization so it can handle multiple namespaces.Denis V. Lunev
This patch makes the fib to be initialized as a subsystem for the network namespaces. The code does not handle several namespaces yet, so in case of a creation of a network namespace, the creation/initialization will not occur. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Check fib4_rules_init failure.Denis V. Lunev
This adds error paths into both versions of fib4_rules_init (with/without CONFIG_IP_MULTIPLE_TABLES) and returns error code to the caller. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
