path: root/net/ipv4/cipso_ipv4.c
2006-09-25[NetLabel]: rework the Netlink attribute handling (part 1)Paul Moore
At the suggestion of Thomas Graf, rewrite NetLabel's use of Netlink attributes to better follow the common Netlink attribute usage. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: make the CIPSOv4 cache spinlocks bottom half safePaul Moore
The CIPSOv4 cache traversal routines are triggered both the userspace events (cache invalidation due to DOI removal or updated SELinux policy) and network packet processing events. As a result there is a problem with the existing CIPSOv4 cache spinlocks as they are not bottom-half/softirq safe. This patch converts the CIPSOv4 cache spin_[un]lock() calls into spin_[un]lock_bh() calls to address this problem. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: correct improper handling of non-NetLabel peer contextsPaul Moore
Fix a problem where NetLabel would always set the value of sk_security_struct->peer_sid in selinux_netlbl_sock_graft() to the context of the socket, causing problems when users would query the context of the connection. This patch fixes this so that the value in sk_security_struct->peer_sid is only set when the connection is NetLabel based, otherwise the value is untouched. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Make code static.Adrian Bunk
This patch makes needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: CIPSOv4 enginePaul Moore
Add support for the Commercial IP Security Option (CIPSO) to the IPv4 network stack. CIPSO has become a de-facto standard for trusted/labeled networking amongst existing Trusted Operating Systems such as Trusted Solaris, HP-UX CMW, etc. This implementation is designed to be used with the NetLabel subsystem to provide explicit packet labeling to LSM developers. The CIPSO/IPv4 packet labeling works by the LSM calling a NetLabel API function which attaches a CIPSO label (IPv4 option) to a given socket; this in turn attaches the CIPSO label to every packet leaving the socket without any extra processing on the outbound side. On the inbound side the individual packet's sk_buff is examined through a call to a NetLabel API function to determine if a CIPSO/IPv4 label is present and if so the security attributes of the CIPSO label are returned to the caller of the NetLabel API function. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
