path: root/net/ipv4/ah4.c
2010-02-22xfrm: SA lookups signature with markJamal Hadi Salim
pass mark to all SA lookups to prepare them for when we add code to have them search. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25xfrm: Use the user specified truncation length in ESP and AHMartin Willi
Instead of using the hardcoded truncation for authentication algorithms, use the truncation length specified on xfrm_state. Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18ah4: convert to ahashSteffen Klassert
This patch converts ah4 to the new ahash interface. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: AH/ESP in netns!Alexey Dobriyan
2008-11-25netns xfrm: state lookup in netnsAlexey Dobriyan
2008-11-25ah4/ah6: remove useless NULL assignmentsAlexey Dobriyan
struct will be kfreed in a moment, so... Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: clean up net/ipv4/ah4.c esp4.c fib_semantics.c inet_connection_sock.c ↵Jianjun Kong
inetpeer.c ip_output.c Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-12[IPSEC]: Fix bogus usage of u64 on input sequence numberHerbert Xu
Al Viro spotted a bogus use of u64 on the input sequence number which is big-endian. This patch fixes it by giving the input sequence number its own member in the xfrm_skb_cb structure. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[XFRM]: constify 'struct xfrm_type'Eric Dumazet
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move all calls to xfrm_audit_state_icvfail to xfrm_inputHerbert Xu
Let's nip the code duplication in the bud :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: RFC4303 compliant auditingPaul Moore
This patch adds a number of new IPsec audit events to meet the auditing requirements of RFC4303. This includes audit hooks for the following events: * Could not find a valid SA [sections 2.1, 3.4.2] . xfrm_audit_state_notfound() . xfrm_audit_state_notfound_simple() * Sequence number overflow [section 3.3.3] . xfrm_audit_state_replay_overflow() * Replayed packet [section 3.4.3] . xfrm_audit_state_replay() * Integrity check failure [sections 3.4.4.1, 3.4.4.2] . xfrm_audit_state_icvfail() While RFC4304 deals only with ESP most of the changes in this patch apply to IPsec in general, i.e. both AH and ESP. The one case, integrity check failure, where ESP specific code had to be modified the same was done to the AH code for the sake of consistency. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move state lock into x->type->inputHerbert Xu
This patch releases the lock on the state before calling x->type->input. It also adds the lock to the spots where they're currently needed. Most of those places (all except mip6) are expected to disappear with async crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move integrity stat collection into xfrm_inputHerbert Xu
Similar to the moving out of the replay processing on the output, this patch moves the integrity stat collectin from x->type->input into xfrm_input. This would eventually allow transforms such as AH/ESP to be lockless. The error value EBADMSG (currently unused in the crypto layer) is used to indicate a failed integrity check. In future this error can be directly returned by the crypto layer once we switch to aead algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10[IPSEC]: Move IP protocol setting from transforms into xfrm4_input.cHerbert Xu
This patch makes the IPv4 x->type->input functions return the next protocol instead of setting it directly. This is identical to how we do things in IPv6 and will help us merge common code on the input path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move IP length/checksum setting out of transformsHerbert Xu
This patch moves the setting of the IP length and checksum fields out of the transforms and into the xfrmX_output functions. This would help future efforts in merging the transforms themselves. It also adds an optimisation to ipcomp due to the fact that the transport offset is guaranteed to be zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Get rid of ipv6_{auth,esp,comp}_hdrHerbert Xu
This patch removes the duplicate ipv6_{auth,esp,comp}_hdr structures since they're identical to the IPv4 versions. Duplicating them would only create problems for ourselves later when we need to add things like extended sequence numbers. I've also added transport header type conversion headers for these types which are now used by the transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Use IPv6 calling convention as the convention for x->mode->outputHerbert Xu
The IPv6 calling convention for x->mode->output is more general and could help an eventual protocol-generic x->type->output implementation. This patch adopts it for IPv4 as well and modifies the IPv4 type output functions accordingly. It also rewrites the IPv6 mac/transport header calculation to be based off the network header where practical. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Set skb->data to payload in x->mode->outputHerbert Xu
This patch changes the calling convention so that on entry from x->mode->output and before entry into x->type->output skb->data will point to the payload instead of the IP header. This is essentially a redistribution of skb_push/skb_pull calls with the aim of minimising them on the common path of tunnel + ESP. It'll also let us use the same calling convention between IPv4 and IPv6 with the next patch. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move state lock into x->type->outputHerbert Xu
This patch releases the lock on the state before calling x->type->output. It also adds the lock to the spots where they're currently needed. Most of those places (all except mip6) are expected to disappear with async crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move output replay code into xfrm_outputHerbert Xu
The replay counter is one of only two remaining things in the output code that requires a lock on the xfrm state (the other being the crypto). This patch moves it into the generic xfrm_output so we can remove the lock from the transforms themselves. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC] ah: Remove keys from ah_data structureHerbert Xu
The keys are only used during initialisation so we don't need to carry them in esp_data. Since we don't have to allocate them again, there is no need to place a limit on the authentication key length anymore. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-26[IPSEC] AH4: Update IPv4 options handling to conform to RFC 4302.Nick Bowler
In testing our ESP/AH offload hardware, I discovered an issue with how AH handles mutable fields in IPv4. RFC 4302 (AH) states the following on the subject: For IPv4, the entire option is viewed as a unit; so even though the type and length fields within most options are immutable in transit, if an option is classified as mutable, the entire option is zeroed for ICV computation purposes. The current implementation does not zero the type and length fields, resulting in authentication failures when communicating with hosts that do (i.e. FreeBSD). I have tested record route and timestamp options (ping -R and ping -T) on a small network involving Windows XP, FreeBSD 6.2, and Linux hosts, with one router. In the presence of these options, the FreeBSD and Linux hosts (with the patch or with the hardware) can communicate. The Windows XP host simply fails to accept these packets with or without the patch. I have also been trying to test source routing options (using traceroute -g), but haven't had much luck getting this option to work *without* AH, let alone with. Signed-off-by: Nick Bowler <nbowler@ellipticsemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[XFRM]: Add module alias for transformation type.Masahide NAKAMURA
It is clean-up for XFRM type modules and adds aliases with its protocol: ESP, AH, IPCOMP, IPIP and IPv6 for IPsec ROUTING and DSTOPTS for MIPv6 It is almost the same thing as XFRM mode alias, but it is added new defines XFRM_PROTO_XXX for preprocessing since some protocols are defined as enum. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Acked-by: Ingo Oeser <netdev@axxeo.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce icmp_hdr(), remove skb->h.icmphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV4]: encapsulation annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: core network changesPaul Moore
Changes to the core network stack to support the NetLabel subsystem. This includes changes to the IPv4 option handling to support CIPSO labels. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[IPSEC]: Use HMAC template and hash interfaceHerbert Xu
This patch converts IPsec to use the new HMAC template. The names of existing simple digest algorithms may still be used to refer to their HMAC composites. The same structure can be used by other MACs such as AES-XCBC-MAC. This patch also switches from the digest interface to hash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] proto: Move transport mode input path into xfrm_mode_transportHerbert Xu
Now that we have xfrm_mode objects we can move the transport mode specific input decapsulation code into xfrm_mode_transport. This removes duplicate code as well as unnecessary header movement in case of tunnel mode SAs since we will discard the original IP header immediately. This also fixes a minor bug for transport-mode ESP where the IP payload length is set to the correct value minus the header length (with extension headers for IPv6). Of course the other neat thing is that we no longer have to allocate temporary buffers to hold the IP headers for ESP and IPComp. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-01[IPSEC]: Kill unused decap state argumentHerbert Xu
This patch removes the decap_state argument from the xfrm input hook. Previously this function allowed the input hook to share state with the post_input hook. The latter has since been removed. The only purpose for it now is to check the encap type. However, it is easier and better to move the encap type check to the generic xfrm_rcv function. This allows us to get rid of the decap state argument altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPSEC]: Sync series - fast pathJamal Hadi Salim
Fast path sequence updates that will generate ipsec async events Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[CRYPTO]: crypto_free_tfm() callers no longer need to check for NULLJesper Juhl
Since the patch to add a NULL short-circuit to crypto_free_tfm() went in, there's no longer any need for callers of that function to check for NULL. This patch removes the redundant NULL checks and also a few similar checks for NULL before calls to kfree() that I ran into while doing the crypto_free_tfm bits. I've succesfuly compile tested this patch, and a kernel with the patch applied boots and runs just fine. When I posted the patch to LKML (and other lists/people on Cc) it drew the following comments : J. Bruce Fields commented "I've no problem with the auth_gss or nfsv4 bits.--b." Sridhar Samudrala said "sctp change looks fine." Herbert Xu signed off on the patch. So, I guess this is ready to be dropped into -mm and eventually mainline. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[IPSEC]: Add xfrm_init_stateHerbert Xu
This patch adds xfrm_init_state which is simply a wrapper that calls xfrm_get_type and subsequently x->type->init_state. It also gets rid of the unused args argument. Abstracting it out allows us to add common initialisation code, e.g., to set family-specific flags. The add_time setting in xfrm_user.c was deleted because it's already set by xfrm_state_alloc. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
