path: root/net/ipv4/ah4.c
2006-04-01[IPSEC]: Kill unused decap state argumentHerbert Xu
This patch removes the decap_state argument from the xfrm input hook. Previously this function allowed the input hook to share state with the post_input hook. The latter has since been removed. The only purpose for it now is to check the encap type. However, it is easier and better to move the encap type check to the generic xfrm_rcv function. This allows us to get rid of the decap state argument altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPSEC]: Sync series - fast pathJamal Hadi Salim
Fast path sequence updates that will generate ipsec async events Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[CRYPTO]: crypto_free_tfm() callers no longer need to check for NULLJesper Juhl
Since the patch to add a NULL short-circuit to crypto_free_tfm() went in, there's no longer any need for callers of that function to check for NULL. This patch removes the redundant NULL checks and also a few similar checks for NULL before calls to kfree() that I ran into while doing the crypto_free_tfm bits. I've succesfuly compile tested this patch, and a kernel with the patch applied boots and runs just fine. When I posted the patch to LKML (and other lists/people on Cc) it drew the following comments : J. Bruce Fields commented "I've no problem with the auth_gss or nfsv4 bits.--b." Sridhar Samudrala said "sctp change looks fine." Herbert Xu signed off on the patch. So, I guess this is ready to be dropped into -mm and eventually mainline. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[IPSEC]: Add xfrm_init_stateHerbert Xu
This patch adds xfrm_init_state which is simply a wrapper that calls xfrm_get_type and subsequently x->type->init_state. It also gets rid of the unused args argument. Abstracting it out allows us to add common initialisation code, e.g., to set family-specific flags. The add_time setting in xfrm_user.c was deleted because it's already set by xfrm_state_alloc. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
