path: root/net/ipv4/af_inet.c
2005-06-13[SCTP] Add support for ip_nonlocal_bind sysctl & IP_FREEBIND socket optionNeil Horman
Signed-off-by: Neil Horman <nhorman@redhat.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-25[PATCH] kill gratitious includes of major.h under net/*Al Viro
A lot of places in there are including major.h for no reason whatsoever. Removed. And yes, it still builds. The history of that stuff is often amusing. E.g. for net/core/sock.c the story looks so, as far as I've been able to reconstruct it: we used to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket", &net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of net/* had moved a lot of stuff from net/socket.c to net/core/sock.c, this crap had followed... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
