path: root/net/ipv4/af_inet.c
2009-04-17[PATCH] net: remove superfluous call to synchronize_net()Eric Dumazet
inet_register_protosw() function is responsible for adding a new inet protocol into a global table (inetsw[]) that is used with RCU rules. As soon as the store of the pointer is done, other cpus might see this new protocol in inetsw[], so we have to make sure new protocol is ready for use. All pending memory updates should thus be committed to memory before setting the pointer. This is correctly done using rcu_assign_pointer() synchronize_net() is typically used at unregister time, after unsetting the pointer, to make sure no other cpu is still using the object we want to dismantle. Using it at register time is only adding an artificial delay that could hide a real bug, and this bug could popup if/when synchronize_rcu() can proceed faster than now. This saves about 13 ms on boot time on a HZ=1000 8 cpus machine ;) (4 calls to inet_register_protosw(), and about 3200 us per call) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-20alloc_percpu: add align argument to __alloc_percpu.Rusty Russell
This prepares for a real __alloc_percpu, by adding an alignment argument. Only one place uses __alloc_percpu directly, and that's for a string. tj: af_inet also uses __alloc_percpu(), update it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Jens Axboe <axboe@kernel.dk>
2009-02-08gro: Optimise IPv4 packet receptionHerbert Xu
As this function can be called more than half a million times for 10GbE, it's important to optimise it as much as we can. This patch does some obvious changes to use 2-byte and 4-byte operations instead of byte-oriented ones where possible. Bit ops are also used to replace logical ops to reduce branching. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01ipv4: Delete redundant sk_family assignmentHerbert Xu
sk_alloc now sets sk_family so this is redundant. In fact it caught my eye because sock_init_data already uses sk_family so this is too late anyway. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-29gro: Avoid copying headers of unmerged packetsHerbert Xu
Unfortunately simplicity isn't always the best. The fraginfo interface turned out to be suboptimal. The problem was quite obvious. For every packet, we have to copy the headers from the frags structure into skb->head, even though for 99% of the packets this part is immediately thrown away after the merge. LRO didn't have this problem because it directly read the headers from the frags structure. This patch attempts to address this by creating an interface that allows GRO to access the headers in the first frag without having to copy it. Because all drivers that use frags place the headers in the first frag this optimisation should be enough. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25netns: igmp: allow IPPROTO_IGMP sockets in netnsAlexey Dobriyan
Looks like everything is already ready. Required for ebtables(8) for one thing. Also, required for ipmr per-netns (coming soon). (Benjamin) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15tcp: Add GRO supportHerbert Xu
This patch adds the TCP-specific portion of GRO. The criterion for merging is extremely strict (the TCP header must match exactly apart from the checksum) so as to allow refragmentation. Otherwise this is pretty much identical to LRO, except that we support the merging of ECN packets. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15ipv4: Add GRO infrastructureHerbert Xu
This patch adds GRO support for IPv4. The criteria for merging is more stringent than LRO, in particular, we require all fields in the IP header to be identical except for the length, ID and checksum. In addition, the ID must form an arithmetic sequence with a difference of one. The ID requirement might seem overly strict, however, most hardware TSO solutions already obey this rule. Linux itself also obeys this whether GSO is in use or not. In future we could relax this rule by storing the IDs (or rather making sure that we don't drop them when pulling the aggregate skb's tail). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-23net: some optimizations in af_inetEric Dumazet
1) Use eq_net() in inet_netns_ok() to speedup socket creation if !CONFIG_NET_NS 2) Reorder the tests about inet_ehash_secret generation (once only) Use the unlikely() macro when testing if inet_ehash_secret already generated. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c include/net/mac80211.h net/phonet/af_phonet.c
2008-11-20TPROXY: supply a struct flowi->flags argument in inet_sk_rebuild_header()Balazs Scheidler
inet_sk_rebuild_header() does a new route lookup if the dst_entry associated with a socket becomes stale. However inet_sk_rebuild_header() didn't use struct flowi->flags, causing the route lookup to fail for foreign-bound IP_TRANSPARENT sockets, causing an error state to be set for the sockets in question. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/ipv4/ net/ipv6/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Allow binding to non-local addresses if IP_TRANSPARENT is setTóth László Attila
Setting IP_TRANSPARENT is not really useful without allowing non-local binds for the socket. To make user-space code simpler we allow these binds even if IP_TRANSPARENT is set but IP_FREEBIND is not. Signed-off-by: Tóth László Attila <panther@balabit.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (39 commits) [PATCH] fix RLIM_NOFILE handling [PATCH] get rid of corner case in dup3() entirely [PATCH] remove remaining namei_{32,64}.h crap [PATCH] get rid of indirect users of namei.h [PATCH] get rid of __user_path_lookup_open [PATCH] f_count may wrap around [PATCH] dup3 fix [PATCH] don't pass nameidata to __ncp_lookup_validate() [PATCH] don't pass nameidata to gfs2_lookupi() [PATCH] new (local) helper: user_path_parent() [PATCH] sanitize __user_walk_fd() et.al. [PATCH] preparation to __user_walk_fd cleanup [PATCH] kill nameidata passing to permission(), rename to inode_permission() [PATCH] take noexec checks to very few callers that care Re: [PATCH 3/6] vfs: open_exec cleanup [patch 4/4] vfs: immutable inode checking cleanup [patch 3/4] fat: dont call notify_change [patch 2/4] vfs: utimes cleanup [patch 1/4] vfs: utimes: move owner check into inode_change_ok() [PATCH] vfs: use kstrdup() and check failing allocation ...
2008-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: fix ip_rt_frag_needed rt_is_expired netfilter: nf_conntrack_extend: avoid unnecessary "ct->ext" dereferences netfilter: fix double-free and use-after free netfilter: arptables in netns for real netfilter: ip{,6}tables_security: fix future section mismatch selinux: use nf_register_hooks() netfilter: ebtables: use nf_register_hooks() Revert "pkt_sched: sch_sfq: dump a real number of flows" qeth: use dev->ml_priv instead of dev->priv syncookies: Make sure ECN is disabled net: drop unused BUG_TRAP() net: convert BUG_TRAP to generic WARN_ON drivers/net: convert BUG_TRAP to generic WARN_ON
2008-07-26[PATCH] sysctl: make sure that /proc/sys/net/ipv4 appears before per-ns onesAl Viro
Massage ipv4 initialization - make sure that net.ipv4 appears as non-per-net-namespace before it shows up in per-net-namespace sysctls. That's the only change outside of sysctl.c needed to get sane ordering rules and data structures for sysctls (esp. for procfs side of that mess). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25list_for_each_rcu must die: networkingPaul E. McKenney
All uses of list_for_each_rcu() can be profitably replaced by the easier-to-use list_for_each_entry_rcu(). This patch makes this change for networking, in preparation for removing the list_for_each_rcu() API entirely. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-18ipv4: clean the init_ipv4_mibs error pathsPavel Emelyanov
After moving all the stuff outside this function it looks a bit ugly - make it look better. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put icmpmsg statistics on struct netPavel Emelyanov
2008-07-18mib: put icmp statistics on struct netPavel Emelyanov
2008-07-18mib: put udplite statistics on struct netPavel Emelyanov
2008-07-18mib: put udp statistics on struct netPavel Emelyanov
Similar to... ouch, I repeat myself. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put net statistics on struct netPavel Emelyanov
Similar to ip and tcp ones :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put ip statistics on struct netPavel Emelyanov
Similar to tcp one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put tcp statistics on struct netPavel Emelyanov
Proc temporary uses stats from init_net. BTW, TCP_XXX_STATS are beautiful (w/o do { } while (0) facing) again :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18ipv4: add pernet mib operationsPavel Emelyanov
These ones are currently empty, but stuff from init_ipv4_mibs will sequentially migrate there. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16tcp: add net to tcp_mib_initPavel Emelyanov
This one sets TCP MIBs after zeroing them, and thus requires the net. The existing single caller can use init_net (temporarily). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03ipv4: Do cleanup for ip_mr_initWang Chen
Same as ip6_mr_init(), make ip_mr_init() return errno if fails. But do not do error handling in inet_init(), just print a msg. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-14[IPV4]: Use NIPQUAD_FMT to format ipv4 addresses.YOSHIFUJI Hideaki
And use %u to format port. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[INET]: uc_ttl assignment in inet_ctl_sock_create is redundant.Denis V. Lunev
uc_ttl is initialized in inet(6)_create and never changed except setsockopt ioctl. Remove this assignment. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[NETNS]: Inet control socket should not hold a namespace.Denis V. Lunev
This is a generic requirement, so make inet_ctl_sock_create namespace aware and create a inet_ctl_sock_destroy wrapper around sk_release_kernel. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[INET]: Let inet_ctl_sock_create return sock rather than socket.Denis V. Lunev
All upper protocol layers are already use sock internally. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[INET]: Rename inet_csk_ctl_sock_create to inet_ctl_sock_create.Denis V. Lunev
This call is nothing common with INET connection sockets code. It simply creates an unhashes kernel sockets for protocol messages. Move the new call into af_inet.c after the rename. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-24[NETNS]: Enable TCP/UDP/ICMP inside namespace.Denis V. Lunev
2008-03-24[NETNS]: Allow to create sockets in non-initial namespace.Denis V. Lunev
Allow to create sockets in the namespace if the protocol ok with this. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: Process INET socket layer in the correct namespace.Denis V. Lunev
Replace all the reast of the init_net with a proper net on the socket layer. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-17[NET] endianness noise: INADDR_ANYAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[UDP]: Revert udplite and code split.David S. Miller
This reverts commit db1ed684f6c430c4cdad67d058688b8a1b5e607c ("[IPV6] UDP: Rename IPv6 UDP files."), commit 8be8af8fa4405652e6c0797db5465a4be8afb998 ("[IPV4] UDP: Move IPv4-specific bits to other file.") and commit e898d4db2749c6052072e9bc4448e396cbdeb06a ("[UDP]: Allow users to configure UDP-Lite."). First, udplite is of such small cost, and it is a core protocol just like TCP and normal UDP are. We spent enormous amounts of effort to make udplite share as much code with core UDP as possible. All of that work is less valuable if we're just going to slap a config option on udplite support. It is also causing build failures, as reported on linux-next, showing that the changeset was not tested very well. In fact, this is the second build failure resulting from the udplite change. Finally, the config options provided was a bool, instead of a modular option. Meaning the udplite code does not even get build tested by allmodconfig builds, and furthermore the user is not presented with a reasonable modular build option which is particularly needed by distribution vendors. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[UDP]: Allow users to configure UDP-Lite.YOSHIFUJI Hideaki
Let's give users an option for disabling UDP-Lite (~4K). old: | text data bss dec hex filename | 286498 12432 6072 305002 4a76a net/ipv4/built-in.o | 193830 8192 3204 205226 321aa net/ipv6/ipv6.o new (without UDP-Lite): | text data bss dec hex filename | 284086 12136 5432 301654 49a56 net/ipv4/built-in.o | 191835 7832 3076 202743 317f7 net/ipv6/ipv6.o Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-29[ICMP]: Add return code to icmp_init.Denis V. Lunev
icmp_init could fail and this is normal for namespace other than initial. So, the panic should be triggered only on init_net initialization path. Additionally create rollback path for icmp_init as a separate function. It will also be used later during namespace destruction. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[INET]: Remove struct net_proto_family* from _init calls.Denis V. Lunev
struct net_proto_family* is not used in icmp[v6]_init, ndisc_init, igmp_init and tcp_v4_init. Remove it. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
