path: root/net/ieee80211/ieee80211_tx.c
2008-05-07remove ieee80211_tx_frame()Adrian Bunk
After the softmac removal ieee80211_tx_frame() was no longer used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28ieee80211: fix misannotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-29ieee80211: fix unaligned access in ieee80211_copy_snapDaniel Drake
There is no guarantee that data+SNAP_SIZE will reside on an even numbered address, so doing a 16 bit read will cause an unaligned access in some situations. Based on a patch from Jun Sun. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] IEEE80211: Use htons() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-17Merge branch 'gfar' of ↵Jeff Garzik
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into upstream
2007-02-10[NET] IEEE80211: Fix whitespace errors.YOSHIFUJI Hideaki
2007-02-09[PATCH] ieee80211: Fix sparse warningLarry Finger
Sparse issues the warning "warning: symbol 'crypt' shadows an earlier one" in net/ieee80211/ieee80211_tx.c. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-11-14[PATCH] ieee80211: Fix kernel panic when QoS is enabledZhu Yi
The 802.11 header length is affected by the wireless mode (WDS or not) and type (QoS or not). We should use the variable hdr_len instead of the hard coded IEEE80211_3ADDR_LEN, otherwise we may touch invalid memory. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-29[PATCH] ieee80211: remove ieee80211_tx() is_queue_full warningZhu Yi
2006-08-29[PATCH] ieee80211: Fix header->qos_ctl endian issueZhu Yi
Signed-off-by: Jackie Wu <jackie.wu@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-05[PATCH] ieee80211: fix not allocating IV+ICV space when usingencryption in ↵Hong Liu
ieee80211_tx_frame We should preallocate IV+ICV space when encrypting the frame. Currently no problem shows up just because dev_alloc_skb aligns the data len to SMP_CACHE_BYTES which can be used for ICV. Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-06-05[PATCH] softmac: complete shared key authenticationDaniel Drake
This patch finishes of the partially-complete shared key authentication implementation in softmac. The complication here is that we need to encrypt a management frame during the authentication process. I don't think there are any other scenarios where this would have to happen. To get around this without causing too many headaches, we decided to just use software encryption for this frame. The softmac config option now selects IEEE80211_CRYPT_WEP so that we can ensure this available. This also involved a modification to some otherwise unused ieee80211 API. Signed-off-by: Daniel Drake <dsd@gentoo.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-04-24[PATCH] ieee80211: Fix TX code doesn't enable QoS when using WPA + QoSZhu Yi
Fix ieee80211 TX code when using WPA+QOS. TKIP/CCMP will use the TID field of qos_ctl in 802.11 frame header to do encryption. We cannot ignore this field when doing host encryption and add the qos_ctl field later. Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-27[PATCH] ieee80211: Add TKIP crypt->build_ivZhu Yi
This patch adds ieee80211 TKIP build_iv() method to support hardwares that can do TKIP encryption but relies on ieee80211 layer to build the IV. It also changes the build_iv() interface to return the key if possible after the IV is built (this is required by TKIP). Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-27[PATCH] WEP fields are incorrectly shown to be INSIDE snap in the docDenis Vlasenko
>If encryption is enabled, each fragment payload size is reduced by enough space >to add the prefix and postfix (IV and ICV totalling 8 bytes in the case of WEP) >So if you have 1500 bytes of payload with ieee->fts set to 500 without >encryption it will take 3 frames. With WEP it will take 4 frames as the >payload of each frame is reduced to 492 bytes. Text is correct, but in picture (IV,payload,ICV) sits inside SNAP. Patch corrects this. Signed-Off-By: Denis Vlasenko <vda@ilport.com.ua> Acked-By: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] ieee80211: enable hw wep where host has to build IVJohannes Berg
This patch fixes some of the ieee80211 crypto related code so that instead of having the host fully do crypto operations, the host_build_iv flag works properly (for WEP in this patch) which, if turned on, requires the hardware to do all crypto operations, but the ieee80211 layer builds the IV. The hardware also has to build the ICV. Previously, the host_build_iv flag couldn't be used at all for WEP, and not alone (with both host_decrypt and host_encrypt disabled) because the crypto algorithm wasn't assigned. This is also fixed. I have tested this patch both in host crypto mode and in hw crypto mode (with the Broadcom chipset). [resent, signing digitally caused it to be MIME-junked, sorry] Signed-Off-By: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05Remove linux/version.h include from drivers/net/phy/* and net/ieee80211/*.Jeff Garzik
Unused, and causes the files to be needlessly rebuilt in some cases.
2005-10-26[PATCH] ieee80211 build fixJames Ketrenos
James Ketrenos wrote: > [3/4] Use the tx_headroom and reserve requested space. This patch introduced a compile problem; patch below corrects this. Fixed compilation error due to not passing tx_headroom in ieee80211_tx_frame. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-21ieee80211 subsystem:Michael Buesch
* Use GFP mask on TX skb allocation. * Use the tx_headroom and reserve requested space. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-10-20Fixed oops if an uninitialized key is used for encryption.Hong Liu
Without this patch, if you try and use a key that has not been configured, for example: % iwconfig eth1 key deadbeef00 [2] without having configured key [1], then the active key will still be [1], but privacy will now be enabled. Transmission of a packet in this situation will result in a kernel oops. Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-10-19Fixed problem with not being able to decrypt/encrypt broadcast packets.Hong Liu
2005-10-13Merge branch 'master'Jeff Garzik
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04Merge branch 'upstream-fixes'Jeff Garzik
2005-10-04[PATCH] ieee80211: fix gfp flags typeRandy Dunlap
Fix implicit nocast warnings in ieee80211 code, including __nocast: net/ieee80211/ieee80211_tx.c:215:9: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03Merge branch 'upstream-fixes'Jeff Garzik
2005-10-03[PATCH] ieee80211: fix gfp flags typeRandy Dunlap
Fix implicit nocast warnings in ieee80211 code: net/ieee80211/ieee80211_tx.c:215:9: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-22[PATCH] ieee80211: Added handle_deauth() callback, enhanced tkip/ccmp ↵James Ketrenos
support of varying hw/sw offload tree de81b55e78e85997642c651ea677078d0554a14f parent c8030da8c159f8b82712172a6748a42523aea83a author James Ketrenos <jketreno@linux.intel.com> 1127104380 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127315225 -0500 Added handle_deauth() callback. Enhanced crypt_{tkip,ccmp} to support varying splits of HW/SW offload. Changed channel freq to u32 from u16. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Updated copyright datesJames Ketrenos
tree 0d3e41e574fcb41b9da7f0b7e1d27ec350726654 parent dbe2885fe2f454d538eaaabefc741ded1026f476 author James Ketrenos <jketreno@linux.intel.com> 1126720499 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127314531 -0500 Updated copyright dates. NOTE: This is a split out of just the copyright updates from patch 24/29 in the prior series. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Add QoS (WME) support to the ieee80211 subsystemJames Ketrenos
tree a3ad796273e98036eb0e9fc063225070fa24508a parent 1b9c0aeb377abf8e4a43a86cff42382f74ca0259 author Mohamed Abbas <mabbas@linux.intel.com> 1124447069 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127313435 -0500 Add QoS (WME) support to the ieee80211 subsystem. NOTE: This requires drivers that use the ieee80211 hard_start_xmit (ipw2100 and ipw2200) to add the priority parameter to their callback. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Return NETDEV_TX_BUSY when QoS buffer fullJames Ketrenos
tree ba6509c7cd1dd4244a2f285f2da5d632e7ffbb25 parent 7b5f9f2ddcabdaea214527a895e6e8445cafdd80 author James Ketrenos <jketreno@linux.intel.com> 1124447000 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127313383 -0500 Per the conversations with folks at OLS, the QoS layer in 802.11 drivers can now result in NETDEV_TX_BUSY being returned when the queue a packet is targetted for is full. To implement this, ieee80211_xmit will now call the driver's is_queue_full to determine if the current priority queue is full. If so, NETDEV_TX_BUSY is returned to the kernel and no processing is done on the frame. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Fix TKIP, repeated fragmentation problem, and ↵James Ketrenos
payload_size reporting tree 8428e9f510e6ad6c77baec89cb57374842abf733 parent d78bfd3ddae9c422dd350159110f9c4d7cfc50de author Liu Hong <hong.liu@intel.com> 1124446520 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127313183 -0500 Fix TKIP, repeated fragmentation problem, and payload_size reporting 1. TKIP encryption Originally, TKIP encryption issues msdu + mpdu encryption on every fragment. Change the behavior to msdu encryption on the whole packet, then mpdu encryption on every fragment. 2. Avoid repeated fragmentation when !host_encrypt. We only need do fragmentation when using host encryption. Otherwise we only need pass the whole packet to driver, letting driver do the fragmentation. 3. change the txb->payload_size to correct value FW will use this value to determine whether to do fragmentation. If we pass the wrong value, fw may cut on the wrong bound which will make decryption fail when we do host encryption. NOTE: This requires changing drivers (hostap) that have extra_prefix_len used within them (structure member name change). Signed-off-by: Hong Liu <liu.hong@intel.com> Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee82011: Added ieee80211_tx_frame to convert generic 802.11 data ↵James Ketrenos
frames, and callbacks tree 40adc78b623ae70d56074934ec6334eb4f0ae6a5 parent db43d847bcebaa3df6414e26d0008eb21690e8cf author James Ketrenos <jketreno@linux.intel.com> 1124445938 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127313102 -0500 Added ieee80211_tx_frame to convert generic 802.11 data frames into txbs for transmission. Added several purpose specific callbacks (handle_assoc, handle_auth, etc.) which the driver can register with for being notified on reception of variouf frame elements. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: adds support for the creation of RTS packetsJames Ketrenos
tree b45c9c1017fd23216bfbe71e441aed9aa297fc84 parent 04aacdd71e904656a304d923bdcf57ad3bd2b254 author Ivo van Doorn <IvDoorn@gmail.com> 1124445405 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127313029 -0500 This patch adds support for the creation of RTS packets when the config flag CFG_IEEE80211_RTS has been set. Signed-Off-By: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Renamed ieee80211_hdr to ieee80211_hdr_3addrJames Ketrenos
tree e9c18b2c8e5ad446a4d213243c2dcf9fd1652a7b parent 4e97ad6ae7084a4f741e94e76c41c68bc7c5a76a author James Ketrenos <jketreno@linux.intel.com> 1124444315 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127312922 -0500 Renamed ieee80211_hdr to ieee80211_hdr_3addr and modified ieee80211_hdr to just contain the frame_ctrl and duration_id. Changed uses of ieee80211_hdr to ieee80211_hdr_4addr or ieee80211_hdr_3addr based on what was expected for that portion of code. NOTE: This requires changes to ipw2100, ipw2200, hostap, and atmel drivers. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Hardware crypto and fragmentation offload supportJames Ketrenos
tree 5322d496af90d03ffbec27292dc1a6268a746ede parent 6c9364386ccb786e4a84427ab3ad712f0b7b8904 author James Ketrenos <jketreno@linux.intel.com> 1124432367 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127311810 -0500 Hardware crypto and fragmentation offload support added (Zhu Yi) Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Fixed a kernel oops on module unloadJames Ketrenos
tree 367069f24fc38b4aa910e86ff40094d2078d8aa7 parent a33a1982012e9070736e3717231714dc9892303b author James Ketrenos <jketreno@linux.intel.com> 1124430800 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127310571 -0500 Fixed a kernel oops on module unload by adding spin lock protection to ieee80211's crypt handlers (thanks to Zhu Yi) Modified scan result logic to report WPA and RSN IEs if set (vs.being based on wpa_enabled) Added ieee80211_device as the first parameter to the crypt init() method. TKIP modified to use that structure for determining whether to countermeasures are active. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-16[PATCH] ieee80211 Cleanup memcpy parameters.James Ketrenos
Cleanup memcpy parameters. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-07[wireless ieee80211,ipw2200] Lindent source codeJeff Garzik
No code changes, just Lindent + manual fixups. This prepares us for updating to the latest Intel driver code, plus gives the source code a nice facelift.
2005-08-28[PATCH] ieee80211: Remove EAPOL debugJouni Malinen
IEEE 802.11 code has no business touching payloads of EAPOL frames. There are some EAPOL structures defined for debugging and these were confusingly called EAP types which they are not. Let's just remove these before someone else starts using them in the kernel. Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-25ieee80211: new constants from latest 802.11x specificationsJiri Benc
From: Gertjan van Wingerde <gwingerde@home.nl> Attached patch updates the definitions of the generic ieee80211 stack to the latest versions of the published 802.11x specification suite. Signed-off-by: Gertjan van Wingerde <gwingerde@home.nl> Signed-off-by: Jiri Benc <jbenc@suse.cz>
2005-06-27[PATCH] ieee80211: remove pci.h #include'sAdrian Bunk
I was wondering why editing pci.h triggered the rebuild of three files under net/, and as far as I can see, there's no reason for these three files to #include pci.h . Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jiri Benc <jbenc@suse.cz>
2005-05-27[PATCH] net/ieee80211/: make two functions staticAdrian Bunk
This patch makes two needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-05-15[PATCH] net/ieee80211/ieee80211_tx.c: swapped memset argumentsAdrian Bunk
Fix swapped memset() arguments in net/ieee80211/ieee80211_tx.c found by Maciej Soltysiak. Patch by Jesper Juhl. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-05-12[NET] ieee80211 subsystemJeff Garzik
Contributors: Host AP contributors James Ketrenos <jketreno@linux.intel.com> Francois Romieu <romieu@fr.zoreil.com> Adrian Bunk <bunk@stusta.de> Matthew Galgoci <mgalgoci@parcelfarce.linux.th eplanet.co.uk>
