path: root/net/ieee80211/ieee80211_crypt_wep.c
2005-11-05Remove linux/version.h include from drivers/net/phy/* and net/ieee80211/*.Jeff Garzik
Unused, and causes the files to be needlessly rebuilt in some cases.
2005-09-22[PATCH] ieee80211: in-tree driver updates to sync with latest ieee80211 seriesJames Ketrenos
Changed crypto method from requiring a struct ieee80211_device reference to the init handler. Instead we now have a get/set flags method for each crypto component. Setting of TKIP countermeasures can now be done via set_flags(IEEE80211_CRYPTO_TKIP_COUNTERMEASURES) Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Fix TKIP, repeated fragmentation problem, and ↵James Ketrenos
payload_size reporting tree 8428e9f510e6ad6c77baec89cb57374842abf733 parent d78bfd3ddae9c422dd350159110f9c4d7cfc50de author Liu Hong <hong.liu@intel.com> 1124446520 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127313183 -0500 Fix TKIP, repeated fragmentation problem, and payload_size reporting 1. TKIP encryption Originally, TKIP encryption issues msdu + mpdu encryption on every fragment. Change the behavior to msdu encryption on the whole packet, then mpdu encryption on every fragment. 2. Avoid repeated fragmentation when !host_encrypt. We only need do fragmentation when using host encryption. Otherwise we only need pass the whole packet to driver, letting driver do the fragmentation. 3. change the txb->payload_size to correct value FW will use this value to determine whether to do fragmentation. If we pass the wrong value, fw may cut on the wrong bound which will make decryption fail when we do host encryption. NOTE: This requires changing drivers (hostap) that have extra_prefix_len used within them (structure member name change). Signed-off-by: Hong Liu <liu.hong@intel.com> Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21[PATCH] ieee80211: Fixed a kernel oops on module unloadJames Ketrenos
tree 367069f24fc38b4aa910e86ff40094d2078d8aa7 parent a33a1982012e9070736e3717231714dc9892303b author James Ketrenos <jketreno@linux.intel.com> 1124430800 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127310571 -0500 Fixed a kernel oops on module unload by adding spin lock protection to ieee80211's crypt handlers (thanks to Zhu Yi) Modified scan result logic to report WPA and RSN IEs if set (vs.being based on wpa_enabled) Added ieee80211_device as the first parameter to the crypt init() method. TKIP modified to use that structure for determining whether to countermeasures are active. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-16[PATCH] ieee80211 Added wireless spy supportJames Ketrenos
Added wireless spy support to Rx code path. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> NOTE: Looks like scripts/Lindent generated output different than the Lindented version already in-kernel, hence all the whitespace deltas... *sigh* Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-07[wireless ieee80211,ipw2200] Lindent source codeJeff Garzik
No code changes, just Lindent + manual fixups. This prepares us for updating to the latest Intel driver code, plus gives the source code a nice facelift.
2005-05-12[NET] ieee80211 subsystemJeff Garzik
Contributors: Host AP contributors James Ketrenos <jketreno@linux.intel.com> Francois Romieu <romieu@fr.zoreil.com> Adrian Bunk <bunk@stusta.de> Matthew Galgoci <mgalgoci@parcelfarce.linux.th eplanet.co.uk>
