path: root/net/ethernet/eth.c
2005-08-29[NET]: Remove explicit initializations of skb->input_devDavid S. Miller
Instead, set it in one place, namely the beginning of netif_receive_skb(). Based upon suggestions from Jamal Hadi Salim. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[NET]: Micro optimization in eth_header()Denis Vlasenko
Signed-off-by: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
