path: root/net/core/dev.c
2014-06-09net-gro: reset skb->truesize in napi_reuse_skb()Eric Dumazet
[ Upstream commit e33d0ba8047b049c9262fdb1fcafb93cb52ceceb ] Recycling skb always had been very tough... This time it appears GRO layer can accumulate skb->truesize adjustments made by drivers when they attach a fragment to skb. skb_gro_receive() can only subtract from skb->truesize the used part of a fragment. I spotted this problem seeing TcpExtPruneCalled and TcpExtTCPRcvCollapsed that were unexpected with a recent kernel, where TCP receive window should be sized properly to accept traffic coming from a driver not overshooting skb->truesize. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03net: flow_dissector: fail on evil iph->ihlJason Wang
commit 6f092343855a71e03b8d209815d8c45bf3a27fcd upstream. We don't validate iph->ihl which may lead a dead loop if we meet a IPIP skb whose iph->ihl is zero. Fix this by failing immediately when iph->ihl is evil (less than 5). This issue were introduced by commit ec5efe7946280d1e84603389a1030ccec0a767ae (rps: support IPIP encapsulation). Cc: Eric Dumazet <edumazet@google.com> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 3.2: the affected code is in __skb_get_rxhash()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03net: core: Always propagate flag changes to interfacesVlad Yasevich
[ Upstream commit d2615bf450694c1302d86b9cc8a8958edfe4c3a4 ] The following commit: b6c40d68ff6498b7f63ddf97cf0aa818d748dee7 net: only invoke dev->change_rx_flags when device is UP tried to fix a problem with VLAN devices and promiscuouse flag setting. The issue was that VLAN device was setting a flag on an interface that was down, thus resulting in bad promiscuity count. This commit blocked flag propagation to any device that is currently down. A later commit: deede2fabe24e00bd7e246eb81cd5767dc6fcfc7 vlan: Don't propagate flag changes on down interfaces fixed VLAN code to only propagate flags when the VLAN interface is up, thus fixing the same issue as above, only localized to VLAN. The problem we have now is that if we have create a complex stack involving multiple software devices like bridges, bonds, and vlans, then it is possible that the flags would not propagate properly to the physical devices. A simple examle of the scenario is the following: eth0----> bond0 ----> bridge0 ---> vlan50 If bond0 or eth0 happen to be down at the time bond0 is added to the bridge, then eth0 will never have promisc mode set which is currently required for operation as part of the bridge. As a result, packets with vlan50 will be dropped by the interface. The only 2 devices that implement the special flag handling are VLAN and DSA and they both have required code to prevent incorrect flag propagation. As a result we can remove the generic solution introduced in b6c40d68ff6498b7f63ddf97cf0aa818d748dee7 and leave it to the individual devices to decide whether they will block flag propagation or not. Reported-by: Stefan Priebe <s.priebe@profihost.ag> Suggested-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-05-13netfilter: don't reset nf_trace in nf_reset()Patrick McHardy
[ Upstream commit 124dff01afbdbff251f0385beca84ba1b9adda68 ] Commit 130549fe ("netfilter: reset nf_trace in nf_reset") added code to reset nf_trace in nf_reset(). This is wrong and unnecessary. nf_reset() is used in the following cases: - when passing packets up the the socket layer, at which point we want to release all netfilter references that might keep modules pinned while the packet is queued. nf_trace doesn't matter anymore at this point. - when encapsulating or decapsulating IPsec packets. We want to continue tracing these packets after IPsec processing. - when passing packets through virtual network devices. Only devices on that encapsulate in IPv4/v6 matter since otherwise nf_trace is not used anymore. Its not entirely clear whether those packets should be traced after that, however we've always done that. - when passing packets through virtual network devices that make the packet cross network namespace boundaries. This is the only cases where we clearly want to reset nf_trace and is also what the original patch intended to fix. Add a new function nf_reset_trace() and use it in dev_forward_skb() to fix this properly. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10net: add a synchronize_net() in netdev_rx_handler_unregister()Eric Dumazet
[ Upstream commit 00cfec37484761a44a3b6f4675a54caa618210ae ] commit 35d48903e97819 (bonding: fix rx_handler locking) added a race in bonding driver, reported by Steven Rostedt who did a very good diagnosis : <quoting Steven> I'm currently debugging a crash in an old 3.0-rt kernel that one of our customers is seeing. The bug happens with a stress test that loads and unloads the bonding module in a loop (I don't know all the details as I'm not the one that is directly interacting with the customer). But the bug looks to be something that may still be present and possibly present in mainline too. It will just be much harder to trigger it in mainline. In -rt, interrupts are threads, and can schedule in and out just like any other thread. Note, mainline now supports interrupt threads so this may be easily reproducible in mainline as well. I don't have the ability to tell the customer to try mainline or other kernels, so my hands are somewhat tied to what I can do. But according to a core dump, I tracked down that the eth irq thread crashed in bond_handle_frame() here: slave = bond_slave_get_rcu(skb->dev); bond = slave->bond; <--- BUG the slave returned was NULL and accessing slave->bond caused a NULL pointer dereference. Looking at the code that unregisters the handler: void netdev_rx_handler_unregister(struct net_device *dev) { ASSERT_RTNL(); RCU_INIT_POINTER(dev->rx_handler, NULL); RCU_INIT_POINTER(dev->rx_handler_data, NULL); } Which is basically: dev->rx_handler = NULL; dev->rx_handler_data = NULL; And looking at __netif_receive_skb() we have: rx_handler = rcu_dereference(skb->dev->rx_handler); if (rx_handler) { if (pt_prev) { ret = deliver_skb(skb, pt_prev, orig_dev); pt_prev = NULL; } switch (rx_handler(&skb)) { My question to all of you is, what stops this interrupt from happening while the bonding module is unloading? What happens if the interrupt triggers and we have this: CPU0 CPU1 ---- ---- rx_handler = skb->dev->rx_handler netdev_rx_handler_unregister() { dev->rx_handler = NULL; dev->rx_handler_data = NULL; rx_handler() bond_handle_frame() { slave = skb->dev->rx_handler; bond = slave->bond; <-- NULL pointer dereference!!! What protection am I missing in the bond release handler that would prevent the above from happening? </quoting Steven> We can fix bug this in two ways. First is adding a test in bond_handle_frame() and others to check if rx_handler_data is NULL. A second way is adding a synchronize_net() in netdev_rx_handler_unregister() to make sure that a rcu protected reader has the guarantee to see a non NULL rx_handler_data. The second way is better as it avoids an extra test in fast path. Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jiri Pirko <jpirko@redhat.com> Cc: Paul E. McKenney <paulmck@us.ibm.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27bridging: fix rx_handlers return codeCristian Bercaru
[ Upstream commit 3bc1b1add7a8484cc4a261c3e128dbe1528ce01f ] The frames for which rx_handlers return RX_HANDLER_CONSUMED are no longer counted as dropped. They are counted as successfully received by 'netif_receive_skb'. This allows network interface drivers to correctly update their RX-OK and RX-DRP counters based on the result of 'netif_receive_skb'. Signed-off-by: Cristian Bercaru <B43982@freescale.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-12-06net-rps: Fix brokeness causing OOO packetsTom Herbert
[ Upstream commit baefa31db2f2b13a05d1b81bdf2d20d487f58b0a ] In commit c445477d74ab3779 which adds aRFS to the kernel, the CPU selected for RFS is not set correctly when CPU is changing. This is causing OOO packets and probably other issues. Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-11-16af-packet: fix oops when socket is not presentEric Leblond
[ Upstream commit a3d744e995d2b936c500585ae39d99ee251c89b4 ] Due to a NULL dereference, the following patch is causing oops in normal trafic condition: commit c0de08d04215031d68fa13af36f347a6cfa252ca Author: Eric Leblond <eric@regit.org> Date:   Thu Aug 16 22:02:58 2012 +0000     af_packet: don't emit packet on orig fanout group This buggy patch was a feature fix and has reached most stable branches. When skb->sk is NULL and when packet fanout is used, there is a crash in match_fanout_group where skb->sk is accessed. This patch fixes the issue by returning false as soon as the socket is NULL: this correspond to the wanted behavior because the kernel as to resend the skb to all the listening socket in this case. Signed-off-by: Eric Leblond <eric@regit.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-30vlan: don't deliver frames for unknown vlans to protocolsFlorian Zumbiehl
[ Upstream commit 48cc32d38a52d0b68f91a171a8d00531edc6a46e ] 6a32e4f9dd9219261f8856f817e6655114cfec2f made the vlan code skip marking vlan-tagged frames for not locally configured vlans as PACKET_OTHERHOST if there was an rx_handler, as the rx_handler could cause the frame to be received on a different (virtual) vlan-capable interface where that vlan might be configured. As rx_handlers do not necessarily return RX_HANDLER_ANOTHER, this could cause frames for unknown vlans to be delivered to the protocol stack as if they had been received untagged. For example, if an ipv6 router advertisement that's tagged for a locally not configured vlan is received on an interface with macvlan interfaces attached, macvlan's rx_handler returns RX_HANDLER_PASS after delivering the frame to the macvlan interfaces, which caused it to be passed to the protocol stack, leading to ipv6 addresses for the announced prefix being configured even though those are completely unusable on the underlying interface. The fix moves marking as PACKET_OTHERHOST after the rx_handler so the rx_handler, if there is one, sees the frame unchanged, but afterwards, before the frame is delivered to the protocol stack, it gets marked whether there is an rx_handler or not. Signed-off-by: Florian Zumbiehl <florz@florz.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-10net: do not disable sg for packets requiring no checksumEd Cashin
[ Upstream commit c0d680e577ff171e7b37dbdb1b1bf5451e851f04 ] A change in a series of VLAN-related changes appears to have inadvertently disabled the use of the scatter gather feature of network cards for transmission of non-IP ethernet protocols like ATA over Ethernet (AoE). Below is a reference to the commit that introduces a "harmonize_features" function that turns off scatter gather when the NIC does not support hardware checksumming for the ethernet protocol of an sk buff. commit f01a5236bd4b140198fbcc550f085e8361fd73fa Author: Jesse Gross <jesse@nicira.com> Date: Sun Jan 9 06:23:31 2011 +0000 net offloading: Generalize netif_get_vlan_features(). The can_checksum_protocol function is not equipped to consider a protocol that does not require checksumming. Calling it for a protocol that requires no checksum is inappropriate. The patch below has harmonize_features call can_checksum_protocol when the protocol needs a checksum, so that the network layer is not forced to perform unnecessary skb linearization on the transmission of AoE packets. Unnecessary linearization results in decreased performance and increased memory pressure, as reported here: http://www.spinics.net/lists/linux-mm/msg15184.html The problem has probably not been widely experienced yet, because only recently has the kernel.org-distributed aoe driver acquired the ability to use payloads of over a page in size, with the patchset recently included in the mm tree: https://lkml.org/lkml/2012/8/28/140 The coraid.com-distributed aoe driver already could use payloads of greater than a page in size, but its users generally do not use the newest kernels. Signed-off-by: Ed Cashin <ecashin@coraid.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-10net: small bug on rxhash calculationChema Gonzalez
[ Upstream commit 6862234238e84648c305526af2edd98badcad1e0 ] In the current rxhash calculation function, while the sorting of the ports/addrs is coherent (you get the same rxhash for packets sharing the same 4-tuple, in both directions), ports and addrs are sorted independently. This implies packets from a connection between the same addresses but crossed ports hash to the same rxhash. For example, traffic between A=S:l and B=L:s is hashed (in both directions) from {L, S, {s, l}}. The same rxhash is obtained for packets between C=S:s and D=L:l. This patch ensures that you either swap both addrs and ports, or you swap none. Traffic between A and B, and traffic between C and D, get their rxhash from different sources ({L, S, {l, s}} for A<->B, and {L, S, {s, l}} for C<->D) The patch is co-written with Eric Dumazet <edumazet@google.com> Signed-off-by: Chema Gonzalez <chema@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-10net: Statically initialize init_net.dev_base_headRustad, Mark D
commit 734b65417b24d6eea3e3d7457e1f11493890ee1d upstream. This change eliminates an initialization-order hazard most recently seen when netprio_cgroup is built into the kernel. With thanks to Eric Dumazet for catching a bug. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19af_packet: don't emit packet on orig fanout groupEric Leblond
[ Upstream commit c0de08d04215031d68fa13af36f347a6cfa252ca ] If a packet is emitted on one socket in one group of fanout sockets, it is transmitted again. It is thus read again on one of the sockets of the fanout group. This result in a loop for software which generate packets when receiving one. This retransmission is not the intended behavior: a fanout group must behave like a single socket. The packet should not be transmitted on a socket if it originates from a socket belonging to the same fanout group. This patch fixes the issue by changing the transmission check to take fanout group info account. Reported-by: Aleksandr Kotov <a1k@mail.ru> Signed-off-by: Eric Leblond <eric@regit.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19net/core: Fix potential memory leak in dev_set_alias()Alexey Khoroshilov
[ Upstream commit 7364e445f62825758fa61195d237a5b8ecdd06ec ] Do not leak memory by updating pointer with potentially NULL realloc return value. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19net: Allow driver to limit number of GSO segments per skbBen Hutchings
[ Upstream commit 30b678d844af3305cda5953467005cebb5d7b687 ] A peer (or local user) may cause TCP to use a nominal MSS of as little as 88 (actual MSS of 76 with timestamps). Given that we have a sufficiently prodigious local sender and the peer ACKs quickly enough, it is nevertheless possible to grow the window for such a connection to the point that we will try to send just under 64K at once. This results in a single skb that expands to 861 segments. In some drivers with TSO support, such an skb will require hundreds of DMA descriptors; a substantial fraction of a TX ring or even more than a full ring. The TX queue selected for the skb may stall and trigger the TX watchdog repeatedly (since the problem skb will be retried after the TX reset). This particularly affects sfc, for which the issue is designated as CVE-2012-3412. Therefore: 1. Add the field net_device::gso_max_segs holding the device-specific limit. 2. In netif_skb_features(), if the number of segments is too high then mask out GSO features to force fall back to software GSO. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-08-10net: feed /dev/random with the MAC address when registering a deviceTheodore Ts'o
commit 7bf2357524408b97fec58344caf7397f8140c3fd upstream. Cc: David Miller <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-07-25net: remove skb_orphan_try()Eric Dumazet
commit 62b1a8ab9b3660bb820d8dfe23148ed6cda38574 upstream. Orphaning skb in dev_hard_start_xmit() makes bonding behavior unfriendly for applications sending big UDP bursts : Once packets pass the bonding device and come to real device, they might hit a full qdisc and be dropped. Without orphaning, the sender is automatically throttled because sk->sk_wmemalloc reaches sk->sk_sndbuf (assuming sk_sndbuf is not too big) We could try to defer the orphaning adding another test in dev_hard_start_xmit(), but all this seems of little gain, now that BQL tends to make packets more likely to be parked in Qdisc queues instead of NIC TX ring, in cases where performance matters. Reverts commits : fc6055a5ba31 net: Introduce skb_orphan_try() 87fd308cfc6b net: skb_tx_hash() fix relative to skb_orphan_try() and removes SKBTX_DRV_NEEDS_SK_REF flag Reported-and-bisected-by: Jean-Michel Hautbois <jhautbois@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 3.2: - Adjust context - SKBTX_WIFI_STATUS is not defined] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-06-10Revert "net: maintain namespace isolation between vlan and real device"David S. Miller
[ Upstream commit 59b9997baba5242997ddc7bd96b1391f5275a5a4 ] This reverts commit 8a83a00b0735190384a348156837918271034144. It causes regressions for S390 devices, because it does an unconditional DST drop on SKBs for vlans and the QETH device needs the neighbour entry hung off the DST for certain things on transmit. Arnd can't remember exactly why he even needed this change. Conflicts: drivers/net/macvlan.c net/8021q/vlan_dev.c net/core/dev.c Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-20net: In unregister_netdevice_notifier unregister the netdevices.Eric W. Biederman
[ Upstream commit 7d3d43dab4e978d8d9ad1acf8af15c9b1c4b0f0f ] We already synthesize events in register_netdevice_notifier and synthesizing events in unregister_netdevice_notifier allows to us remove the need for special case cleanup code. This change should be safe as it adds no new cases for existing callers of unregiser_netdevice_notifier to handle. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11net: fix /proc/net/dev regressionEric Dumazet
[ Upstream commit 2def16ae6b0c77571200f18ba4be049b03d75579 ] Commit f04565ddf52 (dev: use name hash for dev_seq_ops) added a second regression, as some devices are missing from /proc/net/dev if many devices are defined. When seq_file buffer is filled, the last ->next/show() method is canceled (pos value is reverted to value prior ->next() call) Problem is after above commit, we dont restart the lookup at right position in ->start() method. Fix this by removing the internal 'pos' pointer added in commit, since we need to use the 'loff_t *pos' provided by seq_file layer. This also reverts commit 5cac98dd0 (net: Fix corruption in /proc/*/net/dev_mcast), since its not needed anymore. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Mihai Maruseac <mmaruseac@ixiacom.com> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-04-02net: fix napi_reuse_skb() skb reserveEric Dumazet
[ Upstream commit 2a2a459eeeff48640dc557548ce576d666ab06ed ] napi->skb is allocated in napi_get_frags() using netdev_alloc_skb_ip_align(), with a reserve of NET_SKB_PAD + NET_IP_ALIGN bytes. However, when such skb is recycled in napi_reuse_skb(), it ends with a reserve of NET_IP_ALIGN which is suboptimal. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29gro: more generic L2 header checkEric Dumazet
[ Upstream commit 5ca3b72c5da47d95b83857b768def6172fbc080a ] Shlomo Pongratz reported GRO L2 header check was suited for Ethernet only, and failed on IB/ipoib traffic. He provided a patch faking a zeroed header to let GRO aggregates frames. Roland Dreier, Herbert Xu, and others suggested we change GRO L2 header check to be more generic, ie not assuming L2 header is 14 bytes, but taking into account hard_header_len. __napi_gro_receive() has special handling for the common case (Ethernet) to avoid a memcmp() call and use an inline optimized function instead. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Shlomo Pongratz <shlomop@mellanox.com> Cc: Roland Dreier <roland@kernel.org> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-11-30net/core: fix rollback handler in register_netdevice_notifierRongQing.Li
Within nested statements, the break statement terminates only the do, for, switch, or while statement that immediately encloses it, So replace the break with goto. Signed-off-by: RongQing.Li <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-28net: Fix corruption in /proc/*/net/dev_mcastAnton Blanchard
I just hit this during my testing. Isn't there another bug lurking? BUG kmalloc-8: Redzone overwritten INFO: 0xc0000000de9dec48-0xc0000000de9dec4b. First byte 0x0 instead of 0xcc INFO: Allocated in .__seq_open_private+0x30/0xa0 age=0 cpu=5 pid=3896 .__kmalloc+0x1e0/0x2d0 .__seq_open_private+0x30/0xa0 .seq_open_net+0x60/0xe0 .dev_mc_seq_open+0x4c/0x70 .proc_reg_open+0xd8/0x260 .__dentry_open.clone.11+0x2b8/0x400 .do_last+0xf4/0x950 .path_openat+0xf8/0x480 .do_filp_open+0x48/0xc0 .do_sys_open+0x140/0x250 syscall_exit+0x0/0x40 dev_mc_seq_ops uses dev_seq_start/next/stop but only allocates sizeof(struct seq_net_private) of private data, whereas it expects sizeof(struct dev_iter_state): struct dev_iter_state { struct seq_net_private p; unsigned int pos; /* bucket << BUCKET_SPACE + offset */ }; Create dev_seq_open_ops and use it so we don't have to expose struct dev_iter_state. [ Problem added by commit f04565ddf52e4 (dev: use name hash for dev_seq_ops) -Eric ] Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-30vlan: allow nested vlan_do_receive()Eric Dumazet
commit 2425717b27eb (net: allow vlan traffic to be received under bond) broke ARP processing on vlan on top of bonding. +-------+ eth0 --| bond0 |---bond0.103 eth1 --| | +-------+ 52870.115435: skb_gro_reset_offset <-napi_gro_receive 52870.115435: dev_gro_receive <-napi_gro_receive 52870.115435: napi_skb_finish <-napi_gro_receive 52870.115435: netif_receive_skb <-napi_skb_finish 52870.115435: get_rps_cpu <-netif_receive_skb 52870.115435: __netif_receive_skb <-netif_receive_skb 52870.115436: vlan_do_receive <-__netif_receive_skb 52870.115436: bond_handle_frame <-__netif_receive_skb 52870.115436: vlan_do_receive <-__netif_receive_skb 52870.115436: arp_rcv <-__netif_receive_skb 52870.115436: kfree_skb <-arp_rcv Packet is dropped in arp_rcv() because its pkt_type was set to PACKET_OTHERHOST in the first vlan_do_receive() call, since no eth0.103 exists. We really need to change pkt_type only if no more rx_handler is about to be called for the packet. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) mm: memory hotplug: Check if pages are correctly reserved on a per-section basis Revert "memory hotplug: Correct page reservation checking" Update email address for stable patch submission dynamic_debug: fix undefined reference to `__netdev_printk' dynamic_debug: use a single printk() to emit messages dynamic_debug: remove num_enabled accounting dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions uio: Support physical addresses >32 bits on 32-bit systems sysfs: add unsigned long cast to prevent compile warning drivers: base: print rejected matches with DEBUG_DRIVER memory hotplug: Correct page reservation checking memory hotplug: Refuse to add unaligned memory regions remove the messy code file Documentation/zh_CN/SubmitChecklist ARM: mxc: convert device creation to use platform_device_register_full new helper to create platform devices with dma mask docs/driver-model: Update device class docs docs/driver-model: Document device.groups kobj_uevent: Ignore if some listeners cannot handle message dynamic_debug: make netif_dbg() call __netdev_printk() dynamic_debug: make netdev_dbg() call __netdev_printk() ...
2011-10-24Merge branch 'master' of ra.kernel.org:/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-10-24rtnetlink: Add missing manual netlink notification in dev_change_net_namespacesEric W. Biederman
Renato Westphal noticed that since commit a2835763e130c343ace5320c20d33c281e7097b7 "rtnetlink: handle rtnl_link netlink notifications manually" was merged we no longer send a netlink message when a networking device is moved from one network namespace to another. Fix this by adding the missing manual notification in dev_change_net_namespaces. Since all network devices that are processed by dev_change_net_namspaces are in the initialized state the complicated tests that guard the manual rtmsg_ifinfo calls in rollback_registered and register_netdevice are unnecessary and we can just perform a plain notification. Cc: stable@kernel.org Tested-by: Renato Westphal <renatowestphal@gmail.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-21dev: use name hash for dev_seq_opsMihai Maruseac
Instead of using the dev->next chain and trying to resync at each call to dev_seq_start, use the name hash, keeping the bucket and the offset in seq->private field. Tests revealed the following results for ifconfig > /dev/null * 1000 interfaces: * 0.114s without patch * 0.089s with patch * 3000 interfaces: * 0.489s without patch * 0.110s with patch * 5000 interfaces: * 1.363s without patch * 0.250s with patch * 128000 interfaces (other setup): * ~100s without patch * ~30s with patch Signed-off-by: Mihai Maruseac <mmaruseac@ixiacom.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19net: validate HWTSTAMP ioctl parametersRichard Cochran
This patch adds a sanity check on the values provided by user space for the hardware time stamping configuration. If the values lie outside of the absolute limits, then the ioctl request will be denied. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19net: Move rcu_barrier from rollback_registered_many to netdev_run_todo.Eric W. Biederman
This patch moves the rcu_barrier from rollback_registered_many (inside the rtnl_lock) into netdev_run_todo (just outside the rtnl_lock). This allows us to gain the full benefit of sychronize_net calling synchronize_rcu_expedited when the rtnl_lock is held. The rcu_barrier in rollback_registered_many was originally a synchronize_net but was promoted to be a rcu_barrier() when it was found that people were unnecessarily hitting the 250ms wait in netdev_wait_allrefs(). Changing the rcu_barrier back to a synchronize_net is therefore safe. Since we only care about waiting for the rcu callbacks before we get to netdev_wait_allrefs() it is also safe to move the wait into netdev_run_todo. This was tested by creating and destroying 1000 tap devices and observing /proc/lock_stat. /proc/lock_stat reports this change reduces the hold times of the rtnl_lock by a factor of 10. There was no observable difference in the amount of time it takes to destroy a network device. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19net: add skb frag size accessorsEric Dumazet
To ease skb->truesize sanitization, its better to be able to localize all references to skb frags size. Define accessors : skb_frag_size() to fetch frag size, and skb_frag_size_{set|add|sub}() to manipulate it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18net: allow vlan traffic to be received under bondJohn Fastabend
The following configuration used to work as I expected. At least we could use the fcoe interfaces to do MPIO and the bond0 iface to do load balancing or failover. ---eth2.228-fcoe | eth2 -----| | |---- bond0 | eth3 -----| | ---eth3.228-fcoe This worked because of a change we added to allow inactive slaves to rx 'exact' matches. This functionality was kept intact with the rx_handler mechanism. However now the vlan interface attached to the active slave never receives traffic because the bonding rx_handler updates the skb->dev and goto's another_round. Previously, the vlan_do_receive() logic was called before the bonding rx_handler. Now by the time vlan_do_receive calls vlan_find_dev() the skb->dev is set to bond0 and it is clear no vlan is attached to this iface. The vlan lookup fails. This patch moves the VLAN check above the rx_handler. A VLAN tagged frame is now routed to the eth2.228-fcoe iface in the above schematic. Untagged frames continue to the bond0 as normal. This case also remains intact, eth2 --> bond0 --> vlan.228 Here the skb is VLAN tagged but the vlan lookup fails on eth2 causing the bonding rx_handler to be called. On the second pass the vlan lookup is on the bond0 iface and completes as expected. Putting a VLAN.228 on both the bond0 and eth2 device will result in eth2.228 receiving the skb. I don't think this is completely unexpected and was the result prior to the rx_handler result. Note, the same setup is also used for other storage traffic that MPIO is used with eg. iSCSI and similar setups can be contrived without storage protocols. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Jesse Gross <jesse@nicira.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Tested-by: Hans Schillstrom <hams.schillstrom@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-03RPS: Ensure that an expired hardware filter can be re-added laterBen Hutchings
Amir Vadai wrote: > When a stream is paused, and its rule is expired while it is paused, > no new rule will be configured to the HW when traffic resume. [...] > - When stream was resumed, traffic was steered again by RSS, and > because current-cpu was equal to desired-cpu, ndo_rx_flow_steer > wasn't called and no rule was configured to the HW. Fix this by setting the flow's current CPU only in the table for the newly selected RX queue. Reported-and-tested-by: Amir Vadai <amirv@dev.mellanox.co.il> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-28net: rps: fix the support for PPPOEChangli Gao
The upper protocol numbers of PPPOE are different, and should be treated specially. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-09-15net: consolidate and fix ethtool_ops->get_settings callingJiri Pirko
This patch does several things: - introduces __ethtool_get_settings which is called from ethtool code and from drivers as well. Put ASSERT_RTNL there. - dev_ethtool_get_settings() is replaced by __ethtool_get_settings() - changes calling in drivers so rtnl locking is respected. In iboe_get_rate was previously ->get_settings() called unlocked. This fixes it. Also prb_calc_retire_blk_tmo() in af_packet.c had the same problem. Also fixed by calling __dev_get_by_index() instead of dev_get_by_index() and holding rtnl_lock for both calls. - introduces rtnl_lock in bnx2fc_vport_create() and fcoe_vport_create() so bnx2fc_if_create() and fcoe_if_create() are called locked as they are from other places. - use __ethtool_get_settings() in bonding code Signed-off-by: Jiri Pirko <jpirko@redhat.com> v2->v3: -removed dev_ethtool_get_settings() -added ASSERT_RTNL into __ethtool_get_settings() -prb_calc_retire_blk_tmo - use __dev_get_by_index() and lock around it and __ethtool_get_settings() call v1->v2: add missing export_symbol Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> [except FCoE bits] Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15net: copy userspace buffers on device forwardingMichael S. Tsirkin
dev_forward_skb loops an skb back into host networking stack which might hang on the memory indefinitely. In particular, this can happen in macvtap in bridged mode. Copy the userspace fragments to avoid blocking the sender in that case. As this patch makes skb_copy_ubufs extern now, I also added some documentation and made it clear the SKBTX_DEV_ZEROCOPY flag automatically instead of doing it in all callers. This can be made into a separate patch if people feel it's worth it. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24net: convert core to skb paged frag APIsIan Campbell
Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24rps: support IPIP encapsulationEric Dumazet
Skip IPIP header to get proper layer-4 information. Like GRE tunnels, this only works if rxhash is not already provided by the device itself (ethtool -K ethX rxhash off), to allow kernel compute a software rxhash. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-22dynamic_debug: make netdev_dbg() call __netdev_printk()Jason Baron
Previously, if dynamic debug was enabled netdev_dbg() was using dynamic_dev_dbg() to print out the underlying msg. Fix this by making sure netdev_dbg() uses __netdev_printk(). Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22net: vlan: goto another_round instead of calling __netif_receive_skbJiri Pirko
Now, when vlan tag on untagged in non-accelerated path is stripped from skb, headers are reset right away. Benefit from that and avoid calling __netif_receive_skb recursivelly and just use another_round. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-18net: rps: support PPPOE session messagesChangli Gao
Inspect the payload of PPPOE session messages for the 4 tuples to generate skb->rxhash. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-18net: rps: support 802.1QChangli Gao
For the 802.1Q packets, if the NIC doesn't support hw-accel-vlan-rx, RPS won't inspect the internal 4 tuples to generate skb->rxhash, so this kind of traffic can't get any benefit from RPS. This patch adds the support for 802.1Q to RPS. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-17net: remove ndo_set_multicast_list callbackJiri Pirko
Remove no longer used operation. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-17net: introduce IFF_UNICAST_FLT private flagJiri Pirko
Use IFF_UNICAST_FTL to find out if driver handles unicast address filtering. In case it does not, promisc mode is entered. Patch also fixes following drivers: stmmac, niu: support uc filtering and yet it propagated ndo_set_multicast_list bna, benet, pxa168_eth, ks8851, ks8851_mll, ksz884x : has set ndo_set_rx_mode but do not support uc filtering Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-17rps: Inspect GRE encapsulated packets to get flow hashTom Herbert
Crack open GRE packets in __skb_get_rxhash to compute 4-tuple hash on in encapsulated packet. Note that this is used only when the __skb_get_rxhash is taken, in particular only when the device does not compute provide the rxhash (ie. feature is disabled). This was tested by creating a single GRE tunnel between two 16 core AMD machines. 200 netperf TCP_RR streams were ran with 1 byte request and response size. Without patch: 157497 tps, 50/90/99% latencies 1250/1292/1364 usecs With patch: 325896 tps, 50/90/99% latencies 603/848/1169 Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-17rps: Infrastructure in __skb_get_rxhash for deep inspectionTom Herbert
Basics for looking for ports in encapsulated packets in tunnels. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-17rps: Add flag to skb to indicate rxhash is based on L4 tupleTom Herbert
The l4_rxhash flag was added to the skb structure to indicate that the rxhash value was computed over the 4 tuple for the packet which includes the port information in the encapsulated transport packet. This is used by the stack to preserve the rxhash value in __skb_rx_tunnel. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
