path: root/net/can/af_can.c
2012-06-19canfd: add support for CAN FD in PF_CAN coreOliver Hartkopp
- handle ETH_P_CAN and ETH_P_CANFD skbuffs - update sanity checks for CAN and CAN FD - make sure the CAN frame can pass the selected CAN netdevice on send - bump core version and abi version to indicate the new CAN FD support Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-06-19canfd: add new data structures and constantsOliver Hartkopp
- add new struct canfd_frame - check identical element offsets in struct can_frame and struct canfd_frame - new ETH_P_CANFD definition to tag CAN FD skbs correctly - add CAN_MTU and CANFD_MTU definitions for easy frame and mode detection - add CAN[FD]_MAX_[DLC|DLEN] helper constants to remove hard coded values - update existing struct can_frame with helper constants and comments Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-05-23can: update documentation wording error frames -> error messagesOliver Hartkopp
As Heinz-Juergen Oertel pointed out 'CAN error frames' are a already defined term for the CAN protocol violation indication on the wire. To avoid confusion with the error messages created by CAN drivers available via CAN RAW sockets update the documentation and change the naming from 'error frames' to 'error messages' or 'error message frames'. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2011-10-17can: remove references to berlios mailinglistMarc Kleine-Budde
The BerliOS project, which currently hosts our mailinglist, will close with the end of the year. Now take the chance and remove all occurrences of the mailinglist address from the source files. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-09-15net/can/af_can.c: Change del_timer to del_timer_syncrajan.aggarwal85@gmail.com
This is important for SMP platform to check if timer function is executing on other CPU with deleting the timer. Signed-off-by: Rajan Aggarwal <Rajan Aggarwal rajan.aggarwal85@gmail.com> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-17net/can: use printk_ratelimited() instead of printk_ratelimit()Manuel Zerpies
Since printk_ratelimit() shouldn't be used anymore (see comment in include/linux/printk.h), replace it with printk_ratelimited(). Signed-off-by: Manuel Zerpies <manuel.f.zerpies@ww.stud.uni-erlangen.de> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-05-04can: rename can_try_module_get to can_get_protoKurt Van Dijck
can: rename can_try_module_get to can_get_proto can_try_module_get does return a struct can_proto. The name explains what is done in so much detail that a caller may not notice that a struct can_proto is locked/unlocked. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-04can: make struct can_proto constKurt Van Dijck
commit 53914b67993c724cec585863755c9ebc8446e83b had the same message. That commit did put everything in place but did not make can_proto const itself. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-06can: convert protocol handling to RCUOliver Hartkopp
This patch removes spin_locks at CAN socket creation time by using RCU. Inspired by the discussion with Kurt van Dijck and Eric Dumazet the RCU code was partly derived from af_phonet.c Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27can: make struct proto constOliver Hartkopp
can_ioctl is the only reason for struct proto to be non-const. script/check-patch.pl suggests struct proto be const. Setting the reference to the common can_ioctl() in all CAN protocols directly removes the need to make the struct proto writable in af_can.c Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02can: deny filterlist access on non-CAN interfacesOliver Hartkopp
In commit 20dd3850bcf860561496827b711fa10fecf6e787 "can: Speed up CAN frame receiption by using ml_priv" the formerly used hlist of receiver lists for each CAN netdevice has been replaced. The hlist content ensured only CAN netdevices to be accessed by the can_rx_(un)register() functions which accidently dropped away together with the hlist receiver implementation. This patch re-introduces the check for CAN netdevices in can_rx_(un)register(). Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03can: Speed up CAN frame receiption by using ml_privOliver Hartkopp
this patch removes the hlist that contains the CAN receiver filter lists. It uses the 'midlayer private' pointer ml_priv and links the filters directly to the CAN netdevice, which allows to omit the walk through the complete CAN devices hlist for each received CAN frame. This patch is tested and does not remove any locking. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15can: fix NOHZ local_softirq_pending 08 warningOliver Hartkopp
When using nanosleep() in an userspace application we get a ratelimit warning NOHZ: local_softirq_pending 08 for 10 times. The echo of CAN frames is done from process context and softirq context only. Therefore the usage of netif_rx() was wrong (for years). This patch replaces netif_rx() with netif_rx_ni() which has to be used from process/softirq context. It also adds a missing comment that can_send() must no be used from hardirq context. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Urs Thuermann <urs@isnogud.escape.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30can: use correct NET_RX_ return valuesOliver Hartkopp
Dropped skb's should be documented by an appropriate return value. Use the correct NET_RX_DROP and NET_RX_SUCCESS values for that reason. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-14can: Use WARN_ONCE() instead of BUG_ON() for sanity check in receive pathOliver Hartkopp
To ensure a proper handling of CAN frames transported in skbuffs some checks need to be performed at receive time. As stated by Michael Olbrich and Luotao Fu BUG_ON() might be to restrictive. This is right as we can just drop the non conform skbuff and the Kernel can continue working. This patch replaces the BUG_ON() with a WARN_ONCE() so that the system remains healthy but we made the problem visible (once). Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Urs Thuermann <urs@isnogud.escape.de> CC: Michael Olbrich <m.olbrich@pengutronix.de> CC: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-10can: af_can.c use rcu_barrier() on module unload.Jesper Dangaard Brouer
This module uses rcu_call() thus it should use rcu_barrier() on module unload. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Acked-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-17can: Network Drop Monitor: Make use of consume_skb() in af_can.cOliver Hartkopp
Since commit ead2ceb0ec9f85cff19c43b5cdb2f8a054484431 ("Network Drop Monitor: Adding kfree_skb_clean for non-drops and modifying end-of-line points for skbs") so called end-of-line points for skb's should use consume_skb() to free the socket buffer. In opposite to consume_skb() the function kfree_skb() is intended to be used for unexpected skb drops e.g. in error conditions that now can trigger the network drop monitor if enabled. This patch moves the skb end-of-line point in af_can.c to use consume_skb(). Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26can: remove some pointless conditionals before kfree_skb()Wei Yongjun
Remove some pointless conditionals before kfree_skb(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06can: omit unneeded skb_clone() callsOliver Hartkopp
The AF_CAN core delivered always cloned sk_buffs to the AF_CAN protocols, although this was _only_ needed by the can-raw protocol. With this (additionally documented) change, the AF_CAN core calls the callback functions of the registered AF_CAN protocols with the original (uncloned) sk_buff pointer and let's the can-raw protocol do the skb_clone() itself which omits all unneeded skb_clone() calls for other AF_CAN protocols. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04can: omit received RTR frames for single ID filter listsOliver Hartkopp
Since commit d253eee20195b25e298bf162a6e72f14bf4803e5 the single CAN identifier filter lists handle only non-RTR CAN frames. So we need to omit the check of these filter lists when receiving RTR CAN frames. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03can: Fix CAN_(EFF|RTR)_FLAG handling in can_filterOliver Hartkopp
Due to a wrong safety check in af_can.c it was not possible to filter for SFF frames with a specific CAN identifier without getting the same selected CAN identifier from a received EFF frame also. This fix has a minimum (but user visible) impact on the CAN filter API and therefore the CAN version is set to a new date. Indeed the 'old' API is still working as-is. But when now setting CAN_(EFF|RTR)_FLAG in can_filter.can_mask you might get less traffic than before - but still the stuff that you expected to get for your defined filter ... Thanks to Kurt Van Dijck for pointing at this issue and for the review. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)Johannes Berg
Some code here depends on CONFIG_KMOD to not try to load protocol modules or similar, replace by CONFIG_MODULES where more than just request_module depends on CONFIG_KMOD and and also use try_then_request_module in ebtables. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05can: add sanity checksOliver Hartkopp
Even though the CAN netlayer only deals with CAN netdevices, the netlayer interface to the userspace and to the device layer should perform some sanity checks. This patch adds several sanity checks that mainly prevent userspace apps to send broken content into the system that may be misinterpreted by some other userspace application. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Acked-by: Andre Naujoks <nautsch@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08can: Fix can_send() handling on dev_queue_xmit() failuresOliver Hartkopp
The tx packet counting and the local loopback of CAN frames should only happen in the case that the CAN frame has been enqueued to the netdevice tx queue successfully. Thanks to Andre Naujoks <nautsch@gmail.com> for reporting this issue. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Urs Thuermann <urs@isnogud.escape.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-07[CAN]: Move proto_{,un}register() out of spin-locked regionUrs Thuermann
The implementation of proto_register() has changed so that it can now sleep. The call to proto_register() must be moved out of the spin-locked region. Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07[CAN]: Clean up module auto loadingUrs Thuermann
Remove local char array to construct module name. Don't call request_module() when CONFIG_KMOD is not set. Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Add PF_CAN core moduleOliver Hartkopp
This patch adds the CAN core functionality but no protocols or drivers. No protocol implementations are included here. They come as separate patches. Protocol numbers are already in include/linux/can.h. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
