path: root/net/caif
2011-04-11caif: code cleanupStephen Hemminger
Cleanup of new CAIF code. * make local functions static * remove code that is never used * expand get_caif_conf() since wrapper is no longer needed * make args to comparison functions const * rename connect_req_to_link_param to keep exported names consistent Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: performance bugfix - allow radio stack to prioritize packets.Sjur Brændeland
In the CAIF Payload message the Packet Type indication must be set to UNCLASSIFIED in order to allow packet prioritization in the modem's network stack. Otherwise TCP-Ack is not prioritized in the modems transmit queue. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: Bugfix use for_each_safe when removing list nodes.Sjur Brændeland
2011-02-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/netdev.c
2011-02-08net/caif: Fix dangling list pointer in freed object on error.David S. Miller
rtnl_link_ops->setup(), and the "setup" callback passed to alloc_netdev*(), cannot make state changes which need to be undone on failure. There is no cleanup mechanism available at this point. So we have to add the caif private instance to the global list once we are sure that register_netdev() has succedded in ->newlink(). Otherwise, if register_netdev() fails, the caller will invoke free_netdev() and we will have a reference to freed up memory on the chnl_net_list. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net: cleanup unused macros in net directoryShan Wei
Clean up some unused macros in net/*. 1. be left for code change. e.g. PGV_FROM_VMALLOC, PGV_FROM_VMALLOC, KMEM_SAFETYZONE. 2. never be used since introduced to kernel. e.g. P9_RDMA_MAX_SGE, UTIL_CTRL_PKT_SIZE. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-15caif: checking the wrong variableDan Carpenter
In the original code we check if (servl == NULL) twice. The first time should print the message that cfmuxl_remove_uplayer() failed and set "ret" correctly, but instead it just returns success. The second check should be checking the value of "ret" instead of "servl". Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10CAIF: Fix IPv6 support in receive path for GPRS/3GKumar Sanghvi
Checks version field of IP in the receive path for GPRS/3G data and appropriately sets the value of skb->protocol. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-10caif: don't set connection request param size before copying dataDan Rosenberg
The size field should not be set until after the data is successfully copied in. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22Net: caif: Makefile: Remove deprecated itemsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Also, use the ccflags-$ flag instead of EXTRA_CFLAGS because EXTRA_CFLAGS is deprecated and should now be switched. Last but not least, took out if-conditionals. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-03caif: Remove noisy printout when disconnecting caif socketsjur.brandeland@stericsson.com
2010-11-03caif: Bugfix for socket priority, bindtodev and dbg channel.André Carvalho de Matos
Changes: o Bugfix: SO_PRIORITY for SOL_SOCKET could not be handled in caif's setsockopt, using the struct sock attribute priority instead. o Bugfix: SO_BINDTODEVICE for SOL_SOCKET could not be handled in caif's setsockopt, using the struct sock attribute ifindex instead. o Wrong assert statement for RFM layer segmentation. o CAIF Debug channels was not working over SPI, caif_payload_info containing padding info must be initialized. o Check on pointer before dereferencing when unregister dev in caif_dev.c Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/pcmcia/pcnet_cs.c net/caif/caif_socket.c
2010-10-05caif: fix two caif_connect() bugsEric Dumazet
caif_connect() might dereference a netdevice after dev_put() it. It also doesnt check dev_get_by_index() return value and could dereference a NULL pointer. Fix it, using RCU to avoid taking a reference. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05caif: remove duplicated includeNicolas Kaiser
Remove duplicated include. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21caif: Use default send and receive buffer size in caif_socket.Sjur Braendeland
CAIF sockets should use socket's default send and receive buffers sizes. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21caif: Fix function NULL pointer check.Sjur Braendeland
Check that receive function pointer is not null before calling it. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21caif: Minor fixes in log prints.Sjur Braendeland
Use pr_debug for flow control printouts, and refine an error printout. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21caif: Remove buggy re-definition of pr_debugSjur Braendeland
Remove debugging quirk redefining pr_debug to pr_warning. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-06net/caifcaif_dev.c: Use netdev_<level>Joe Perches
Convert pr_<level>("%s" ..., (struct netdev *)->name ...) to netdev_<level>((struct netdev *), ...) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-06net/caif: Use pr_fmtJoe Perches
This patch standardizes caif message logging prefixes. Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s(): " fmt, __func__ Add missing "\n"s to some logging messages Convert pr_warning to pr_warn This changes the logging message prefix from CAIF: to caif: for all uses but caif_socket.c and chnl_net.c. Those now use their filename without extension. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/caif/cfrfml.c: use asm/unaligned.hJeff Mahoney
caif does not build on ia64 starting with 2.6.32-rc1. Using asm/unaligned.h instead of linux/unaligned/le_byteshift.h fixes the issue. include/linux/unaligned/le_byteshift.h:40:50: error: redefinition of 'get_unaligned_le16' include/linux/unaligned/le_byteshift.h:45:50: error: redefinition of 'get_unaligned_le32' include/linux/unaligned/le_byteshift.h:50:50: error: redefinition of 'get_unaligned_le64' include/linux/unaligned/le_byteshift.h:55:51: error: redefinition of 'put_unaligned_le16' include/linux/unaligned/le_byteshift.h:60:51: error: redefinition of 'put_unaligned_le32' include/linux/unaligned/le_byteshift.h:65:51: error: redefinition of 'put_unaligned_le64' include/linux/unaligned/le_struct.h:31:51: note: previous definition of 'put_unaligned_le64' was here Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10caif: Bugfix - Increase default headroom size for control channel.Sjur Braendeland
Headroom size for control channel must be at least 48 bytes in some scenarios. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-22caif: precedence bugDan Carpenter
Negate has precedence over comparison so the original assert only checked that "rfml->fragment_size" was larger than 1 or 0. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29caif: Kconfig and Makefile fixesSjur Braendeland
Use "depends on" instead of "if" in Kconfig files. Fixed CAIF debug flag, and removed unnecessary clean-* options. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-20caif: Add debug connection type for CAIF.Sjur Braendeland
Added new CAIF protocol type CAIFPROTO_DEBUG for accessing CAIF debug on the ST Ericsson modems. There are two debug servers on the modem, one for radio related debug (CAIF_RADIO_DEBUG_SERVICE) and the other for communication/application related debug (CAIF_COM_DEBUG_SERVICE). The debug connection can contain trace debug printouts or interactive debug used for debugging and test. Debug connections can be of type STREAM or SEQPACKET. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-20caif: Use link layer MTU instead of fixed MTUSjur Braendeland
Previously CAIF supported maximum transfer size of ~4050. The transfer size is now calculated dynamically based on the link layers mtu size. Signed-off-by: Sjur Braendeland@stericsson.com Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-20caif: Bugfix - RFM must support segmentation.Sjur Braendeland
CAIF Remote File Manager may send or receive more than 4050 bytes. Due to this The CAIF RFM service have to support segmentation. Signed-off-by: Sjur Braendeland@stericsson.com Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-20caif: Bugfix not all services uses flow-ctrl.Sjur Braendeland
Flow control is not used by all CAIF services. The usage of flow control is now part of the gerneal initialization function for CAIF Services. Signed-off-by: Sjur Braendeland@stericsson.com Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11Merge branch 'master' of ↵David S. Miller
2010-06-09caif: fix a couple range checksDan Carpenter
The extra ! character means that these conditions are always false. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31caif: cleanup: remove duplicate checksDan Carpenter
"phyinfo" can never be null here because we assigned it an address, so I removed both the assert and the second check inside the if statement. I removed the "phyinfo->phy_layer != NULL" check as well because that was asserted earlier. Walter Harms suggested I move the "phyinfo->phy_ref_count++;" outside the if condition for readability, so I have done that. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31caif: remove unneeded null check in caif_connect()Dan Carpenter
We already dereferenced uaddr towards the start of the function when we checked that "uaddr->sa_family != AF_CAIF". Both the check here and the earlier check were added in bece7b2398d0: "caif: Rewritten socket implementation". Before that patch, we assumed that we recieved a valid pointer for uaddr, and based on that, I have removed this check. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-29caif: unlock on error path in cfserl_receive()Dan Carpenter
There was an spin_unlock missing on the error path. The spin_lock was tucked in with the declarations so it was hard to spot. I added a new line. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Brændeland <sjurbren@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23caif: Bugfix - use MSG_TRUNC in receiveSjur Braendeland
Fixed handling when skb don't fit in user buffer, instead of returning -EMSGSIZE, the buffer is truncated (just as unix seqpakcet does). Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23caif: Bugfix - missing spin_unlockSjur Braendeland
Splint found missing spin_unlock. Corrected this an some other trivial split warnings. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23caif: Bugfix - Poll can't return POLLHUP while connecting.Sjur Braendeland
Discovered bug when testing async connect. While connecting poll should not return POLLHUP, but POLLOUT when connected. Also fixed the sysfs flow-control-counters. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23caif: Bugfix - handle mem-allocation failuresSjur Braendeland
Discovered bugs when injecting slab allocation failures. Add checks on all memory allocation. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23caif: Bugfix - use standard Linux listsSjur Braendeland
Discovered bug when running high number of parallel connect requests. Replace buggy home brewed list with linux/list.h. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23caif: Bugfix - wait_ev*_timeout returns long.Sjur Braendeland
Discovered bug when testing on 64bit architecture. Fixed by using long to store result from wait_event_interruptible_timeout. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23net-caif: drop redundant Kconfig entriesMike Frysinger
There is already a submenu entry that is always displayed, so there is no need to also show a dedicated CAIF comment. Drop dead commented code while we're here, and change the submenu text to better match the style everyone else is using. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net/caif: Use kzallocJulia Lawall
Use kzalloc rather than the combination of kmalloc and memset. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28Bugfix: Link selection was swapped in switch.Sjur Braendeland
2010-04-28caif: Bugfixes in CAIF netdevice for close and flow controlSjur Braendeland
Changes: o Bugfix: Flow control was causing the device to be destroyed. o Bugfix: Handle CAIF channel connect failures. o If the underlying link layer is gone the net-device is no longer removed, but closed. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28caif: Rewritten socket implementationSjur Braendeland
Changes: This is a complete re-write of the socket layer. Making the socket implementation more aligned with the other socket layers and using more of the support functions available in sock.c. Lots of code is copied from af_unix (and some from af_irda). Non-blocking mode should be working as well. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28caif: Disconnect without waiting for responseSjur Braendeland
Changes: o Function cfcnfg_disconn_adapt_layer is changed to do asynchronous disconnect, not waiting for any response from the modem. Due to this the function cfcnfg_linkdestroy_rsp does nothing anymore. o Because disconnect may take down a connection before a connect response is received the function cfcnfg_linkup_rsp is checking if the client is still waiting for the response, if not a disconnect request is sent to the modem. o cfctrl is no longer keeping track of pending disconnect requests. o Added function cfctrl_cancel_req, which is used for deleting a pending connect request if disconnect is done before connect response is received. o Removed unused function cfctrl_insert_req2 o Added better handling of connect reject from modem. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28caif: Add reference counting to service layerSjur Braendeland
Changes: o Added functions cfsrvl_get and cfsrvl_put. o Added support release_client to use by socket and net device. o Increase reference counting for in-flight packets from cfmuxl Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
