path: root/net/caif/cfdbgl.c
2010-09-06net/caif: Use pr_fmtJoe Perches
This patch standardizes caif message logging prefixes. Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s(): " fmt, __func__ Add missing "\n"s to some logging messages Convert pr_warning to pr_warn This changes the logging message prefix from CAIF: to caif: for all uses but caif_socket.c and chnl_net.c. Those now use their filename without extension. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-20caif: Bugfix not all services uses flow-ctrl.Sjur Braendeland
Flow control is not used by all CAIF services. The usage of flow control is now part of the gerneal initialization function for CAIF Services. Signed-off-by: Sjur Braendeland@stericsson.com Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net-caif: add CAIF core protocol stackSjur Braendeland
CAIF generic protocol implementation. This layer is somewhat generic in order to be able to use and test it outside the Linux Kernel. cfctrl.c - CAIF control protocol layer cfdbgl.c - CAIF debug protocol layer cfdgml.c - CAIF datagram protocol layer cffrml.c - CAIF framing protocol layer cfmuxl.c - CAIF mux protocol layer cfrfml.c - CAIF remote file manager protocol layer cfserl.c - CAIF serial (fragmentation) protocol layer cfsrvl.c - CAIF generic service layer functions cfutill.c - CAIF utility protocol layer cfveil.c - CAIF AT protocol layer cfvidl.c - CAIF video protocol layer Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
