path: root/net/bridge
2013-02-11bridge: set priority of STP packetsStephen Hemminger
Spanning Tree Protocol packets should have always been marked as control packets, this causes them to get queued in the high prirority FIFO. As Radia Perlman mentioned in her LCA talk, STP dies if bridge gets overloaded and can't communicate. This is a long-standing bug back to the first versions of Linux bridge. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-03bridge: add empty br_mdb_init() and br_mdb_uninit() definitions.Rami Rosen
This patch adds empty br_mdb_init() and br_mdb_uninit() definitions in br_private.h to avoid build failure when CONFIG_BRIDGE_IGMP_SNOOPING is not set. These methods were moved from br_multicast.c to br_netlink.c by commit 3ec8e9f085bcaef0de1077f555c2c5102c223390 Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-03bridge: Correctly unregister MDB rtnetlink handlersVlad Yasevich
Commit 63233159fd4e596568f5f168ecb0879b61631d47: bridge: Do not unregister all PF_BRIDGE rtnl operations introduced a bug where a removal of a single bridge from a multi-bridge system would remove MDB netlink handlers. The handlers should only be removed once all bridges are gone, but since we don't keep track of the number of bridge interfaces, it's simpler to do it when the bridge module is unloaded. To make it consistent, move the registration code into module initialization code path. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-21bridge: call br_netpoll_disable in br_add_ifGao feng
When netdev_set_master faild in br_add_if, we should call br_netpoll_disable to do some cleanup jobs,such as free the memory of struct netpoll which allocated in br_netpoll_enable. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Acked-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19bridge: Correctly encode addresses when dumping mdb entriesVlad Yasevich
When dumping mdb table, set the addresses the kernel returns based on the address protocol type. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Acked-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19bridge: Do not unregister all PF_BRIDGE rtnl operationsVlad Yasevich
Bridge fdb and link rtnl operations are registered in core/rtnetlink. Bridge mdb operations are registred in bridge/mdb. When removing bridge module, do not unregister ALL PF_BRIDGE ops since that would remove the ops from rtnetlink as well. Do remove mdb ops when bridge is destroyed. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-15bridge: add flags to distinguish permanent mdb entiresAmerigo Wang
This patch adds a flag to each mdb entry, so that we can distinguish permanent entries with temporary entries. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-14bridge: remove temporary variable for MLDv2 maximum response code computationAng Way Chuang
As suggested by Stephen Hemminger, this remove the temporary variable introduced in commit eca2a43bb0d2c6ebd528be6acb30a88435abe307 ("bridge: fix icmpv6 endian bug and other sparse warnings") Signed-off-by: Ang Way Chuang <wcang@sfc.wide.ad.jp> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-13bridge: fix icmpv6 endian bug and other sparse warningsstephen hemminger
Fix the warnings reported by sparse on recent bridge multicast changes. Mostly just rcu annotation issues but in this case sparse found a real bug! The ICMPv6 mld2 query mrc values is in network byte order. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-12bridge: add support of adding and deleting mdb entriesCong Wang
This patch implents adding/deleting mdb entries via netlink. Currently all entries are temp, we probably need a flag to distinguish permanent entries too. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-12bridge: notify mdb changes via netlinkCong Wang
As Stephen mentioned, we need to monitor the mdb changes in user-space, so add notifications via netlink too. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-11bridge: fix seq check in br_mdb_dump()Cong Wang
In case of rehashing, introduce a global variable 'br_mdb_rehash_seq' which gets increased every time when rehashing, and assign net->dev_base_seq + br_mdb_rehash_seq to cb->seq. In theory cb->seq could be wrapped to zero, but this is not easy to fix, as net->dev_base_seq is not visible inside br_mdb_rehash(). In practice, this is rare. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Graf <tgraf@suug.ch> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-10bridge: make buffer larger in br_setlink()Dan Carpenter
We pass IFLA_BRPORT_MAX to nla_parse_nested() so we need IFLA_BRPORT_MAX + 1 elements. Also Smatch complains that we read past the end of the array when in br_set_port_flag() when it's called with IFLA_BRPORT_FAST_LEAVE. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-07bridge: export multicast database via netlinkCong Wang
V5: fix two bugs pointed out by Thomas remove seq check for now, mark it as TODO V4: remove some useless #include some coding style fix V3: drop debugging printk's update selinux perm table as well V2: drop patch 1/2, export ifindex directly Redesign netlink attributes Improve netlink seq check Handle IPv6 addr as well This patch exports bridge multicast database via netlink message type RTM_GETMDB. Similar to fdb, but currently bridge-specific. We may need to support modify multicast database too (RTM_{ADD,DEL}MDB). (Thanks to Thomas for patient reviews) Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Graf <tgraf@suug.ch> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Cong Wang <amwang@redhat.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-05bridge: implement multicast fast leaveDavid S. Miller
V3: make it a flag V2: make the toggle per-port Fast leave allows bridge to immediately stops the multicast traffic on the port receives IGMP Leave when IGMP snooping is enabled, no timeouts are observed. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-12-05bridge: implement multicast fast leaveAmerigo Wang
V2: make the toggle per-port Fast leave allows bridge to immediately stops the multicast traffic on the port receives IGMP Leave when IGMP snooping is enabled, no timeouts are observed. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Enable a userns root rtnl calls that are safe for unprivilged usersEric W. Biederman
- Only allow moving network devices to network namespaces you have CAP_NET_ADMIN privileges over. - Enable creating/deleting/modifying interfaces - Enable adding/deleting addresses - Enable adding/setting/deleting neighbour entries - Enable adding/removing routes - Enable adding/removing fib rules - Enable setting the forwarding state - Enable adding/removing ipv6 address labels - Enable setting bridge parameter Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Allow userns root to control the network bridge code.Eric W. Biederman
Allow an unpriviled user who has created a user namespace, and then created a network namespace to effectively use the new network namespace, by reducing capable(CAP_NET_ADMIN) and capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns, CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls. Allow setting bridge paramters via sysfs. Allow all of the bridge ioctls: BRCTL_ADD_IF BRCTL_DEL_IF BRCTL_SET_BRDIGE_FORWARD_DELAY BRCTL_SET_BRIDGE_HELLO_TIME BRCTL_SET_BRIDGE_MAX_AGE BRCTL_SET_BRIDGE_AGING_TIME BRCTL_SET_BRIDGE_STP_STATE BRCTL_SET_BRIDGE_PRIORITY BRCTL_SET_PORT_PRIORITY BRCTL_SET_PATH_COST BRCTL_ADD_BRIDGE BRCTL_DEL_BRDIGE Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Push capable(CAP_NET_ADMIN) into the rtnl methodsEric W. Biederman
- In rtnetlink_rcv_msg convert the capable(CAP_NET_ADMIN) check to ns_capable(net->user-ns, CAP_NET_ADMIN). Allowing unprivileged users to make netlink calls to modify their local network namespace. - In the rtnetlink doit methods add capable(CAP_NET_ADMIN) so that calls that are not safe for unprivileged users are still protected. Later patches will remove the extra capable calls from methods that are safe for unprivilged users. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-14bridge: add root port blockingstephen hemminger
This is Linux bridge implementation of root port guard. If BPDU is received from a leaf (edge) port, it should not be elected as root port. Why would you want to do this? If using STP on a bridge and the downstream bridges are not fully trusted; this prevents a hostile guest for rerouting traffic. Why not just use netfilter? Netfilter does not track of follow spanning tree decisions. It would be difficult and error prone to try and mirror STP resolution in netfilter module. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-14bridge: implement BPDU blockingstephen hemminger
This is Linux bridge implementation of STP protection (Cisco BPDU guard/Juniper BPDU block). BPDU block disables the bridge port if a STP BPDU packet is received. Why would you want to do this? If running Spanning Tree on bridge, hostile devices on the network may send BPDU and cause network failure. Enabling bpdu block will detect and stop this. How to recover the port? The port will be restarted if link is brought down, or removed and reattached. For example: # ip li set dev eth0 down; ip li set dev eth0 up Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-14bridge: add template for bridge port flagsstephen hemminger
Provide macro to build sysfs data structures and functions for accessing flag bits. If flag bits change do netlink notification. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-14bridge: bridge port parameters over netlinkstephen hemminger
Expose bridge port parameter over netlink. By switching to a nested message, this can be used for other bridge parameters. This changes IFLA_PROTINFO attribute from one byte to a full nested set of attributes. This is safe for application interface because the old message used IFLA_PROTINFO and new one uses IFLA_PROTINFO | NLA_F_NESTED. The code adapts to old format requests, and therefore stays compatible with user mode RSTP daemon. Since the type field for nested and unnested attributes are different, and the old code in libnetlink doesn't do the mask, it is also safe to use with old versions of bridge monitor command. Note: although mode is only a boolean, treating it as a full byte since in the future someone will probably want to add more values (like macvlan has). Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-04bridge: Avoid 'statement with no effect' compiler warningsLee Jones
Instead of issuing (0) statements when !CONFIG_SYSFS which will cause 'warning: ', we'll use inline statements instead. This will effectively do the same thing, but suppress any unnecessary warnings. Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: bridge@lists.linux-foundation.org Cc: netdev@vger.kernel.org Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02eth: Rename and properly align br_reserved_address arrayBen Hutchings
Since this array is no longer part of the bridge driver, it should have an 'eth' prefix not 'br'. We also assume that either it's 16-bit-aligned or the architecture has efficient unaligned access. Ensure the first of these is true by explicitly aligning it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02eth: Make is_link_local() consistent with other address testsBen Hutchings
Function name should include '_ether_addr'. Return type should be bool. Parameter name should be 'addr' not 'dest' (also matching kernel-doc). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02bridge: Use is_link_local() in store_group_addr()Ben Hutchings
Parse the string into an array of bytes rather than ints, so we can use is_link_local() rather than reimplementing it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-31Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net-next Jeff Kirsher says: ==================== This series contains updates to ixgbe, ixgbevf, igbvf, igb and networking core (bridge). Most notably is the addition of support for local link multicast addresses in SR-IOV mode to the networking core. Also note, the ixgbe patch "ixgbe: Add support for pipeline reset" and "ixgbe: Fix return value from macvlan filter function" is revised based on community feedback. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-31net: set and query VEB/VEPA bridge mode via PF_BRIDGEJohn Fastabend
Hardware switches may support enabling and disabling the loopback switch which puts the device in a VEPA mode defined in the IEEE 802.1Qbg specification. In this mode frames are not switched in the hardware but sent directly to the switch. SR-IOV capable NICs will likely support this mode I am aware of at least two such devices. Also I am told (but don't have any of this hardware available) that there are devices that only support VEPA modes. In these cases it is important at a minimum to be able to query these attributes. This patch adds an additional IFLA_BRIDGE_MODE attribute that can be set and dumped via the PF_BRIDGE:{SET|GET}LINK operations. Also anticipating bridge attributes that may be common for both embedded bridges and software bridges this adds a flags attribute IFLA_BRIDGE_FLAGS currently used to determine if the command or event is being generated to/from an embedded bridge or software bridge. Finally, the event generation is pulled out of the bridge module and into rtnetlink proper. For example using the macvlan driver in VEPA mode on top of an embedded switch requires putting the embedded switch into a VEPA mode to get the expected results. -------- -------- | VEPA | | VEPA | <-- macvlan vepa edge relays -------- -------- | | | | ------------------ | VEPA | <-- embedded switch in NIC ------------------ | | ------------------- | external switch | <-- shiny new physical ------------------- switch with VEPA support A packet sent from the macvlan VEPA at the top could be loopbacked on the embedded switch and never seen by the external switch. So in order for this to work the embedded switch needs to be set in the VEPA state via the above described commands. By making these attributes nested in IFLA_AF_SPEC we allow future extensions to be made as needed. CC: Lennert Buytenhek <buytenh@wantstofly.org> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-31net: create generic bridge opsJohn Fastabend
The PF_BRIDGE:RTM_{GET|SET}LINK nlmsg family and type are currently embedded in the ./net/bridge module. This prohibits them from being used by other bridging devices. One example of this being hardware that has embedded bridging components. In order to use these nlmsg types more generically this patch adds two net_device_ops hooks. One to set link bridge attributes and another to dump the current bride attributes. ndo_bridge_setlink() ndo_bridge_getlink() CC: Lennert Buytenhek <buytenh@wantstofly.org> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-29net, ixgbe: handle link local multicast addresses in SR-IOV modeJohn Fastabend
In SR-IOV mode the PF driver acts as the uplink port and is used to send control packets e.g. lldpad, stp, etc. eth0.1 eth0.2 eth0 VF VF PF | | | <-- stand-in for uplink | | | -------------------------- | Embedded Switch | -------------------------- | MAC <-- uplink But the embedded switch is setup to forward multicast addresses to all interfaces both VFs and PF and onto the physical link. This results in reserved MAC addresses used by control protocols to be forwarded over the switch onto the VF. In the LLDP case the PF sends an LLDPDU and it is currently being forwarded to all the VFs who then see the PF as a peer. This is incorrect. This patch adds the multicast addresses to the RAR table in the hardware to prevent this behavior. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com> Tested-by: Sibai Li <sibai.li@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2012-10-10bridge: Pull ip header into skb->data before looking into ip header.Sarveshwar Bandi
If lower layer driver leaves the ip header in the skb fragment, it needs to be first pulled into skb->data before inspecting ip header length or ip version number. Signed-off-by: Sarveshwar Bandi <sarveshwar.bandi@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-01netlink: add attributes to fdb interfacestephen hemminger
Later changes need to be able to refer to neighbour attributes when doing fdb_add. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19netdev: make address const in device address managementstephen hemminger
The internal functions for add/deleting addresses don't change their argument. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/netfilter/nfnetlink_log.c net/netfilter/xt_LOG.c Rather easy conflict resolution, the 'net' tree had bug fixes to make sure we checked if a socket is a time-wait one or not and elide the logging code if so. Whereas on the 'net-next' side we are calculating the UID and GID from the creds using different interfaces due to the user namespace changes from Eric Biederman. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-12netfilter: log: Fix log-level processingJoe Perches
auto75914331@hushmail.com reports that iptables does not correctly output the KERN_<level>. $IPTABLES -A RULE_0_in -j LOG --log-level notice --log-prefix "DENY in: " result with linux 3.6-rc5 Sep 12 06:37:29 xxxxx kernel: <5>DENY in: IN=eth0 OUT= MAC=....... result with linux 3.5.3 and older: Sep 9 10:43:01 xxxxx kernel: DENY in: IN=eth0 OUT= MAC...... commit 04d2c8c83d0 ("printk: convert the format for KERN_<LEVEL> to a 2 byte pattern") updated the syslog header style but did not update netfilter uses. Do so. Use KERN_SOH and string concatenation instead of "%c" KERN_SOH_ASCII as suggested by Eric Dumazet. Signed-off-by: Joe Perches <joe@perches.com> cc: auto75914331@hushmail.com Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-08netlink: hide struct module parameter in netlink_kernel_createPablo Neira Ayuso
This patch defines netlink_kernel_create as a wrapper function of __netlink_kernel_create to hide the struct module *me parameter (which seems to be THIS_MODULE in all existing netlink subsystems). Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-22Merge git://1984.lsi.us.es/nf-nextDavid S. Miller
Pablo Neira Ayuso says: ==================== This is the first batch of Netfilter and IPVS updates for your net-next tree. Mostly cleanups for the Netfilter side. They are: * Remove unnecessary RTNL locking now that we have support for namespace in nf_conntrack, from Patrick McHardy. * Cleanup to eliminate unnecessary goto in the initialization path of several Netfilter tables, from Jean Sacren. * Another cleanup from Wu Fengguang, this time to PTR_RET instead of if IS_ERR then return PTR_ERR. * Use list_for_each_entry_continue_rcu in nf_iterate, from Michael Wang. * Add pmtu_disc sysctl option to disable PMTU in their tunneling transmitter, from Julian Anastasov. * Generalize application protocol registration in IPVS and modify IPVS FTP helper to use it, from Julian Anastasov. * update Kconfig. The IPVS FTP helper depends on the Netfilter FTP helper for NAT support, from Julian Anastasov. * Add logic to update PMTU for IPIP packets in IPVS, again from Julian Anastasov. * A couple of sparse warning fixes for IPVS and Netfilter from Claudiu Ghioc and Patrick McHardy respectively. Patrick's IPv6 NAT changes will follow after this batch, I need to flush this batch first before refreshing my tree. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-08-15bridge: fix rcu dereference outside of rcu_read_lockStephen Hemminger
Alternative solution for problem found by Linux Driver Verification project (linuxtesting.org). As it noted in the comment before the br_handle_frame_finish function, this function should be called under rcu_read_lock. The problem callgraph: br_dev_xmit -> br_nf_pre_routing_finish_bridge_slow -> -> br_handle_frame_finish -> br_port_get_rcu -> rcu_dereference And in this case there is no read-lock section. Reported-by: Denis Efremov <yefremov.denis@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: check netpoll tx status on the right deviceAmerigo Wang
Although this doesn't matter actually, because netpoll_tx_running() doesn't use the parameter, the code will be more readable. For team_dev_queue_xmit() we have to move it down to avoid compile errors. Cc: David Miller <davem@davemloft.net> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14bridge: use list_for_each_entry() in netpoll functionsAmerigo Wang
We don't delete 'p' from the list in the loop, so we can just use list_for_each_entry(). Cc: David Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14bridge: add some comments for NETDEV_RELEASEAmerigo Wang
Add comments on why we don't notify NETDEV_RELEASE. Cc: David Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: make __netpoll_cleanup non-blockAmerigo Wang
Like the previous patch, slave_disable_netpoll() and __netpoll_cleanup() may be called with read_lock() held too, so we should make them non-block, by moving the cleanup and kfree() to call_rcu_bh() callbacks. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: use GFP_ATOMIC in slave_enable_netpoll() and __netpoll_setup()Amerigo Wang
slave_enable_netpoll() and __netpoll_setup() may be called with read_lock() held, so should use GFP_ATOMIC to allocate memory. Eric suggested to pass gfp flags to __netpoll_setup(). Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netfilter: PTR_RET can be usedWu Fengguang
This quiets the coccinelle warnings: net/bridge/netfilter/ebtable_filter.c:107:1-3: WARNING: PTR_RET can be used net/bridge/netfilter/ebtable_nat.c:107:1-3: WARNING: PTR_RET can be used net/ipv6/netfilter/ip6table_filter.c:65:1-3: WARNING: PTR_RET can be used net/ipv6/netfilter/ip6table_mangle.c:100:1-3: WARNING: PTR_RET can be used net/ipv6/netfilter/ip6table_raw.c:44:1-3: WARNING: PTR_RET can be used net/ipv6/netfilter/ip6table_security.c:62:1-3: WARNING: PTR_RET can be used net/ipv4/netfilter/iptable_filter.c:72:1-3: WARNING: PTR_RET can be used net/ipv4/netfilter/iptable_mangle.c:107:1-3: WARNING: PTR_RET can be used net/ipv4/netfilter/iptable_raw.c:51:1-3: WARNING: PTR_RET can be used net/ipv4/netfilter/iptable_security.c:70:1-3: WARNING: PTR_RET can be used Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-08-09time: jiffies_delta_to_clock_t() helper to the rescueEric Dumazet
Various /proc/net files sometimes report crazy timer values, expressed in clock_t units. This happens when an expired timer delta (expires - jiffies) is passed to jiffies_to_clock_t(). This function has an overflow in : return div_u64((u64)x * TICK_NSEC, NSEC_PER_SEC / USER_HZ); commit cbbc719fccdb8cb (time: Change jiffies_to_clock_t() argument type to unsigned long) only got around the problem. As we cant output negative values in /proc/net/tcp without breaking various tools, I suggest adding a jiffies_delta_to_clock_t() wrapper that caps the negative delta to a 0 value. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Maciej Żenczykowski <maze@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: hank <pyu@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-30bridge: make port attributes conststephen hemminger
Simple table that can be marked const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22net: fix race condition in several drivers when reading statsKevin Groeneveld
Fix race condition in several network drivers when reading stats on 32bit UP architectures. These drivers update their stats in a BH context and therefore should use u64_stats_fetch_begin_bh/u64_stats_fetch_retry_bh instead of u64_stats_fetch_begin/u64_stats_fetch_retry when reading the stats. Signed-off-by: Kevin Groeneveld <kgroeneveld@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
