Add a per-port flag to control the unknown multicast flood, similar to the
unknown unicast flood flag and break a few long lines in the netlink flag
exports.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
When I added support to export the vlan entry flags via xstats I forgot to
add support for the pvid since it is manually matched, so check if the
entry matches the vlan_group's pvid and set the flag appropriately.
Use one of the vlan xstats padding fields to export the vlan flags. This is
needed in order to be able to distinguish between master (bridge) and port
vlan entries in user-space when dumping the bridge vlan stats.
In the bridge driver we usually have the same function working for both
port and bridge. In order to follow that logic and also avoid code
duplication, consolidate the bridge_ and brport_ linkxstats calls into
one since they share most of their code. As a side effect this allows us
to dump the vlan stats also via the slave call which is in preparation for
the upcoming per-port vlan stats and vlan flag dumping.
This patch adds stats support for the currently used IGMP/MLD types by the
bridge. The stats are per-port (plus one stat per-bridge) and per-direction
(RX/TX). The stats are exported via netlink via the new linkxstats API
(RTM_GETSTATS). In order to minimize the performance impact, a new option
is used to enable/disable the stats - multicast_stats_enabled, similar to
the recent vlan stats. Also in order to avoid multiple IGMP/MLD type
lookups and checks, we make use of the current "igmp" member of the bridge
private skb->cb region to record the type on Rx (both host-generated and
external packets pass by multicast_rcv()). We can do that since the igmp
member was used as a boolean and all the valid IGMP/MLD types are positive
values. The normal bridge fast-path is not affected at all, the only
affected paths are the flooding ones and since we make use of the IGMP/MLD
type, we can quickly determine if the packet should be counted using
cache-hot data (cb's igmp member). We add counters for:
* IGMP Queries
* IGMP Leaves
* IGMP v1/v2/v3 reports
* MLD Queries
* MLD Leaves
* MLD v1/v2 reports
These are invaluable when monitoring or debugging complex multicast setups
with bridges.
This patch adds support for the IFLA_STATS_LINK_XSTATS_SLAVE attribute
which allows to export per-slave statistics if the master device supports
the linkxstats callback. The attribute is passed down to the linkxstats
callback and it is up to the callback user to use it (an example has been
added to the only current user - the bridge). This allows us to query only
specific slaves of master devices like bridge ports and export only what
we're interested in instead of having to dump all ports and searching only
for a single one. This will be used to export per-port IGMP/MLD stats and
also per-port vlan stats in the future, possibly other statistics as well.
I made a dumb off-by-one mistake when I added the vlan stats counter
dumping code. The increment should happen before the check, not after
otherwise we miss one entry when we continue dumping.
Fixes: a60c090361ea ("bridge: netlink: export per-vlan stats")
Add a new LINK_XSTATS_TYPE_BRIDGE attribute and implement the
RTM_GETSTATS callbacks for IFLA_STATS_LINK_XSTATS (fill_linkxstats and
get_linkxstats_size) in order to export the per-vlan stats.
The paddings were added because soon these fields will be needed for
per-port per-vlan stats (or something else if someone beats me to it) so
avoiding at least a few more netlink attributes.
Add support for per-VLAN Tx/Rx statistics. Every global vlan context gets
allocated a per-cpu stats which is then set in each per-port vlan context
for quick access. The br_allowed_ingress() common function is used to
account for Rx packets and the br_handle_vlan() common function is used
to account for Tx packets. Stats accounting is performed only if the
bridge-wide vlan_stats_enabled option is set either via sysfs or netlink.
A struct hole between vlan_enabled and vlan_proto is used for the new
option so it is in the same cache line. Currently it is binary (on/off)
but it is intentionally restricted to exactly 0 and 1 since other values
will be used in the future for different purposes (e.g. per-port stats).
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Remove the shared br_log_state function and print the info directly in
br_set_state, where the net_bridge_port state is actually changed.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Acked-by: Ido Schimmel <idosch@mellanox.com>
if_nlmsg_size() overestimates the minimum allocation size of netlink
dump request (when called from rtnl_calcit()) or the size of the
message (when called from rtnl_getlink()). This is because
ext_filter_mask is not supported by rtnl_link_get_af_size() and
rtnl_link_get_size().
The over-estimation is significant when at least one netdev has many
VLANs configured (8 bytes for each configured VLAN).
This patch-set "rightsizes" the protocol specific attribute size
calculation by propagating ext_filter_mask to rtnl_link_get_af_size()
and adding this a argument to get_link_af_size op in rtnl_af_ops.
Bridge module already used filtering aware sizing for notifications.
br_get_link_af_size_filtered() is consistent with the modified
get_link_af_size op so it replaces br_get_link_af_size() in br_af_ops.
br_get_link_af_size() becomes unused and thus removed.
Signed-off-by: Ronen Arad <ronen.arad@intel.com>
Acked-by: Sridhar Samudrala <sridhar.samudrala@intel.com>
br_fill_ifinfo is called by br_ifinfo_notify which can be called from
many contexts with different locks held, sometimes it relies upon
bridge's spinlock only which is a problem for the vlan code, so use
explicitly rcu for that to avoid problems.
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
The bridge and port's vlgrp member is already used in RCU way, currently
we rely on the fact that it cannot disappear while the port exists but
that is error-prone and we might miss places with improper locking
(either RCU or RTNL must be held to walk the vlan_list). So make it
official and use RCU for vlgrp to catch offenders. Introduce proper vlgrp
accessors and use them consistently throughout the code.
Currently it's possible for someone to send a vlan range to the kernel
with the pvid flag set which will result in the pvid bouncing from a
vlan to vlan and isn't correct, it also introduces problems for hardware
where it doesn't make sense having more than 1 pvid. iproute2 already
enforces this, so let's enforce it on kernel-side as well.
Reported-by: Elad Raz <eladr@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Use SWITCHDEV_F_SKIP_EOPNOTSUPP to skip over ports in bridge that don't
support setting ageing_time (or setting bridge attrs in general).
If push fails, don't update ageing_time in bridge and return err to user.
If push succeeds, update ageing_time in bridge and run gc_timer now to
recalabrate when to run gc_timer next, based on new ageing_time.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Add IFLA_BRPORT_MULTICAST_ROUTER to allow setting/getting port's
multicast_router via netlink.
Add IFLA_BRPORT_FLUSH to allow flushing port's fdb similar to sysfs's
flush.
Add the following attributes in order to export port's timer values:
IFLA_BRPORT_MESSAGE_AGE_TIMER, IFLA_BRPORT_FORWARD_DELAY_TIMER and
IFLA_BRPORT_HOLD_TIMER.
Add IFLA_BRPORT_TOPOLOGY_CHANGE_ACK and IFLA_BRPORT_CONFIG_PENDING to
allow getting port's topology_change_ack and config_pending respectively
via netlink.
Add IFLA_BRPORT_(ID|NO) to allow getting port's port_id and port_no
respectively via netlink.
Add IFLA_BRPORT_DESIGNATED_(COST|PORT) to allow getting the port's
designated cost and port respectively via netlink.
Add IFLA_BRPORT_BRIDGE_ID to allow getting the designated bridge id via
netlink.
Add IFLA_BRPORT_ROOT_ID to allow getting the designated root id via
netlink.
When KASAN is enabled the frame size grows > 2048 bytes and we get a
warning, so make it smaller.
net/bridge/br_netlink.c: In function 'br_fill_info':
>> net/bridge/br_netlink.c:1110:1: warning: the frame size of 2160 bytes
>> is larger than 2048 bytes [-Wframe-larger-than=]
Add IFLA_BR_VLAN_DEFAULT_PVID to allow setting/getting bridge's
default_pvid via netlink.
Add support to allow getting/setting netfilter tables settings.
Currently these are IFLA_BR_NF_CALL_IPTABLES, IFLA_BR_NF_CALL_IP6TABLES
and IFLA_BR_NF_CALL_ARPTABLES.
Add support to set/get all of the igmp's configurable intervals via
netlink. These currently are:
IFLA_BR_MCAST_LAST_MEMBER_INTVL
IFLA_BR_MCAST_MEMBERSHIP_INTVL
IFLA_BR_MCAST_QUERIER_INTVL
IFLA_BR_MCAST_QUERY_INTVL
IFLA_BR_MCAST_QUERY_RESPONSE_INTVL
IFLA_BR_MCAST_STARTUP_QUERY_INTVL
Add IFLA_BR_MCAST_STARTUP_QUERY_CNT to allow setting/getting
br->multicast_startup_query_count via netlink. Also align the ifla
comments.
Add IFLA_BR_MCAST_LAST_MEMBER_CNT to allow setting/getting
br->multicast_last_member_count via netlink.
Add IFLA_BR_MCAST_HASH_MAX to allow setting/getting br->hash_max via
netlink.
Add IFLA_BR_MCAST_HASH_ELASTICITY to allow setting/getting
br->hash_elasticity via netlink.
Add IFLA_BR_MCAST_QUERIER to allow setting/getting br->multicast_querier
via netlink.
Add IFLA_BR_MCAST_QUERY_USE_IFADDR to allow setting/getting
br->multicast_query_use_ifaddr via netlink.
Add IFLA_BR_MCAST_SNOOPING to allow enabling/disabling multicast
snooping via netlink.
Add IFLA_BR_MCAST_ROUTER to allow setting and retrieving
br->multicast_router when igmp snooping is enabled.
Simple attribute that flushes the bridge's fdb.
Add IFLA_BR_GROUP_ADDR attribute to allow setting and retrieving the
group_addr via netlink.
Export the following bridge timers (also exported via sysfs):
IFLA_BR_HELLO_TIMER, IFLA_BR_TCN_TIMER, IFLA_BR_TOPOLOGY_CHANGE_TIMER,
IFLA_BR_GC_TIMER via netlink.
Add IFLA_BR_TOPOLOGY_CHANGE and IFLA_BR_TOPOLOGY_CHANGE_DETECTED and
export them via netlink.
Add IFLA_BR_ROOT_PATH_COST and export it via netlink.
Add IFLA_BR_ROOT_PORT and export it via netlink.
Add IFLA_BR_BRIDGE_ID and export br->bridge_id via netlink.
Add IFLA_BR_ROOT_ID and export br->designated_root via netlink. For this
purpose add struct ifla_bridge_id that would represent struct bridge_id.
Add IFLA_BR_GROUP_FWD_MASK attribute to allow setting and retrieving the
group_fwd_mask via netlink.
When I did the conversion to rhashtable I missed the required locking of
one important user of the vlan list - br_get_link_af_size_filtered()
which is called:
br_ifinfo_notify() -> br_nlmsg_size() -> br_get_link_af_size_filtered()
and the notifications can be sent without holding rtnl. Before this
conversion the function relied on using rcu and since we already use rcu to
destroy the vlans, we can simply migrate the list to use the rcu helpers.
One obvious way to converge more code (which was also used by the
previous vlan code) is to move pvid inside net_bridge_vlan_group. This
allows us to simplify some and remove other port-specific functions.
Also gives us the ability to simply pass the vlan group and use all of the
contained information.
This patch changes the bridge vlan implementation to use rhashtables
instead of bitmaps. The main motivation behind this change is that we
need extensible per-vlan structures (both per-port and global) so more
advanced features can be introduced and the vlan support can be
extended. I've tried to break this up but the moment net_port_vlans is
changed and the whole API goes away, thus this is a larger patch.
A few short goals of this patch are:
- Extensible per-vlan structs stored in rhashtables and a sorted list
- Keep user-visible behaviour (compressed vlans etc)
- Keep fastpath ingress/egress logic the same (optimizations to come
later)
Here's a brief list of some of the new features we'd like to introduce:
- per-vlan counters
- vlan ingress/egress mapping
- per-vlan igmp configuration
- vlan priorities
- avoid fdb entries replication (e.g. local fdb scaling issues)
The structure is kept single for both global and per-port entries so to
avoid code duplication where possible and also because we'll soon introduce
"port0 / aka bridge as port" which should simplify things further
(thanks to Vlad for the suggestion!).
Now we have per-vlan global rhashtable (bridge-wide) and per-vlan port
rhashtable, if an entry is added to a port it'll get a pointer to its
global context so it can be quickly accessed later. There's also a
sorted vlan list which is used for stable walks and some user-visible
behaviour such as the vlan ranges, also for error paths.
VLANs are stored in a "vlan group" which currently contains the
rhashtable, sorted vlan list and the number of "real" vlan entries.
A good side-effect of this change is that it resembles how hw keeps
per-vlan data.
One important note after this change is that if a VLAN is being looked up
in the bridge's rhashtable for filtering purposes (or to check if it's an
existing usable entry, not just a global context) then the new helper
br_vlan_should_use() needs to be used if the vlan is found. In case the
lookup is done only with a port's vlan group, then this check can be
skipped.
Things tested so far:
- basic vlan ingress/egress
- pvids
- untagged vlans
- undef CONFIG_BRIDGE_VLAN_FILTERING
- adding/deleting vlans in different scenarios (with/without global ctx,
while transmitting traffic, in ranges etc)
- loading/removing the module while having/adding/deleting vlans
- extracting bridge vlan information (user ABI), compressed requests
- adding/deleting fdbs on vlans
- bridge mac change, promisc mode
- default pvid change
- kmemleak ON during the whole time
Remove the unnecessary switchdev.h include from br_netlink.c.
Acked-by: Jiri Pirko <jiri@resnulli.us>
This enables bridge vlan_protocol to be configured through netlink.
When CONFIG_BRIDGE_VLAN_FILTERING is disabled, kernel behaves the
same way as this feature is not implemented.
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
