path: root/net/bridge/br_ioctl.c
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-04bridge: range check STP parametersstephen hemminger
Apply restrictions on STP parameters based 802.1D 1998 standard. * Fixes missing locking in set path cost ioctl * Uses common code for both ioctl and sysfs This is based on an earlier patch Sasikanth V but with overhaul. Note: 1. It does NOT enforce the restriction on the relationship max_age and forward delay or hello time because in existing implementation these are set as independant operations. 2. If STP is disabled, there is no restriction on forward delay 3. No restriction on holding time because users use Linux code to act as hub or be sticky. 4. Although standard allow 0-255, Linux only allows 0-63 for port priority because more bits are reserved for port number. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: change console message interfacestephen hemminger
Use one set of macro's for all bridge messages. Note: can't use netdev_XXX macro's because bridge is purely virtual and has no device parent. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-05bridge: remove dev_put() in add_del_if()Eric Dumazet
add_del_if() is called with RTNL, we can use __dev_get_by_index() instead of [dev_get_by_index() + dev_put()] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: net/mac80211/mlme.c
2008-09-08netns bridge: allow bridges in netns!Alexey Dobriyan
Bridge as netdevice doesn't cross netns boundaries. Bridge ports and bridge itself live in same netns. Notifiers are fixed. netns propagated from userspace socket for setup and teardown. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Stephen Hemminger <shemming@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08bridge: don't allow setting hello time to zeroStephen Hemminger
Dushan Tcholich reports that on his system ksoftirqd can consume between %6 to %10 of cpu time, and cause ~200 context switches per second. He then correlated this with a report by bdupree@techfinesse.com: http://marc.info/?l=linux-kernel&m=119613299024398&w=2 and the culprit cause seems to be starting the bridge interface. In particular, when starting the bridge interface, his scripts are specifying a hello timer interval of "0". The bridge hello time can't be safely set to values less than 1 second, otherwise it is possible to end up with a runaway timer. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[NET]: Rework dev_base via list_head (v3)Pavel Emelianov
Cleanup of dev_base list use, with the aim to simplify making device list per-namespace. In almost every occasion, use of dev_base variable and dev->next pointer could be easily replaced by for_each_netdev loop. A few most complicated places were converted to using first_netdev()/next_netdev(). Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25bridge: add support for user mode STPStephen Hemminger
This patchset based on work by Aji_Srinivas@emc.com provides allows spanning tree to be controled from userspace. Like hotplug, it uses call_usermodehelper when spanning tree is enabled so there is no visible API change. If call to start usermode STP fails it falls back to existing kernel STP. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
2007-02-28[BRIDGE]: Fix locking of set path cost.Stephen Hemminger
This change goes with earlier change to get rid of work queue for path cost. Now stp_set_path_cost does its own locking. This is to allow it to call br_path_cost() which calls ethtool interfaces (might sleep). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] BRIDGE: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-28[PATCH] bridge: fix possible overflow in get_fdb_entriesChris Wright
Make sure to properly clamp maxnum to avoid overflow Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Eugene Teo <eteo@redhat.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
