path: root/net/batman-adv/soft-interface.c
2013-05-29batman-adv: change VID semantic in the BLA codeAntonio Quartulli
In order to make batman-adv fully vlan aware later, the semantic used for variables storing the VLAN ID values has to be changed in order to be adapted to the new one which will be used batman-adv wide. In particular, the VID has to be an "_unsigned_ short int" and its 4 MSB will be used as a flag bitfield, while the remaining 12 bits are used to store the real VID value Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Acked-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
2013-05-29batman-adv: use eth_hdr() when it makes senseAntonio Quartulli
Instead of casting the result of skb_mac_header() to "struct ethhdr *" every time, the eth_hdr inline function can be use to beautify the code and improve its readability. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2013-05-21batman-adv: Avoid double freeing of bat_countersMartin Hundebøll
On errors in batadv_mesh_init(), bat_counters will be freed in both batadv_mesh_free() and batadv_softif_init_late(). This patch fixes this by returning earlier from batadv_softif_init_late() in case of errors in batadv_mesh_init() and by setting bat_counters to NULL after freeing. Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-04-22batman-adv: fix global protection fault during soft_iface destructionAntonio Quartulli
batadv_mesh_free() schedules some RCU callbacks which need the bat_priv struct to do their jobs, while free_netdev(), which is called immediately after, is destroying the private data. Put an rcu_barrier() in the middle so that free_netdev() is invoked only after all the callbacks returned. This bug has been introduced by ab8f433dd39be94e8617cff2dfe9f7eca162eb15 ("batman-adv: Move deinitialization of soft-interface to destructor") Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-27batman-adv: Allow to modify slaves of soft-interfaces through rntl_linkSven Eckelmann
The sysfs configuration interface of batman-adv to add/remove slaves of an soft-iface is not deadlock free and doesn't follow the currently common way to modify slaves of an interface. An additional configuration interface though rtnl_link is introduced which provides easy device adding/removing with tools like "ip": $ ip link set dev eth0 master bat0 $ ip link set dev eth0 nomaster Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-27batman-adv: Allow to use rntl_link for device creation/deletionSven Eckelmann
The sysfs configuration interface of batman-adv to add/remove soft-interfaces is not deadlock free and doesn't follow the currently common way to create new virtual interfaces. An additional interface though rtnl_link is introduced which provides easy device creation/deletion with tools like "ip": $ ip link add dev bat0 type batadv $ ip link del dev bat0 Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-27batman-adv: rename batadv_softif_destroy to reflect sysfs use caseMarek Lindner
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> CC: Sven Eckelmann <sven@narfation.org> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-27batman-adv: Move deinitialization of soft-interface to destructorSven Eckelmann
The deinitialization of the soft-interface created in ndo_init/constructor should be done in the destructor and not directly before calling unregister_netdevice Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-27batman-adv: Move soft-interface initialization to ndo_initSven Eckelmann
The initialization of an net_device object should be done in the init/constructor function and not from the outside after the register_netdevice was done to avoid race conditions. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-13batman-adv: network coding - receive coded packets and decode themMartin Hundebøll
When receiving a network coded packet, the decoding buffer is searched for a packet to use for decoding. The source, destination, and crc32 from the coded packet is used to identify the wanted packet. The decoded packet is passed to the usual unicast receiver function, as had it never been network coded. Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-13batman-adv: network coding - save overheard and tx packets for decodingMartin Hundebøll
To be able to decode a network coded packet, a node must already know one of the two coded packets. This is done by buffering skbs before transmission and buffering packets sniffed with promiscuous mode from other hosts. Packets are kept in a buffer similar to the one with forward-skbs: A hash table, where each entry, which corresponds to a src-dst pair, has a linked list packets. Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-13batman-adv: network coding - code and transmit packets if possibleMartin Hundebøll
Before adding forward-skbs to the coding buffer, the buffer is searched for a potential coding opportunity. If one is found, the two packets are network coded and transmitted right away. If not, the forward-skb is added to the buffer. Network coded packets are transmitted with information about the two receivers and the two coded packets. The first receiver is given by the MAC header, while the second is given in the payload/bat-header. The second receiver uses promiscuous mode to receive the packet and check the second destination. Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-03-13batman-adv: network coding - add the initial infrastructure codeMartin Hundebøll
Network coding exploits the 802.11 shared medium to allow multiple packets to be sent in a single transmission. In brief, a relay can XOR two packets, and send the coded packet to two destinations. The receivers can decode one of the original packets by XOR'ing the coded packet with the other original packet. This will lead to increased throughput in topologies where two packets cross one relay. In a simple topology with three nodes, it takes four transmissions without network coding to get one packet from Node A to Node B and one from Node B to Node A: 1. Node A ---- p1 ---> Node R Node B 2. Node A Node R <--- p2 ---- Node B 3. Node A <--- p2 ---- Node R Node B 4. Node A Node R ---- p1 ---> Node B With network coding, the relay only needs one transmission, which saves us one slot of valuable airtime: 1. Node A ---- p1 ---> Node R Node B 2. Node A Node R <--- p2 ---- Node B 3. Node A <- p1 x p2 - Node R - p1 x p2 -> Node B The same principle holds for a topology including five nodes. Here the packets from Node A and Node B are overheard by Node C and Node D, respectively. This allows Node R to send a network coded packet to save one transmission: Node A Node B | \ / | | p1 p2 | | \ / | p1 > Node R < p2 | | | / \ | | p1 x p2 p1 x p2 | v / \ v / \ Node C < > Node D More information is available on the open-mesh.org wiki[1]. This patch adds the initial code to support network coding in batman-adv. It sets up a worker thread to do house keeping and adds a sysfs file to enable/disable network coding. The feature is disabled by default, as it requires a wifi-driver with working promiscuous mode, and also because it adds a small delay at each hop. [1] http://www.open-mesh.org/projects/batman-adv/wiki/Catwoman Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-01-19batman-adv: update copyright yearsAntonio Quartulli
2013-01-19batman-adv: postpone sysfs removal when unregisteringSimon Wunderlich
When processing the unregister notify for a hard interface, removing the sysfs files may lead to a circular deadlock (rtnl mutex <-> s_active). To overcome this problem, postpone the sysfs removal in a worker. Reported-by: Sasha Levin <sasha.levin@oracle.com> Reported-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-01-12batman-adv: unbloat batadv_priv if debug is not enabledMarek Lindner
2013-01-12batman-adv: don't compile the BLA switch if not requestedAntonio Quartulli
When the Bridge Loop Avoidance component is not compiled-in, its boolean switch should be not compiled as well. This patch surrounds the switch with a proper ifdef. This behaviour was introduced by 9fd6b0615b5499b270d39a92b8790e206cf75833 ("batman-adv: add bridge loop avoidance compile option") Signed-off-by: Antonio Quartulli <ordex@autistici.org> Acked-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2013-01-12batman-adv: Do not add multicast MAC addresses to translation tableLinus Lüssing
The current translation table mechanism is not suitable for multicast addresses and we are currently flooding such frames anyway. Therefore this patch prevents multicast MAC addresses being added to the translation table. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Acked-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-03net: remove unnecessary NET_ADDR_RANDOM "bitclean"Jiri Pirko
NET_ADDR_SET is set in dev_set_mac_address() no need to alter dev->addr_assign_type value in drivers. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-30batman-adv: use ETH_P_BATMANAntonio Quartulli
The ETH_P_BATMAN ethertype is now defined kernel-wide. Use it instead of the private BATADV_ETH_P_BATMAN define. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2012-11-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Minor line offset auto-merges. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-16batman-adv: process broadcast packets in BLA earlierAntonio Quartulli
The logic in the BLA mechanism may decide to drop broadcast packets because the node may still be in the setup phase. For this reason, further broadcast processing like the early client detection mechanism must be done only after the BLA check. This patches moves the invocation to BLA before any other broadcast processing. This was introduced 30cfd02b60e1cb16f5effb0a01f826c5bb7e4c59 ("batman-adv: detect not yet announced clients") Reported-by: Glen Page <glen.page@thet.net> Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2012-11-14batman-adv: substitute tt_poss_change with a per-tt_entry flagAntonio Quartulli
tt_poss_change is a node-wide flag which tells whether the node is in a roaming state (a client recently moved to/away from it) in order to let it apply special re-routing rules. However this flag does not give a clear idea of the current state because it is not possible to understand *which client* is actually involved in the roaming. For this reason a better approach has been chosen: instead of using a node-wide variable, the roaming state is now given by a per-tt_entry ROAM flag which, in case of packet coming through the node, tells the node whether the real destination is in roaming state or not. With this flag change, batadv_check_unicast_ttvn() has also been rearranged in order to better fit the new re-routing logic and to be much more readable. Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-11-07batman-adv: Add get_ethtool_stats() support for DATMartin Hundebøll
Added additional counters for D.A.T. Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-11-07batman-adv: Distributed ARP Table - add runtime switchAntonio Quartulli
This patch adds a runtime switch that enables the user to turn the DAT feature on or off at runtime Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-11-07batman-adv: Distributed ARP Table - add snooping functions for ARP messagesAntonio Quartulli
In case of an ARP message going in or out the soft_iface, it is intercepted and a special action is performed. In particular the DHT helper functions previously implemented are used to store all the ARP entries belonging to the network in order to provide a fast and unicast lookup instead of the classic broadcast flooding mechanism. Each node stores the entries it is responsible for (following the DHT rules) in its soft_iface ARP table. This makes it possible to reuse the kernel data structures and functions for ARP management. Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-11-07batman-adv: add UNICAST_4ADDR packet typeAntonio Quartulli
The current unicast packet type does not contain the orig source address. This patches add a new unicast packet (called UNICAST_4ADDR) which provides two new fields: the originator source address and the subtype (the type of the data contained in the packet payload). The former is useful to identify the node which injected the packet into the network and the latter is useful to avoid creating new unicast packet types in the future: a macro defining a new subtype will be enough. Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-10-29batman-adv: don't allow ECTP traffic on batman-advSimon Wunderlich
We have seen this to break networks when used with bridge loop avoidance. As we can't see any benefit from sending these ancient frames via our mesh, we just drop them. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-10-29batman-adv: Set special lockdep classes to avoid lockdep warningSven Eckelmann
Transmissions over batman-adv devices always start another nested transmission over devices attached to the batman-adv interface. These devices usually use the ethernet lockdep class for the tx_queue lock which is also set by default for all batman-adv devices. Lockdep will detect a nested locking attempt of two locks with the same class and warn about a possible deadlock. This is the default and expected behavior and should not alarm the locking correctness prove mechanism. Therefore, the locks for all netdevice specific tx queues get a special batman-adv lock class to avoid a false positive for each transmission. Reported-by: Linus Luessing <linus.luessing@web.de> Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-09-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/team/team.c drivers/net/usb/qmi_wwan.c net/batman-adv/bat_iv_ogm.c net/ipv4/fib_frontend.c net/ipv4/route.c net/l2tp/l2tp_netlink.c The team, fib_frontend, route, and l2tp_netlink conflicts were simply overlapping changes. qmi_wwan and bat_iv_ogm were of the "use HEAD" variety. With help from Antonio Quartulli. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-23batman-adv: Fix change mac address of soft iface.Def
Into function interface_set_mac_addr, the function tt_local_add was invoked before updating dev->dev_addr. The new MAC address was not tagged as NoPurge. Signed-off-by: Def <def@laposte.net>
2012-08-23batman-adv: change interface_rx to get orig nodeAntonio Quartulli
In order to understand where a broadcast packet is coming from and use this information to detect not yet announced clients, this patch modifies the interface_rx() function by passing a new argument: the orig node corresponding to the node that originated the received packet (if known). This new argument if not NULL for broadcast packets only (other packets does not have source field). Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-08-23batman-adv: Don't break statements after assignment operatorSven Eckelmann
2012-08-23batman-adv: Split batadv_priv in sub-structures for featuresSven Eckelmann
The structure batadv_priv grows everytime a new feature is introduced. It gets hard to find the parts of the struct that belongs to a specific feature. This becomes even harder by the fact that not every feature uses a prefix in the member name. The variables for bridge loop avoidence, gateway handling, translation table and visualization server are moved into separate structs that are included in the bat_priv main struct. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-08-23batman-adv: convert remaining packet counters to per_cpu_ptr() infrastructureMarek Lindner
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Acked-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-07-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/batman-adv/bridge_loop_avoidance.c net/batman-adv/bridge_loop_avoidance.h net/batman-adv/soft-interface.c net/mac80211/mlme.c With merge help from Antonio Quartulli (batman-adv) and Stephen Rothwell (drivers/net/usb/qmi_wwan.c). The net/mac80211/mlme.c conflict seemed easy enough, accounting for a conversion to some new tracing macros. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-06batman-adv: check incoming packet type for blaSimon Wunderlich
If the gateway functionality is used, some broadcast packets (DHCP requests) may be transmitted as unicast packets. As the bridge loop avoidance code now only considers the payload Ethernet destination, it may drop the DHCP request for clients which are claimed by other backbone gateways, because it falsely infers from the broadcast address that the right backbone gateway should havehandled the broadcast. Fix this by checking and delegating the batman-adv packet type used for transmission. Reported-by: Guido Iribarren <guidoiribarren@buenosaireslibre.org> Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
2012-07-01batman-adv: Don't leak information through uninitialized packet fieldsSven Eckelmann
The reserved fields in batman-adv packets are not set to a constant value. The content of these memory regions is leaked unintentionally to the network. This regression was introduced in 3b27ffb00fbe9d9189715ea13ce8712e2f0cb0c5 Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2012-07-01batman-adv: Remove bat_ prefix from bat_{debugfs, sysfs}.{c, h}Sven Eckelmann
The "bat_" prefix in the source files implementing the batman-adv sysfs and debugfs interface doesn't have a special meaning and are only used by these files and files that implement the actual B.A.T.M.A.N. path finding algorithm. The prefix is better suited to mark files that are used to implement the main part of the path finding. All other files should not use it and therefore gets renamed. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2012-07-01batman-adv: Prefix types structs with batadv_Sven Eckelmann
Reported-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2012-07-01batman-adv: Prefix packet structs with batadv_Sven Eckelmann
2012-07-01batman-adv: Prefix main enum with BATADV_Sven Eckelmann
2012-07-01batman-adv: Prefix packet enum with BATADV_Sven Eckelmann
2012-07-01batman-adv: Prefix types enum with BATADV_Sven Eckelmann
2012-07-01batman-adv: Prefix gateway enum with BATADV_Sven Eckelmann
2012-06-28batman-adv: Prefix main defines with BATADV_Sven Eckelmann
2012-06-28batman-adv: Prefix types defines with BATADV_Sven Eckelmann
2012-06-28batman-adv: Prefix packet defines with BATADV_Sven Eckelmann
2012-06-25batman-adv: Prefix soft-interface local static functions with batadv_Sven Eckelmann
All non-static symbols of batman-adv were prefixed with batadv_ to avoid collisions with other symbols of the kernel. Other symbols of batman-adv should use the same prefix to keep the naming scheme consistent. Signed-off-by: Sven Eckelmann <sven@narfation.org>
